View Full Version : Honda Prelude
- caliper re-painting oem color
- motor oil
- Prelude, the Black Sheep.
- Need timing help!!!
- estimated cost of front bumper and wing painting? OEM granada black
- quesiton about 5th gen ludes
- Alternator belt
- Prelude Electrical Grounds. Where?
- stipped coating off head bolts, still usable???
- Shifting is messed up on H22?
- P13 ECU - bb4 h22a - whats this ecu good for?
- WTB: 5th Gen SS Auto Trans
- H22a Auto Tensioner Blew ...
- Gauge Cluster .......?
- mugen shift knob questions, help?
- wondering what you guys thought...
- jrsc
- does anyone have pictures of different grills?
- Megan Racing header question.
- Anyone on H&R Race Springs?
- anyone using TB spacer?
- o2 sensor ?
- Is it true that B series adjustable cam gears work on H series?
- JDM H23a or H22a for the same price?
- Selling Prelude
- parts
- 95 Exedy Clutch Install + Megan RU Strut (56K Beware!)
- Oil Leak?
- h22 w h23 crank turbo??
- Grinding in 5th Gear
- IAB question
- how many bulbs in the cluster? 92-96 prelude
- Exhaust restriction questions.. 2.25 Vs. 2.5
- I need an answer As Soon As Possible....please help..its a small question..
- wierd thing happening with the gas pedal
- h22a rebuild, what to upgrade while staying smog "legal"
- *Wiring Question*
- EVO 5 manifold compatible with the H22???????
- h22a WONT START! (no one knows what to do)
- h23 intake mani?????
- Cleaning motor mounts???
- Noisy rear wheel bearings
- What is this??
- 4th gen gauge el gauge cluster conversion (searched)
- connecting rods??
- H22 Aftermarket Rods What do u think??
- Prelude Reliability
- lowering spring question
- Converting a/c from R12 to R134a
- Eropean Salvage and Junk Yards
- H23 crank and revs
- code 22? vtec pressure switch? help please
- 93prelude vtec wiring harness????
- Will 5th gen springs fit 4th gen? (searched)
- look to buy oem lip kit for 98 prelude
- Anyone have a recommendation for replacing the carpet inside?
- timing belt snapped only going 5mph
- Opinions on this intake.........
- Front mount question MT vs AT
- Auto Tensioner Failing! Hoorayy!
- 4-5G Prelude air intake... TUBE, SIDE BRANCH what?
- Help 99 prelude h22a4 boggin problem
- bent valves? need help asap thanks
- Car pulling to the right...
- abs light is on and won't go off
- JDM BB6 prelude navigation + digital climate control system
- Limited Edition Prelude
- Greddy SP1???
- is my ss tranny dead?
- vtec wiring tomorrow last minute q
- what pistons on a h23 vtec
- Golden Eagle Fuel Rail
- headlights keep burning out on 5th GEN WTF
- 88,89 foglights
- OBX cat anybody tried???
- Euro R manifold NEW and Nos Wet Nitrous Kit 75 and 85 Shot
- EGR block off!! SEARCHED - OBD2
- Vtec gasket..$26..to much??
- interference
- timing belt condition
- question
- tripple pillar pods
- Messed Up Prelude
- I am taking pic request's for a Jdm lude front clip
- Help with Accord Popper
- offset question
- h22a internals
- Spark plugs wet with fuel?
- Orange County - I need new valves. Where should I take it?
- h22
- omg $1000 for door sills
- what piston should i get?
- Helms Diagram for O2 Sensor
- vafcII help
- what is a forge piston?
- IACV relocation kit?
- pistons
- 4ws question - plz help!
- Hondata Intake Manifold Gasket.
- Prelude Pic thread orginazation.
- NA v.s. Boost
- compression test results
- exhaust question
- exhaust resonance?
- Kteller Resonator
- need camber kit?
- question about camber
- EL GAUGE conversion question.
- wheel hop-- HP limits
- AEM intake=gas hog
- Lowering Springs = Worse Handling?
- ware to find a JDM h22 half clip
- Sparks Header for H22?/
- h23 cams
- Gas/Octance boost
- Do you guys recommend this O2 sensor deal???
- Thermostat help
- 5th Gen. Passenger AirBag Cover
- Plug gap
- an-r header
- want to take ac out
- Carbon Fiber ?
- anyone running on stretched steelies?
- Valve Adjustment ?
- Prelude for first car?
- Camshafts
- SOUNDCLIPS of my lude
- Prelude 5th Gen OEM Rear Lip
- Need advice
- quick release wheel
- VAFC2 brand new 275obo
- '92 Driver Side Knocking Noise (checked CV)
- Tuning H22A with auto transmission
- 92'4WS Question
- Disable abs cel light
- h auto tranny up 4 $ale...socal....
- Suspension questions for my prelude
- Headunit problems
- block options and head rebuild questions
- Who mods this Prelude forum?
- Power Steering...Yay or Nay?
- would a b18 fit ?
- b20 prelude
- How good of a plan is this...
- 3rd gear pull
- competition clutch stage 1 vs ebay "execdy stage 3 kit"
- installing cam seals?
- '97 Prelude - Retrofit completed (pics)
- Prelude JDM Digital Climate Contol Owners
- internal coil testing?
- More performance for my 99 Prelude
- WANTED ASAP !!!! 97-00 prelude vtec oilpan !!!!!
- Are my pistons still good? (pics inside)
- white smoking out of the exhaust! help please!
- checking if ignitor good or bad?
- h23a1 m.i.d ?'s
- where to find driver side window for 1995 prelude
- Idle Problem Troubleshooting
- Do any preludes in USDM have heated side mirrors?
- 5th Gen Type S Lip Pics?
- H23 vtec compression and deck height?
- brakes
- catch can question
- Ported h22 heads. What are you guys flowing?
- Power door locks stopped working
- stock oil pressure sender removal
- A little confused
- ABS light... intermittent in 95SE
- s2k rims (searched)
- problem with 4th gen turn signal
- Problem: running rich?
- cat back dynos fro Vtec Prelude
- Are all mufflers created equal?
- what the hell should i so
- Accord front lips compatible with 4th gen prelude
- ATTS light
- what fuel pressure psi should i be boosting?
- Greddy Header pics & more to come.
- A few Questions
- a quick suspension question
- Megan header pics
- Visions H22 ECU
- Would you purchase this header?
- boring
- putting a new cv axle in...*quick question*
- Jdm Headlight Diagram
- Crower Stage 2????
- 5 lug conversion
- 4th gens on 15 or 16 rims
- 2.2L into a 2.5L
- H22A Throttle Body & Coolant
- Clutch System
- What am I missing for my Auto -> Manual Swap
- CAR IS STILL IDLEING FUNNY! WHAT COULD IT BE????? Getting very frustrated.
- Eliminating my ATTS.....
- Lightweight Flywheel on my 5th Gen
- my 93vtec prelude is choking now!
- Shipping and Paint - OEM lip (5th Gen)
- unburnt fuel?
- manual tensioner conversion.
- Why wont my replacement ECU work?!
- question about turbo downpipe
- Guys! My car is trippin. please help me out
- Wheel Tech Question
- which calipers fit my 92 lude
- Where to find headers for 92 f22a s
- ECU problem wiring diagram
- UK Honda tuners
- wwrs rear and sides w/ accord type r front lip?
- Headers, Which one you recommend?
- free stuff for my lude
- its smokin
- question
- AEM pullies BET
- Question about 5th Gen OEM Spoiler
- Gonna geta LUDE
- oil leaking from valve cover
- Hole for aftermarket Water Temp sensor??
- Offset question
- HID headlight kit
- Mahle Pistons for H22? Anyone tried?
- fan doesnt work
- What Cams to use?! I searched!
- close up pic of 95 se 5 spoke wheel
- i need specs on my 3rd gen b20a3
- 4th Generation or 5th Generation Type S?
- Making a stronger electrical connection?
- what h23 parts fit a h22 help!!!!
- Camshafts
- Modify collector?
- Ok, what would be worth my $$
- What Rods to go with in my H22
- tranny swap
- this is not an lsd, right
- when I first start it in the morning it won't go into first gear but after a few minutes it shits fi
- 2001 Honda Prelude Speakers
- 1988 honda prelude, wont start
- 1991 2.1 5speed error code
- Any sealant needed to join the block and tranny?
- $100 ebay all aluminum radiator???
- 87 2.0 rebulid
- power steering question
- T-Belt tension adjuster broken ??
- drive axle starting to click
- WILL h23 si prelude oil pan work on h22 block?
- tranny problems
- transmission noise, throw out bearing??
- fuel milegae??? how many miles
- does anyone know where i can see all the kits from mugen?
- will a h22 catback fit the h23?
