hmm what part is this? isn't something supposed to go here??
Old Oct 21, 2003 | 01:35 PM
Matgallis's Avatar
Default hmm what part is this? isn't something supposed to go here??
What goes here?
This is over by the intake filter and the battery.
Old Oct 21, 2003 | 01:41 PM
4bidden's Avatar
Default Re: hmm what part is this? isn't something supposed to go here?? (92`Legend)
Looks like the nipple on top of the transmission right where the cables attach. A rubber plug usually covers the top of it. I use that hole to fill my transmission with oil.
Old Oct 21, 2003 | 03:06 PM
Matgallis's Avatar
Default Re: hmm what part is this? isn't something supposed to go here?? (4bidden)
isn't this where u also check the level of the oil in the tranny?
Old Oct 21, 2003 | 09:35 PM
stevieteg's Avatar
if you have a manual trans, then there is no dipstick to check the fluid level, and that is just a filler hole. If you have an auto then you need to find the dipstick that goes in that hole. If your worried about it, just find something to cap it off with.
Old Oct 21, 2003 | 11:37 PM
EK22Tim's Avatar
Default Re: hmm what part is this? isn't something supposed to go here?? (stevieteg)
Hmm, I capped mine off and it started blowing fluid out around the shift fork-- I took the cap off after a 20 mi. drive and it popped off, it was totally pressurized in there. I just left it off- figured it was a breather.
Old Oct 22, 2003 | 06:29 AM
v4lu3s's Avatar
RTFM
thats not a fillelr hole its a vent/breather tube for the tranny. It is suspposed to have a rubber cap that allows it to breathe without worrying abouto anything falling into the tranny.
the filler hole is just behind the axle on the diffrerential.
Old Oct 22, 2003 | 07:24 AM
94vtecmn's Avatar
Default Re: (v4lu3s)
The only correct answer
Old Oct 22, 2003 | 10:31 PM
Matgallis's Avatar
Default Re: (94vtecmn)
edit: just saw the post about where the filler is for the tranny
the_rex
11
Apr 9, 2008 05:26 PM
Sutterlude
Feb 26, 2008 10:01 AM
korndog
Jan 26, 2005 02:16 PM
professorman
Sep 3, 2004 04:57 PM
2002 GT
Apr 30, 2003 11:18 PM
