PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 [63] 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Hmm, where can I get this
  2. Distributor plug
  3. 1993 lude warms up and dies.
  4. Will a main relay for a 90-91 be the same as my 89?
  5. Best high flow cat.
  6. Anyone have pictures or map of where tranny drain and fill bolts are????
  7. Prsssure Washing the Engine Bay - Is it safe?
  8. Wheel choices...4th gen Lude
  9. prelude 92 coolant boiling and rpm gets stuck around 2000
  10. Burns Stainless Mufflers
  11. 94 Prelude Vtec...exhaust fitment. (Help!)
  12. Recharge freon
  13. Oil Catch Can Measurements
  14. just a couple simple questions
  15. m2b4
  16. My engine is making a loud knocking noise iin the bottom like from the oil pan
  17. I was just wondering...
  18. 5th Gen Climate Control Issue
  19. looking for a h22a4 wiring harness?
  20. Will a 5th gen catback skunk2 exhaust bolt on a 4th gen??
  21. car is lagging? can help?
  22. I think I am stupid.. lets find out.
  23. 93 lude, Dizzy- coils questions
  24. Can anyone tell me how to replace the oil (SP-10) in my A/C Compressor.
  25. HELP: Idle issue
  26. Car is dying on me at stoplight, help!
  27. 2001 Prelude - Cranks but won't fire - no spark
  28. avic-d3
  29. valve adjustment specs?
  30. starter/alternator differences w/ h22/h23
  31. Doing some checking around..
  32. my car died on me help me out
  33. SOMEBODY HELP PLEASE!
  34. Slicks on a 5th gen.
  35. torques specs on the girdle bolts H22A 95 prelude si vtec
  36. Quick question with evo2 exhaust
  37. compession and leakage test result..need some advice
  38. headlight adjustment
  39. Exhaust with no CAT. Good or bad.
  40. Gears grind
  41. quick question on the dmv transfer form!!!!!!!!!
  42. I am about to rebuild an h22 engine...
  43. M2B4 help
  44. atts light and check engine on 5th gen
  45. ABS code 81
  46. ect sensor
  47. Picture Request (Clutch Hard Lines)
  48. 4th Gen Power Window Help! Please!
  49. '97 h22a4 rebuild post
  50. What Altenator belt for H22 SWAP with NO AC/POWERSTEERING
  51. 97 lude SIR ???
  52. 2000 Prelude SH Misfire
  53. springs or coil overs 93 prelude?
  54. vafc 2 tuning help!!??
  55. Tanabe G-Power medallion...should I add an extra resonator?
  56. Thoughts on Greddy Evo2 Exhaust
  57. HT, recommend me an exhaust
  58. rpm guage jumping up and down and engine dies. please help out of town. emergency.
  59. WTB 5th Gen Lude's
  60. My fuel/temp gauges aren't working.
  61. '93 prelude h23 A1 Si or is it?
  62. Oil capacity
  63. Help! which head do I have?
  64. DAMN i messed up
  65. A/C problem
  66. Larger Injector question
  67. Will A H22 ACT HD pressure plate work with OEM DISK?
  68. Need Help!
  69. Automatic Prelude question
  70. tanny question
  71. h22a4 cylinder help!
  72. Drag Racing Coilover setup
  73. electric water pump / overheating / thermostat is good but the problem
  74. Single?/Dual? Exhaust
  75. ENGINE Swaps
  76. 1992 Prelude Type S, Looking for more Low-end Power
  77. Accord V6 in a Prelude?
  78. Loss of 3rd gear????
  79. coil question! need your help please
  80. SOHC 5th gen????
  81. What purpose does the rear wheel bearing washer serve?
  82. Help!! car cranks but doesn't fire over
  83. 96 Preluve VTEC - CEL CODE # 9
  84. 89 2.0SI boiling over only when moving..help
  85. h22 crankshaft and sleeves question
  86. H22a Swap - OEM Parts Needed List
  87. Overheating problem
  88. CEL Code 145 : help
  89. Cooling temperature: What is normal in degrees F
  90. skunk2 stuff
  91. setting cams to tdc
  92. 5th Gen BB6 Sidemarkers
  93. 94-96 console in 93 prelude
  94. car bogs
  95. Vtec Issues..
  96. clutch problem
  97. smoothest 1" drop for 4th gen?
  98. HVAC controls
  99. Fuel in carter
  100. Starter problem.
  101. Shaken
  102. Neuspeed racing springs
  103. Issue with ground?
  104. fog light installation?
  105. Function & Form Coilovers
  106. Confusion over camber kit degree ranges
  107. H23 block + Type S pistons
  108. "The Tank" is now "The Hulk"... or maybe Kermit...
  109. door panel suggestions
  110. Running stock P5M in H22 Civic - Engine Starting Problems
  111. Dome/Trunk/HVAC Controls/License Plate
  112. 92 prelude h23a1 to h23a euro swap
  113. How to put gauges/tv in 4th gen. dash (write-up & pics)
  114. CEL code 23, knock sensor
  115. Bad Clutch or transmission?
  116. m2a4 question for sh to base swap?
  117. when will i be able to send im?
  118. How does this work?
  119. repair or replace flex pipe?
  120. Transmission problem - sound on 3rd gear
  121. COOLANT LEAK
  122. the prelude is gone but, got another car...still in the HONDA family :)
  123. Ebay fitment Front lip
  124. question for prelude engine
  125. H22a: Safe/Limp mode (rev limiter)
  126. Water Pump???
  127. And he's down for the count...
  128. 4 to 1 header
  129. Tranny Problem - Pops out of 3rd gear
  130. neuspeed spark plug wires
  131. No vtec at altitude
  132. h22a4 5th gen overheating
  133. 93 lude
  134. After driving and coming to idle at a stop. engine cuts off immediately.
  135. AEM v2 intake for preludes
  136. g23 help
  137. spring rates D2
  138. prelude Mishap.
  139. Looking for Info
  140. Lower control ball joint
  141. keep blowing fuses trying to hook up upgraded horn ..
  142. Blue'ish smoke under hard acceleration
  143. Odd sound while rolling back or reversing (VIDEO INSIDE)
  144. bent valves?
  145. h23a1 tranny on a h22a engine
  146. Front end is lower on right then left by ~2"
  147. Forbidden Motorsports customer service
  148. safc oem stock setting
  149. 14" steelies on 90' 2.0 prelude si?
  150. Just installed RSR ExMag..
  151. headlight adjustment
  152. CHanging transmission fluid on 99 prelude
  153. What hoses connec to H22 Type S water line?
  154. Where to get tuning done near CHICAGO area.
  155. 97-01 prelude GREDDY CATBACK sonds TOO deep need help
  156. New/used header
  157. Recommend an Indash navigation?
  158. What is this small black box in my dash board?
  159. Bypassing
  160. just finnished my swap
  161. headers/catback/exhaust
  162. h22a manual trans problem
  163. will a poa run a h23 blue top vtec?
  164. rear fog lights
  165. How much can i get for this 1998 SH
  166. first gen honda prelude aftermarket parts?
  167. oil pump swap part numbers
  168. 3rd gear grind used syncromesh, is it my short shifter adapter?
  169. My car is lagging between 2500 and 4000 rpm...
  170. dyno results
  171. hood damper?
  172. stock 5th gen prelude ground clearance
  173. Suspension Techniques Sway bars (92-96)
  174. oil pump swap for crank sensor
  175. balance shafts
  176. Internal to External coil conversion
  177. valve cover question...
  178. Coolant hose quick question.
  179. how do you pull the timing belt sprocket off the crank ?
  180. h22a boring without resleeving???
  181. cams
  182. dummmy question?
  183. h22a4 Timing Help!
  184. getting the rotor out of the distributor
  185. 87 lude wont start
  186. looking for jdm fog light bulbs
  187. Bent valves?
  188. 93 prelude si hesitates at low rpms? Also cruise control question.
  189. h23 clutch problem (searched)
  190. Can anyone recommened a good replacement distributor?
  191. Koni yellow perch
  192. Mugen Chip...
  193. built head questions..
  194. jdm style headlights 4th gen
  195. steering wheel not straight
  196. 92 Swap To H22a4 Startz But boggs out and /or dies when givin gas
  197. Would Tein H.Tech with a .6 inch drop be worth it over stock?
  198. h22a4 turbo
  199. How to remove sunroof seal?
  200. bumper lights?
  201. obd2 h23 blue top into obd1 car.what to expect?
  202. What turbo?
  203. how to change timing belt
  204. Cotter Pin
  205. SRS Problems - need some help please!
  206. Unknown transmission damage
  207. Crazy color to use on bb6!??
  208. HELP! h23 to h22a4
  209. f22 block with different heads?
  210. Quick T.B question?
  211. 4th gen front end swap
  212. Quick question...
  213. my odometer needs work
  214. how many PSI h22a4??
  215. h23 thick headgasket
  216. whats the best drag racing setup for 98 lude?
  217. is a 3rd gen prelude 4x114?
  218. piratemcfred still looking for the adater plate email is maste4269@yahoo.com
  219. searched but pics are down(climate control fix)
  220. looking for a sh to base adapter plate for atts removal?
  221. OIL PUMP HELP
  222. prelude dsm turbo setup
  223. Valve adjustment? h22a4??
  224. Will these fit on a lowered 5th gen?
  225. What type of gas should I use for 4th gen 92 Si?
  226. Battery Drain?
  227. Valve adjustment?
  228. getting the shakes
  229. H23 > H22a2 Swap Problems
  230. Flood car,whats good whats not
  231. won't run
  232. H22A4 PROBLEMSSSS.!!!!! HELP....
  233. paint and lip kit opinions needed please
  234. anyone have a tow hook on their 5th gen?
  235. How reliable would a '97 Prelude with 150k miles be?
  236. 1993 prelude f20a4 engine starting problem
  237. Stock H2B Dyno Results 216/166
  238. Swap F22a1
  239. Primary installed in secondary o2 bung
  240. Best turbo intake manifold for h22
  241. what trans will go on base model h22?
  242. swapping differential h-series vs b-series?????
  243. Summer Turbo Build (Finally Unveiled!!!) H22A-T
  244. f22a intake manifold?
  245. how to change h23a vtec blue top timing belt ?
  246. Electrical problems, need help!
  247. Hytech Twin Loop Muffler Installed * 4TH GEN Review
  248. 98 turbo lude atts unit slipping under load
  249. 1993 Prelude. ELECTRICAL PROBLEM! help!!
  250. 92 prelude fuel rail q
