View Full Version : Honda Prelude
- is there an easy way to set balance belt?
- Prelude Meetings???
- h23a1 or h22?
- H22 Timing covers p/n
- Someone help
- '93 Lude - ELD output
- 93' Lude Alternator problem
- h2b kit
- Pre-Buy Questions: 2001 Prelude
- Possible dizzy problems!
- Built H22 problems with starting
- wiring harness?
- h23 harness on h22a1 motor
- What generation do I have
- Weird Symptoms...Please Help
- 5th gen. is this Master Cylinder or Clutch
- Big problem with h22 ! need help
- Help, CEL #1 on h22
- Could this be the cause of Code 12?
- I need help with and engine swap!!!!!
- 5th gen. The thing on the front bumper?
- JDM fog lights with cruise control wiring?
- OBDI H22A ECUs
- Which pistons should i get
- Short in Circuit! PLEASE HELP!!
- The right way to take off the H22 Intake Mani.?
- Prelude power steering problem
- Should I get an F22b instead...?
- F22b dohc in 92 type s wiring
- Fat tires on a lude
- 5th gen sway bars
- wiring issue/ignition issue.
- 1/4 mile posts! Preludes!
- Slammed Lude Camber Kit - Ball joint or Anchor style Ingalls?
- H23 Prelude Engine needs help
- Ebay traction bar?
- Check engine light is on, but no Codes Flash!?!
- need P28 for h22a in a prelude
- want to swap my 2gen enjin to b16A
- h23 prelude NEEDS HELP
- h22 no power
- 92 Prelude S F22a1 Idle prob
- Stage 1 Cams idle issue.
- sleeved H22 & F22 build
- harmonic balancer issue
- Taking the next step
- having clutch issues
- RESISTOR BOX H22a4
- '89 Prelude si clutch
- CEL and ATTS Light On
- OBX cams any good for H22A4
- CD7 damper in BB2?
- Lowering BB2 with OEM-parts?
- question about an fpr?
- H22A Issue ??
- I NEED HELP PEOPLE wit my HARDNESS
- H22A Swap
- short circuit? Car died in the middle of the night..
- Nos Advise
- 93 Prelude hesitating really bad
- 92 prelude limp mode
- what head gasket
- Another Rear Sway Bar gives. Are 4th gen/5th gen the same?
- DIY Tow Hitch Install
- help i want to buy a 1985 honda prelude
- 11.5:1 compression?
- Are these optional 3rd gen prelude rims (enkei)?
- H22 swap to II gen prelude
- interchangeable parts
- bb6 auto trans issues
- transmission how to???
- 17X7 +40 offset on 5th gen. Short Answer
- Might be intrested in a 97 prelude...
- BB6 Check Engine Light, Working fine
- somebody help the dutch
- 1996 Honda Prelude SI Auto Rod Bearing
- Idle problems!!
- H23 VTEC Opinion Needed!
- best budget prelude trans setup?
- Prelude needs new motor...
- h22 connecting rod #s
- Please Help-Major oil loss of unknown origin
- distributor question
- Car drops rpms/shutters w/ ac on.
- Can't turn off the heat
- Carbon Fiber License Plate Trunk Filler
- Prelude vs Gsr
- Engine rebuild needed? and if so..
- Where is main flasher relay located at?3 prong?
- What would it take for my h22a to reach 300hp
- Im Looking for the best Prelude owner!!??
- Alternator/Charging Issues
- h22/f22 dual tentioner
- check engine light
- CD PLAYER NOT WORKING HELP!!
- How bad is this damage
- air coming from oil fill hole. normal or blow-by?
- F22A1 bore ?
- DC Front Upper bar Install problem...help!
- 95 prelude true right hand drive for sale? or need advice what to do with
- 95 prelude problem no shops can figure out!
- h22a bore question.
- i need an advice i have engine problems in my honda prelude
- H22A timing
- Best turbo for my lude?
- Alternator problem?
- Backfiring and soot question
- Correcting ATTS problem.
- How did you mount your race seat in your 5th gen?
- Body kit Supplier in Canada?
- h22 map
- weird problem with DRL and headlight
- 92 Lude w/ Auto trans worth the $$$?
- Auto Tranny issue, help
- Antifreeze Leak Need Help...
- H22 TPS ?'s . . .
- ATTS
- 1999 SH, LOW MPG problem
- h22 oil pan interchangeable????
- jdm h22 in a hatch eg problems problems
- 88 integra to 92 prelude sunroof/moonroof conversion??
- Do you recommend...
- H22a Rod bolts
- Question
- J series in a bb4!!??
- rebuild kit
- bogging before vtec
- my93 lude vs 01 mustang gt
- got my 92 h22a swapped in but..
- 92 lude tranny prob?
- H22A1 Head Screwed
- To those looking to install adjustable ball joints...
- What i need to get my swap done on a 97 Prelude AUTO to Manual???
- Worth a swap?
- 5th generation Prelude - Climate control cable - need help
- Steering wheel options in a 4TH Gen?
- type s cams...again
- wiper issue
- Is F22 Manual Trans and H22 Manual Trans are exactly same?????
- h22a injector questions
- Head Gasket replacement
- Compression test. Good? Bad?
- 92 prelude swapping in jdm h22a...Help!!
- h23 ground
- Somebody help tell me where I can get this blacktrax manifold for my h22
- Sooo... boosted bb6 doesn't need front mount?
- my new lude!!!
- New 5th gen, what you guys think?
- WTF is wrong with my motor?! helppp
- Auto h23, how much hp is the tranny good for?`
- worth buying?
- anyone been pulled over for HID with no projector or retrofit?
- nitrous problem need help
- 4th gen lcd indash?
- Having problems lining up SPC adustable ball joint plate
- bad mpg!!! Why???
- Car wont turn on
- What is this something it came from a jdm bb6 prelude
- Knock sensor question
- Interior Lighting
- Fog light switch (not oem)
- axles
- Quick question??
- Timing Belt Part Number Supersession
- 97 prelude questions
- tranny help!!
- Flywheel pilot bearing
- help plz.....
- vtech help
- Driver side Clunks when it's cold...
- *****Newb Question That need to be idmediatly Answerd ******
- 92 to 95 Lude Center Interior Swap
- Is p19 required for JDM H22 engine trans swap?
- 92 prelude tweeters and covers
- Where to go for upper control arm bushings?
- f20b swap, flashing check engine light
- Engine light came on... when it wasn't supposed to.
- phearable.net chipped ECU
- anyone got pics of a 5th gen prelude with JDM rear window visor
- Wire EDM rear fog switch for front fogs on 93 lude?
- '93 'lude error coding help
- Installed JDM engine in car, no longer starts.
- Need Help on new swap
- Car type
- f20b motor in a 4th gen
- Honda prelude lock problems
- Back in Love with my Prelude
- h23 vtec turbo need hel
- Injectors
- Just bought a prelude
- car bogging?
- sunroof and tailight question 4th gen
- Random revving
- need body kit
- Pressure Plate Torque?
- Alignment question, do I need one?
- distributor help please...
- Good LSD to replace ATTS in H22 tranny.
- Starting/Battery????
- F20b motor question
- question
- f20b auto upgrade
- plz help
- h22a, h22a1, h22a4 lets talk
- More power in H22A JDM ?
- Anyone Know If These Wheels Fit The BB6
- Timing Belt Adjustment?
- interior question?
- f20b motor mounts?
- Vtec Wiring Help
- Jdm h22a what piston rings?
- h22a bearing clearance
- Wheels for my Daily Driver 5th Gen
- 2 of header pipes not getting hot
- what head gasket for JDM H22 Type-S 11:1 comp.
- carbon fiber trunk release???
- 1993 prelude bogging
- H22 ticking sound after valve adjustment, tune-up, etc. Need help :)
- Head and block
- 01 prelude TB manifold plz help
- alternator harness cover
- 93 Si Vtec Brake question?
- Replace or Rebuild?, Lude on its last leg. (almost)
- oil leak...have no idea where from
- swapping gears out??
- i have 97 sh and need a half shaft
- 1988 Prelude SI with a B20a5, want to buy head.
- h22 strocker
- 92-95 obd1 usdm prelude distributor
- RS-R ExMAG on 5th Gen SH?
- OBD2 H23 Timing expert help??
- who makes this part??
- camber kit install
- still need premium?
- What is ATTS stans for and what does it Do???
- 2000 Prelude squeal/scrape
- h2b with built head and ITB or built head with Pistons
- HELP!!!!! OBD2 to OBD1 Distributor
- p12 vtec
- CEL
- Does 5th gen honda prelude comes with lsd manual transmission?
- Prelude No Start H22
- A little help is needed...
- Prelude chewing up tires. How does this alignment looks?
- Koni yellow online store help
- Which ignition coil fits the h22?
- My Lude Just keeps DYING!!!!!!!
- strange noise when a/c fan is on
- what wiring and ecu do i use on my h22a in my 98 acura cl??????
