View Full Version : Honda Prelude
- Shaking steering wheel when braking?
- (Brake Lamp) light???.. help?
- adj cam gears
- 94 lude pillar guage pod
- full engine build for FI?
- prelude headers?
- One quick question about a lude
- Question about Mugen MF10s.
- Whats wrong with my brakes? Shaking really bad
- bad injector (help)
- 19 inch wheels????
- 5spd tranny is crap when cold, any suggestions?
- F22 to H22 Swap
- H-series 2.4L VTEC 4th Gen. Turbo ... Problems??
- Mugen plastic lens, headlight covers
- S2000 Oil Filter
- time for new brakes....
- help on distributor!!! H22a
- Cap and rotor install...
- h22a/h23a1 tranny gimping vtec?
- SAFC where to mount? (searched)
- H22a with bad idle and car kept on dying. HLEP
- H22A4 lower header piece
- What value would u put on this prelude
- What speakers Fit in a 93 Prelude !!! I dunno, Need heLP
- Most fuel efficient Rim size?
- What shifter do u prefer?
- 1997 Prelude, got some questions......
- JDM F22B DOHC
- 5zigen fireball catback system
- Where can I get my engine built?
- power stearing
- uberdata for a p13???
- Anybody got a flywheel? (56K watch out)
- eyelids
- Bushings??
- RPMs at 80mph (4th gen. only)
- Uberdata on 93 prelude??
- WHats my stock ecu??? prelude '93 vtec
- ECU reset
- B20a/vtec pics
- help.....car wont start...alarm problem?
- Troubleshooting a Prelude problem
- Help, car won't start...won't turn over or even click
- 01 Prelude SH, V2,RS*R exmag, initial hesitation,doI needmore fuel or what?
- cambers question
- auto gearbox shifting
- White Smoke Came Out The Exhaust For a Short While
- should i turbo or supercharge???
- FLUIDYNE Radiator
- h22a4 base camshaft vs type s, how to identify them
- sombody help! H22 topout question....
- "Clunk" when i make a right turn
- Were can I buy this part?
- Trunk light in cluster will not go away!~!
- Anyone have any pics of 5th gens with Rota Circuit 10 or Rota Downshift wheels?
- WTB - JDM 92-96 Prelude digital climate control with all the sensors
- pully question
- timing belt
- alignment question
- Winter Tires
- What do I need to get it runnin???
- Induction kit-rattles
- h22 in a eg?
- 97 prelude
- Is the 95 Accord EX 5sp ok for a swap?
- some one keyed my car, what can i do?
- searched - no luck - exhaust questions...
- DSM Manifold on H22a1???
- motor problems (HELP)
- exhaust question
- My baby is gone...
- type r pads on lude?
- Have you guys ever heard of this?!?!?!
- Haynes Manual vs. Helms Manual
- idle problems
- DC Sports Short Shifter and Short Shift Adapter
- What kinda stuff causes a code 1??
- diff between bb4 and bb6 motors?
- post up your prelude pictures in here!
- finally done with my car
- Oil light stays on
- short shifter
- bump stop.. where to buy?
- Red 5th gen prelude with carbon fiber hood?
- Some pics from Limerock
- Cosworth pistons...Same as Jun pistons?
- Is there a 1 piece projector lights for 93lude?
- H22a vac boc question
- will lower compression pistons damper power?
- greddy evo + wings west rs = scrape?
- tires
- VTEC Solenoid Screen Question...
- What is best Spark plugz to use
- parts for 200 for a h22a
- aem intake and stock filter compare?
- Honda engine revs
- Starting my Manual swap...need advice
- us and jdm p13
- Jdm 1 piece headlights
- i need pics of prelude leather seats out all the years of prelude special edition 4th gen
- fuel regulator question!help!
- OBD1 h22a in a OBD2 car? can u do it?
- Satan Approved: Need Engine ASAP!!!
- f22b1 block h23a1 block
- CAR PROBLEMS!!! grrr...
- HID conversion
- valve cover
- Has anyone made a Airbag tray for when you take out Passenger Airbag?
- PROBLEMs on the homefront!! sleeved h22 compression test (RESULTS inside)..
- 92-96 Prelude Headlight Removal
- VAFC Hack or FMU and Inline pump
- what happens if the cam sprockets are off??? good or bad???
- cars in cali
- WTB: oil pan, driver airbag, passenger air bag, K-member, control arms......
- how do i find cel codes for 2g prelude si
- 5th gear and reverse
- H22 rebuild
- where to find an iceman intake
- h23/vtec or straight h22?
- my dyno sheet
- h22 Turbo header manifold
- crazy grinding??
- Type S Engine
- Yellow headlights.
- 99 TYPE SH SWITCHING MOTOR & TRANS TO OBDI SETUP
- WHAT KIND OF ENGINE DO I HAVE
- Little bottom end advice....
- more issues found with my motor
- muffler from a local shop instead of catback??
- For all of you who live in california...
- I need help/input on whats wrong!!!
- What do you think i can run with my setup
- Pirate's New H23/F23 Hybrid DYNO RESULTS
- CAI PROBLEM!!!!!
- I just bought a 93 Prelude 16 Valve Automatic, asking some rediculous questions.
- Help with 5th gen with Cat removal.
- Driving on a messed up engine?
- JDM sidemarkers
- bearings and front stabilizer bar
- H22 and H23 distributors....Question....
- I'm an ass, satan_srv here my lude
- Questions on K&N High Air FLow Filter and a Cold Air Flow Intake
- I need new spark plugs for my 4th gen (S Prelude) 140 hp one :/
- Need pictures of 4th Gen Motors..(SI, h22, and si vtec if there is a diff)
- Where do u find rails and sliders???
- Post some exhaust sound clips
- STRUT BARS - TIE BARS
- Tein Flex question
- Removing fuel filter
- Knocking/Thumping noise
- ohms Resistance
- Tanabe Ultra Medallion Titanium Exhaust
- H23 - whats the best part for more horsepower?
- Press Gas... REVS GO DOWN?!
- prelude Si gauge question
- any tensioner pictures?
- JDM digital climate control (different question)
- redline rpm's
- f22b dohc knock sensor Q
- Found out my problem with the Lude
- Is it bad to stall your caR?
- Automatic Back Rub at Idle
- f22 trans same as h23??
- Big time stuttering / stumbling issue 93 vtec
- help!!! oil in spark plug holes
- reset my ecu!?!
- 02 sensor help
- V-afc ?
- ES oval
- Need serious help with my 89' prelude 2.0S Please help..im lost
- prelude video clips
- How to keep your Boosted motor from blowing....
- Synch problem??
- H23 VTEC (Specifically for Satan_SRV)
- What upgrades can i do my 4th gen that won't reduce engine life?
- H22a cant go pass 120mph. help.
- Open Invitation Meeting 2 / OIM2
- edgeracing.com
- Pricing on install
- Timing belt installation
- Camber kit found on ebay. Need opinions
- skunk 2 intake manifold
- slipping clutch?
- Shift Points (man i konw you guys want to jump on me for searching, just read it...)
- http://oem.overnightautoparts.com?? anyone ever bought
- prelude stock cd player anti-thief code
- HELLLLLLPPPPPPP!!!!!
- Ignition Wiring
- h22a spark plug wire help
- Found the Oil Leak Cause, Now Need Help on How/What to Fix
- Turbo Automatic
- Oil Pressure Guage
- Skunk2 exhaust doesnt fit
- which belt does JRSC need to run AEM pullies?
- oil pressure sensor
- rsx seats in prelude???
- Anyone use the cai from cosmoracing? If you have can you tell me sound / gain?
- anyone used the Mugen brake pads?
- 89 prelude stutters when floored
- looking for pick of 5th gens w/ angled N1 style exhaust
- alignment ring?
- Whats Wrong with my motor!?!? (relinked)
- Please help question for a friend
- vibrant exhaust
- Tire/Rim Questions
- JDM Tail Lights
- walbro: reg 255 or high pressure 255
- You 92-96 Prelude Suspension Set up...what is it?
- 92 Prelude...Taking off Stock Bottom Air Box to your Stock intake.?
- injector clip question
- Need clutch and flywheel opinions...
- CAI Installed= CP
- HID --> JDM headlight fitment
- Anybody here with a 1st gen Prelude?
- radio wiring help for 92 lude si
- ment to shift to 4th but hit 2nd......now having alot of ticking please help
- Exhaust Sound Clips
- general questions about my lude
- 5th Gen Trunk Mount Bike Rack Recommendations?
- rpm drops while driving
- toooooo louuuuuuuuuuud
- Door speakers........
- the NEW TL engine...in a 5th gen lude?
- Can You use RSX (K20A) pistons in a H22 or H23 block?
- Cooling boosted lude
- new trade sell site tradersoup.com
- removed EGR but still gettin CEL (obd1)
- The Proper Way?
- 4WS question
- car covers
- Tanabe sway bar question ?
- Turbo 3th gen Prelude B20A5
- IACV trouble shooting.
- dc sport vs. mugen header(the $145 one on ebay)
- V-tec How Should it Sound????????
- what are some rims that fit 95 prelude sr-v\?
- axle question!!!
- free mods
- Vtec stumble problem
- Anyone know the AEM cai imitation piping website?
- Clutch Fork Pivot!!!
- how wel does the h22a4 head flow
- Lightweight mirrors
- Viper Security System
- Anyone heard of/have KYB GR-2 Shocks/Struts?
- Motor too old for synthetic?
- could this be a cam shaft problem?
- Engine Swap
- H22 tranny fluid, how much and what kind?????
