PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 [105] 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. skunk2 intake manifold problems
  2. CEL comes on after car travels for a while car runs great
  3. Individual Throttle Body
  4. Auto scanner
  5. 4th gen preludes
  6. '09-'10 Prelude?
  7. APC or OBX coilovers?
  8. Getting new seats in 4th gen
  9. Running into issues with my car...
  10. Flashing Codes
  11. When to replace the control arm
  12. h22a euro r
  13. h22 over heating
  14. Chip For the H22 ECU?
  15. Clutch pedal soft.. replaced cmc and slave already
  16. bumper pole?
  17. Transmission swap
  18. Shifting Cable QUESTION???? HELP!!?? PLEASE?
  19. H22a tranny questions, concerns, need advise M2b4 - M2L5
  20. sway bar recomended?
  21. Ajustable Coils and Struts???
  22. 98 Prelude Valve Train build up
  23. cv axle question (abs/no abs difference?)
  24. I NEED HELP!!! Are you the one?
  25. 93lude vtec; oil light came on, then engine died with a smell?
  26. Any objections to new rods bearings on only two journals
  27. Plexiglass EGR Blockoff Plate?
  28. cel 21, no vtec after swap
  29. Please HELP!!!! engine trouble
  30. fujitsubo header modification
  31. tuning, what does it mean?
  32. Prelude Factory Spoilers
  33. Type R Spoiler
  34. squeaking!
  35. H22A Wiring Harness Question? HELP!!! HELP!! PLEASE!
  36. WTB 92-93 JDM Prelude Foglight Switch
  37. honda prelude full service manual?
  38. sohc dohc solenoid?
  39. H22A weight????
  40. Please help me: Rubber bushings still good???
  41. prelude wheels offset #?
  42. US H22 ECU
  43. CEL Code 80 - EGR system
  44. quick belt question
  45. H23 Turbo Kit
  46. 92-93 JDM Foglight Switch
  47. FS: Fujita 97-01 Prelude CAI & Exedy Stage 1 clutch
  48. How to DROP compression?
  49. Selling a 5th gen.
  50. vtec.cold.no engage.
  51. type S, skunk or jun witch is best?
  52. 91 Prelude project....Help a civic guy out!!!!
  53. bearings and oil squirters questions
  54. 4th gen stuff with lots of pics FS
  55. H22 wont hold a steady RPM?
  56. 5th gen with Koni Yellow/GC setup
  57. problem w/ swap
  58. which flywheel
  59. high idle speed
  60. Accessing rear shocks from trunk
  61. JUN Vs. OEM flywheel
  62. 4th Gen K series swap
  63. FILTERS???
  64. Integra guys dont feel VTEC, Prelude guys get a big grin with VTEC...Why?
  65. 4th Gen Prelude Help....LEAK coming from trunk area
  66. Another EL question
  67. need links on how to swap a h22 into prelude.
  68. Which # is the correct part for the moonroof?
  69. New Shifter setup
  70. ABS light wont go out
  71. Type S Cams and Pistons in an H22a4
  72. screeeeeeeeeeeeeeeeeeeeeeeeech....WHAM!........phe w.
  73. door handle "loose"
  74. mechanic advise
  75. v-afc good or bad???
  76. skunk2 intake manifold on a h22a
  77. Left rocker skirt OEM 1997-2001
  78. Check Engine Light
  79. Wings West
  80. Brake Light when driving?
  81. How much a different between 2.25 and 2.5in exhaust
  82. To the few of you who have h23 vtec's...
  83. M2T4
  84. Transmission Oil cause problems
  85. Type S H22
  86. Problem starting when motor is warmed up
  87. Speedo/CEL problem
  88. 98 H22 swap in 95 NON vtec question
  89. Need HELP from the gurus. Boosted H22
  90. IC piping question
  91. Huh? 4th Gen in Honda Tuning
  92. Transmission problem... H22 with the tip tronic tranny
  93. charcoal canister
  94. EL Conversion question
  95. car jerks and tach jumps above 4k rpm...misfiring? 97 SH
  96. Ignition trouble. WTF.
  97. Axle Nut Size
  98. mugeun header? PIC REQUEST
  99. crazy idle prob.
  100. Auto To Manual Swap Help
  101. is this true
  102. Fouled another set of plugs...need advice
  103. high beams problem
  104. bb4 side markers template
  105. Hiccup at 3500
  106. code 3 check engine (yes i check the search)
  107. reprogram ecu?
  108. motor mount inserts
  109. wheel fitment
  110. 85' Prelude 1.8carb wont start!
  111. h22 manifold work on an h23?
  112. Turn Key, Nothing for 5 sec., Then starts.
  113. how to install skuk2 intake manifold
  114. bogging problems
  115. Hp Bang for Buck
  116. injector question
  117. Prelude Tranny noise!!
  118. Dizzy order for plug wires?
  119. Prelude with V6
  120. Need an Opinion
  121. boot and kob setup?
  122. 4 bidden short shifter thread pitch
  123. 4th gen prelude question
  124. Wheel Spacer and wide wheels
  125. 92-96 Honda Prelude Wings West RS Front Lip Installation
  126. Hey Tippyman, i read you did a valve job?
  127. Bumper support interchangeable???
  128. Car clicks but won't turn over
  129. greddy header?
  130. Supercharged BB6
  131. Short Ram higher speeds in Gears
  132. need some help prelude fuse guys
  133. timing belt is being a bitch
  134. lower resonator section necessary for OEM airbox install?
  135. Has anyone else seen the Stage 3 Turbo Kit on ebay for $650?
  136. I have heard people mention a H22A ShortBlock, is there such a thing?
  137. teach me about oil catch cans
  138. After Market 5th gen Headlights !!!
  139. smsp header.
  140. a lil help
  141. OEM Honda Gasket Kits...
  142. Thanks bb_one....look what came in yesterday
  143. H23a1 to F22a6?
  144. Changing tail lights
  145. b20a vtec
  146. I just realized something about running cai's on 4th gens...
  147. Final Drives
  148. Looking for H22A1 VTEC Head
  149. Looking For Any Other Prelude's W/ Wingwest Lip Kit, or Wingswest 3pc Wing
  150. Anyone try 0w-30 GC in their H22?
  151. Wow, I'm more of a noob than I thought. (stupid clutch question)
  152. Honda TSB Part Numbers
  153. Get a lot of your failed parts replaced free by Honda
  154. i need some help
  155. Help me decide
  156. adjusting valves
  157. Aftermarket Flywheel and pilot bearing
  158. Quick question for fellow 4th gen owners
  159. bolt bolt and cam torque specs
  160. spash gaurd?
  161. What year h22 came internal coil
  162. farewell thread w/ some pearls of wisdom dispensed throughout:
  163. smog sensor
  164. Radio turns on/off , Gauge needles drop and go back up
  165. wheel fitment
  166. Quick tire question...
  167. Apexi Neo
  168. Crankshaft Bolt Issue
  169. 5th Gen: AUTO to MANUAL Swap Help!
  170. Headers, now smoke.
  171. Need help w/ front end of 92
  172. Spark plug issue
  173. 2000 Prelude / can't get driver side door open.
  174. 92 SIR
  175. 92 Prelude jdm headlight beam problem...
  176. ready to get a CAI
  177. DSS axles on the way...what else should I replace?
  178. what is the HUB SIZE of 97 prelude
  179. Clutch advice needen; Competition Clutch
  180. Which Tanabe exhaust should I buy?
  181. anyone know what part of the wiring harness this is or where it goes
  182. Unbolted from cat.
  183. High Compression Numbers?
  184. Knock sensor H22A
  185. cams!
  186. prelude knock sensor question
  187. 86 prelude Si starting problem its unexplainable no reason for it PLEASE HELP????????
  188. Shifter Cable Assembly. HELP
  189. 1997 Prelude Water in the trunk!
  190. is this the VSS?
  191. compression test (normal)
  192. Quick Question: 4th gen. OEM front bumpers
  193. eBay one piece headlights installed
  194. Fuse keeps blowing
  195. Tell me what you guys think!
  196. maybe a stupid question but what gasket to use with type s OS .25 pistons
  197. kaiten clutches
  198. more erg stuff to blockoff
  199. question on hybrid
  200. H23 to H22 wire problems..HELP!
  201. My car stumbles on start up?
  202. 4th Gen Seat Swap: RSX seats
  203. Supertech retainers
  204. Bulb # Q????
  205. Painting A Carbon Fiber Hood
  206. Quick tune up Question.
  207. help reinstalling climate control/dash vents (4g)
  208. H22A1 Head on my H23 Block.
  209. Jdm H22 dizz cap
  210. T-belt Q's
  211. 2 down 1 to go: my epic battle with my h22a swap (video 56k beware)
  212. Positive impression of new formula Honda MTF
  213. Tuning..........?
  214. tranny quastion ??
  215. Most recent dyno
  216. Problem With Auto -> Manual Swap
  217. can't put the car in gear
  218. s-s-s-s-s-s-s-haking
  219. new tires
  220. Wheel Question
  221. Ignition Problem - Help
  222. CEL #67
  223. 97 Prelude SH... Low RPM Stalling
  224. mvalve adjustment question?
  225. post pics of some sick 3rd gens!
  226. Back motor BRK't 97-01
  227. How to Take Dash off 97-01 5th gen
  228. poly bushings
  229. Vss between base and sh
  230. taking the motor out
  231. F22B motor question
  232. flat vs dish valves
  233. M2B4 grind? syncromesh?
  234. getting a tune up
  235. how the hell do u get the door panel off
  236. Looking to buy a prelude... dont know much about them... a little help please
  237. Suspension Noise
  238. 16X7, 40mm offset. 205/50/16 or 225/45/16?
  239. Type M (Mugen Replica) Lip on a Prelude
  240. SRS light
  241. IACV and Euro r
  242. Honda prelude rpm problem
  243. another noob question
  244. anyone everheard of amc quaife
  245. motor mount inserts
  246. Engine swaps for 92-96 prelude
  247. Reset ECU after installing intake? Necessary?
  248. another header question sorry
  249. legend struts on a prelude?
  250. valve adjustment
