View Full Version : Honda Prelude
- spark plugs changed
- Help PrecisionH23a
- middle cover ASAP
- downpipe
- compression numbers nasty!
- New user and IMing?
- 92 prelude owners! Replacing VSS?
- Installing Balance shaft seal
- egr removal help!!!
- Fuel rail
- dog bite = car parts
- turbo sh?
- If anybody is interested in superpro bushings check this out....
- bb6 window visors...
- decking an h22?
- i was look at geting a OBX Intake Manifold for prelude are they any good
- What or who is PO or PO.COM???
- what kind of transmission is this?
- Paround Richmond, VA that does clutch install for cheap?
- 97 prelude clutch problem
- Give me some possibilities please
- Idle Problem
- servicing radiatior for 2000 prelude
- Sportshift Tranny ?
- mahle pistons
- loud knocking noise (audio inside)
- Wow, this is irritating!!
- Interchangeable Bushing Kits
- heck engine light for misfire on all cylinders?
- knock sensor help
- anyone know torque specs for '83 prelude headbolts?
- NEED HELP!! One easy ? about the h23a1 can u answer it?
- h23a1
- Need help with tie bar install
- Might Pick up another Honda, Pic and questions
- turbo for f22 engine
- shifter cables and brake lamp light...
- need help with 93 idle problems
- SH Block with h23 tranny? (Searched)
- 4th and 5th generation CARPET colors??
- water pump question
- O.S Pistons
- Why does handbrake have to be lifted so high???
- Oil filter relocation
- Front Wheel Bearings
- Throttle Control Lever (alias, throttle pressure lever)
- looking for pics of 4th gens without sunroof...
- My 4th gear is costing me races. Do i have options.
- Some kind of TV screen/display fitted in my dash, what is this???
- How do I fit standard headunit, in my JDM prelude??
- $th gen intake manifold
- are 92-96 and 97-01 strut bars interchangable?
- Newbie questions about an H23A1
- Buy a used h22a4 or a remanufactured ...???
- eibach pro vs sportline
- Valve Cover??
- i need to get EMS i dont know which one i need for my prelude 92 it has a h22
- Overheating at idle issues - thermostat related
- H22 decision HELP
- 94 JDM H22 O2 Sensor...
- engine swaps
- 1997 Prelude AT STALLING!
- h23a1 ecu
- What to do with my vtech h22
- bb6 side markers....please help
- obx intake manifold
- type SH clutch same as base?
- AEM Big Brake Kit
- Clutch Help PLEASE
- Why does Greddy's CARB Legal Turbo Kit Not Work For The Type-SH?
- Ebay Turbos...
- Crankshaft pulley
- base 97 lude manual trans problem
- Prelude for Track?
- Distributor has motor oil driping inside
- Does anyone have a list of all ABS cell codes (searched)
- 4th gen seats in a 5th gen?
- are TOKICO HP SHOCKS any good for my 97 base?
- Emergency brake light comes on when stepping on regular brake
- seperate rev tach
- Hey this might sound like a Dumb Q, but which way did you install Horse Shoe Clips for Tranny cables
- What to upgrade? I upgraded suspension...what next??? looking for some good input
- Cataligue code fo M2Z4 tranny
- what kind of swap on a 98 prelude
- Forged pistons and FRM sleeves
- EGR PROBLEM WUT SHOULD I DO??????
- OBX Valve Cover
- Set me in the right direction...Suspension...
- h23 knock sensor work on a h22?
- Thinking about turbo?
- going to a buy a 97, couple questions.
- emissions ecu problems
- Piston bore???
- Hondata
- Supercharger on a 4th gen h22 lude?
- Prelude turbo=Blown engine
- Catalytic converter??
- why is my clutch pedal letting off so high???
- speedometer and rpm not working
- 6 speed box info or poss group buy
- Bad gas mileage on a '91
- ingalls engine torque damper 97-01
- Questions about valve connecting to heater hose (Need help ASAP)
- what is too lean for N/A??
- misshifted from 3rd to 2nd... i need your opinions!
- h22a or h22a4 block??
- Speedometer Indicator.... 97 prelude
- Would you go with uberdata or vafc-II???
- Had to share...my blowout on the highway...
- what on earth is wrong with my car?
- '92 prelude si
- IACV decisions
- ??H22A in an Acura?? CAN IT BE DONE??
- jdm bb6 side markers.........
- How do I supercharge my Prelude?
- i want silence
- ECU shield/case removal
- Exhaust Pics
- Differences is MAIN RELAYS??
- has anyone put aftermarket camshafts on there h22?? if so...
- Eliminating the oil filter cooler....
- New Rim offset
- rear suspension
- Would you put regular 87 octane fuel in your 5th gen?
- egr
- Heat + Rubber= bad
- Speedo needle/coil swap
- different between Type S and Type SH.
- Which Block/Piston/Rod to use?
- 97+ prelude OEM clutch.............TRIED searching I pROMISE
- Engine rebuild
- 97 prelude shifts HARD when cold. Pls help!
- problem starting/stalling (h23 '92 manual)
- how to for tuning a 99base
- Does MSD fry stock internal coil?
- installing OEM foglights on a 4th gen... any tips?
- ebrake light
- hissing noise associated with Megan/DC headers
- takes awful long time to start the car!
- ***OK Let's cut down on repeated threads about H22 Bogging/Hesitation Phenomena-Post Links Here***
- b16 in an 87 prelude?
- New Exhaust
- just blew up
- Looking For Urethane Bushings For Gen5 Prelude SH
- Manual Steering rack
- thermostat differences- H22/H23
- Obd2-Obd1 wiring diagrams for prelude!!
- Just got my head back from portflow!!
- Got my car back together rough idle and stalls.
- will jdm h22a stock injectors be fine for 7-8 psi on a IHI-RHb5 turbo ?
- Driveshaft Replacement Need Quick Answer.
- Is it worth it (already searched) Base Handling
- 11.5 flywheel
- Coolant Leak! Need to Identify hose and sensors!
- o2 sensor questions regarding accord/ prelude o2 sensors
- Lowering, springs - looking for reviews
- 4th gen 4ws help
- Spark plug gap for a h22?
- Added a spoiler with a 3rd brake light...
- ATTS Shut Off At High Horse Power???
- CEL 61
- Immobilizer Bypass?
- boost
- STR 570 Pro cam gears
- Lowest Recommended Octane for H23
- tach and speedo lights flash on and off and speed needle sticks
- Earth Points
- h23 and h22 exhaust diff
- corner lights 4th gen?
- Dyno from Europe:)
- Need Advice
- burnt clutch smell.... cause for alarm?
- H22a4 long block q's
- Transmission decides to take a crap?
- 92 auto predlude trans wont reverse? sell it or fix it?
- Problems with ATTS
- is it hard to install adj cam gears?
- "Black box" underneath intake manifold.
- s2000 steering wheel
- periodic/rhythmic shaking of steering wheel. why?
- pistons in other engine (searched)
- Balace Shaft Belt Tension - Help
- Ecu help
- 5th gen owners.. where to run the power wire?
- type-s pistons
- weight reduction
- The "OFFICIAL" What can I do to get better gas mileage thread.
- my h23
- Flex pipe replacement options, 94 vtec
- Which Greddy Exhaust Kits Are CARB Legal?
- fastest times in a 5th gen
- Forged Rods for the H23
- Roof and suspension creaking?
- Build Vtec Prelude or Vtec Integra
- Cleaning up the engine bay?
- Will It Be Okay To Drive It For The Weekend?
- Knock sensor torque spec?
- How long will it last?
- Diffeence in skunk2 and skunk2 pro series?
- 91 prelude ecu
- 99 prelude engine swap
- tranny problems...
- chamber kits ????
- Oil Pressure Sender location
- Will a header for 97+ fit a 4th gen h22? Is there any difference?
- Who makes the turbo manifold posted on this page by kamAccord
- Exhaust HP boost 5th generation prelude
- What does this Warning Gauge mean
- 4th and 5th gen prelude ratios
- transmission removal from block
- valve adjustment
- type S pistons...need ravalve/port the head????
- Type-S or Rebuild USDM H22
- Write up on 5th Gen prelude oil change
- moderator or @$$wipe?(you said you wouldn't delete it)
- distributor
- blancer shaft leak
- 75K Miles Tuneups
- 89 Prelude help
- radiator fan issue
- Prelude Intermediate Shaft
- JDM Headlight wiring (searched)
- 5th gen Fog Lights...
- bb6 jdm visors.......
- abs light
- f22 internal coil to h22 coil?
- lightweight underdrive pulley
- Need to change ignition switch
- 5-lug swap on 92-96 (SEARCHED)
- having doubts about Hondata
- Which Exhaust System?
- Shifter kicking out of gear! Problem?
- question about shock settings...
- Anyone have before and after ET's for final drive gears?
- rough idle, many parts replaced
- sleeving the engine?
- what is this broken part?
- NTB H23 long block or full swap
- molding front lip.
- brake pressure problem
- How do I get the outside joint joint off (axle disassemble)?
- What to do about seafoam
- Collector Mod after header
- disconnecting the secondaries
- Removal of the speed sensor 4 nos
- auto to manual tranny conversion
- auto to h23 manuel conversion = fuc%in amazing!!
- POD filter
- Question about JDM FOGLIGHTS???
- Prelude VTEC on track (vid.)
