View Full Version : Honda Prelude
- h22 swap
- OEM 5th gen header, top half
- what should I do about my exhaust?
- h22 swap quick question
- help searched location of the obd2 service plug
- Skunk2 or Ferrea Valves for My h22
- Moton Suspension
- S2000 IACV fit Euro-R?
- 92-96 prelude seats
- Exhaust troubles
- weird noise
- so some dude just backed onto my car...
- What is wrong with my car - i fixed it
- prelude VSS and power steering sensor
- radiator flush
- There are supposed to be nuts here right?
- wierd problem that happen this morning :(
- more type s piston questions
- h23 to f22 knock sensor problem
- window switches
- Best Rotor/Pad setup
- h22 crank pully?
- cost of regular h23 rebuild
- need a decent exhaust with a warrantie?!!!!!
- 2.5 or 2.25 es muffler/piping.
- Breather Filter
- 98 prelude, power wire under driver side need help
- Automatic Stalling
- Suggestion....
- Arias H23 Piston
- hooking a tach up in an 89
- any 5th gens out there have a MSD SCI?
- HELP.. got an h22 with a Euro R manifold Leaking..
- annoying buzzing sound, coming from stock header "pipes"?!
- Crower Maxi Light
- ecu help
- quick question
- Overheating- Fan doesn't start
- Exterior Color by Vin Number ?
- 1993 H22a
- low beam headlight/ tail light not working
- OaksRacing Prelude Video's - 10.99 run and a Burn Out Video
- No Intake Pressure
- Rattling noise coming from the engine
- Anyone got any stock taillights for a 92-96 prelude??
- APEXI VAFC2
- Stock compression ok for S/C
- Horrible Whine at 35 - 50 MPH
- cause for oil consumption??
- wide body kit for 4th Gen lude
- Suspension Upgrade
- m2b4 trans
- Checklist for h22 swap into a 93 S...
- Cheap compression???
- Vacuum question (pix)
- R34 TAILLIGHT
- 3rd brake light
- For a friend with a 99' lude
- For those who have done a Manual Swap: mounting the clutch pedal bracket
- code 43 help...
- Right Rod Bearing for my H22??
- rmf=no ac on 5th gen lude???
- h23 head bolts torque specs
- ECU H23 Question, about P72
- to all those h22-f22 peps
- BG Sport Springs
- ECU and wiring questions...help please
- oil?
- test pipe (5th gen.)
- Ever did business with OrzSports?
- 3rd gen questions -
- Read this if you lost points in a thread yesterday from George Knighton.
- Suspension niose - knocking?
- 5th Gen Prelude Greddy Evo 2 Problem / request
- 6 disc changer
- code 43. where to start?
- radiator swap..
- engine codes
- H22a Fan problem
- can a baby seat fit in the back of a prelude comfortably???
- more torque!
- Type S swap into Prelude type SH, need help
- New car
- Prelude Type S
- 2.3
- H22a4 swap info....Help!!
- turbo'd h22
- Quaife LSD & Custom Houseman 4.85 Final Drive
- 97-01 prelude spoilers
- how to install turbo?
- Nitrous Burp Need HELP
- rear brake pad replacement prob..ideas?
- H22A4 oil pan stuck
- H22 Closed deck Open deck...which for boost..?
- H22 and H23 AC compressor!!!!!!!!! i neeed major help!
- How Hard is this . . .
- prelude motor ?
- need help hooking up autometer a/f gauge on prelude
- LSD i know what LSD is but have a couple of ?
- name that buzzing noise
- building obd2 block
- PLEASE review my checklist for 275 hp H23...
- DIY 5th gen projectors
- Clutch pedal
- Weird - 1 yr long problem - no conclusion - P13, p14? WTF
- Carbon fiber hood
- I got a 98 H22a4 motor....
- Is the F20B ECU OBDII A or B
- exhaust question
- vis trunk owners stand up
- Strut Bars
- Starting issues
- pspectuning? Are they still alive?
- 1 psi change in fuel pressure. What's the change in A/F ratio?
- can other b&m fuel regulator for honda and acura fit any h22a vtec
- Starting problems
- H2B
- where is the speed sensor? (b20a5)
- car problem, help!
- 3rd gen Prelude Si...Possible H22
- how much do you think???
- H22 Integra, Distributer Help ASAP!
- Fuel Gauge
- quick intake tube vacuum question
- Where to get parts???
- 95 Prelude h22 Clutch problems
- 93 prelude si 4ws
- help help help...radiator
- JDM H22 woont rev past 6k
- Springs
- H23 Trans and H22
- Engine Oil and Tranny Fluid Question...
- Anybody parting a 97-01 Prelude?
- ac drain location
- h22?
- AEM SRI Install Trouble
- What OBD harness does a 99 Prelude M/T use?
- type r? SIR
- Worthless questions huh
- engine swap
- VTEC QUESTION
- front foglight switch plug?
- Search function not working???
- Turbo h22
- ENDYNE Port and Polish
- compressor clutch?
- help...
- Threw a code 8
- Who makes charger kits for the H22
- tein s tech question
- vtec vafc problems not working right please help h22
- Question about s2k filter
- exhaust
- lowering my 5th gen, should i get shocks struts?
- H23 ENGINE FOR SALE 92-96 PRELUDE SI
- where can i get this
- mp3 player using bluetooth to play in my car?
- h22a vtec oil question
- breather line from atts?
- difference between usdm H23 and JDM H23??
- what exhaust to get for'95 v-tech
- H22a4 probs...HELP
- Radio Noise after going aftermarket help! 5th generation
- New Clutch Time...
- Headlights
- ECU Question again....................
- '89 Prelude Questions
- What type of Clutch?
- H22A alternator belt size with AEM pulley and no AC...?
- h22 head bolt rounded
- Which site is better?
- Have a 00 H22a engine..
- To those w/ the greddy turbo kit
- I got TUNED y0! - 200whp I/H/E h22a @ RLZ
- Sunroof problem (spring sticking out)
- Will an apexi world sport fit a 92-96 prelude vtec?
- where do your h22's idle
- USDM H23 to a JDM H22
- jdm 97-01 PRELUDE DIGITAL CLIMATE CONTROL complete with HARNESS n SENSORS
- integra front end on prelude?
- 92-96 h22 vs 97-01 h22 lost motion assembly?
- bb6 wire tuck
- Paint on CF and more?
- Why can't 94-97 accord energy suspension motor mount inserts fit 92-96 prelude?
- problem with code PE-1 code on radio
- WTB 97-01 Prelude Front bumper body kit or lip kit
- Help! How do I tell the difference . . .
- Vtec Question
- Prelude seats ?
- 5th gen Base springs fit SH?
- Engine trouble Help!!!!!!!
- How to wire 4th JDM fog lights with a standard 4pin realy.
- Sunroof Spring (broken sunroof)
- TOKICO ILLUMINAS on 4thgen?
- Valve cover.....
- Euro-r OBD2a or b?
- 4thgen nonturbo @ capital raceway friday nite 13.1@85 (Impressive)
- 10 sec h22 setup
- 2000 lude short shift
- Prelude Turbo "internals" poll
- 2000 lude h22a4 what mods should I do?
- Temporary Filter or Wait?
- Another Rare Mugen Item Find - worth it?
- Little button on drivers and passengers windows?
- rsr vs eibach
- VTECH Conversion on a USDM H23
- crank pulley
- h23 engine
- Filters
- 98 prelude eyelids?
- 1st gear grind- mounts? tranny?
- 93 Prelude h23a smokes at idle sometimes
- engine fault codes
- 1pc headlights
- Where to get Type-S pistons
- Fogging in headlights
- oversize rings
- O2 sensor problem's
- Need help with my h22 ..Please ?
- How to remove AEM fuel rail, fuel pressure regulator?
- My 2001 is running very lean, and misfiring. Would IAT cause this?
- CRANK removal h22a prelude 1999
- compleat motor rebuild or swap?
- 96 JDM H22
- 92 Prelude Help...Won't Start
- 97-01 prelude ignition timing obdII-obdI jumper p28 ecu???
- Power loss being at higher elevation. Help.
- 01 lude burns oil so fast what to do, PLEASE HELP!
- Do the 16" Mugen M7's 4X114.3 with +45 offset fit the 4th gen prelude?
- camber kits...
- Hrmm...Random
- 92-96 Fog light Relay Harness Questions.
- CF Hood Adjustment...
- Distributor Question - Damaged Beyond Repair?
- replaced slave and master clyinder and bleed and now my car wont start?
- b20b swap in 91si
- 5th Gen Eyebrows??
- Milled my head .30 how much do i advance ?
- redlined 5th gear...
- Engine Swap
- Question....
- tuning on 89 octane?
- Help diagnose spark problem
- H22A distributor question
- H23 Rods
- need help ! with my h22
- Fog lights don't work - possible reasons?
- Will F20B oil pump bolt to H22a1
- Greasin' up my axles
