PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 [268] 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Stock Tach in 4g prelude vtec is going crazy.
  2. ATTS screwin ME???
  3. So does everyone in here....
  4. 95 Prelude Trimlines
  5. questions, questions
  6. Installed my RS*R exhaust (pics)
  7. Blue gauges for 4th gen, requested pics
  8. New piston rings - make break in or not and WHY?
  9. Rear Sway Bars For 5th Gen
  10. How many bolts are on the DC sport 4-2-1 downpipe flange?.
  11. Pics of the Prospeed Headers you guys been waiting for!
  12. H22 tranny versus F22 and H23 tranny. Who wins?
  13. How much time for install?
  14. Brake Lamp
  15. ITR 15" on 5th gen Prelude?
  16. what's next pulleys or header
  17. Lookin for the lightest 18 inch rims possible...must be bronze..Pics welcome
  18. Remove Balancer shafts?
  19. wheres harness to check the cel 5th gen
  20. What are the injectors size on a 95 JDM H22A motor ?
  21. Prelude injectors into civic dx?
  22. Test Pipe VS. High Flow CAT
  23. b21a in japan come in only automatic? or manual also..
  24. does anyone know of an h22 stroker kit???
  25. chipped ECU for 5th gen SS auto?
  26. S-AFC II Wiring for OBD1 ECU
  27. is there a sensor on the very top of the throttlebody on the manifold
  28. I am looking for Prelude Ecu VTEC
  29. radiator fan stays on
  30. For the FI ludes .....why is my HG going at 1 bar?
  31. H23A Crankshaft Crank in H22A Block?
  32. grinding probs
  33. H23 Crower Regrinds for $140 a pair? New from Crower? WTF
  34. Spring Rates
  35. are Tokico shocks really made in China?
  36. 1991 SI VTEC H22A Stock in Australia?
  37. Is this a good price on parts and labor
  38. Pictures of MY Skunk2 Prelude h22a Manifold!!!!!!!!!!!!!!!!!!!!!!!
  39. has anyone ever tried the crower dohc regrinds for H23?
  40. cracked cv boot
  41. weird whistle noise
  42. Fidanza flywheel problems...
  43. problems starting car!! please help!
  44. Anyone know what color this prelude is.... color code?
  45. clutch creaking?!
  46. Update On SMSP Production Header
  47. Pics of Corey's Front Suspension
  48. Cam Gear questions
  49. injectors if you are switch from si to vtec injectors do you need the resistor packs
  50. just showing off my shizit!(pics)
  51. when i get close to redline it knocks me back
  52. What to do with my 92si
  53. prelude sh axles
  54. Valve Adjustment Tool
  55. Changing CV boots on 93'
  56. Prelude Type S engine into JDM Prelude Si VTEC
  57. BB1, BB2, BB6 Header differences
  58. AEM Cold Air On EBAY!!!
  59. 93' Si nitrous? exhaust? cold air intake?
  60. Strength of H22 block
  61. Prelude SiR
  62. Prelude H22A Apexi VAFC Settings?
  63. speedometer going nuts
  64. H22 knock sensor...
  65. Horsepower pt. 2 .... h22? b18? turbo?
  66. new owner
  67. california emissions.....upgrade ECU?
  68. Massive Dyno Pains
  69. JDM H22 Vtec head on JDM H23
  70. (H23 help people with HELM's) which rod goes where
  71. 5th gen nos
  72. Check engine and ATTS light, wtf...............
  73. Timming belt changing?!
  74. 4th Gen Suspension Techinques REAR sway bar
  75. Anyone dyno or try the type s cams???
  76. tires:Kumho Ecsta Supra 712
  77. Balancer shaft removal?
  78. Balance shafts belt removed!
  79. Are these prelude injectors???
  80. 88 Prelude engine? B20A?
  81. how to get water out of an engine?
  82. Stock Door Lock Remote
  83. dinan performance chips
  84. Break-in my engine
  85. Head Milling woes
  86. Erratic Idle
  87. best suspention
  88. 4th gen console swap
  89. S2000 steering wheel...
  90. 18" rims on a 4th gen
  91. WTB: carbon fiber hood for prelude (link to classifieds)
  92. help on my prelude
  93. How should I take care of my car since I am going to be tracking it/autXing it??
  94. Main Bearings
  95. accord v6 fit preludes?
  96. Mechanic at Honda Dealership in MD
  97. Fiberglassing...
  98. any one runing a euro r i.m.
  99. Stock Prelude
  100. wtb: wings west lip kit
  101. Horn & Signals!
  102. How Do You Do Your Compression Tests?
  103. Swap?
  104. HP and RAM air intake
  105. What is the weight of stock valves in H22?
  106. Noises at high rpm's?
  107. Rev-limiter
  108. Dropping your lude front-vs-back
  109. WTB: 97-01 Prelude Driverside Headlight
  110. need help on exsaust systems
  111. shifter threads
  112. Advancing timing
  113. vafc question
  114. Streetability of ACT puck clutches?
  115. 4th gen electroluminescent gauge install...
  116. Good Place to buy the front turn siginal lights for a 5-gen lude
  117. Which ecu is better to run on a h22? p28?p72?p13?
  118. Who can tell a difference between jdm h22 cams and jdm h22 type s cams?
  119. anyone running a stock 97+ boosted?
  120. JDM h22 compression psi?
  121. need suggestions building my h23 head...
  122. Problem with ECT! Help!
  123. New to ludes, can someone help me?
  124. Who makes "racing" seats with bolt-in rails for our cars?
  125. Advancing ignition timing on a 99 Prelude
  126. got a nasty vibration in the car...
  127. dc header w/ mod collector...
  128. My compression fixed itself?
  129. building my h22 for turbo
  130. LudeFest WEST
  131. hondata goes in next week on my boosted h23, got any tips
  132. rsx 6spd in an h23?
  133. bumper help
  134. SRS light,and brake light question
  135. A few Questions about my recent swap
  136. carbon fibre hoods...
  137. 97-01 JRSC Prelude 1/4 mile times??????????????????
  138. parting out 95 vtec *approved thread*
  139. What internals for JRSC
  140. HeadLight porblem Prelude 92-96
  141. Nitrous on an 98 Prelude???
  142. h22a bagder sleeves
  143. Is this a concern?
  144. engine swapping!!
  145. What's needed for an h22a swap in my car
  146. grinding ??????
  147. front strut bar...
  148. prelude seats....
  149. h22, h23 intake manifold comparison
  150. Will a 3rd Gen Prelude suspension fit on a 2nd Gen Lude
  151. Experience on 00-01 Prelude
  152. nitto NeoGen
  153. JDM H22a
  154. Horsepower Gain
  155. Shop quoted me $1,200, to replace piston rings. Sound right?
  156. changing gauge cluster light color
  157. Bought Euro R Intake Manifold for my 99 Lude
  158. does anyone know how to convert 4ws to 2ws?
  159. what is the downside to 4ws? can it be disabled/removed?
  160. 96 Prelude S bought cheap with low miles.
  161. Where can i get Ingalls or other quality cambe kits?
  162. Transmission fluid additive?
  163. Clunk Clink Noise
  164. Turbo prelude peeps, make sure you put a restrictor in your oil feed line.......
  165. Does anyone know where I can get a DC Sport downpipe??
  166. engine swap: need your opinion on this swap
  167. Recommended throttle body?
  168. service manuals are online
  169. is it true that some 4th gen Si Ludes came prewired for VTEC??
  170. Prelude 2.0 si engine...
  171. h22a fuel pressure
  172. Stock rods...
  173. Will mobil 1 synthetic 15w - 50 be a good oil choice
  174. ECU question about JDM H22A.
  175. Lip Kit for 97 Prelude
  176. need help on strut brake collar for TEINS.
  177. dc short shift kit for 98 perlude
  178. anyone tune with crower cams stage 3?
  179. Has anyone dynod their H23 STOCK?
  180. quad throttle body setup?
  181. HID conversion CATZ vs. G-Garage (McCulloch)???
  182. changing cam gears...need help!!
  183. is a v-afc really worth it?
  184. first time to the track with my prelude
  185. 1991 Prelude Probs
  186. Calling all 1998 + preludes
  187. Finally got past the barrier
  188. here are the pics of my Greddy SP some of you asked for....
  189. (WTB) doesnt any1 have a frigkin h23/knock sensor
  190. 3rd gen engine swap?????
  191. video or sound clips
  192. what is the torque specs on the bolts that hold the crank in place?
  193. Installing CD Decks?
  194. iceman intake?
  195. busted PS pump
  196. how much did you pay for your prelude??
  197. Test Pipe for H23...
  198. H23A Heatshield ?
  199. Legend Brake upgrade
  200. Clutch & Tranmission Help
  201. Fourth gen suspension questions...need to upgrade to stiffer spring after 3rd ruined dp.
  202. 96 dx accord + 1k for a 94 si vtec lude, is it worth it???!@!@!?!@!@!@?!?@!
  203. Modding DC CC header -- Suggestions please!
  204. Think im going to remove the balancer belt..need opinions
  205. is it possible....
  206. 5th gen catback
  207. aftermarket radiator for 5th gen fit 4th gen?
  208. No idea what to do...
  209. where is the ecu?
  210. 4th gen gauges....... colors......
  211. SSR competition wheels... 4 lug pattern?
  212. Type-S piston question: Press fit or full float?
  213. h22 trannies
  214. 215 do me any good?
  215. whats the widest tire you can use on a 5th gen?
  216. h22a With NOS
  217. did u guys have to cut your fender wall to install aem intake?
  218. Michigan Users
  219. 4th gen tranny gearing Question
  220. ABS lights on??
  221. AEM fuel rail question
  222. H22A Swap with H23 Tranny
  223. i need some #'s on a prelude and gsr
  224. When upgrading the 5th gen front rotors and calipers with..
  225. transmission question - hard shifting
  226. FRONT LIP....Which one is this?
  227. My car is totalled!!! suggestions???
  228. 92 Si problem.....
  229. f max turbo kit for sale
  230. mugen head gasket
  231. Biggest Shot'O Nitrous On An H23?
  232. problem with heat controls
  233. Wanted Prelude 98 SH ECU
  234. Im so frustrated i cant decide what suspension set up i want. please help
  235. Help me fix the Prelude curse!!! SHOCK KNOCK
  236. should i....
  237. What is Corey's set-up?
  238. well clutch is gone
  239. Socket size for knock sensor
  240. WANTED: STOCK 4th gen Si muffler
  241. OT: Ran over intake! YEAH!!
  242. Turbo Manifold....
  243. Progress rear sway bar.
  244. faulty pcv valve
  245. Ever heard of adding a new O2 bung?
  246. vafc or safc
  247. 16" tires....NEED HELP
  248. Honda MTF - is it worth it?
  249. how much have u put in2 ur car and how many tickets have u gotten (stat project)
  250. Compression test: low #'s
