View Full Version : Honda Prelude
- Raleigh drivers
- Lowered Prelude-Excessive Tire Wear
- Wiring
- WTB WWRS LIP KIT!
- lifter tick
- Bench testing
- taking out engine
- Apexi VAFC throttle position???????
- Oil Additives
- fuel filter
- whats everyone reving there accord euro r to?
- Fuel
- 5th gen lude
- Need help! how much would you pay for this car?
- difference between lude intermidiate and accord?
- Prelude clutch!
- Finishing touches- help needed
- Shift Cable Routing Help Needed
- rear strut noise
- Planning on turbo setup for 2008 ! Need some advice. h22a1 4th gen.
- Pic request: 15" Sportmax 002 Wheels on 4th gen
- Heater stays on?
- Jun 3s too large of a cam for stock compression?
- post your yellow preludes
- Wings West Rear lip
- wheel/tire size and FD combo's. Tested & Compared on a race track
- temp goes up when ac is on. perfectly fine when ac is off. what is the problem?
- Need map sensor hose diagram please
- Vtec head torque specs
- Above H22 name tag
- Balance shaft removal kit
- People with 5th gens+auto*
- Quiet Deep Exhaust
- Low brake pedal after MC install
- Need a Pic of a Non abs Firewall
- firing order
- So i pulled the head off my prelude today....PICS!! HELP
- prelude shop manual
- F22 and h22 fuel rail? the same?
- Will this bulb fit?
- Prelude Sh final drive ratio
- intake air bypass control system
- Brake Bleeding Problem
- Auto to 5 spd
- 1996 honda prelude h22a1
- h23 crankshaft in a h22a4 block?
- Need New Turbo Ready Intake Manifold
- Crank Pulley comparison for OBD1 JDM H22A and OBD2 H22A4?
- Brake Bleeding Sequence
- HOW CAN I TELL IF I HAVE A N/A or fi EXAUST SETUP???
- Alignment = no bueno.. Camber kit needed. halp?
- New exhaust car seems doggy
- Removing passenger airbag on 95 Prelude
- F20B Swap Help
- SH engine parts
- how to put cv back in?
- ssr header
- springs?
- H22A Pistons?
- USDM vs JDM Transmission Internals... Same?
- no fouler trick
- did a jdm h22a swap into a 4th gen n car won't start!! help
- jdm h22 in 92 lude. problem.. help if you can!!! thanks
- anything else b4 planning on boost?
- H22 water pump
- good place to get block sleeved?
- new wheels bb4
- 1992 seats in a 1991 civic dx hatch??
- DSM turbo manifold fits h23? (already searched)
- What is the difference between DC Sports 4-2-1 Ceremic headers and stock headers?
- Check Engine light code P0700 P0740 P1738
- Front bumper beam??
- HID retrofit
- 1992 Honda Prelude Stock Speaker size?
- has anyone ran melling sleeves in the h22
- need help bad
- problem with my lude
- h22 and h23
- major car issue. any ideas?
- new car
- Lower control arm
- help!!! knukles remove
- Best place for an H22 build
- h23a1 My rad fans never turn on.
- Prelude JDM headlights question
- wat do you think i could get out of my lude$$
- What is this?
- Balance shaft timing marks
- Door Wiring - Fising Wiring from Door to under dash
- Automatic Shifter (brake?) problem
- tuning the lude
- WTB Prelude
- Idle Air Control Valve
- Prelude comparicy
- help!!!
- speedometer not working
- question about camber
- what is this sensor called?
- basic questions
- Oil pressure switch socket size ?
- what fan to use with koyo radiator
- Bad noise when turning right and found out the WHEEL is WIGGLY!!
- everytime i filll my tank my car WONT start !!
- IACV Coolant Lines
- 93 prelude to 96 prelude gauge cluster?
- ABS Code
- ESP D series alternator Bracket
- abs light and ebrake light after rear pads replaced?
- Need help!!! Searched
- jdm h22 valve clearance.
- ECU Cost Estimate
- 93 prelude engine?
- Wierd Idle, when stopping
- trans problems????
- HORRIBLE MPG!!!
- What car should I buy?
- Looking to buy a 5th gen lude, have a question...
- Running Water Cooled Turbo?
- Mounting ideas for P28 in BB6?
- How do I set up the timing belt auto-tensioner on a 98 prelude
- Tsudo Exhaust Fitment Question
- how do you pull the abs light code ?
- Prelude problem-Need help!!!!!
- electric nightmare
- f22a1 dizzy to a h22a4 dizzy
- I can see my flywheel!!! h22a
- Common oil leaks on h22a motor
- engine code
- who has the pe super strong timing belts?
- Putting together a 92 prelude.
- 5th gen mounts, searched couldn't find
- Timing Belt installed ...valve adjustment necessary ?
- Euro R manifold Users
- Lower ball joint is stuck in steering knuckle
- VTEC - Oil Pressure.
- Distributor rotor keeps going back
- water inside 2000 honda prelude when it rains
- FRIED cd Battery Wire, Now Throwing CEL for Engine Coolant Temp~!?
- new 4th gen front end
- 3.5 in exhaust on 5th gen prelude?
- H22a Tops out at about 118mph
- Are Prelude SH and Integra Type R brake Pads and Rotors the same?
- ob2 to ob1
- men i have a slow take off..NEED HELP!!!!
- Transmission Problem?
- looking to pick up a local h22, seller said it needs thrust washers...
- Manual Tensioner Torque Spec adjustment nut
- FPR on h22, same as b/d series?
- Lots of exhaust pressure, failed emission
- (ACG-S) fuse whats it for?
- Balance SHaft Eliminator kit spacer
- Manual Tensioner
- Bad Mechanic
- vafcII install into a 93 srv obdI HELP!!
- Help me pick a set of expensive coilovers for my BB6
- Need to know which year and model an H23A3 motor...
- Stage 3 Clutch for 96 Lude Vtec
- stock seat question
- 4th gen skid plate
- Lining Up cam gear marks to set timing
- Few Questions about Track Times
- help!!!
- weird electrical problem (gauges) gurus? 4th gen
- 95 Died while Driving and Won't Start
- 5th gen: excessive road noise
- NEW TO H22
- THE MOST GHETTO SHIZZEL
- 94 Center Console Conversion
- half-size radiator
- v8 vtec
- H22 block h23 crank/rods...need help!
- What do i need to install a JDM h22 into a 99 Base Prelude
- Prelude 98 base, vtec doesn't engaging at all
- 5th Gen auto to manual swap?
- Is the timing off?
- Wheel suggestions for 96' prelude?
- balance shaft ?'s
- 2000 h22af cams.
- So far so good, except...
- =====Cat. problem????=====
- ECU
- Stripped Head Bolt...
- **** EuroR Dyno Testing Results***** good stuff
- H22 engine coolant plug
- 98 LSD Transmission?
- Type-SH engine into a Si model prelude
- 93 lude wont start
- tien s techs?
- need some help (tranny mount)
- Blown Head Gasket
- Failed emissions (searched)
- Idle problems !!
- 4th Gen Prelude maintenance advice Q's
- Water in exhaust PLEASE HELP
- clutch grinding
- 4th gen h23 engine gone-ideas?
- REALLY loud whistle at idle. Can't find leak...
- Apexi VAFC and Hondata s200???????
- 4th Gen 95' Honda Prelude h22a parts and shell
- new motor in old prelude?
- Need a P28 chipped ECU with JDM H22A BASEMAPS!!!!! I'll send paypal!
- DRL Light
- lookin to buy a 5th gen prelude
- Idle trouble when starting
- LOOKING! ENGINE AND MAYBE TRANY FOR 89 PRELUDE, MANUAL
- What cleaner do i use for electricals?
- clutch problem (brand new clutch) need some advice
- Axle problem =/
- Prelude Idle Problem...
- chips?
- found problem need answer to problem
- engine misfire
- OBD help
- low offset wheel on a 4th gen
- vtec and non-vtec exhaust?
- 93 lude wont rev past 3 thousand rpm
- Buying a 97 prelude....need help?
- Picture request: Power mirror wiring diagram (non power folding)
- cars heatin up?
- turboed jdm h22 only pushing 230hp help
- Buddy Club exhaust for a type SH
- Cel on but when i go to check it the light stays solid and doesnt flash
- Wire Harness
- 89 Prelude Si!!!
- Tie Rod
- UK Accord Type R U2Q7 LSD information
- Prelude remapped chip
- A/C compressor!
- car handles terrible...HELP
- 5g Euro-R IM swap question(s).
- HELP! Car won't start!
- lost hp?
- -----A/C specs.-----
- H22 H23 REBUILD OPTIONS... IDEAS?
- Need some advice, tranny issues (M2S4 just blown.. rebuild or replace?)
- JE High Compression Pistion
- H22a4 turbo?
- Exedy Clutch/Fidenza flywheel combo
- 4th Gen install questions for mugen options
- Caliper pin/boot
- 5th Gen Suspension
- h23 vs h22 intake mani
- 99 prelude Wheel bearing questions.
- Anyone in here running the Greddy E-Manage?
- h22a vtec
- ES motor mount inserts in a DD
- pic request: sprint springs on 4th gen
- Transmission Auto/TCU??
- 3G Prelude Engine Question
- anyone have a supercharged 1997-2001 automatic??
