PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 [215] 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. OIL LEAK!
  2. 4th gen coilovers
  3. 250 for brand new slipstreams for a 4th gen
  4. whats the fastest street prelude???
  5. HELP ME identify this Aftermarket H22A cam PLEASE
  6. Honda Prelude BB6 Navigation????
  7. H22 wont start, need help.
  8. JDM 5th Gen Honda Prelude with 4ws Conversion to USDM 99 Lude??
  9. need new exhaust!!
  10. OBD1 Knocksensor
  11. H22 skunk2 manifold problem
  12. evap hose
  13. H23 Drag Turbo Kits
  14. h22a into 92 accord PROBLEMS
  15. H23 better then H22?
  16. H22A Turbo...Backfiring, Stalling, Pulsating in 3rd, 4th, 5th, Oil Vaporing out of breather...any he
  17. H22 sensors
  18. racing with a auto.. --.--
  19. is it true...
  20. you guys ever hear of a nirtous shot kit?
  21. Bringing a H23 up to H22 status?!
  22. *Noob ?* Manual Tranny Fluid?
  23. i need to find a cometic head gasket
  24. Are SH and Base headers the same?
  25. motegi body kit ?
  26. What's a good price for an H23 manual tranny?
  27. K&N filter
  28. JRSC w/VAFC=BIG problems!! HELP!!
  29. just got my 95 prelude si
  30. H23 VTEC Head Swap in line?
  31. need advice on camber kit
  32. SRS Light Reset MES Fix - Legit Documentation
  33. ebay strut bars
  34. Where do these plugs go??? :hammer:
  35. msd 6a install on 98 prelude
  36. CAI question.
  37. do throttle body spacers work on a 99 prelude
  38. Gonna tune my vafc myself for the first time.
  39. Can't really figure out what this is?? [Pic inside]
  40. Do i need obd1 clips for rc 550cc saturated injectors
  41. stock exhaust?
  42. Autotensioner to manual tensioner???
  43. Replaced Knock Sensor. Do I need to reset my battery????
  44. Help: H22a with P28
  45. REQ: Pic of OEM JDM H22 FPR
  46. Question about my guage cluster on my 98 prelude
  47. Question about my guage cluste in my 98 prelude non SH
  48. 98' Wiring Harness.....need help findin one
  49. PRELUDE MOTOR
  50. 70mm throttle body worth it on my setup??
  51. Quick timing belt question
  52. Ok Guys Please Help me with upgrade Tips!
  53. dash, power windows,& sun roof quit
  54. 1991 A/C Red Light
  55. please help me figure this out!
  56. spaceballs!
  57. H23 what ecu?
  58. OBD II to OBD I changeover and SMOG
  59. Cd player doest work, neither does the clock
  60. Will the brakes clear factory 14"s?
  61. 94 Accord H23 surging when A/C turned on.
  62. LSD or not
  63. JDM H22A from Accord is only 180hP ?
  64. auto tranny upgrades
  65. Ats final drive
  66. ABS light question
  67. bent valves?
  68. h22 tranny
  69. CD player needs code after battery reset, any suggestions?
  70. HELP!! H22 alt. belt
  71. F22B timing belt hardware & intake manifold gasket = H23?
  72. Oil Pump Swap Questions.......
  73. suspension
  74. DH-Racing 's manifold, what do you guys think about this?
  75. High Flow Catalytic Converter that is OBD2 Compliant?
  76. H22A motor question
  77. 91 Prelude Wheel Offset?
  78. h22 pistons wut should i get
  79. Where can I get the glow gauges for my 91 SI 5spd?
  80. Pulling out the carpet from a 4th Gen. How??
  81. h23 pistons
  82. DOHC
  83. JDM H22A Spark Plug Wires
  84. Jumpy lude... need some help
  85. prospeed header touching crossmember
  86. Skunk2 Stage 1 Cams
  87. Tein HTECH Springs
  88. prelude turbo
  89. how much do 3rd gen gauge clusters run?
  90. Honda prelude p5m ecu question
  91. suspension/ weight.. KNOCKING NOISE????
  92. car is running like poo poo.
  93. IAC adapter for Euro R manifold?
  94. Info: OBD 1 jdm p13's
  95. 97-01 Prelude Rotor setup
  96. noise when slowing....
  97. wheel bearing
  98. H22A PISTONS need ADVICE
  99. smoked out taillights
  100. need opinions
  101. 1994 H22a Front Balancer Shaft
  102. Is this a good price for a prelude?
  103. H22a vtec head bolt on for a jdm f22b1 dohc?
  104. Knocking sound == bad
  105. prelude engine
  106. injectors and plugs
  107. My head is cracked! Any alternitive options?
  108. prelude interior
  109. Question about my tranny???
  110. Hey...a question to the Moderators........
  111. TURBO???
  112. question about installing back seats...
  113. what goes here and where can i get it?
  114. ignitor problems?
  115. Code 3 and no Vtec, please help
  116. Engine swap question
  117. help me wire my Gauge's so i stop looking like a damn ricer!!!
  118. i read the faq...can't seem to figure out how to get the engines code....
  119. ABS light came on... any help
  120. brake light problem
  121. 87-91 Prelude Cold Air Intakes 3" one piece
  122. f22 to h23, need new alternator?
  123. Valve Seal Job on H22...
  124. Stage 2 Crower cams ?
  125. Engine Light .. weird?
  126. VTEC not wanting to kick in!!! HELP PLEASE!!!!
  127. engine light on...please help
  128. HOndata question for H23 ... help now please !
  129. h23 prelude ecu
  130. Tranmission Swapping
  131. JDM Engines
  132. jdm 1 piece headlight BULBS replacement
  133. brake cel coming on after previous lowering
  134. 1st gear rev limiter
  135. questions about H23 and B18b....plz help
  136. p72 ucu better than p13?
  137. h22a tranny help, please!!!!
  138. h22 exhaust help
  139. Question for Sharkcohen
  140. starting trouble
  141. Jackson Racing roots style supercharger
  142. a/c and vent problems
  143. Fuse 10
  144. What ECU Is This? W/ PIC!
  145. i'm a dumbass: stripped 10mm brake line --> brake hose bolt, what's next?
  146. 4th Gen Prelude A/C
  147. Code 17- Help!!
  148. H22A into 2000 lude...is this compatible?
  149. H23 DOHC VTEC and F20B information requested...
  150. cams
  151. My power seems to be falling off at around 6800 to 7000 rpm?
  152. world sport exhaust
  153. Mugen Body Kit for the Prelude BB6
  154. just bought a 88
  155. anyone seen Chk4tix2 or know how to get ahold of him?
  156. I have a 91 SI and I want to lower it - What springs or coil overs are best for this car?
  157. vibration/grinding when turning... tranny problem?
  158. '00 Prelude' Tranny question
  159. Wuts the difference
  160. JDM H23A DOHC VTEC specific parts...
  161. back light wiring problem on 5th gen
  162. Ignition Coil Negative Pickup
  163. Will the Accord catalytic converter work fine with the h22?
  164. rebuild engine or buy new one?
  165. new to honda-tech
  166. Which distributor cap on jdm h22??
  167. neuspeed header prelude
  168. 91 accord h22 swap
  169. grinding noise when i accelerate hard
  170. 1998 BB6 vehicle speed wire location
  171. FAQ: Prelude Tune up and Routine Maintenance
  172. honda enkei wheel referb
  173. So My Timing Belt Keeps Sliding Over......
  174. How hard is it to get dual exhaust on a prelude?
  175. Engine swap
  176. redlining??
  177. h22a differential
  178. timing belt came off while driving
  179. Fluidine instalation gone bad
  180. Question about RS*R ExMag exhaust
  181. h22a running too cold?help
  182. *Sacramento* / Need Valve Adjustment and Timing Belt Change / Good Honda Shops?
  183. Prelude SH burning quart of oil within a week!!!
  184. Replacing rod bearings
  185. Clutch?
  186. 5th gen SRS light
  187. Koni and Tokico
  188. code 9 and 14 need help
  189. Noise from engine bay sounds like crickets
  190. question about h22 turbo
  191. clutch question
  192. Heat Shield over Cat .... is it required?
  193. Quick question about DC Header
  194. If I take out the service connector will it stop the check engine light coming on?
  195. what to do?
  196. what does the map sensor look like and where is it?
  197. Can Someone work this check engine code out please??
  198. your recommendation and your reviews on brake pads and rotors.
  199. new lude
  200. installed a new clutch exedy stage one and 2nd gear grinds alot whats the problem
  201. Reliability
  202. what to do next?
  203. AEM PS belt size 93 si h23
  204. Nasty sound coming from h22a. Sound recording.
  205. cheap upgrades...
  206. Radiator Fans
  207. what honda/acura oem lips fit on a 3rd gen
  208. Local NoVA Shops?
  209. over heating probs
  210. Engin??????
  211. Quick exhaust question
  212. G-Tech Pro/Competition
  213. console or shift boot
  214. Removing pistons with engine in car
  215. Laser Spark Plugs
  216. My friend just got his Dyno!! h22 all mota!
  217. H22A N/A engine building
  218. Prelude RWD Conversion
  219. Shift problems?
  220. i need a Skunk mani and Hondata Gasket Dyno!!!
  221. [rant]Damn Fuel lines!!! one headache after another [/rant]
  222. FAQ: Dropping in a new motor and it doesnt work, what to start checking...
  223. car wont start! no spark?
  224. High compression pistons AND boost?
  225. Where is the location of the service connector for 1994 2.2 prelude import?
  226. Used Prelude
  227. New engine or keep fixing
  228. exhaust fit?
  229. Tranny or Clutch or Slave Cylinder????
  230. DC headers?
  231. My rev meter is on 1000 rpm when car is at standstill? (94 honda prelude 2.2 vtec)
  232. PRELUDE CLUTCH
  233. how would i do this?
  234. rev limit range on the jdm h22a
  235. Turbo after 70?
  236. front right shock squeaking
  237. clutch pedal problems
  238. half shaft transmission prob
  239. 98 Prelude - timing belt interval
  240. Prelude Suspension - Upper Arm
  241. help me on my v-tec is not working
  242. Accord won't rev past 2K
  243. dammit jus bought the car and....
  244. i have a problem with my redline with a new motor swap
  245. in need of a h23a1
  246. smoking engine
  247. need some answers from u engine experts; buying a 94prelude shell w/ blown engine.. u know the res
  248. auto to manual
  249. does anyone know where i can get a cheap genuine honda EGR valve?
  250. what is the fastest generation
