PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 [214] 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. H23 C&R Radiator: 50/50 mix?
  2. fixing rear camber with washers or a spacer?
  3. i need dyno for pulley
  4. COMPUTER HELP
  5. would i be ok to.....
  6. I need some help
  7. lude batery specs
  8. H22A7 Data & Specs needed
  9. Anyone know a good HID site...?
  10. Big Annoying Problem
  11. need help with cel codes
  12. H23 and nitrous
  13. WANTED!!!! A pillar triple gauge pod
  14. 2 quick pre-startup questions for H23 to JDM H22A vtec swap ..
  15. ECU protection mode
  16. wierd acceleration
  17. window rattling
  18. injectors
  19. 2.2k Idle Until I Come to a Complete Stop?
  20. What is needed for a m2b4 swap into a base model fifth generation
  21. INTAKE INSTALL AUTO TRANS CAR BUCKING?? HELP!!
  22. Boost and anal cali
  23. Cam gear question.
  24. 4th gen Automatic Tranny reliability/life span?
  25. ATTS SH tranny on Base 5th gen
  26. 1997 Honda Prelude SH CLUTCH
  27. Suspension for prelude sh
  28. People with the JDM h22 swap
  29. JRSC on H23???
  30. Sorry about this annoying post
  31. JDM H22 swap or....what?
  32. Need help on oil leak please
  33. bilstein shocks
  34. Replace a Flex Pipe?
  35. new swap h22a4 on obd1 ecu
  36. going turbo... which oem pistons to use?
  37. 2000 SH / 92 Si and '02 blown S2K compression test results
  38. relocating battery
  39. 88 lude lighting/electrical problems...
  40. H22a EURO R TB Gasket???
  41. High Idle
  42. SATURATED INJECTORS ON A PRELUDE
  43. car extreme lag at 6600 rpms jsut now.. Help
  44. AHHH.....got in an accident :/
  45. 2 quick questions on Hid's for a 93 prelude..
  46. where can i get a Helms manual???
  47. wondering what i need for a b18 or h22 swap into a 3rd gen lude
  48. eclipse manifold on an h23?
  49. h22 egr valve
  50. 93 Prelude S
  51. brighter gauges?
  52. keep fouling out plugs
  53. H22a manual
  54. I need some Help w/ m2b4 tranny swap (type s w/lsd)
  55. AC Removal
  56. Auto Shift Knob a pain to install or easy?
  57. '87 alternator replacement - stuck
  58. Advice needed UK
  59. question on resistor product (20hp gains) on ebay? joke? kill my car?
  60. torque help
  61. Tuning with Hondata
  62. A QUICK QUESTION ABOUT AIR/FUEL GUAGE....
  63. skunk2 coilovers
  64. Anybody have experience with RSR exhausts?
  65. Building up the H22A1
  66. Quarter mile times?
  67. Power inverter noise...
  68. pgm-fi main relay
  69. what does Si stand for?????????
  70. h22 crank pully/ h23
  71. 2 questions I'm ashamed to ask...
  72. Removing front shocks
  73. broken timing belt
  74. 89 Lude question- how-to make flip up light "sleep"
  75. help... car just crapped out on me.
  76. AEM cold air intake
  77. jdm 88 prelude
  78. 5 gen engines
  79. Bypass?
  80. PARTING OUT!! 93 Si, H22 and H23 stuff, ive got lots of it
  81. I'm Just Guessing... (Timing Belt).
  82. H22A4 powered 94 Integra GSR mid-engine RWD conversion
  83. This is the 4th alternator in 2 months... wth?
  84. What is the optimal A/F ratio for 5th Gen?
  85. Anyone know where I can find an new shift knob for an automatic?
  86. Questions on Swap...
  87. Best Upgrade for $500 to my 93 lude?
  88. selling prelube engine and tranny
  89. oil coming from the back of car
  90. Timing Sequence Q
  91. Jackson Racing Supercharger...
  92. Where can I get mugen front bumper for 95?
  93. Some of Honda's History/Acheivements continued...
  94. Are there wires I can buy to add to my wiring harness instead of cutting off of another?
  95. Are there alternative wires I can add instead of cutting those needed off a wiring harness?
  96. Help - Throttle body or TPS problem or something else?
  97. question on racing seats
  98. 4th Gen. Front Lip
  99. whic engine is this? *pic*
  100. how to read Autometer A/F gauge
  101. 3rd gen light problem
  102. How low to go with a Type-SH???????????????
  103. what other boltons could i get?
  104. Auto wouldnt go to 4th...
  105. Hypergrounds???
  106. Nology Hotwires on 93 Lude...
  107. fuse problem
  108. Help on rod positions
  109. Wideband A/F ratio gauge installation help!!!
  110. electrical issue?
  111. how do you get rid of scratches?
  112. autometer A/F gauge ... stays on lean till 4k then goes up to rich
  113. Need Throttle body or TPS??
  114. Whos running 90mm bores on the street???
  115. P13 ECU: I know it's JDM, but is it for a 5-speed or Auto?
  116. My Dyno, and what to do next
  117. Do Ground Wires really work?
  118. 93 Prelude 2.3 swap for H22...
  119. Best clutch and flywheel???????
  120. h22a1 knowledge needed......
  121. Converting from auto to manual?
  122. 5 gear RPM question.
  123. Any good header for 5th gen lude
  124. Oil Consumption
  125. Eibach pro kits: the 3rd gens fit on the 4th gens???
  126. B-20 question
  127. scared to post
  128. Distributor Problems
  129. Best Pre-Swap upgrades?
  130. Tranny Upgrade Question
  131. what cam is engraved with s10
  132. icm/ignitor
  133. Will 5th Generation SMSP header fit on a 4th Generation Prelude/4th Generation Honda Accord?
  134. What would it take to do this swap?
  135. Very Strange Brake Problem.....
  136. Question about tire size for Prelude.
  137. Prelude question
  138. Best Buy for Springs
  139. 1989 prelude no spark or fuel
  140. A 158hp is all I got.......Think my 5 speed 97 lude sh is still out of tune......
  141. installing autometer AF guage, i need a pin sheet
  142. WTB : USED Koni Sport Shocks for 5th gen
  143. suspension overhaul
  144. problemmm with car
  145. h23 / h22 Vtec Head
  146. how to bypass the cold start valve?
  147. Radiator hose blew on freeway???
  148. My CF front lip = DEAD
  149. help my car wont start no spark and no fuel
  150. Progress or ST Rear Sway Bar?
  151. tru short shifter? 5th gen?
  152. JUN prelude nostrils
  153. h22a different model specs
  154. Hmm..how much to convert my tranny....?
  155. Apex-i N1 Catback Exhaust....
  156. vtec 2nd gear...
  157. I found this clutch and im wondering if its good
  158. losing oil help!!!!
  159. QUICK QUESTION
  160. 4WS / ABS / Speed Sensor ?!
  161. The official 5 speed swap thread.
  162. Clunk from rear suspention...
  163. new to the lude scene, simple question
  164. Prelude Parts
  165. 230+whp
  166. RE: Dream H22 thread - ppl saying Turbochargers don't belong on Hondas....
  167. weird vibration after header install
  168. question
  169. What octane should I be running? Just making sure...
  170. 4th Gen White Face Gauges?
  171. PLEASE HELP!!!!!!!!!!!
  172. changing oil, need opinions
  173. wiring regard h22 swap into a 88 lude
  174. Wiring Q.Ecu to Fuel Pump Relay?What wire am i looking for?
  175. Royal Purple oil
  176. any 3rd genners out there?
  177. re: removal of intake control solenoid valve
  178. anyone running a apexi Gt spec exhaust on their 96 si?
  179. Act Performance street disc and Prolite Flywheel 8.8lb
  180. headlight/turn signal wiring
  181. pulling cd player unit?
  182. Hmmm..AEM Intake Question
  183. idle to high after gauge install
  184. Best Catback Exhaust system for 93 Lude S?
  185. how to do a motor swap for a prelude
  186. aftermarket h23 rods on jdm h22 pistons
  187. F.S. or Trade: JUN H22 Intake Cam *BRAND NEW!!*
  188. failed emissions need help
  189. Some insanely newbish questions....sorry guys :(
  190. Skunk2 H22 manifold measurements
  191. FS: h22 skunk2 stage 1 cams
  192. Test Pipe
  193. Loud knocking noise while driving. usually in 1st 2nd and 3rd gear
  194. Help!... 200whp on a H22a
  195. Amplifier Install
  196. What can I do to be safe w/ nos?
  197. Ok..In need of some help (money on the line)!
  198. ecu reset?
  199. H22 bore question about boosting....!!!!!!!!!
  200. Crower camshafts wieght !
  201. Type-s cams into stock motor -> yes or not?
  202. HELP!! CAR DIES AFTER STARTUP
  203. why is my h22 running differantly?
  204. Oxygen sensor wires
  205. Dream H22..what would you do?
  206. Burning oil
  207. JDM Euro R throttle body size
  208. A different sport shift qusetion
  209. running no thermostat bad?
  210. Which rods with type S pistons
  211. is notching necessary for pauter h-beams into a jdm h22?
  212. Is the F22 alternator the same as the H22 alternator ?
  213. Anyone running 1mm oversized valves with cams that have at least 12.4mm of lift (H22)???
  214. Clutches
  215. H22 and F22/34 valve info needed...
  216. prelude problems cant start
  217. Hondata P28 (s100) Mounting in Prelude
  218. b21a1 to an f22b
  219. Apexi V-AFC tunning
  220. couple questions about installing boltons
  221. JDM VS USDM TB and IM
  222. How many miles do YOU get?
  223. Continue New Set for H22 NA..............
  224. What do 91 Honda Prelude 2.0 SI Manuals run 1/4 time?
  225. 5th gen has front spindle?
  226. Wheel Size
  227. what should be my average 1/4 time
  228. Prelude Floor Mats
  229. exhaust manifold question?
  230. name the sensor....
  231. H22 balance shaft plugs
  232. Anyone know Hondaddict?
  233. Major Help Needed with Engine,,, Wont start at all!!!
  234. springs, cambers, and struts ... oh my
  235. converting my gay 4th gen sunroof to the 5th gen Glass
  236. New Set Up for NA H22A? What should hp and 1/4 be expected?
  237. another turbo
  238. H23 - H22 swap
  239. Hooking Up Air fuel Guage
  240. to everyone that has bought a jdm motor
  241. SH Axle different that base?
  242. need help, something wrong with starting
  243. Bolt from Hell. H22A Tensioner Bearring Bolt.
  244. Where to get A/C compatable turbo manifold for H22?
  245. where a good place to buy a good battery
  246. WHAT IS STOCK H22A JDM COMPRESSION ?
  247. 4th gen with jdm headlights and hids
  248. auto-manual swap
  249. What OBD1 Distributor Can I Use?
  250. having problems finding the n1 exhuast for my 4th gen
