View Full Version : Honda Prelude
- auto >>> manuel??
- Help! Need a quick answer. Cam Cap Oring
- what would cause...?
- hondata ECU question
- HOW TO:VTEC brake conversion
- 2001 prelude Converting to OBD1 from OBD2
- fan switch
- headers
- Couple questions for a new prelude owner.
- koni yellow with skunk2 lowering spring 2.5" race
- Tail Lamps Insufficient???
- Billet Spark Plug Cover
- Allmotor H22 skunk2 Stage 2 cam's. Vavle to piston clearance problem
- h22a cams??
- H22 into a 92 si
- Rusty liners
- What do you guys use...
- Help wit nos on a usdm h22
- ECU Code wandering if anybody has ever heard of this one
- gas prices
- H22A OBD1 swap in a F20 OBD2 5th Gen
- pickup coil 1992 honda prelude
- 4ws, already researched
- h23 rebuild
- Random question why is the SH header shorter?
- EL gauge cluster question
- h22a sputters
- Question regarding Honda OEM vs Aftermarket clutches
- Help Me Identify this motor H23A1 Is this JDM???
- Catylic Converter
- anybody who live in WI knows how to do prelude timing....
- Stuck E Brake
- WANTED ASAP: OBD2A H22a4 Engine Harness (mod approved)
- Help, car sputters and hesitates after headgasket change
- Changing one brake pad
- Engine boggin
- Trying to Replace Antenna On My 1992 Prelude!
- Intake mani/itbs
- Buying A Prelude
- Has anyone run TWM ITBs on their H motor IN A PRELUDE???
- ITR Seats in a Prelude
- Buying 92 Prelude SI
- Clutch Install Problems
- 4th gen wont start. Need some advice
- PLEASE HELP... IGNITION? FUEL? INTAKE? I DON'T KNOW!
- wiring harness problem
- Transmission Dilemma
- swapping f22b engine into blown up prelude
- How do i know i have a JDM engine?
- cool prelude tribute video
- RPM instability when braking
- f22 block, with what i think is an h23 head
- Endyne Dynamics JG (6 bolt H23 Cam Gear)
- Please help with idle problem
- knock sensor ?
- Car does not go past 3000 on the rpm
- Anyone know where i can get the back centerconsole with the lock and key
- Broken stud
- Auto-Cerm
- EGR removal difficulties
- Does it matter where the colored side of spring goes on a tial 44mm?
- vtec rotor upgrade
- Which distributor to use with JDM h22a motor/usdm h23a harness?
- Prelude radio blockoff tray
- megan racing vs hks
- P13 pin ?
- Motor
- New OEM Brake Upgrade Option -- S2000 & RSX Type-S -- Installed, Tested, & Reviewed
- Air bag tray (4th gen)
- Block storage?
- RyWire VTEC Sub-Harness. Need help.
- help... where can I buy the o-rings (gaskets) for H22 DC sports headers?
- Engine Tune Question
- Washed engine and now car runs poorly-PLEASE HELP
- Misfiring and car dieing!
- engine dies while driving.... PLEASE HELP
- big brake kit
- Hondata Stock h22a map. Anyone?
- Help Please F22 with H23 head ECU ???
- Prelude SH questions
- con rod bearing with oil hole - part numbers
- WTB H23 prelude motor, long block only. Must run!! Needed for 95 SI
- egr problems
- Is the EGR Sensor shared with other vehicles?
- Blue smoke at vtec xover on freshly built motor No smoke before or after xover???
- Distributor cap
- Prelude Bumper ??? what type is this anyone knows?
- 94 prelude si
- CEL missing connector?
- Exhaust valve question....
- Weird Electrical problems...
- h23 help ASAP!!
- Fuse Blowing
- Front lip options for '93 Si.
- dohc f22b header
- Woodruff key. Help
- 3rd gen prelude h22 swap
- Problem with my jdm h22a!
- Cherrybomb Glasspack
- h22a4 No POWER
- Odometer Not Working
- p14 to p13 ecu
- Rota gt3's
- Is Three Inch Exhaust really worth it?
- Leaking valve stem seals???
- oem rear lip???
- light weight wheels
- VOILA! |s2000 projectors in my g/f 2001 Prelude headlamps| check it....
- NSX Callipers
- Any way to hold the auto tensioner for the timing belt closed without the stopper tool?
- ????Need experienced opinions on what you think are the best cams for a stock block allmotor H22????
- leaking catalytic converter---please help!
- h22 leaking oil @ timing cover, what all could it be?
- prelude tiptronic shifter wiring.
- Compression Ratio for 5th Gen
- INTERCHANGEABLE HEADS!?!?!?
- pulling my motor, what should I do
- can u fold down the 5th gen rear seat backing?
- EGR valve with aftermarket intake manifold question
- CEL and SRS light on
- '92 prelude gas/temp gauges off?
- Bearing Cap Bridge Help
- Need help ID'ing a part
- transmission
- 97'prelude SH a few questions. I appreciate any help.
- I am having trouble finding engine parts for my H23
- cam ?'s
- Need HONE or BORED H22 if new RINGS installed?
- h22a4 clarification?
- Stereo wont turn on!!!!!
- 98 ECM work in a 97??? need help/answer ASAP!
- How to jump MT Starter outside of car
- Carbon Fiber Trim Kit
- Camber Kit... Whats the difference?
- Megan Rear Toe Control Amrs Help
- Misfire in all 4 and sometimes dies
- bad vibration only on acceleration between 35 and 50 mph
- Aero magic front lip
- Insufficient EGR flow 5g prelude
- whats up with the aem v2???
- 5th gen fog lights?
- HELP...major problems
- Yet more car problems... exhaust? Fuel Filter? Help!
- 97 Prelude Tiptronic Transmission Question
- intake for my car?
- Import car show schedule
- Help. Half Shaft inboard joint pulled out
- Type-s?
- PS Steering Rack leak....what to replace?
- are after market valves worth it?
- CEL 67 Catalytic converter issues
- Valve adjustment Aftermath, IDLE woes
- P28 HELP!!! Did I get screwed?!?
- caty where can i get a reg one
- V-afc question. need help fast!
- installing MSD ignition
- What years did H22 come with a resistor box?
- Will a Type S ECU pass emissions?
- Pinout for <b>5TH GEN</b> DCC
- Need technical info (Sensor Readings)
- Tiptronic Prelude (97+ SS) Conversion to OBD1
- i need hel whit my tranny
- 98 Prelude SH front end shakes when I left off the gas?
- 89 honda prelude horn location
- Harness Pins
- tein ss coilovers
- hi i have a problem whit my tranny prelude!!
- sh tranny to base tranny conversion....
- suspension question...
- racing seats??
- lambo doors?
- body kit ???
- auto cams different from manual cams?
- 94-96 Center console w/97+ Ebrake handle?
- Question about the possiblity of selling my '99 Lude (not a 4sale post)
- unusual A/T electrical issue - shop cant even figure it out
- throttle body purge port problems
- Rear Engine Bracket Mount Stay
- ***Need Help to ID Brake Kit***
- Engine Swap Replacement Parts H22-H23
- Socket size for oil cooler removel?
- Clutch slipping during warm/ hot weather
- F20b into prelude....tranny???
- Opinions on Ebay OBX oil pan for H22
- vent, grille for 4th gen prelude?
- my h23 is being changed...just want to know a few things
- Shifting into 1st from cold start
- Prelude Exhauast
- ABS light is on. 92 SI Automatic AWS
- Mounting Avic D3 navi
- Aem V2
- how to check if a crankshaft is good.
- HELP!
- i got a problem....
- Horn issue.
- boost gauge/turbo timer...
- anyone ever used engine restore lubricant?
- tell me what you guys think of this vibrant exhaust system
- Running Lean
- Shocks & Struts
- aftermarket h22 flywheel markings???
- will oversized rings work?
- **Pic Request: 5th Preludes on AP1 Wheels ** Thanks
- cam gear keys
- a few auto to man tensioner questions
- Exhaust???!!!
- just another quick question
- 4th gen best Offset for 16" Slipstreams
- 1992 Prelude not shifting into overdrive, Help
- cap and rotor
- need help rebuilding a h22a4
- quick question about h22 tensioner
- which pulley most h22a4 used ?
- would this fit my 5th gen???
- innovate lm1
- Prelude shocks
- Idle problems
- black housing headlights
- quick question...
- rsx rear seats in 5th gen?
- Whats the Best Transmission???
- 3rd gen motors
- What are these connections?
- Which wire off the ECU do i hook up an Air/Fuel
- belt whine? how long should it last if at all?
- code 43 and sporadic tach related?
- Bent suspension?
- Where is my VTEC OP wire ?!?
- Studs ON Cat
- New Exhuast and the problems that came with it
- 1997 type-sh
- How to lock the balance shafts and to remove them?
- Q45 gatlin projector will fit into 5th Gen Prelude headlight?
- JDM vs USDM Brake Pedal
- Alternator Relocation 1990 si prelude help plz!!
- timming belt rubbing/coming off?
- greddy evo2 question
- OK Check engine light is on...
- H23(non vtec) Question
- 2001 prelude h22how do i solve the problem of clutch geting stuck n grinding clutch?
- rear lower ball joints
- 89 lude questions
- Factory repair manual
- sh to non sh conversion.
- 5th gen half-shaft compatibilty
- Windows going up
- **How To: SEARCH**
- Ground Control Spring Rates
- H23/F22
- Suspension predictability
