PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 [249] 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. thoughts and opinions?
  2. H22 QUESTIONS?
  3. Catch Can
  4. Attn: H22/H23 owners who fixed spun main bearing blocks
  5. 4gen H22 fuel pressure
  6. JDM Headlight H4 bracket
  7. header removal help!
  8. lost reverse on the lude ?
  9. Hondata IM gasket and Euro-R intake manifold
  10. NEW PRELUDE!?!?!?
  11. passenger axle trying to pop out?
  12. check engine light probs!!!! Cant get codes to come up!!!
  13. 4th gen stock wheel weights
  14. spun rod bearing???
  15. usdm distributor and ecu change from jdm?
  16. Radiators
  17. where can i find a high beam bulb for 4th gen JDM Headlights
  18. NEED SOME HELP: prelude tranny code
  19. Black sensor on FPR on H22
  20. anyone have this problem???
  21. How to build an H22A1 for boost
  22. Looking to trade my usdm 92-93 fog light switch for a usdm 94-96 fog switch
  23. Aftermarket Steering Wheel install
  24. Horn relay..... help
  25. Bad News On Skunk2 Intake Manifolds!
  26. cleaning inside headlight housing
  27. Type S head on base H22a4 question
  28. Cheapest place to get h22 timing belts and water pump..
  29. PART #s for JDM ASAP
  30. Rec. Sparc SeatS?
  31. a/f gauge into o2
  32. Fire Sale! Greddy Turbo Kit, Exhaust, Flywheel...Make an OFFER...parts must GO!!
  33. Prelude SS
  34. 92-96 NONVTEC prelude injectors? Please help
  35. Euro R H22 Manifold Specs
  36. worth of h23 head
  37. best intake j's racing or aem
  38. flywheel resurfacing in OC
  39. AEM V2 impressions?
  40. Speedometer problem.
  41. pics!! HID kit on lude, got question.
  42. The H22 I am building.
  43. Timing Belt life
  44. 95 Prelude Si h23
  45. cheap header good power??
  46. 92-96 Prelude headlight aiming, etc?
  47. Which tanny is good?
  48. why won't this 92-96 neuspeed upper strut bar fit on my 95 lude
  49. 93 fog light don't work with a 94 switch
  50. intake question
  51. Question on cams...
  52. Looking to buy a Prelude...have questions
  53. Probably Ignitor problem...
  54. Question about type-s valvetrain
  55. Venom intake
  56. Ignition wiring HELP
  57. H22and h23 tranny seals interchanable?
  58. ssGot rear ended today
  59. For Sale H23
  60. R33 tail lights!!!! dc rear strut bar!!!!
  61. *A MUST READ for those who are new to heavily modding your Prelude*
  62. Project Madness!!! Part 2...
  63. feilds sfc vtec help
  64. ? about installing a car alarm
  65. differential fluid
  66. a h22 manifold on a h23?
  67. Annoying fan noise
  68. Does anyone have a basemap for a haltech e6k or e6x for H22
  69. need help installing an AVC-R boost controller
  70. eclipse GSX AWD turbo STOCK, making prelude daily driver...
  71. h23 shipping weight and costs
  72. need help......
  73. 5th gen lude website
  74. 450 injectors in a h23 turbo
  75. 4th Gen Prelude
  76. what is the thing under drivers seat?
  77. putting the built motor on a bottle, how much will this handle?
  78. help i cant do any thing on this forum
  79. TIMING QUESTION HELP!!!!!!!!!!!!!!!
  80. Anyone know where i can get an IAC or EACV for my h22?
  81. JRSC kits
  82. I need help with my vaccume on 89 prelude !!!!!
  83. ASAP I need to know how to rewire JDM headlight harness for 4th gen
  84. JDM ClusteR?
  85. ASAP I need to know how to rewire JDM harness for 4th gen
  86. guess what I found this morning
  87. best geared tranny?
  88. OSU
  89. Ractive Cat
  90. H22A7 Engine Noise
  91. ring gear on flywheel came loose
  92. 4th Gen for the wifey
  93. how reliable is h23 vtec?
  94. using f23 crank, not h23/f22, in h22...the joys of a custom setup...need help
  95. MATHMATICS
  96. Prelude jdm Folding mirrors ? Jdm Digital climate control
  97. 97+ exhaust
  98. Toronto Engine Builders?
  99. Getting a swap
  100. 0-60, quarter
  101. Why are USDM H22A's so hard to find?
  102. gauge help!
  103. 5 spd sport shift into a 5th gen??
  104. removing a/c compressor
  105. will a b21 90-91 si motor bolt up in a 88si with the 88 clutch and tranny?
  106. Crazy Idea??
  107. RATS
  108. ATTS
  109. I NEED HELP
  110. HELP!! AXLE problem .....real problem...not axle removal question
  111. Best Exhaust for Boosted Prelude
  112. **Wrecked car so have greddy turob kit, NX, Teins, And more for sale....**
  113. Turbo or Allmotor
  114. Ideal shift RPM on h22?
  115. Greddy lip quality?
  116. Help resetting ECU of my TPS sensor
  117. My Poor baby got broken into..... :(
  118. Why was my thread locked?
  119. Videos: My 1996 Prelude VTEC in action
  120. Group Buy on Greddy Turbo Timers!
  121. h22 vac problem
  122. H22 EGR Hookup, H22 EG
  123. HONDATA
  124. winter oil
  125. Finally hit a dynojet... balancer shaft test
  126. Transmission swap?
  127. Driveshaftshop Level 1 Driveshaft Snapped
  128. Turbo Accord Fuel Setup?
  129. H23vtec, with Type S pistons question
  130. Idles Rough... New Engine
  131. HID BALLAST AND IGNITOR PLACEMENT?
  132. valve spring adjustment
  133. B20A5 head swapped onto ZC block?
  134. I/H/E setup + OBDII...what are my options?
  135. Ground Control Spring Rates
  136. 3 guage pod pillar
  137. Notching Type S pistons??
  138. Changing from boost to NA
  139. refference: 1/4 miles timeslips for different vehicles
  140. new to the site . need help
  141. Attn: Lude Owners who track their cars!!! Suspension question.
  142. Mugen Exhaust kind of loud in my opinion
  143. 88-91 lude tranny, with a 90-93 teg ls engine?
  144. Old School to New School
  145. 97-01 prelude question
  146. Got stock valves?? I NEED EM.
  147. Just wanted to tell everyone good bye for a little bit....
  148. H23a Problem
  149. hey new to this board
  150. used search can't find topic that had the guy trying to break the 600 hp mark
  151. Type-S pistons question
  152. timing belt tensioner ?s and intro
  153. smsp dyno yet anyone?
  154. Intake comparsion (dyno)
  155. Thermostat? Overheating?
  156. Help: Camber kit & upper control arm clearance
  157. P13 base map
  158. stock radio removal from 86 lude?
  159. Quickest start
  160. ideas on what its worth....
  161. how do you???
  162. Battery relocated.
  163. Strut Bars for last gen. Prelude?
  164. Supercharge
  165. tailights
  166. help! - Blew up h22a
  167. Difference between VAFC-II and Hondata?
  168. prelude anti sway bars install
  169. Painting valve cover....steps?
  170. H22A All-Motor Setups
  171. brake upgrade
  172. Orange County Meet ******Super Autobacs*******
  173. exedy clutch install
  174. break in have not run for 6 months
  175. intake/exhaust valves hitting each other!! Help
  176. Valve Adjustment ?'s
  177. Tranny questions
  178. What are you turbocharged ludes runnin
  179. transmission fill/drain plug...
  180. Shifter Problems
  181. crower stage 3 cams for h22
  182. Eibach Pro-Kit and Koni yellows?!
  183. Bringing back a 96 Si.
  184. wrong firing order?
  185. vtec controllers?
  186. what's involved with replacing pistons
  187. new to h-t.com & need help
  188. 98 Prelude Exhaust piece...where do i get a new one?
  189. Poll: New FS/WTB Thread rule
  190. what wire is the ref wire for the o2 sensor at the computer?
  191. F22 Crank in H22
  192. Excel Wheels
  193. Auto-X'ing
  194. Type-S Cams H23 VTEC?
  195. Type S Internals In A S2000 Motor
  196. 88-91 Prelude Swaps
  197. tranny forks
  198. 1995 prelude H23 DOHC NON-VTEC dual set of intake runners HELP!!!!!
  199. Would it be possible?
  200. help me with my h22a4
  201. fan assembly
  202. headlight problem
  203. Difference between h22a4 base and h22a4 SH head question???
  204. H23 for sale
  205. Steering wheel/turn signal problem/dilemma
  206. H23
  207. how to make a jdm internal coil work?
  208. dammit. timing belt snapped during freeway
  209. I'm back...
  210. Prelude Greddy Turbo Kit for sale and other related FI parts
  211. FS jdm climate control
  212. puttin the tranny back
  213. Valve adjustments & nitrous questions h22
  214. Inner Tie Rod. Going to be replacing the weekend>Help
  215. SPORT SHIFT, shifting hard and late
  216. JDM or USDM h22 ???
  217. Dyno run issues
  218. 1996 Prelude VTEC Model Question
  219. in process of removin rear hub need help....
  220. forbidden shifter
  221. No Foglights w/ FMIC?
  222. Anyone with Apexi World Sport?
  223. centrifugal prelude supercharger????
  224. Crane Cams
  225. OMFG Im bout to kill myself...
  226. tail lights
  227. Changing Valve Cover & Dressing up the engine bay
  228. crossmember
  229. where is IM brace???
  230. 4th gen foglights...
  231. Exhaust for 4th gen
  232. yet another GT4 prelude teaser
  233. quick question about h22 drop-out
  234. H23 crank
  235. Good Idea???
  236. H22 intake mod...Idea's and opinions wanted.
  237. ITB prelude
  238. PSpec ShortShifter installed...
  239. gears grinding
  240. oil turning black after 500 miles
  241. FOR SALE: SPRINGS AND CAMBER KIT
  242. The Famous 1995 Prelude SE
  243. valve spring specs OEM
  244. Does anyone have a 97-01 prelude with oil consumption problems?
  245. 4th gen Mugen Bumper on ebay ! ! !
  246. Will 4th gen Vtec radiator fit into an Si?
  247. HP and Torque limitations of stock clutch?
  248. 97 H22 head on 93 H23 block
  249. what is wrong with my motor??!?! i cant figrue it out....
  250. How low do you guys like to go, Pic of my car
