PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. cel p0401
  2. help w/vtec
  3. DIY: 4gp Cruise Control Delete
  4. H22 Crankshaft For Sale!
  5. my turbo 4th gen on the Dyno.
  6. Misfires, Jumpy idle, etc etc etc etc.
  7. whats inside the apexi ws2?
  8. oil pump questions
  9. Knock Sensor Question
  10. looking for some specific valves
  11. p14 ecu questions?
  12. Dohc f20b help
  13. Mystery Motor. Crank Questions W/ Pics
  14. Fitment Question
  15. 5th Gen Auto - Not Shifting - 5spd Swap Pending
  16. Headers
  17. JDM H22A Bearings
  18. 94 f22b swap to 98 h22a4 HELP!!!!!!!!!
  19. Any 1 turbo their h23?
  20. Car dies when the clutch is pushed
  21. h22 oil pan question
  22. my prelude update.....
  23. tranny check-up
  24. New Member
  25. Won't Start, please help!
  26. Question about lowering the Lude
  27. Prelude ECU Problem!!! Help!!!
  28. crank pulley came off now its miss firing
  29. OBD1 JDM H22 in 97 Prelude with F20b Dist.
  30. 92 Prelude SI w/ JDM H22A swap engine light
  31. DIY: How to install JDM DSP Speakers
  32. JDM DSP Headunit
  33. 1998 prelude transmission flare
  34. 96 SI ECU trouble code 65
  35. thoughts?
  36. Trany question
  37. Ignition key assembly, small steel plunger ?
  38. need help
  39. 4th generation camber kit
  40. H22A4 LMA's how much play is allowed????
  41. JDM F22B and F22B2 a/c compressor are the same?
  42. sh to non sh tranny???can i do so
  43. Exhaust leek
  44. Thicker head gasket for turbo?
  45. Dash lights!
  46. Dash lights!
  47. Prelude with F20b, false misfire codes?
  48. POST PICS OF YOUR SLAMMED LUDES!!!
  49. What block will fit '97 Prelude
  50. Electrical Issues
  51. new prelude owner with some questions
  52. Coolant issue
  53. 1993 Honda Prelude SI
  54. Missfire sometimes
  55. gaping plugs for nitrous
  56. type s tranny
  57. how to reset the SRS and CHECK ENGINE? please help
  58. h22 turbo 3mm headgasket opinion
  59. just did a compression test on my h22a4
  60. f22b OBD1/h23 OBD1 Vs. f22b OBD2
  61. M2B4 H22 LSD Transmission Axle Seals? Not Same as Reg.?
  62. bleh
  63. 1984 Honda Prelude transmission question
  64. Need help Rebuilding 5th Gen h22
  65. Need some help 1995 Prelude
  66. euro r intake manifold
  67. AEM or Hondata?
  68. Eratic fluctuating idle
  69. need help! 93 vtec rough start when cold
  70. is valve lapping necessary?
  71. White smoke out of hood
  72. WTB PRELUDE/HONDA lug nuts (stock)
  73. coilovers on prelude not working!?
  74. stiff chassis mod
  75. accord gas tank work on prelude?
  76. F20b in a 94 prelude with single cam engine
  77. VSS Problem, Guru's please help
  78. 98 Prelude Stalling, Hard to Start, Boggin, Weird Problems Need Help!!!!!
  79. New member that has questions..PICS
  80. looking for h22a head gasket P/N
  81. Auto to Manual Swap, Power Steering Assembly?
  82. Need some help with h22 obd2 to 1 and reading cel... Thanks!
  83. Wheel isn't centerd in the wheel well.
  84. RODS AND PISTONS
  85. ICM pin out
  86. for all you bb6 rear window visor lovers!
  87. my rear tail lights
  88. H22 swap
  89. H22 SWAP HELP
  90. ? on my left cv shaft axle
  91. need help with wiring issues
  92. Where to get pilot bearing?
  93. Seized balance shaft can engine still run?
  94. H22a Accord On and Off Idle Noise *Video INSIDE*
  95. Which is better? 4th gen or 5th?
  96. Which is better? 4th gen or 5th?
  97. What are the pros and cons of tiptronic
  98. NEWBIE
  99. H series with F20C RWD Tranny?
  100. h22a valve covers- picture thread
  101. Coolant water when taking off airfilter?
  102. Will ap1 wheels fit on 99 prelude?
  103. H22a p13?
  104. H.I.D. INSTALL 5th Gen Prelude
  105. 1995 prelude si h23a1 with a 0 code?
  106. P1297 with Jumpy Tach and unstable dash lights
  107. 4th gen window visors
  108. head gasket choice
  109. bb6 jdm h23 swap need help
  110. broken sensors dont know what it is
  111. crack crankcase lsd tranny
  112. hit a curb... need help!
  113. need advice h22a1 block h22a head
  114. H22 stock valve keepers/locks work on crower retainers?
  115. Turbo H22 help
  116. 4th gen rims?
  117. Oil baffles with/ without piston squirters?
  118. HOW CAN THIS BE?!!?
  119. 97 prelude help!
  120. Need DIY guide for replacing front LCA 5th gen
  121. Going jdm
  122. transmission not going into gear... help help help
  123. f22a head swap
  124. ge manifold/fpr question!!
  125. (h22a)IAB control
  126. H22 Valve change through the years?
  127. Prelude gets no fuel help
  128. HELP!! CEL code p1259
  129. Oxygen sensor wiring help needed!
  130. Power steering ??
  131. Will a 03 odyssey knock sensor fit h22a4?
  132. usdm type s prelude??
  133. 92-96 carbon fiber stock wing
  134. What am I looking at?
  135. Whats with the oil pump?
  136. JDM H22a getting fixed... help me out prz
  137. No crank No start key light flashing on dash help?!
  138. b18c swap into 91 prelude
  139. H23A1 Problems
  140. How many miles can you expect a Honda Prelude to last for?
  141. Prelude/Accord (JDM Sir-T) Internals compatability
  142. Cam Help
  143. I'd like to know what I'm doing wrong...
  144. 97 prelude compression numbers
  145. Clutch Problems..
  146. *Car running hotter, idle bounce* help
  147. Turbo build, looking for parts and info
  148. Leaking trunk in 97 prelude. Please help
  149. auto/manual prelude?
  150. Helpp!!!!!!
  151. New rebuilt H23a1 overheating
  152. G23 or boost h22?
  153. climate control not working
  154. d2 coilover purple
  155. F23 rods
  156. H22 wiring in racecar
  157. Bearing Clearances…ASAP
  158. My 1st place WIN at HONDA DAY,ATCO
  159. Transmission internals question
  160. tach issue
  161. H22 Sleeve Questions
  162. H22A build
  163. 4ws steering rack and pinion (Power steering does not go back to center)
  164. 88 prelude 4ws "help needed"
  165. Are Prelude and Accord Rear T Brackets Dfferent??
  166. car wont start
  167. 93 Prelude F22A1 Need help please
  168. i need some advice
  169. 240BHP STOCK INTERNAL H22A DynoGraph
  170. h22a knock sensor wiring help???
  171. 2000 prelude keeps poping brakes light fuse
  172. 94 prelude clanking sound
  173. 92-96 prelude seatbelt hardness??
  174. need help deciding on vented carbon hood 5thgen
  175. turbo for a prelude
  176. crank sensor question H22a
  177. Megan racing rear toe arms help
  178. Help with my 97 lude window
  179. 1993 honda prelude f22a1
  180. 1986 prelude - how to find shop/mechanic help?
  181. best clutch choice for daily driven and dragging
  182. Injector Questions/Help
  183. NEED HELP TRYING TO DECIDE WHAT TO CHOOSE TO LOWER 2001 PRELUDE!
  184. Piston Rod
  185. How to increase horsepower in a 1988 honda prelude?
  186. OBX ITBs
  187. PLZ HELP!! MAIN BEARING WON'T FIT FLUSH!?
  188. B series swap in 92-95 prelude?
  189. want to put a 5speed in my currently tip-tronic 01 prelude
  190. power folding mirrors
  191. H22a Fuel Rail Please Help
  192. advice needed (engine swap)
  193. 5th gear grind
  194. '92 Si Front Wheel Bearing
  195. Honda Prelude 1998 From Saudi Arabia
  196. h22a tach flopping and occasuonal engine miss..
  197. H22a Engine harness
  198. new to forum, need help with my 94 prelude si
  199. How to remove bearing cap bridge?
  200. 2.2 Non-VTEC Crankshaft pulley
  201. Idle problem, any suggestions?
  202. What rims are these?
  203. 1993 Honda prelude swerving problem, help asap please
  204. 93 Lude rear wheel hub problems
  205. Immobilizer problem
  206. How to fix this...
  207. Gas MPG out of a F22B
  208. Lost my h22a
  209. Have a question RE;code 6,ECT sensor
  210. 91 steering column question
  211. 1996 stereo help
  212. HELP! Need advice on a no start condition
  213. transmission oil change
  214. 97 honda prelude sh Help!!!
  215. '93 Honda Prelude Acceleration Problem
  216. 4th Gen Prelude TSB's
  217. 5th Gen Prelude TSB's
  218. F Series Tranny to H Series?
  219. Which parts to upgrade?? Need help asap please!!
  220. Just found out no one makes a heater core...
  221. 4th gen suspension
  222. F20b Turbo Setup Question
  223. What modifications to make? Noob in need of help!
  224. H23 Bore Help!
  225. prelude engine swap
  226. dc5 type r steering wheel
  227. vacume issues and break and clutch not holding pressure
  228. 97 lude front right wheel makes metal screeching sound when turn left
  229. 1992-96 prelude
  230. 4th gen Walbro fuel pump install problem
  231. Koyo radiators (rad caps)
  232. h22 head assembly ?
  233. Whoaa!! Must see all the TSB's for 5th gens IMPORTANT!
  234. H22 main and rod bearings question
  235. Idle probs
  236. 88 prelude carbed
  237. type S intake manifold gasket
  238. 5th gen lude shift cables
  239. first post/introduction
  240. 1989 honda prelude
  241. 2000 SH turn off known CEL's? Does a Chipped P5P exist?
  242. Steering angle sensor
  243. Motor won't crank to prime oil pump
  244. heated 02 sensor
  245. HELP
  246. Almost 40k for a Prelude????? LOL.
  247. need sensos for h22
  248. honda prelude cruise control not working
  249. '97 immobilizer ?'s
  250. Washer fluid system issue. Help!!
