View Full Version : Honda Prelude
- adjusting clutch
- weight of complete H22 swap?
- Secondary butterfly plate question (h22a1) + other misc EGR stuff.
- AEM V2 only in SRI Version for 5th gen Prelude??
- Almost positive it's the axles
- exhaust system for sr
- vtech swap???
- 5th gen USDM climate control work on a 4th gen prelude?
- Seibon Hood wont line up
- What does this switch do?
- questions about 95 SE
- wheel repair
- Belt squeaks when I start my car, then stops...
- apexi n1 sound clip please!!!???
- JDM h22a with LSD: hydro tranny?
- helms
- I have H23 What should I do?
- Wiring the knock sensor...
- VSS Question
- Engine Damper
- Prelude With the SNL TwinLoop?
- just replaced H23, CEL 23 and car is GUZZLING gas
- 5th Gen Head Lights
- Question about Euro-R Mani install...
- fuel injector differences?
- turbo on stock 98 prelude
- Inner Tie Rod Boot
- Gona boost....oh but how much
- 5th gen aftermarket parts
- All Cylinders Leaking Compression
- Wiring Harness, where to hide ?
- Hood pins on seibon oem hood
- What does the average JDM H22 run at the drag strip?
- No fuel, searched!
- timing belt
- crazy speedometer
- swapping a h22a into a saturn
- HELP will b16a map sensor work on h22a
- 88 Prelude Si won't start - bad ignition switch?
- 89 prelude problem
- Climate Control AC Button Problem
- **Searched** Quick H23 manual tensioner conversion question
- H22 clutch/master cylinder issue------PLEASE HELP!!!!!
- Anyone happen to read the NEW Turbo Magazine?H22A FRM Misprint?!
- ...searched.... h23 rods in h22
- clock problems
- Prelude SH Radius Rods
- Grinding into 3rd and 5th?
- BB6 leather seats were they rare???
- Where did you get your thin H22 head gasket from?
- i hate my stock seats
- JDM h22a Exhaust Manifold Gasket questions
- Price of used twinloop?
- Help on finding a good CF Hood for cheap
- Turbo advice
- 1993 si vtec
- fog light bracket
- piece behind the oil filter
- Question About Manual Rack Conversion
- fog lights on 92 lude
- prelude ss vs prelude sh
- Question about the EL gauges?
- car wont start after starting normally...
- Is my toe what's vibrating?
- keyless for 99 works for 98?
- Help Weird Idel problem after swap.
- 3rd gen. Prelude Headlight help
- h23a vtec question
- Replacing tired H22 with slightly used H23...Questions
- swapping 92 gauge cluster to 94, any info?
- Very Hard Shifting(H22a)
- bleed clutch system,
- Aftermarket Prelude Motor Mounts ( thought nobody made them for 5th gens)
- Please confirm that i am jumping the service connector correctly.
- Changing Coolant in 5th gen
- anyone using EXEDY OE replacement clutchs?
- Clutch Help!!!
- compression test question?
- *Searched already* Walbro Fuel Pump Install
- AEM cold air intake, wont fit in my car?
- clutch problem? I need some advice
- Clutch Problems? I need some advice
- h22 swap
- how much to spend?
- few problems, just finished replacing H23
- Help. Tachometer and Speedometer bounces
- Exact pinout for p13 and p14 ECU
- keyless entry on ludes?
- h23 and jdm f22 same parts?
- H22 CEL help
- idle prob
- Intermittent Idle Problem... NEED HELP!
- OPINIONS-'93 LUD not charging power HELP
- Accord Side Skirts on 4th gen???
- RSR down springs
- H22 Timing belt installation- HELP!
- should I part out the 'lude or sell it whole?
- who is using an EGT to tune?
- engine swap without transmission?
- Hondata s300 with stock injectors?
- vtec problem
- Is this a good combo?
- Heater Core Removal
- need jdm h22a vacuum diagram
- high mileage means trouble for atts?
- Electrical issues!?? please help!!
- Wont turn over ?? Fuel Relay, Pump, What ???
- Rear brake pinout
- Question about H22A valvetrain
- Finishing up swap few questions 92 si -> JDM H22a swap
- Really loud rattle..but only when it Rains!!!
- need help finding these clips
- Balance shaft assembly
- My headlight socket melted....
- Lower ball joint castle nut wont budge. How to make a removal easy?
- how to install headlights
- Help car won't start after ECU swap
- Energy Suspension kit
- Does anyone know where the DOHC F22b crank sensor is?
- 205/40/17 not wide enough???
- Swapping obd2a to obd1 help
- 4th gen cupholder
- Location of Main relay on 1990 prelude
- Clutch Help
- AEM CAI installed, having problems
- Knock when I turn the wheels
- What yr 4thgen models did this center console come in??
- Upgrading Valves Only (Good or Bad?)
- JDM bb4 sidemarkers
- k series engine???
- Small Rad? (searched)
- A question about forged pistons
- bulbs for JDM one-piece headlights
- TDC and CKP sensors Where ?
- Sounds like MARBLES in the engine!?!?!
- is the stock headunit connected to the keyless entry and alarm?
- nitrous
- El glow gauge install problem
- Anyone have a picture of their 5th gen lowered on H&R Race springs?
- Wire tuck ?
- what turbo manifolds are you high hp guys using?
- starter ? and trans ?
- spun bearings
- Weird brake problem 2
- the 2.4L H motor who's done it?
- Motor Swap, Manual Swap 92' Prelude
- What is the best rev limit for an H22 with Ti valve springs?
- noob....reseting radio code
- help on the h23
- (asking for some help) car won't go - tranny, clutch or axle?
- ATTS Unit with s300
- how do u check a block to what years it is
- The infamous 2.8~3K hesitation...quick question
- JDMCarboy exhaust + kteller piping question
- Gauge Cluster Problem
- Stainless Steel Brake Lines - already searched
- Has anybody ever used the new dc sports 2 1/2 inch header for the h22a
- Air Conditioning Problems
- How much revs can a stock H22a4 handle?
- Can someone verify my equations? Just wanna be sure I did the math correctly.
- problem with sudden valve noise
- H22A4 with 96 OBD2 P13 ECU?
- Dont know what this part name is???
- obd1 to obd1
- think I got the shaft
- H22 Block - Will Type S Pistons Work??
- No Spark Problem!! HELP!
- Vacuum vs Electric controlled EGR valve
- A 93 Prelude with H23 Non-Vtec??
- PLEASE help: ECU swap question
- *searched* compression numbers to ratio
- H23A1 and H22A crank cases interchangable?
- will high compression jdm type s pistons fit in my h23a1 lude
- Should I have my thottle body bored?
- red w/ blue stripe OR red w/ yellow stripe--> which is positive??
- Rear vibrations?
- cant drive my new 5 speed
- 93 Prelude starting problem!! HELP
- Hey everyone......I am a NOOOOOOOB!
- missig threads. who keeps taking mine of?
- new to hondas. have some Qs
- question for all you h22 ITB guys??
- Odd Misfire Condition
- Question about CR
- 215-45-16 rt-615
- BA8, F22A1, Fuel pump
- Smoke and fluid on front crossmember
- ALL MOTOR SET-UPS
- Are all F23A's the same?
- s2k cluster in prelude
- h22 and h23 syncros
- Guys with autometer a/f guage
- H22a1 Skunk2 68mm TB map sensor mounting
- -New Prelude owner, need's help-
- hid recommendation for a 92-96 prelude
- h22
- looking for flywheel bolts for '94 Prelude H22
- new car...new to h-t
- JDM H22A TYPE S ENGINE In a Base Model?
- vtec oil pressure
- Whats the difference?
- Feel stupid..where do I jack up my lowered 5th gen?
- brake pad and bleeding problem
- PRELUDE PROBLEMS PT 2... Loud Suction Noise & Severe Hesitation. Please Help!
- High Compression Valve Inquiry
- 5th gen vs 4th gen cat back
- prelude rear HUBS and ITR hubs
- going FROM obd1 TO obd2 (searched)
- jdm obd1 h22a into 97 prelude body - crank sensor problem
- trunk lid hard to close
- timing gun questions
- What is the best way to access the VSS on a 97 type SH?
- problems with my 22
- Need opinion on buying BB1
- First one to fix my problem gets $50
- Greddy Turbo Kit vs JRSC
- Front end Shaking! please help (UNDER LOAD ONLY)
- F20B & H22 Valves
- Stiffer Suspension
- distributor question
- 1997 PRELUDE key question WTF Is this 4?????
- Starting Problem
- H22 hesitating & Bogin
- Weapon R Header
- EVAP canister ?
- Proper Brake break in
- 5th gen wheel on a 4th gen
- Good deal?
- Fried something! Fuel pump wont prime...
- F20a4 tranny on a JDM H22a ?
- Jumpy tach! Can't find problem, plz help!
- vtech activation
- Auto p13 on a MT h22
- intermediate shaft quesiton
- Simple K&N ?
- type-sh rims
- brake light and srs light...
- Help with H23 pistons
- thud when accelerating from a stop
- using non abs hub on abs car, will I get a CEL?
- any1 have pics of a 5th gen on mugen m7's???
- turbo and compression
- how much do you think it should cost...
- 90 prelude si
- 4G Prelude Innovative motor mounts install--
- H23 Final drive on H22 tranny
- Prelude SE Wheels Top Dollar
- help! no gains from power mods
- Tein S-tech better or H-tech? [searched]
- Wierd issue on my 1993 prelude SI
