PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 [263] 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. my 97 Turbo Prelude vs McClaren F1.... who wins???
  2. Pulling the engine
  3. For those with Autopower roll bars
  4. H22 rebuild troubles - PICS inside
  5. Prelude Type-S??
  6. question to turbo luders
  7. Any know is there parts for a Honda Prelude 1985 model
  8. fastest 5th gen prelude?
  9. PULLIES! PITA? or simple?!
  10. help my h23 run 13s!!!
  11. Gram lights or Rota Slipstreams?
  12. all sleeved h-series READ
  13. question about gauge light power hookup in 4th gen..
  14. prelude and accord shift linkage the same?
  15. H22A Crower Stage 3 Cams
  16. SI intake Manifold on and H22
  17. Meanest Cam Suggestions for an All Motor H22 VTEC
  18. Prelude aem EMS ?
  19. can i paint my alternator belt to match my car?
  20. what header works on the JDM F22b dohc motor?
  21. Anyone have this part laying around??
  22. H23 V-tec swap?
  23. WTB: used 92-96 shift lever
  24. JDM pats for prelude
  25. •OT: JDM Prelude Headlights•
  26. F20A4 -> H22A swap
  27. F20A4 -> H22A swap
  28. bought my clutch. OEM repalcement. Comments? thinking of coupling this with a Fidanza 8lbs flywhe
  29. What is so great about the Magnaflow ES Oval Style Muffler?.....exhaust setup pending
  30. 89 Prelude - stalls when outdoor temp is above 90 degrees
  31. what size sheet metal to block egr
  32. Scraped DC header...need help/info
  33. Tuning for high compression pistons
  34. Monster/Buddy club type hood? Any issues on ludes?
  35. Run mid 13s with no turbo,SuperCharger,NOZ
  36. seals and timing belt
  37. my shifting question
  38. Sideskirt?
  39. Are type S cams good for the buck, or should I go with aftermarket cams
  40. 4 wheel steering
  41. Starting problems??
  42. what else for HP on an h22
  43. new v2 intake
  44. no fire on the 23vtec?
  45. h22a and h22a1
  46. RIM SIZE questions...
  47. im trying to find rings an rod bernings for my h23a1 any one have a good price??
  48. anyone have an h22a1 or h23 block for sale?
  49. engine swap
  50. Fuel Pressure regulators
  51. 92 SI ignition switch
  52. Need some help diagnosing the ludes problem
  53. help for tranny swap
  54. Nopi nat- Who is attending this year and what section are you parking in(if you are entering)
  55. Turbo or Nitrous?
  56. Difference in Injectors for prelude
  57. Just finished valve lash adjustment and now I'm getting CEL 15... HELP
  58. Are Automatic and standard H22a/H23/F22 jackshafts (midshafts) different ???
  59. Buying a prelude
  60. coil overs or not?
  61. wheel question
  62. can you convert a auto engine to manuel
  63. A bit of help for my newbieness
  64. Steering Wheel Nuts
  65. ECU Pinout Map
  66. 87 prelude
  67. what does bb4 prelude mean?
  68. Timing Question?
  69. camshaft experts
  70. AC Troble with my H22A4 and my P13 ECU
  71. Who here has taken out ther sunroofs?
  72. HKS Super Dragger Muffler
  73. h23a1 motor value? need to know
  74. Skunk2 intake manifold for h22?
  75. Pulled my head today, and guess what I found...
  76. code for cd player
  77. importing a RHD JDM lude in the states!...
  78. JDM P13 on a USDM H22A4
  79. Big Problem......Any Ideas?
  80. anyone have passernger grille and window reg for 4th gen..
  81. best cams for the price
  82. Need Help With H22a Type SH Engine
  83. where should my pressure be on my fuel pressure regulator at idle and at wot
  84. STOCK fuel press at the rail or filter
  85. Brembo Gran Turismo Brake kit...
  86. using my old H22 accessories on my new H23 block... do I need H22 crank pulley?
  87. H22 with NOS?
  88. Look at the nose on that guy (2point6)
  89. h22 trannies, do they differ between generations?
  90. 4th gen dash switches
  91. LOOKING FOR 96 JDM ECU
  92. P13 / P14 Pinouts
  93. prelude suspension into accord?
  94. push button start
  95. quaife install
  96. Finally got the car back up and running ;) Also put in the forbidden shifter....
  97. your opinion on aftermrkt axles
  98. Speciality Products Camber kit question
  99. h22 oil pump in a h23
  100. got a 5th gen lude yesterday
  101. engine knock problem
  102. 93 prelude
  103. Valves for B20A5 from '90 Prelude
  104. Qustion on 98 Prelude vtec
  105. Found: Shock Knock
  106. jumper plug on 96 lude - check engine light
  107. h22a motor swap
  108. I took second place at the Battle of the Imports...but problems now
  109. h22a block with h23a head is this right can this work?????
  110. Need Help!!! Prelude H22A Swap
  111. Went to the track today. Now I have a slight problem.
  112. Water in headlight lense
  113. tranny cooler question
  114. HELLLLLLP!!!!!!!!!! TIMING BELT CRANK GEAR ?
  115. adequate fuel pump for boosted prelude
  116. problem with air/fuel guage
  117. tranny help quick
  118. why do h23a1 allways have spun bernings?
  119. Helms, Chiltons or Service manuals?
  120. A few comments after my first few days here...
  121. Check Engine Light Help
  122. Need Help Fast!! Buying a Lude today
  123. update (overheating)
  124. Clutch won't pump up??? Any ideas
  125. Ignition timming
  126. Need torque specs for h22a flywheel...
  127. whats the displacement h22 w/ h23 crank and 90mm bore...2.4?
  128. GC install - o rings?
  129. 5th gen questions
  130. EuroR Intake Manifold - Gains?
  131. autometer a/f gauge?
  132. how to install 4gen bucket seat...
  133. Anyone have any MUGEN MF10s on their ludes?
  134. problem with h22a
  135. Where are the timing marks?
  136. Dumbest question:
  137. CAI vs. Short Ram
  138. Car reving and reving, but no power: loss of power?
  139. COOLANT HOSES: WHERE DO THEY GO?
  140. Speed shops in Jacksonville, FL or the surrounding area?
  141. idle drop help
  142. Skunk2 tie-bar 4th Gen on 5th
  143. H22 w/ Crower Stage 2 dyno resluts
  144. Studdering at low RPMs... maybe same as hesitation??
  145. What rings come with JE pistons? Wiesco? (for boost)
  146. hmmm.. 2 ebay or not 2 ebay..
  147. Trust/Greddy... New exhausts?
  148. Prelude Factory Wheel Weights?
  149. what's the proper plug gap for h22a1?
  150. What's the stock tire size JDM 4g VTEC?
  151. Opinion: Which exhaust for the '93 Lude (H22A2)
  152. a little info needed
  153. Prelude hesitation update
  154. What do you think about the JMO torque converters?
  155. 1986 Prelude Si....Engine Swaps?
  156. best bang for the buck? hp gains
  157. Fuel Pump question.
  158. anyone here from around the traverse city area?
  159. 3rd gen 4WS - how does it work?
  160. 3rd gen (88-91) Prelude brakes same as 3rd gen (94-01) Integra?
  161. h22 ecu pinout question
  162. clear front turn signals
  163. help! [I]wrecked[/I] the lude. specifically need tire help
  164. cai box
  165. ok p72 again
  166. ok, just for a laugh
  167. Does anyone here know any Honda techs??
  168. Will a RSX sunroof fit a 4th Gen Prelude??
  169. car won't crank *fuel pump?*
  170. Anyone heard of a-1 performance muffler?
  171. NA H22a dyno graph with mod list...
  172. spring installation (NOOB question)
  173. Passenger mirror for a 97 prelude
  174. 4bidden short shifter instalation
  175. Main Relay
  176. quick headers question
  177. exhaust question
  178. Anyone have this problem?
  179. Too much torque
  180. are the h22 eagle rods the same as the h23???
  181. 5th gen Sport Shift, can you use transtech?
  182. trouble wiring up my h22a in 92si
  183. Which kind of oil should I use on my H22a
  184. 5W20 at the dealer ?
  185. Checking a CEL code - How to ?
  186. camber
  187. OK, I'm staying... but:
  188. Euro R H22a
  189. Damn H22 troubles....I need some insight!
  190. headlight fade
  191. GC CoilOvers or Tein Springs
  192. Transmission Housing?? Clutch Side???
  193. how do i change the orange blinker in my tail light?
  194. Interior Swap
  195. 1997 Prelude SH Price Question!
  196. Need Alarm Help fast!!!
  197. Atts help
  198. Compression Question
  199. Looking to buy 4th gen. Prelude!!!
  200. H22 in S2K
  201. turbocharger/supercharger?
  202. JDM steering Wheel
  203. upgrading accessories
  204. lowering compression...
  205. 5th gen prelude help needed
  206. Anyone using a cometic head gasket to raise compression?
  207. Where is my '97 Prelude's horn? (Yeah, I'm dumb...)
  208. Digital Climate Control
  209. What is this ECU?
  210. B20B in 1990 Prelude?
  211. AHH!! Axle nut drivin me nuts! HELP!
  212. Prelude promo car!
  213. are crank journals same for H23 And H22A4
  214. Where does this seal go? '94 2.2 VTEC
  215. 96 Prelude SI ABS Brake Question
  216. CAMBER KIT
  217. Want to buy a 93+ Prelude need help
  218. 94 Prelude VTEC front tire angle
  219. Do not lower the Type SH?
  220. Vacume lines .. where to?
  221. Pic Request: WHite 4th gen with Kaminari Kit (Volk Racing Car)
  222. anyone know where to get good prices on fenders for 4th gen ludes?
  223. do you guys know anyone that works at HONDA
  224. headers or not
  225. help with cel!!! searched already
  226. Help me i have a question on my tire angle?
  227. 94 lude si for $8k
  228. help fast
  229. Do they make BFG drag radials the right size to fit base rims ?
  230. turbo h23 at the track!!!
  231. What do you think ?
  232. need help!
  233. prelude bumper lenses fitment
  234. Cleaning throttle body and other service questions
  235. where can I get high compression pistons for H22 FAST?!!!
  236. This is crazy
  237. does anyone have any part numbers for an all motor h23
  238. clutch and flywheel
  239. Question about motor??
  240. How much can I sell my 4th GENERATION PRELUDE for? =P
  241. Federal H22 ECU - Are auto and manual swappable?
  242. 2point6 Dyno session frustrations... Slightly OT.
  243. finally car is fixed the nightmare is somewhat over
  244. JDM H22a Cat back question...
  245. Camber Question for a 4th Gen Lude
  246. A message from your MODERATOR... :)
  247. Perlude Swap in Civic
  248. Affects of not tuning right away
  249. Titanium retainers
  250. 92 SI center console swap
