PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Prelude power loss
  2. 98 prelude p1382 wont start after swap please help
  3. h/f series tranny gear swapping
  4. H23 and h22 injector identification
  5. Price my prelude!! (Time to sell...)
  6. Honda Prelude 1990 Sr Swaps?
  7. Honda Prelude Swap ?
  8. JDM auto vtec
  9. Oil pressure switch wiring
  10. code 9 cyp?? h22a4 prelude
  11. H23 manual tensioner conversion timing belt loose?
  12. Please Help 97 Prelude wont start sometimes
  13. hello
  14. Build h22, rosko euro R/68mm TB engine stalls
  15. 94 h22 prelude Vtec exhaust
  16. Mugen twin loop authentic?
  17. Apexi N1 Exh. Hangs too low
  18. h22a4 in 4th gen injectors
  19. 2000 Honda Prelude engine Builder GEORGIA AREA
  20. jdm header wtb can't find where
  21. h23a1 rebuild help
  22. Prelude ATTS LIGHT Help!
  23. Euro-R jdm obd2 to us obd2.
  24. Wiring problem??
  25. turbo set up
  26. How to take starter out 92 prelude?
  27. h22 with f22 crank question
  28. Question on vibration from b-shaft delete
  29. Car starts to lose power and dies, always starts when jumped. Igniter?
  30. '91 Prelude Air Conditioning trouble (pick-up sensor)
  31. JDM H22 now no spark
  32. JDM Header Issue
  33. 92 Prelude S (clicking noise when turn left and gas the floor to go) wtf?!
  34. Just A Small Issue :)
  35. Knox Mountain Hill Cimb
  36. H22a racecar issue!!! Need help ASAP!
  37. 5th gen paint question
  38. Clutch kit?
  39. OEM or After Market Motor Mounts?
  40. Found an old pic - 92 Si
  41. will an obd1 head work on my 98 lude?
  42. installing weathertech HELP?
  43. School's Out + Bordem = Red Emblems?
  44. tps error code
  45. Euro R swap into 4th gen
  46. Is Euro-R intake manifold obd2 compliant?
  47. idle surge
  48. changing axle???
  49. Fuel Pump not priming
  50. H22 transmission LSD install... M2F4 shims
  51. Can this ecu be repaired?
  52. Broken Bolt in inside intake 16 cam seal H23a
  53. JDM one piece headlight wiring help.
  54. Problems with the speedo...
  55. h23a headache looking to finish this project
  56. Are F22 and H22 fuel Injectors the same
  57. Strange ignition (i'm guessing) problem.
  58. cat keeps going bad
  59. Honda Prelude 1991 b20a9 rod knock
  60. 2001 Prelude, Back seats are soaked, bad roof seal?
  61. H23 VTEC Build.
  62. Radiator support
  63. convert a obd2 dizzy to a obd1
  64. wont idle. trouble starting. oil in plugs?
  65. Different radiator?
  66. Will a f22 oil pan fit a h22
  67. JDM H22a p1399? 87 Octane?
  68. weird ignition probs
  69. H22 timing belt tensioner
  70. Obd1 h22 ecus
  71. What's a comparable ECU....
  72. Stant thermostats, any good?
  73. Automatic to Manual Transmission Swap, any problems?
  74. i just hit a deer....
  75. clutch master/ slave
  76. Oxygen sensor light cel! Bogging
  77. Can anyone tell me what wire this is? Vtec?
  78. Crank Position sensor
  79. Wiring harness??
  80. H22a swap in 5th gen lude, will not run?
  81. H22 Transmission Cuff
  82. H22A cutting out! help!
  83. H2B EG hatch vs 4g Prelude
  84. m2u4 atts transmissoin in h22 swapped eg
  85. G23 options "without" an "H" head. ideas?
  86. suspension/wheel/tire sizes
  87. Difference in FUEL RAILS
  88. Flywheel Question
  89. replacement tps
  90. OBD0 B20A5 Starting Issue
  91. reliable boost on H23 vtec blue top
  92. prelude 1998 air blower
  93. Exhaust System
  94. Gas / Temp Display
  95. flare nut leak on gearbox
  96. p2t4 transmission not shifting in most gears
  97. Engine starts and dies... only happens in heat?
  98. Help! Stuck with no ride! No start
  99. IM question, need help
  100. 1988 Prelude oil leak
  101. has anybody had trouble with vacuum leaks between the iab plate?
  102. Wouldn't you like a 6th gear?
  103. 4th gen standard air box question
  104. where can i send my wire harness to be modded for swap?
  105. h23a1 crank pully
  106. Need Info for Help
  107. H22a4 to JDM H22a
  108. H22A Long Block question
  109. WANTED TO BUY ONLY :: NO TRIAL USERS, NO PICTURES - May- July 2012
  110. FOR SALE ONLY ::.. NO TRIAL USERS, NO COMMENTS, PICTURES REQUIRED - May-July 2012
  111. shaking, popping, clunking, pulling to the left..
  112. No luck in Hybrid Forum
  113. Help with 1998 PreludeSH Tranny
  114. 96 Prelude starts up then immediately dies
  115. engine idles but dies under load, or throttle
  116. Can someone with an h22a1 look under the hood and get the valve lash specs for me plz
  117. 97 prelude sputters when giving it gas
  118. SENSOR ASSY., SPEED
  119. CLUTCH MAKES GRINDING NOISE AT 4200RPM
  120. nooob prelude si
  121. Torque spec for part# 11107-PK2-003
  122. good replacemen rear calipers for prelude? better than stock but not extensive $$$
  123. Question about Prelude aftermarket parts
  124. Engine flushed with transmission fluid...
  125. H22a1 has a loss of power?
  126. Seats, what are you using?
  127. Rod Bearing Differences (Oil Hole) H22A1/A4, H23, F22 etc Help!
  128. h23a head possible with h23a1 block?
  129. h23a head possible with h23a1 block?
  130. Ruined sway bar bracket screw hole in frame
  131. 11 Inch Prelude brake upgrade CLARIFICATION
  132. Fuel pump won't prime
  133. H22a1 problems starting
  134. h22a1 h22a4 crankshaft difference.
  135. 93 prelude si w/ jdm h23 vtec blue top..idle issues
  136. yellow maintenance light is on?
  137. Starting problem
  138. h22 to f22 trani swap.
  139. Ignition Control Solenoid Valve
  140. Thermostat Housing
  141. h22a crankshaft question
  142. Automatic transsmission alignment
  143. Removing Exhaust Heat Shield????
  144. Rear Brakes Locking
  145. Radiator Fan Does Not Come On During Idle
  146. Neutral Safety Switch w/ auto to trans swap?
  147. which oil brand and weight to use for turbo jdm h22a1/55-65k miles?
  148. Alternator tensioner bracket?
  149. Painted my valve cover
  150. Replacing 01 H22A with a full Blue Top, Couple of Questions
  151. My new Prelude :D
  152. prelude sounds like a subaru NEED HELP
  153. car cranks but does not start
  154. 1998 accord stock wing
  155. FITV leaking coolant internalls into intake manifold ??
  156. Prelude Swap
  157. Oil type? H22A1?
  158. 5th gen - cross joint drive
  159. curious prelude questions
  160. 5th gen type sh...is it worth for n/a??
  161. h22 gas in crankcase???
  162. Blowing smoke from exhuast
  163. TO GO V-TECH OR NOT????
  164. H22 or H23 To be or not to be
  165. Prelude Bogging down after it is warmed up and re started
  166. 92 PRELUDE SI NO RADIATOR FANS!
  167. $164 + Tax for Valve adjustment?
  168. Need help 2000 prelude DC headers
  169. low offset question
  170. 91 prelude random plugs behind radio
  171. DC Sports header has bad weld causing air leak at Oxygen Sensor
  172. how to replace valvecover thread
  173. Clutch damper removal / replacement
  174. 2000 Prelude 66k service? What needs to be done
  175. Idle problem with H23A Vtec
  176. oil in spark plug holes
  177. shop says they can't replace just the lower ball joint??
  178. Help 98 prelude bb6 starting issue and radio code anyone??
  179. Connectors unplugged
  180. 1998 Prelude Engine Swap
  181. 1990 prelude si
  182. took out my radio now car will only turn over,
  183. 95 prelude no blue/white wire for radio
  184. PS Power Steering Leak puddle under car tiny air bubbles
  185. Weird engine noise.
  186. Rebuild questions: When to replace valve springs?
  187. my car dies after 5.5k
  188. New to Hondas
  189. h23a2 problem to h22a5
  190. Quest for oil leak continues, though coming to an end
  191. 4th gen gearbox info.
  192. 95 prelude bolt pattern?
  193. "Prelude Enthusiasts" Q and A's
  194. sites???????
  195. DH bike on/in a 4th gen.
  196. 1998 Prelude Engine Harness Question
  197. damn code 9
  198. aeromagic front lip 92-96
  199. 2001 Honda prelude sh doesn't want to go into reverse
  200. 98 Prelude Headlights
  201. turbo/internals help
  202. J35 swap into bb6
  203. Prelude BB6 help please
  204. Flat face Valves
  205. Mahle pistons for boost?
  206. Help! Transmission slipping?!
  207. extra blank connector?
  208. Hmotors H22A question
  209. oil getting into radiator
  210. JDM Prelude H22 Type S Camshafts or Aftermarket cams?
  211. 95 Prelude Jack Stand Points? Are these locations safe (pictures)
  212. Balance shafts?
  213. Fan and Radiator question
  214. My Honda Prelude VTEC
  215. problems with koni and ground control
  216. My 4th gen Prelude
  217. I need help with 4th gen prelude center console!!!
  218. Crank pulley came loose
  219. Po420 in bb6 with a cat back exhaust
  220. Am I the only one with a hood spoiler?
  221. how much u think or have seen a lude with these bolt ons do
  222. skunk2 megapower RR exhaust piping???????
  223. 1997 prelude limp mode no codes... no idea, please help!
  224. 95 prelude s
  225. blue top 5g no spark
  226. Need Advice/help
  227. Eliminating balance shafts
  228. site help
  229. immobilizer
  230. RWD mid engine honda prelude
  231. USDM cluster with chrome trim rings???
  232. over revving question.
  233. Trans/ Clutch acting up. Please help
  234. 89 accord lxi help!!
  235. 92 prelude fuel/temp cluster
  236. 92 Prelude swap
  237. A or B stamp?
  238. hp in jdm h22a motor?
  239. Is the pulley bolt on the power steering pump reverse threadded?
  240. Engine block help
  241. H22a4 into eg? HELP!!!
  242. Transmission repair
  243. Slight knock?
  244. my temp gaguge is stuck below the C and it wont go any where
  245. JDM H22 Crank Posistion Sensory bypass help
  246. Oil Pump Seals - Dealership cost question
  247. 1999 auto prelude transmission question
  248. Engine swap question
  249. Can I make P1259 disappear?
  250. Please Help 93 Prelude
