PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 [248] 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. 5zigen R-Rated lowering springs
  2. Skunk 2 Cams
  3. Thinner OEM Head Gasket
  4. transmissions
  5. Rod Knocks: What do they sound like??
  6. future engine swapping in a prelude?
  7. 1st gear problems....Gurus help
  8. SMSP Header dyno'ed *problems*
  9. anyone know the part# for the manual Tensioner
  10. anyone need 2 prelude type SH wheels?
  11. Weight of 4th gens?Stripped?
  12. Clutch and Flywheel help
  13. Aftermarket Clutch and Flywheel for Prelude....
  14. Rusted window plug
  15. 1992 to 1994 Spec Dash Swap
  16. Has anyone ever boosted over 10 psi on stock H22 successfully??
  17. How do I decode Prelude engine blocks?
  18. SAFC/SAFCII? questions?
  19. Questions...
  20. p72 (GsR) Ecu For 92-96 Prelude? Possible?Whats the Deal?
  21. will 15 inch kosei k1 with 38 offset fit a 2001 prelude?
  22. WHERE CAN I GET A GOOD PRICE$
  23. How much could our stock TB's be bored out to?
  24. anyone ever weigh their hood?
  25. Atts & check engine light came on
  26. Which Transmission Fluid?
  27. I bought TEINS and im not 100% satisfied
  28. abs light
  29. running lean and problems why?
  30. jdmh22 redline
  31. 1992-1996 Silver Power Folding Mirrors OEM
  32. 4th gen Glass Sunroof? What if we tried lexan?
  33. what exhaust choice is better
  34. 4gen vtec's obd1 or obd2?
  35. 97 Prelude Sportshift?
  36. fuel pressure
  37. 97 Prelude HELP needed
  38. Symptoms: its one of 2 things: opinions please:
  39. Help!!! Blown head gasket??
  40. scatter shield what the hell does it do?
  41. the weakest link in h series?
  42. Exhaust noise levels in dBA
  43. Autotensioner problems......again
  44. check engine light and atts light 2000 prelude
  45. h23 vtec $ vs. h22 $
  46. anybody got extra 3rd gen parts?
  47. Scarred H23 cyclinder walls, should I bore it out?
  48. Any interest in Accord V6 or K24 swaps into preludes?
  49. Pics for your Pleasure :: Golden Eagle intake manifold pics ::
  50. 4th gen VTEC at Integra weight
  51. Please Read.
  52. can resetting the ECU give you HP gains?
  53. FA: 2001 SH tranny setup
  54. have a turbo h22 and getting hondata... which one is good?
  55. '93 Si Ignition Switch problem?
  56. Will an accord EX wiring harness work on 5th gen lude with jdm H22 swap?
  57. HELP !! quick question about cooling ! 93 lude
  58. Hondata ecu??????
  59. turbo lude
  60. DSM Injectors in a h22a
  61. Anyone Dyno or Gtech Their JDM Lude
  62. Lost to a 92 prelude
  63. Type s swap pro's and con's
  64. Pistons for rebuilt h22a?
  65. best cams for all motor h22
  66. H23a being kind of rough (vavleadjustment)
  67. rebuilt US h22a vs. jdm type-s h22 swap???
  68. Help me! What does a Battery Light and ABS light mean?
  69. High HP clutch on low HP car?
  70. Ca smog test
  71. auto tensioner failing?
  72. HELP!!! 5th gen + code p0133
  73. Just Curious about VTEC.....
  74. Tranny Problem??
  75. To all turbo Preludes
  76. Neuspeed Sports -vs- HR Sports
  77. Lookin' for my first prelude(5th gen)..help from u fine pros
  78. AIR carbon-fiber IM...
  79. installed turbo timer but car dont stay on help
  80. Is the shiftboot frame on all Hondas the same?
  81. '88 lude cel code
  82. Header????
  83. need help on pistons!!!
  84. Slalom and Skidpad for 92 4WS
  85. How can u tell your throw out bearing is bad?????????
  86. How much for this prelude
  87. Skunk 2 Intake mani
  88. cold mornig start problem?
  89. another idea...
  90. CLUTCH??
  91. Double Checking: Full Coilovers could fit a base prelude even though it came off a SH correct?
  92. DO THEY MAKE TRACTION BARS FOR PRELUDES?
  93. H22 head on my H23 block
  94. vtec controller !!!!!!!!!!!!!!!!
  95. Need some info...
  96. what is this?
  97. h22 helms manual
  98. How much for this H23
  99. who is the fastest turbo charged prelude 4th gen?
  100. Clutch problem in my first Prelude!
  101. Black Goo
  102. Clutch adjustment
  103. h23 all motor questions.
  104. having a huge idleing problem. please help.
  105. JDM full OBD1 swap into 5th gen?...any major issues or problems?
  106. best way to find whats draining the battery?
  107. will a 35 offset fit a 5th gen?
  108. Finally Got It Done!!!
  109. Unorthodox Racing Pulley Sets....help!
  110. IM for N/A
  111. 4th gen exhaust differences??
  112. obx good or bad?
  113. ::The Official Prelude Dynos Page ::
  114. See ya guys ... i'm now into K-Series.... (read why)
  115. anyone interested in trading exhausts with me?
  116. Question about hood pins for carbon fiber hoods.
  117. Dyno Day Disappointment...
  118. Looking into Preludes
  119. Busted OEM Tach on my 5th Gen
  120. brake problam ?????
  121. Identify H22A Injectors OBD1
  122. Real world HP numbers with JRSC on 5th gen lude
  123. Where can i find this stock exhaust piece?!?!?!
  124. help
  125. What's the compression numbers for a 96 Si?
  126. Problem with Heater in 92
  127. Quick question....
  128. whats an h22 stock bore in inches
  129. FULL list for major tune up > needs comments/answers/informative information!
  130. Mulitmeter Reading
  131. 97-01 Mugen Spoiler
  132. Hone the H22a1 before dropping pistons?
  133. About to order my Skunk2 stuff...do I have everything right?
  134. Issues between skunk2 stage 2s and their over sized valves (.5mm)
  135. can i put a f22 crank in my h23
  136. Greetings and questions from a new 3G owner...
  137. DRAG PRELUDE
  138. What the hell downpipe is this?
  139. B21 Questions
  140. new head studs needed?
  141. Let's talk Flywheels!
  142. H-Series Parts Compatability
  143. Looking for some advice.
  144. 4th Gen Car cover
  145. CEL - trouble code list
  146. Legend brakes on 4G Vtec
  147. JUN H22 Valve Cover? Where can I buy one?
  148. sunroof inserts?
  149. Throwing h22 motor in SI.
  150. del sol radiator?
  151. why does my battery keep draining???
  152. Non-VTEC to VTEC rotors
  153. redrill wheels to fit...
  154. IS this clutch Disc good?
  155. 97-98 hp vs 99-up hp
  156. WTB: USDM H22 Transmission
  157. rear view mirror fell off, need to put it back on 5th gen lude, help.
  158. ►Prelude Forum RULES - READ ME FIRST! ►
  159. What is safe for nitrous on a H22A4
  160. Tein Flex vs. Tein SS? Suspension guru's needed...
  161. whats wattage bulb do u guys run on jdm fogs?
  162. Check the attitudes...
  163. How do I get this thing off!?
  164. Turbo Mani for H23
  165. need help, can't tell if its timing problem or something
  166. NEW PISTONS ON HONED SLEEVES!!!
  167. 4th gen----> 4x100 or 4x114.3?
  168. WTB: 5th gen OEM rear lower valance/lip Gude Approved!
  169. a/c compressor
  170. Throttle Body ?'s
  171. What is a code 7 for 4WS ecu on a 93?
  172. Tanabe Sustec Under Brace
  173. MY 88 LUDE Will Cut Off In the middle OF Driving
  174. Quick question about light weight wheels
  175. Damn connecting pipe is leaking....HELP
  176. PreludE toO HeavY?
  177. 99 lude squeak in driver front
  178. where to find tranny code
  179. will a jdm h22a lude 4th stock beat a rsx type s stock?
  180. Calling all Australian Prelude owners!
  181. drain the gas tank
  182. 4th gen Si: Handling characteristic
  183. - - PROBLEM WITH STEERING, PLEASE HELP!- -
  184. need some strut bar help for a friend of mine who has a 01 lude
  185. highest watt bulb to use with jdm fogs
  186. H22 rebuild OR Buy a nEw h22
  187. Question about the stock intake????(help)
  188. need help diagnosing a start problem
  189. 5th Generation Prelude as first car?
  190. STR intake manifolds
  191. Problems with .... on my lude 1991
  192. s2000 rims
  193. rodknock on new GE engine
  194. 14" steelies
  195. h22 tranny vs. h23 tranny
  196. Tire size on rims
  197. Bolt pattern on 92si....
  198. My engine ran out of oil!
  199. lude turbo install from this week.
  200. THERE AIN'T NO OTHER
  201. THERE AINT NO OTHER
  202. H23 turbo cams
  203. I hate lude trannys!
  204. Battle of the Spoon CF lips (56k warning)
  205. Running the p72gsr ecu in their h22a???
  206. NX question...
  207. IAB's and boost
  208. auto tranny filter
  209. a question about the prelude doors ..
  210. CRX lee??
  211. high compression valves
  212. rpm wire color?
  213. How long do you go on Synthetic?
  214. Lone luder, got a ? for ya
  215. wing high prelude for sell ( very new )
  216. Melted a valve... Damn nitrous
  217. Anyone need an H22A?
  218. emergency
  219. Vtec problems
  220. oil feed...
  221. too good to be true?
  222. WTB: WW Type lip kit for 5th gen.....
  223. Good site to order Fiber Image hood?
  224. Auto to manual conversion
  225. i need a wiring diagram for radio!!! plz!!! search came up with nadda
  226. Fuel injector question 235cc????? Vs 325cc
  227. spun rod bearing, H23A1. Oversized bearing options?
  228. Where is the best place to buy a 5spd Manual?
  229. OT: well guys, i've "switched teams"
  230. Injector size
  231. Running S2k Pistons on h22 motor
  232. H22a tranny issues... (PLEASE contribute)
  233. NY 5gen timing belt assistance?
  234. will rc 550s work on this setup i know their big but its all i have right now
  235. Bent suspension?.... need advice.
  236. so YOU think you know how to check fuel press. on a prelude
  237. Canadian Preludes? swap questions
  238. if i go all engine
  239. H22 and H23 swap/project.. just take a look and let us know what you think, TIA
  240. h23 stock block....what rpm u guys turning
  241. Cooling Fan Control Unit
  242. Sea Foam Auto Marine Additive
  243. Took the turbo h23 to the track with the new setup...
  244. h22 stock head bolt torque spec
  245. Helms Manual
  246. Skunk2 H22 buildup questions
  247. No second, fourth or reverse gears??
  248. Wuts Redline For JDM h22a
  249. does anyone know a jdm importer i am lookong to replace my azect lip
  250. thoughts and opinions?
