View Full Version : Honda Prelude
- Thumping noise from 99 prelude
- Identify this header Bisimoto SMSP or knockoff?
- power steering confusion
- wheels and tyres size for my 4G...
- How To Set H22A1 Timing Belt?
- Wiring help!!!
- Sick Prelude! H23 is losing power. Please HELP!
- F20b Cylinder head noise? lma's?
- JDM H23a Vtec EGR?
- What can I do to make my 98 prelude launch faster
- Lost Vss signal. broken trans?
- 93 blowing white smoke
- megan headers for h22a4
- Problem installing DDM HID's on 96 prelude
- Are B, D and H series knock sensors interchangeable?
- Honda suspension
- motor swap
- 5th gen, Energy Suspension kit
- arp h22 rod bolts...?
- Could this be synthetic oil symptoms?
- Has anyone done a CL1 cluster in a BB6?
- 95 prelude vtec brake issues
- rear lower control arms for a bb6
- new/old 4th gen owner
- honda prelude rims
- fuel pump fuse(wire burnout)
- VSS Mechanism, automatic and manual interchangeable?
- how can i find out if i have a manual rack and pinion
- '97 Prelude's low beam all of a sudden don't work anymore?
- Which H22?
- ECU Piggybacks
- coolant issue please helpp
- Looking for tranny
- H22a1 build
- Check Engine Light - Not the average problem
- '97 base Prelude's brake light still on after e-brake is down?
- Please help:Chattering noise and no clutch engagement after new clutch and new engine
- honda prelude headers
- Money Saving Tip for increased power
- Hood? Bumper? Frame?
- Front Shock Knock, Sort Of
- Tie rod and cold start up questions
- Enkei RPF1 Question!
- 98 type sh battery/wiring problem
- Car running to rich. Fixes?
- i have a question
- needing help wit my 92 honda pre
- "Quality" HID Kits
- First time honda owner 1991 Prelude SI
- h22 - ek chassis - axle question...
- violent shaking above 60mph when I brake
- H22A1 Help, Rebuilding Long Block
- timing comoonent assembly
- Gauge cluster with blue lights???
- More then likely a STUPID question!!!
- Overheating h23
- The causes the Rev on low RPM on 99 Sh Prelude
- 2000 prelude reving weird
- Honda Prelude H22
- Sh Build 2.3 crank
- JDM Front End BB6
- what should i do, 94 honda prelude si
- H22a1 crank into a JDM H22A
- No power to walbro 255 fuel pump
- Rack and Pinion - Power Steering questions
- honda prelude vtec wiring harness
- Timing belt help?
- Car cranks but won't start
- TOOO hot for TOOO long
- Gauge Cluster out Help!!!!
- How to raise front knuckle with floor jack?
- looking 4...01 prelude CF roof spoiler / rear mugen 01 prelude skirts that fit...
- 4th gen: Power window problem
- Sarona Eyebrow for the bb4
- base-sh trans question
- Starting problems... PLEASE HELP
- Problem Code Question
- Battery Light turns on when I start car. NEed help
- What are the H22A TCU?
- Any issues to watch out for?
- I need a list of parts for 3g swap
- Headlight Projectors?
- EGR valve and ports question
- Need help!!! Shifting and check engine light problem.
- reverse issue on 99 h22 tranny.. HELP PLEASE!!
- 5th gen overheating and now idle issues.
- Will honda ever bring back the Prelude?
- Rear WHeel drive prelude VS. Front WHeel Drive Prelude?
- Why is the prelude so umpopular?
- Engine stalled for a second on the highway
- 4th Gen Headlight level adjustment
- H22a into 94 prelude S.
- Symptoms of leakins injector/loose valves?
- Map Sensor on throttle body
- JDM One Piece Headlights
- Fuel and Temp Gauge light up issues
- Head work
- JDM Motor with USDM flywheel and starter?
- 92 Prelude leaking radiator nightmare!
- 92 prelude aftermarket headlight housings no reg lights only brights
- 97 prelude bump steer issue
- H23 crankshaft on H22
- **SAme No START PROBLEM H23a1~~~>
- daytime running lights anybody???
- flywheel and clutch question
- need help for my h22a to pass emissions!
- code 43
- Please read
- H22/Accord Type R Tranny: U2Q7
- my car wont start
- engine block coolant drain plug question
- JDM H22A in eg charging problems
- H22A Problems...
- Catalytic Converter
- Random Questions
- NEED HELP, Prelude transmission housing feel stuck
- Anyone parting prelude? I need the cd player/surround
- RSX Type R Rims
- 1990 prelude si 2.1
- 37820-P0B-A01 ECU
- Couple Questions On H22 Prelude
- jdm swap from h23 to a f22b
- Adding vtec...
- sun roof drains clogged
- Engine harness help
- Has anyone had a rear-wheel drive prelude?
- Can i put LSD on my 98 Type SH Prelude?
- Dizzy question: Can I swap out an internal coil dizzy with an external?
- Strange wheel lock up after suspension work
- 1992 Honda Prelude
- No fuse in underdash fuse panel for fuel pump?
- i have a h22 wat can i do to make it faster
- Weak defrost : BB6 prelude
- is 99 prelude sh crank pulley same with accod??
- My car has no power please help me im freakin out!!!
- 92 to 94-96 center console conversion/Hazard light
- Turbo Prep - what else can i do.
- 5gen swap
- Yet another H22 crank pulley problem
- H23A1 Rebuild Went wrong HELP!!!!
- DIY Video EGR Valve/Ports Cleanup
- s100
- (need advice) Installing pistons & best replacment bearings for H22
- 4th and 5th gen rear lower tie bar?
- Headers install ?
- k20/k24 swap 4th gen prelude.
- Please Help! 93 Prelude W/ Leaky Trans
- Bringing a Motor Out of Storage
- Cruise Control Delete
- 98 Honda Prelude Clutch Bleeding issue.
- 1994 Prelude H22a No Spark, Help!
- Car dies after long time of idle or giving gas
- 5th gen tsb shock knock fix works for 4th gen?
- 98 Prelude hose part #
- New Guy Here
- preludes and the 3rd gear
- auto to stick?
- Balance belt tensioner Removal
- help! car randomly dies
- JDM H22A
- TPS and Hondata S300...
- Skunk2 stage2 tuner cams?
- Race inspired JDM Lude
- Cutting Springs Help
- 92 isn't starting
- I need help
- Why is the Prelude so unpopular?
- h23 build
- 92' prelude swap
- blown b20
- 4 lug to 5 lug
- 97 prelude sh jdm head
- Replace or adjust valves?
- Suggestions for my 96
- Any 5th Gen's on F2 Type Ones?
- KYB struts, and Neuspeed Bars
- Master cylinder leak.
- whats a map bypass valve?
- IAB troubleshoot
- Anyone know how to swap JDM H23a non vtec black top for JDM H23 vtec blue top?
- shelfed h22
- OBDI H23 Engine harness Pinouts (shocktower connectors)
- Some new in car race vids
- jdm h22 hesitation problems
- Prelude just wont start
- Coilovers from accord
- How to get ATTS off my LUDE
- JDM OBDII H22A Swap - Wiring
- Someone with a 3G want to take some pics for me?
- honda prelude bb1 h22a warning lights?
- Header Coating Question
- Clamp around brake reservoir is stripped
- Prelude Starting Issue
- h23a turbo kit
- need help with headlights
- What's the chassie code?
- Please Help me on this problem!
- Prelude is running rich and wont pass emissions
- after market horn
- 94 Prelude S F22 - H22
- h22 ecu??
- Tossing in a JDM Motor- what am I missing?
- 5spd auto swap - Good Deal on Parts?
- Lifters tappin.
- Pink milky fluid?? Bad radiator? blown headgasket?
- my 96 lude idles up and down wen cold and makes funny noise????
- Abs light before and after brake job?
- Tried looking at everything I can think of, car just wont start... any suggestions?
- 92 prelude running funny..
- Driver side LCA spindle spins when trying to tighten the crown nut
- Atomospheric Pressure sensor
- Whats kinda honda is this
- H22A head torque
- Yo guys wers the bb squad at???
- h22 timing belt and spark plug rethread
- what wheels do you guuys recommend for my bb2?
- h22 OEM type S pistons
- NPR (nippon) h23 OEM pistons
- 5G ABS Light Stuck On
- Aftermarket shit cables
- aftermarket motor mount for 5 gen lude
- Need vacume line help please
- piston ring gaps
- Searched but no find - Leather Seat Install
- Using different main caps
- OBDII JDM H22A into 98 Base
- tstat housing tq for the bolts
- Crank Seal woes
- Soldering larger gauge wiring
- H22 Top mount intake manifold
- wont start
- Has anyone converted a 4 rib A/C compressor to use a 5 rib belt?
- 93 Prelude Si flywheel does fit in 97-01 prelude?????????
- 97 SH - Need Advice on Steering Rack Seals
- Brake Master cylinder... why different?
- limp mode help please
- Dirt racing
- What is this thing called ???? (Clutch kit)
- best H head...
- 92 Prelude Light Problems after Dash & Motor Swap
- smog help !
- So I'm thinking of getting an H22 vtec with A/T
- Can't turn crank by hand...help
- Car has no spark
- Need help picking pistons -type s-
- Type S cams in a jdm head?
- Vibration
