PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 [257] 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Type SH clutch + flywheel change (bunch of Qs)
  2. anybody ever used an f22 crank in a h22 block?????????????
  3. H22 or H23 trany
  4. 98 Prelude BASE model vtec tranny BAR CODE PLEASE!!!!!
  5. sprayed on my prelude without jet!
  6. 1997-1999 Honda Prelude Ignition Switch Safety Recall
  7. 98' Prelude Cat Question
  8. Did I F*uck anything up?
  9. anyone know if lowering wears out cv boots?????
  10. Below the VSS
  11. question about using new sythetic oil
  12. air fuel gauge
  13. where do you hook up the iab's?
  14. I want to buy An ATR tranny
  15. 1993 h22a1 oil pump sensor
  16. Cheap winter mods
  17. Looking for some feedback...
  18. 4:100 and 4:114.3
  19. HAve an EG with h23 bought this car and it turned out bad.
  20. Anyone Got a Turbo or NOS'd H22 in a Si???
  21. just thought id give the prelude guys and girls first dibs.
  22. Safety issue with cars beyond ragular warranty
  23. Hayame performance parts?
  24. HELP TEIN FLEX's with EDFC or TRANNY SWAP?
  25. Longer gears for Prelude
  26. anyone hear the new rs*r exmag exhaust?
  27. VAFC On h22 VTM problem? Maybe?
  28. anyone ran nos on there f22 prelude? let me know how it was
  29. NewB Here w/ fog light Q!
  30. Racing Hart Z5000
  31. What octain do you run?
  32. Does anyone know where to find a JDM B20 for a 3rd gen prelude?
  33. WTB: 5th gen back bumper for prelude
  34. What do I need for a h22 v-tech head
  35. intake installation problem
  36. Anyone have a stock 92-96 hood they don't need anymore?
  37. FS: 92-93 Prelude VTEC gauge cluster *posted w/ permission*
  38. Speedometer Cover Removal
  39. h23 compression and spark plug question
  40. Prelude H23 throttle body coolant hoses can they be bypassed?
  41. ECU wiring diagram required urgent!!
  42. Check out this...
  43. Prelude Bodykits
  44. Anyone have their stock exhaust still?
  45. Car Won't Start
  46. bouncing idle
  47. 1997 Prelude H22, moved x-over, versus B18C5 (dyno plots inside)
  48. Real Tech Q For you Guys - JDM vs. USDM Motors - Rod Bearings?
  49. GETTING A SQUEEK WHEN CLUTCH IS DEPRESSED, HELP!!!!!
  50. Installed Intake Manifold Insulator Gasket
  51. HI, i suck.
  52. vacume<? i cant spell? tube on CAI
  53. Eibach Lower Springs
  54. brake lines..
  55. interchangeable radiators for a 4th Gen
  56. Need Small 4th Gen Parts
  57. Hamp small size oil filter in H22a?
  58. emissions decisions
  59. Changing the Manual tranny fluid...
  60. what's this sound coming from my brakes?
  61. Muffler pipe size
  62. what should be the first mod i put on a 5th gen. prelude?
  63. if i run a turbo in a prelude and blow the engien how much do u think it would cost to repair the en
  64. NOS - cause i cant afford a vtec what do you think?
  65. clutch master cylinder
  66. better mpg
  67. indiglow gauges any one find some good ones? black faced maybe?
  68. prelude s 4 bolt to vtec 5 bolt wheel pattern?
  69. Prelude Quater mile times
  70. Best Mod For Prelude
  71. Interesting vid of preludes
  72. New engine, idle surges.
  73. a/f gauge
  74. mugen wing replica for 5th fit 4th?
  75. oil light blinking, but has good oil pressure?
  76. New 98' Prelude SH
  77. Want to see Dynos on Greddy turbo kits
  78. What would you guys pay for this.....
  79. Which fuel rail?
  80. Recaro slider & Prelude brackets
  81. is it bad to plug up vacuum hoses?
  82. 92-96 Lude suspenion Questions (teg owner so I'm clueless)
  83. i blew my motor now all i got ia 1k cash can i get a h22 with that?
  84. Oil Leaking in timing belt area?? H22a
  85. conventional oil to synthetic oil
  86. 89 prelude h22 swap opinions
  87. Cai 'causing Idle problem??
  88. NSX Side Prelude
  89. budget suspension upgrades
  90. AEM V2 Cold Induction System
  91. Prelude w/JDM H22 having weird Idle problems
  92. Paint and body kit
  93. p72 vs p13 obd1
  94. Question to all my motorhead friends on HT
  95. Tranny Swapping.
  96. WHen I shift in vtec, grey smoke comes out of my taile pipe...
  97. Hard to Steer
  98. Need a price guess...
  99. changeing oil
  100. Differences in Blue Top and Red Top H22 engines...
  101. Needed: 4th Gen driver's side fender ASAP!
  102. Tein Type Flex for 5th gen
  103. SMSP H22 Prototype Header #3 For Sale
  104. AVCR
  105. Need to replace my engine! Anyone selling?
  106. where can I buy a thermostat for jdm h22?
  107. cp pistons or je pistons
  108. Parting out 92 Si.
  109. which rims?! i can't decide!
  110. Question on AEM pulley belts...
  111. A'PEXi exhausts
  112. 5th gen or 4th gen suspension?
  113. FS:obx h22 turbo manifold
  114. Wheres a good place for Dyno tuning in the Dallas Area ??
  115. 5th gen lude nav/TV/control centre
  116. What are your insurance costs on Prelude?
  117. Are all year prelude pistons the same(93 and up)
  118. 94 si octane gas and oil.
  119. About VTEC: Prelude and GS-R (not which is better)
  120. Thinking of buying a 4th gen, have a couple questions
  121. 92 Si steering wheel hub question...
  122. selling my car :(
  123. 91 Prelude Cooling fan
  124. suspension setup....
  125. shift knobs
  126. For the people who say use a P72 to keep IAB control...
  127. Did a search...... Will 5th gen brakes fit 4th gen vtecs???
  128. Need an axel
  129. prelude cluster Q's
  130. need to do some thing about my low gearing any suggestions? red line 5th @125
  131. wierd car problems..
  132. Life Expectancy of a 2.0l
  133. Fuel pressure level, Helm vs most people's actual reading?
  134. removing turn signals
  135. Swapped engine...but car still won't crank...
  136. CAR WONT START!!! NEED HELP!!!
  137. Looking for vtec parts need help!!!
  138. 99 Lude Radio Removal
  139. BAD VALVE ADJUSTMENT!
  140. Exedy 3 puck racing clutch
  141. need help on installing cap and rotor...
  142. Compression Ratio for F22B DOHC motor
  143. Possible transmission trouble?
  144. WTB: 97+ Prelude PS Bracket
  145. New Car
  146. Pic Needed: Placement of e-brake handle in 93+ Prelude...
  147. Best place to order KYB AGX shocks
  148. IAB solenoid polarity obd1 vs obd2
  149. Hyper Voltage System??
  150. what kind of tranny is this
  151. Turbo off Mitsubishi eclipse?
  152. just installed clutch, need help ASAP please
  153. PRELUDE TYPE R??????????
  154. Trouble With Lights
  155. WTF!!! my h22a4 crank will not fitinto my h22a1 block
  156. Need Alternator wiring diagrams..... for the 3 prong one 96? 0r 86?..
  157. h22 pistons & rods in an h23...
  158. How Wide is a Prelude? Quick!
  159. is there a way to tell for LSD and NON-LSD?
  160. rev hard vs max rev
  161. How to tell if motor is JDM-spec?
  162. importperformanceparts.net---piston/rod package
  163. HELP!!!! Just changes timming belt but there is NO power?!!!!
  164. Timing Belt Change
  165. ((ISO)) 5th gen sportshift used transmission in good condition !!!!!!!!!!!
  166. Auto Transmission To Manual On 1997 Base
  167. DOPE TAIL LIGHTS?
  168. 4th gen 3 gauge pillar pods....
  169. Cleaning EGR port
  170. VDC for the prelude?...any experiences with that?
  171. 86 2.0 What size injectors and need more info about this motor!
  172. Engine Rebuild Question for H22a4!
  173. I was curious to know what you 92-95 prelude's launch at?
  174. Quick Carfax help?
  175. Best Headers for JDM H22A
  176. Buying my wife a Prelude
  177. door lock
  178. brake light
  179. Prelude SH automatic?
  180. Ditching the front motor mount.....
  181. lsd or no lsd
  182. Brake light on cluster coming on again
  183. '97-'98 ECU diagram
  184. Hondata on 4th gen prelude
  185. anyone got motors for sale?
  186. EPROM ECU programer
  187. JDM 5th Gen Prelude Foglights
  188. What's the use of i/h/e and other bolt ons?
  189. how much do the sh wheels weigh?
  190. help with H23a FI
  191. p28 for h22..?
  192. Prelude SH 1/4 mile times......
  193. Prelude door makes noises when opening...
  194. Torque converter question...
  195. which ngk plugs are best for h22a1??
  196. does prelude map sensor suck for turbo???
  197. Prelude Cam Gears Question
  198. W.T.F.......slipping clutch after new replacement and flywheel
  199. Wheel ?
  200. Need VSS
  201. h22 or a b16/b18 head fit my f22block
  202. wanted 92-96 prelude mugen body kit owners
  203. stock oil pressure?
  204. Type S Cams plus Pistons
  205. Mugen?
  206. WTB: H22/H23 block, ASAP (mods please read before you move)
  207. Which GM syncromesh for prelude??
  208. need a temperary solution ......
  209. Vibration!
  210. FOUND 4th gen Gauges PODS!! LOOK!
  211. Looking at a new daily driver
  212. vtec SOLENOID TEST?
  213. wanna sell the lude, but for how much??
  214. My friend just bought an 86 lude :)
  215. needed built or stock h23 short block
  216. Tell me about your turboed stock h22 luck.
  217. this is what happens to 4th gen ricers. rofl
  218. H23a to H22a1 Basics
  219. Got owned by the search engine.....
  220. bought 92Si manual ECU, but have 95?!?HELP
  221. New owner
  222. Who here has changed own clutch on Prelude SH?
  223. Coilovers: Skunk2 or GC?? Avid AutoXers and tracksters encouraged to reply!!!
  224. turbo ??
  225. Intake manifold question.
  226. NEED HELP RIGHT NOW! PLZ!!!
  227. Hello, newbie here...
  228. JDM h22 is it a good idea if i get usdm TYPE s camshafts? or should i get jdm type s?
  229. how much prelude injectors cost?
  230. Oil pan alternative???
  231. 5th Gen Motor Mount Inserts
  232. Any performance gains on an aftermarket clutch?
  233. compression ratio?
  234. Need a New Distributor for a 5th gen
  235. h22 in f22 engine bay
  236. where's the big folks?
  237. H22 cam gears
  238. Needing p13 engine harness pinout, please help
  239. tps-zex
  240. Wiring dagrams
  241. computer and engine swap
  242. camber problem?
  243. h22 vs h23 tranny
  244. Might buy another Prelude but need help?
  245. 91 Prelude needs to go fast???
  246. what is a egr control sol valve
  247. Rad Fans not working:HELP
  248. Clutchs
  249. Got rear ended
  250. *NEW MEMBER IN NEW TAMPA*
