View Full Version : Honda Prelude
- h22a DTR street header...
- What other OEM Honda/Acura wheels fit a 5th Gen?
- jdm h22 plug wires
- Swoosh VART 4-in-1 VTEC AirFlow!! has anyone experience with this??
- THROWING CODES!!! woohoo!!!! :thumbdown:
- Are the JDM headlights much brighter than the USDM's???(BB4)
- Oil coming out of breather after boosting help!
- How much play in left rear hub?
- Broken Horn
- What is a good sounding muffler for a custom 2.5" cat back?
- What should compression be...
- buying intake manifold?
- If CEL light comes on for any reason will the atts light come on also?
- H22 hydrolock saved!
- 89 octane in a 93 SI
- 4thGen pulls under braking and acceleration
- STR Cam Seal Honda Prelude JDM
- looking for a new pistons
- Intermediate/Half shaft problem?
- wiring instructions for SAFC
- Replacement Engine Mounts
- H22 prob.
- bumpy ride
- small newbie question about swap
- technical question...
- this is probably insanely stupid but...awd prelude?
- H22 head to H23 block
- Speed Limiter on a 5th Gen Auto....
- ACT clutches noisy?
- Water Leak
- failed smog ... help please
- Is 50000 miles ok to still put supercharger
- do Breather valves help
- turbo additional weight?
- Prelude purchase?
- NJ Dyno
- Type - S Cams on a stock Valvetrain
- Most probable cause of bad compression?
- Removing tranny (4th gen)
- Adding Vtec
- preludeonline.com
- JDM cams difference: regular versus Type-S..info needed
- Is this combination safe on a stock H22
- H22 manual tensioner conversion question......help!
- JDM H22
- 4th Gen Cat
- Removing old mounting tape from side skirts.......
- quick stupid question
- check engine light?(possible water in engine?
- how does this i/h/e setup look can i do better?
- stock h22a4 with a diet of sc61 at 15psi.
- request
- A very Quick Prelude JDM H22 Question
- Timing advance on 97-01 h22a4.
- is accord O2 sensor same for prelude?????????
- 97 Prelude w/ rebuilt engine still burns oil
- Type-S Intake System
- car broken into...need to get a passenger side glass!!
- crower intake cam, stock exhaust cam
- Will these fit?
- Check Engine Light...
- Tech question about coolant leak
- Need help tech's
- Purpose of oil cathc can
- 1/4 Time
- any way of increasing the mpg?
- Temp Sensor Location
- 92 Prelude SI Squeal
- noob question. cel
- Removing TPS Sensor?
- I am new to this site and i got a question.
- engine cleaner?
- flywheel bolt size on h23?
- cylinder liner for H22A
- 2000 Prelude Hondata ECU Flash
- 97-01 lip kit where to buy
- Engine rebuilding
- what is the best cams i can get for all motor?
- compression test
- 440cc Low Impedance Pintle Type Injectors?
- llCrank pully help
- Building a head
- Any H23s or H22 with F22 trannies in here?
- IS CHANGING A DISTRIBUTER ON A 2.2 VTEC 94 PRELUDE HARD?
- I was referred to this forum- Question about engines
- FAO: Satan_srv (Joel)
- My Ebay "Megan" header install ............ '99 base model Prelude (sorry about the novel)
- another stupid question by me..oem or what
- what is code 6 and code 7
- 4ws or ATTS on a 4th gen vtec?
- EEEE EEe EEEE sound...help
- Finally found the problem with my old motor...
- passenger door misalignment
- Fucked up thrust washers.. HOW? PICTS
- Car is running rough. Help pleaseeeeeee!!!!!!!!
- Prelude with greddy lip
- synchromesh mix with tranny oil?
- h22 with p28 computer????, i dont get it???, is it possible
- f22b ecu question
- Jdm engines, how can you verify if it's JDM prelude engines with the comp 10:6?
- h23a swapping to jdm h22a help please..
- What is this??
- Weird Squeak on Right Front wheel area....during turning, braking and driving...
- Passenger door
- map sensor questions
- MSD SCI Install help Prelude 94 Si Vtec
- 2.5" custom piping question...
- radiator hose fell off
- Dash lights out.....update!
- H23a1 w/ H22 trannym i need oppions on this
- best intake for price?
- how to remove secondaries?
- Whats the stock rear sway bar size?(5th gen)
- Bleeding the coolant system.
- ? About my H22a block!
- rear defroster wont work
- Cost on JRSC and tune.
- 1989 prelude with gsr leather seats?
- pulley
- 2000 Prelude Gauge Help
- h23 with h22 piston compression
- searched but to no avail: 1st gen. lude bolt pattern
- NEW here ^^^^^^^^^^^^^
- prepping for the dyno
- smsp header, 2.5" cat, with greddy evo 2 (2.33 inch) how will this effect my car?
- rear OEM trailing arm bushing...how to get?
- should I sell my accord and buy a lude?
- ring gear holder
- OBDI Error Code-Read mE!!!!!!!!!!
- how to rebuild the bottom end of my h22a4
- 5th gen space between wheels?
- Idle problem and white smoke
- Synchromesh
- Snapped crower cam shaft
- How much OIL does a H22 hold?
- brake light and brake problem
- compression test and ignition module help needed pls.
- Cat-back
- bent my valves
- alternator problems after swap.
- 93 H22 turbo head gasket problem?
- rear main seal special tool?
- RM H22 VTEC Camshafts???
- 1FAB Series One Turbo Manifold..Anybody used one yet..
- head lights are weak
- screw missing in throttle body area
- Clutch/Tranny Fluid
- Failed Emissions for a 93 JDM Prelude
- how to brighten dash lights..plzzzzz
- 2nd Radiator Question
- '88 S: Where to buy replacement antenna?
- I GOT CLUTCH AND FLYWHEEL!!!!
- When ordering Struts for Prelude is there a difference between S, Si and Vtec
- Eibach ...whats the lowest they make for Preludes.
- Removing the A/C on a 5th gen Lude
- MSD Ignition and Starting problems
- HELP THINK I BENT VALVES
- After a year of hard work...
- What kind of lube does honda use?
- headlights
- test pipe question?
- Turbo manifold for sc61 WITH ac
- 87 Prelude SI - 2 problems
- B & M
- what is a good 2.5" cat?
- Ripping shiftcables
- Another h22 tranny problem
- anyone relocate there battery in a 5th gen?
- routing ic piping in a 5th gen (searched)
- are your jdm swaps street legal
- exhaust flanges
- Wierd scraping noise when cold
- Timing belt changing question
- 5th Gen Power folding mirror install!!!
- 89 Prelude Clutch replacement help or tips needed
- Doesnt start sometimes
- Fuse/Relay
- JDM H22 valve springs: single and/or dual? Expert advice needed
- Apexi World Sport Canister
- h22 shift linkage
- 5th gen prelude intercooler piping woes.
- h22 integra insanely slow need help
- 87 prelude altinator getting the best of me
- Stripped Hub Assembly???
- kyb agx shocks vs. tokiko illumina
- strange noise from suspension
- suspension bolt difficulty
- Stuff?
- The should i get a camber kit on 5th gen thread
- lude cambering question
- IAB Wiring question! using GSR OBD1? or OBD2? i don't know?!?!
- Has anyone tried tinting windows ?
- turbo vtec problem
- 97 base SS - massive CEL codes!! need help please!!!
- Have you got a caged Prelude? I want to see it!
- 93 vtec reverse tranny don't work
- How do i raise the clutch catch point?
- Brakes Don't Work!!
- quarter panel rust fixing
- Lowring the lude
- Hard to get into reverse...
- who has a half radiator?
- Waterpump manufacturer for Prelude
- New Owner
- what year ???
- dual stage intake delete
- Auto Tranny Question
- shift boot for a 5th gen
- smsp vs. prospeed header
- winter storage
- no start
- Do they make JUN headers for the 5th gen?
- need help asap! 1st gen lude bolt pattern
- need help with my 4th gen!
- Whats the typical values for a copmpression test on H22
- I have NO CLUE what exactly my prelude is?
- Opinions wanted for Crower Stage II cams
- H22 fuel pressure
- Valve Lash Problems..
- Aftermarket ecu?
- First gear starting problem???
- CEL on, have flashes, need code
- 98 lude dies when I step on the gas
- will check engine light come on with skunk 2 IM?
- jdm h22a compression results (not too good)
- h23 crower cam specs! no more searching!
- EDM 4th Gen Bulb Type.
- car wont start
- Trying to find an H22 A4 for an 01 prelude SH Free stuff for hookups
- 2 1/4" exhaust vs. 2 1/2" exhaust
- 92 96 honda prelude carbon fiber vents
- JDM and USDM 97-01 differences???
- wobbly pully..HELP
- Failing Auto Tensioner Dilemma ... Advice Needed.
- idle problems..sparatic idle..ATTENTION TECHS
- prelude vs integra
- Lookin at another lude...
- 4thgen lightweight wheels
- Question about 98 honda prelude Exhaust
- Few Questions from a New Prelude Owner
- New piston?
- skunk 2 or euro R IM?
- Needing more power out of F22B - where to start?
- Cruise not working, ideas?
- which is better or recommended Kyb Agx or Tokico Blues w/ Eibach Springs
- prelude S/im thinking about kyb agx nad eibach question..Bushings??
- what computer to use for 5th gen, p13 or p28 obd1 or obd2
- f23-h22 build, comparison, very interesting
- traction bars
- SMSP header contact info?
