PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 [122] 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Thinking of getting a BB6... Lots of Q's
  2. Possible to chip a P14 ecu for tuning? crome, uberdata, etc. H23a1 prelude
  3. pressed in liners an 88mm pistons h22a???
  4. EGR blockoff plate.
  5. Built/Sleeved H22 + Tuning = Idle/VTEC problems
  6. Does anyone have a Caliper Rebuild write-up?
  7. Rear Wheel Bearing Right & Left
  8. alternator relocation
  9. rear main bad (safe to drive)
  10. should I replace DC header with stock header?
  11. front lip on 5th lude.....
  12. Condenser Fan??
  13. Engine Vibration at higher speeds
  14. What else would you replace?
  15. Headlight surging idle problem
  16. Need help with fender removal on 5th gen (Searched)
  17. IM BACK...2 weeks, no sleep, lots of work=482 whp and 3rd place(the WHOLE saga)
  18. Anyone living near Rancho Cucamonga, CA do me a favor?
  19. 345 injectors big enough??
  20. Anyone done an Auto to Manual swap?
  21. Front engine mount
  22. 5 free horsepower for noobs
  23. headers Q
  24. red valve cover part number
  25. 92 prelude for sell or parting out
  26. greddy sp2 exhaust install...
  27. higher performance camshaft?
  28. will the h22a1 gasket set fit the h22a engine?
  29. transmission swap!!
  30. DSM Blue Top Injectors and a 4th Gen prelude....??????
  31. wet plugs
  32. Mugen MZ3x Wheels
  33. 4th gen audio problem. Help.
  34. (need help) anyone know what size injectors does the Prelude's VTI H22 have?
  35. Shifter Cable compatibility
  36. 4th Gen weight specs
  37. Type S cams with Turbo charger?
  38. H22 and H23 Tranny codes?
  39. 4th gen prelude keep on overheating....change everything..need HELP!
  40. obd1 to obd2 distributor wiring ,please help!!
  41. what clutch/flywheel to get?
  42. Why all the hate on TT cars?
  43. Thermostat Housing O ring
  44. Will this fit my Prelude?
  45. Prelude Scene at 2006 NOPI Nationals....
  46. 0-60 time on 1998 prelude?
  47. Any differences between the jdm h23 and the us h23?
  48. intake/resonator question.
  49. Timming BElt Walking off gears !!!
  50. blue, white, or gray smoke?
  51. 4th Gen-Prelude Diet. Searched
  52. (already searched) What size if the nut holding the axels in??
  53. cams with jr supercharger
  54. alternator question
  55. how low a drop before cambers needed?
  56. Installing wideband questions.
  57. Vafc Mounting spots for 5th gen???
  58. anyone selling anything?
  59. digital speedo
  60. turbo question for an AT lude......
  61. PRELUDE ECU QUESTION....HELP!!!
  62. 1996 Prelude Vtec
  63. help!!!!
  64. Anyony bondo/fill in the "Greddy" logo on the Greddy 5th gen lip?
  65. H23 Vtec swap
  66. NEW Wings West RS/Big Mouth Kit 92-96
  67. 94-96 gauges in 92-93 lude
  68. obd1 ecu for fifth gen prelude.
  69. Ignition switch on on 98 stuck, won't turn.
  70. h22 running rich
  71. HID troubles in 93 lude
  72. Starter throwing arcs
  73. New head gasket?
  74. new a/c evaporator and expansion valve
  75. 4gen mugen rear lip?
  76. 94 Prelude AC compressor problems
  77. IM Removal
  78. Type SH?
  79. Unclipping the injectors
  80. Deals? or Duds?
  81. Underbrace install.. with pics
  82. Idle surge when cold.
  83. Mugen Exhaust for Type SH 4 5th GEN
  84. what size rims are these??
  85. accord lips
  86. neuspeed strut bar
  87. starting problem
  88. Noob Question: Firing sequence
  89. Prelude Half shaft, 5speed or auto?
  90. 4th gen intercooler fitment
  91. 96 prelude with a broken timing belt
  92. jdm front bumper with fog lights
  93. wings west kit question
  94. manifold studs?? <help>
  95. 4th gen speedometer helpp!!
  96. Airbag Replacement
  97. tein springs
  98. HELP, PLEASE, ASAP!! Lude not running right. Cats gone bad???
  99. Thinking about reinstalling power steering...
  100. 1996 Prelude tranny...rebuild?
  101. purpose of fog lights
  102. h23 lude engine damage
  103. daido and taiho
  104. Just a small question about Supercharger (im at work)
  105. H22 Clutch Flywheel preference
  106. catalic converter
  107. aftermarket coolant overflow tank?
  108. vgx brake pads + offbrand rotors?
  109. stupid clutch
  110. How to put in new clutch
  111. Just a quick question!
  112. Tein S-Tech???
  113. Vibration??
  114. Splash Gaurd Removal?
  115. Just Dyno'd the Euro R, where the hell is the power?
  116. need some help with timing
  117. 93 vtec won't pass smog.
  118. wierd sounds somewhere, help me.
  119. Type-S ECU
  120. Something you guys might like...
  121. Can i get any of the options?
  122. M2J5 or M2S4 - which is recomended performance wise
  123. Question about fitv and obd2/1
  124. New Genuine Honda/Acura MTF
  125. h22 in 91?
  126. Tranny Fluid Replacement
  127. Bad fuel filter symptom
  128. Clunk when I engage clutch?
  129. Slight Ticking Noise from the Engine.. what does that mean?
  130. mp1a auto tranny?
  131. how to read casting dates?
  132. ebay intake and filter
  133. Trouble with Ignition Timing
  134. Which side markers are interchangeable
  135. Need help shopping for a BB6
  136. how safe is nitrous on an h22a1
  137. buy another longblock or rebuild h23a1
  138. Heater Core Removal
  139. rh drive swap
  140. VAFC install with pics...
  141. How to make 200whp?
  142. Steel braided lines
  143. Broken Crank Pulley Bolt.. Any ideas?
  144. My Oxygen Sensor & Vtec
  145. Type-S motor parts Q.....
  146. Rust on flywheel and pressure plate..........
  147. customizing your lude...
  148. 4th 96 Si/Sr Here!
  149. question about h series trannies?
  150. JDM Headlight and Foglight question
  151. idle rev and gas throttle help
  152. corner light wires
  153. Front upper ball joints question
  154. arrrrr iab woes
  155. H22 Tanny work on H23block/h22a head?
  156. Power Steering Help
  157. Wheel Bearing Replacement - Special Tools?
  158. H22 injector isssue help!!!!
  159. short shifter
  160. Are the corners sopposed to blink?
  161. will fitting type s pistons on an h22a1 rod weaken the rod?
  162. swapped my h23 trani for an h22 trani have a few ?s........
  163. Prelude dash stero holder...
  164. Running fluidampr pulley, Yay or Nay on balancer shafts?
  165. suspension
  166. H22 all motor build
  167. 4th gen center console
  168. underdrive pulley belt question.
  169. Brake options
  170. Need help ASAP..question about cooling hoses on H22 prelude
  171. What ECU do i have?!!!
  172. Any additional components needed for Tilton Twin-Disc Install?
  173. White Smoke from near the intake manifold and exhaust.
  174. ECU Problems
  175. BB6 JDM window visors
  176. injector quesiton h22a
  177. My UPDATED hesitation thread
  178. Front end shake
  179. tech question about bearing
  180. EGR Ports?
  181. h23A vtec stock head polish? and cams
  182. Dizzy interchange?
  183. 6 speed tranny in prelude?
  184. s2000 Wheel
  185. h22 spun bearing?
  186. 93 prelude si
  187. Where can i find Prelude dynos?
  188. Clutch Adjustment
  189. Differences between adjustable mount and ball jounts?
  190. Trunk springs and superchargers?!?!
  191. exhaust flow questions
  192. radio code?
  193. What engines will fit in an 89 prelude?
  194. Deciding on engine
  195. arp extended wheel studs question...
  196. 97 up prelude headlight pair
  197. RS R catback exhaust
  198. slow acceleration\deceleration jerking help(automatic)
  199. Good machine shop needed in orlando florida area.....
  200. calibration
  201. Re: Forbidden Motorsports 92-96 TRUE Short Shifter
  202. Civic hood damper on a Prelude: Quick how-to--
  203. obd1&2 h22 oil pump compatibility
  204. Much difference between the 92-96 and the 97-01?
  205. Would a F Series mount into a 3rd gen prelude?
  206. prelude question from an eg owner
  207. H22 with h23 head
  208. Picking up an engine today, is this a good price.........
  209. Do I need to reinstall this piece? *pic*
  210. Explicit Speed Performance H22 motor mounts
  211. h22 crank
  212. Door Piece Removal
  213. Body roll ?
  214. SAFC NEO
  215. R12 Evacuation
  216. Lookin to buy valves...Need some advice
  217. Installing an oil pressure gauge
  218. ? on mounting a cheap ebay intake
  219. Speedometer problem
  220. HI i need some help really bad. please hlep me
  221. 4th gen climate control removal
  222. lsd oil
  223. does a crappy start and high idle mean new cap and rotor needed?
  224. A/C Switch Red Light
  225. Horn, cruise, and airbag don't work.... SRS related
  226. 97 Lude Still bogs like a mofo
  227. H22 OIL
  228. HID Help
  229. parts for sale
  230. FS:1999 Honda Prelude Type SH
  231. Sugring idle. Cant find FIAC or IACV, *PICS* - searched extensively
  232. Power Gain From Flex-pipe removal?
  233. Rust !!!
  234. oil sending unit
  235. Do i need H23 transmission???? HELP
  236. 93 prelude
  237. jdm potenza suspension?
  238. Prelude question
  239. adjusting idle
  240. Any difference in 97-01 Type-SH engines?
  241. 2001 Prelude brake light stays on when cold?
  242. Any tips on installing JDM Side Marker Lights
  243. What u guys think about this........
  244. Short Ram Intake
  245. 218hp turbo prelude???? greddy?
  246. Frying ignition coils like its my job....
  247. Spark pllug wires: what you guys think.
  248. I thought the Accord lip was bolt up? Or am I retarded...
  249. h22 tranny problem?
  250. i have a 92 lude i am puting a h22 do i need to get a new wiring harness??
