PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 [231] 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. SPARK PLUG HELP
  2. H22a4 + f22 vtec block
  3. Help with gauges
  4. Question re: 97-01 automatic tranny
  5. Power Steering Noise/Problem on H23 VTEC....
  6. Some ?'s on 5th gen prelude
  7. Valve lash too tight=engine stalling?
  8. resetting ecu...
  9. Just got my Prelude, got question
  10. Newbie Prelude questions
  11. H22 Tranny peices?
  12. Flywheel ?
  13. wiring problem
  14. what is this sensor
  15. stupid question
  16. evap the cause of my throttle surge?
  17. h22a turbo manifold?
  18. Tire size recomendations...Stay big or go OEM?
  19. dynoed prospeed header today.
  20. loss of power in tranny maybe?
  21. vtec doesn't work like it should?
  22. how lon does it take to swap a head??
  23. how to modify dc header
  24. 4th Gen Prelude Question
  25. widest tire size
  26. idle issue
  27. I think I fried my electronics
  28. 4bidden short shifter
  29. h22a hytech header info plz?
  30. need suggestions
  31. 5th gear issue
  32. Immobilizer Removal
  33. Preludeonline.com question
  34. Cannot maintain idle when engine warm
  35. clunking noise from clutch
  36. Boosting a 3gen need info
  37. a/c lines
  38. 2nd Gen Preludes
  39. best quality axles to go with for a Prelude
  40. The amazing exploding distributor (pics on the way)
  41. question: 300+whp centrifugal SC kit for under $3000 - would you want it?
  42. what size belt for alt pulley
  43. losing power?
  44. insurance question
  45. a few questions IM NEW!
  46. Check your oil Pans...Dented Oil Pick-Up
  47. Can you read this dyno and tell me what is going on? (possibly ignition?)
  48. Prelude Carbon Fiber Lip
  49. Fuel Cutoff Problems
  50. searched: USDM H22a1 not passing smog with I/H/E, ref error occurred.
  51. can a 6'6" guy fit into a 3rd gen prelude?
  52. What do you guys reccomend for cams?
  53. Build Question.....
  54. I found a lude setting in a yard, Let me hear your thoughts.
  55. gsr leather seats
  56. gauge cluster install
  57. Why do i have gold emblems?
  58. Lets see your stock lude' wheels that are modified
  59. f22 wiring
  60. New Clutch
  61. NEED SPRINGS OR NOT?
  62. Rear rotors won't budge. need tips on taking it out.
  63. I just bought a new car.....
  64. shops in Raleigh, NC
  65. Rattling Sunroof
  66. Question: h22a pistons
  67. Need Help. Leaking oil
  68. clutch problems with my friend's car
  69. misfiring, crappy idle etc....HELP!!!
  70. 4th GEN TURBO PROBS
  71. h22a woes
  72. 1992 4WS issue...AGAIN!! Has anyone resolved theirs??
  73. Help Me!!! Brake booster idle problem? Vacuum leak?
  74. Crazy night last night, prelude almost boosted
  75. Greddy EVO2 Sound Clip
  76. cruise control
  77. initial timing
  78. Clutch squeaks when I push it in (when cold)
  79. Help Installin an H23
  80. Condensation in headlight, what are the best fix's?
  81. shifter thread size
  82. a ? on milling the head specs
  83. physical size of 92-95 H22A injecors compared to regular B-series injector. ASAP
  84. alot of questions for the turbo guys?
  85. Tranny locks up Plz Help
  86. trying to remove 5thgen back seats
  87. MSD f@#$ my lude!
  88. Safe Shifting
  89. which h22 header makes better performance-an-r or hotshot??
  90. Pressurised Crankcase?
  91. Which exhaust manifold gasket?
  92. KAAZ Lsd anyone?
  93. radiator fan(s)
  94. Pretty much made up my mind but still have clutch questions....
  95. oilp pump qs
  96. What is 5th gen factory rim offset?
  97. muffler/exhaust ideas
  98. whys smsp so $?!
  99. jus got a catback, got a few Qs
  100. Accurate weight of one 5th gen rim?
  101. Is this bushing damaged? (pics)
  102. Need some Turbo Advice
  103. Help: tips on building an h22
  104. Question: H22a w/AEM fuel products
  105. Crank
  106. best flywheel to go with my setup?
  107. Sunroof 92 Prelude Si
  108. Installing corner lenses on 92-96 lude....
  109. Fitting 5th Gen Konis on a 4th Gen Prelude
  110. h23 head on h22.....
  111. quick question for boosted h22's
  112. h22a auto need help
  113. CF Moonroof teaser
  114. Prelude Ba4 b20a with b16a head
  115. Where to buy JUN 3 cams?
  116. What are the STOCK Air Fuel Ratios (AFR) for 4th/5th-gen Prelude VTECs.
  117. VAFC2 vtec adjustment
  118. Lowering Springs??
  119. Dash Brake lights On, all bulbs fine
  120. Hondata and the obd-II crossover
  121. Fuel pressure trough the roof
  122. Now Supercharged JDM H22A
  123. dash speakers
  124. Where does this broken piece go? *Pics*
  125. What is sound deadening material made out of
  126. UNIVERSAL O2 SENSOR
  127. Leaking Coolant
  128. Help - Stock Alarm Stop Working :-(
  129. Putting Prelude on a diet?
  130. weight of 4g leather seat?
  131. 1/4 mile times with smsp on 5th gen?
  132. still having problems with tach wiring install did a search already for 1994 honda civic hatch cx
  133. UKDM Fog Switch ... Advice If You Would.
  134. Tranny fluid
  135. Replacing clutch today, need a little help
  136. greddy cat back.
  137. FLYWHEELS
  138. Mobil 10w-30 or 5w-30
  139. JE piston and eagle rods
  140. Easy fix for a squeaky clutch pedal?
  141. What causes oil pan knock?
  142. Short Ram Air?
  143. prospeed header
  144. Removing the IAB plate?
  145. Major service coming up - anything else I should do?
  146. H23 Performance ignition?
  147. Any1 from Perth Western Australia owning preludes???
  148. SH suspension
  149. Thee bestest header iiiiis?! ........
  150. how many quartz of oil ?
  151. What makes the 5th gen so heavy?
  152. How much motor oil for a 97 base prelude
  153. tires?
  154. H22A4 main bearing cap torque specs please
  155. Timing Belts????
  156. V6 Prelude
  157. VTEC WIRING PROBLEM
  158. JDM digital climate control
  159. Rebuilt H23 VTEC, Won't Crank.....
  160. Inspection results FAILED :(
  161. Clutch options for my Prelude
  162. JDM fog light wiring harness diagram
  163. 92 Prelude Brake Master Cylinder question
  164. Foglight question.
  165. please help, need diagram to pass SMOG
  166. will a h23a vtec fit in a prelude
  167. Tightning 5th gen e-brake.
  168. SWAY BARS: Who Makes the Biggest?
  169. Vin # question
  170. selling my prelude 89
  171. car shakes when i increase throttle position
  172. Neutral has a weird feeling! Help!
  173. Who makes roll bars for preludes?
  174. intercooler piping pics.....
  175. GREDDY CATBACK F/S 01 PRELUDE
  176. slushbox question...help!!!
  177. how much boost
  178. vtec problem
  179. anyone pull a motor and leave the tranny in?
  180. Intake: AEM or Injen
  181. Timed my 0-60..please no flames..just a question
  182. Brake trouble...
  183. neuspeed header?
  184. 5th gen initial RPM after startup?
  185. Power folding mirrors
  186. New Valves, Springs, Retainers needed?
  187. have front/rear strut bars...should i get tie bars?......sway bars? questions
  188. how does this N/A set sound?
  189. Tuning adjustable cam gears w/Crower Stage 2 cams on the H22.
  190. 5th Gen Lip???
  191. What TURBO
  192. intial mods?
  193. good secondary o2 with a bad primary... what happens?
  194. bumper cover alignment
  195. N/A setup cost me $_ _ _ _?
  196. Is this a good price for built block??????
  197. Anyone have the OEM K40 in their Lude?
  198. Service check-connector
  199. throttle body issues.
  200. Just got back after re dynoeing with hondata
  201. manual tranny help
  202. does the apexi ws gain in any hp?
  203. Switching to regular oil for a couple of weeks...ok?
  204. about to order a greddy evo2 exhaust
  205. bolt pattern on aprelude
  206. wats the best sounding exhaust
  207. secondary runners
  208. Kill switch?
  209. civic si with jdm H22 1993 motor need help
  210. ATF cooler hoses on radiator
  211. oil out exhuast? black sute (sp?)
  212. jdm h22 or jdm b18
  213. Hello Neone From England on Here? Vtec Problems!!!!
  214. steering wheel
  215. Draft:anyone know about stroker kits for a b20 out of a prelude
  216. h22a in my 94 honda accord what should i do first
  217. shifter arm
  218. idle problems...weird!
  219. Prelude Wear and Tear Problems
  220. OT: shakes visits WNC!!
  221. whats compression ratio you running, whats your compession test psi.
  222. Radiator hoses
  223. Prelude Ball Joints Question???
  224. 4g Legend brake upgrade
  225. Weapon R 92-01 honda prelude throttle rotor ??
  226. how to remove heat shield....
  227. JDM sidemarker
  228. Looking at 97 prelude
  229. HELP TURBOING MY CAR THIS WEEK
  230. Turbo and high mileage cars?
  231. should i buy the koni yellow adjustables for the SH?
  232. problem with jdm h22a
  233. removal of clear corner
  234. water pump ..
  235. Got my h23vtec running and well....
  236. Odometer?
  237. H23 Bore Question??
  238. blowin a little smoke
  239. type s cams on H22A1
  240. NA Engine Build ?
  241. VAFC Tune
  242. How to Install a GM 2 Bar Map Sensor
  243. valve springs
  244. Fan not coming on Please Help!
  245. How old is my radiator? (pics)
  246. type s and frm wall
  247. 94-96 EL guages. Wire harness from speedo to dash harness. Anyone have a pic of it?
  248. Is There a SIGNAL the ECU puts out which tells you what GEAR you're in ???
  249. pc valve cleansing
  250. Will H22A1 Eagle Rods fit 98-01 H22A4?
