PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 [193] 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Metal Gasket Breaking In?
  2. Exhuaust diameter question ?
  3. press ruin wheel bearings?
  4. CF trunk lids?
  5. F20B DOHC VTEC
  6. Moonroof Drain Tubes
  7. need help on cams
  8. Interesting: 4gen with peugeot 406 headlights :)
  9. Whats the offset of 97 Prelude rims?
  10. Headlights Dim out...Windshield wipers stall
  11. IAB system and boost
  12. Generic Mechanic Contract for Swap - Opinions Needed
  13. timing belt broke and mechanic said engine is shot
  14. just got my new header from smsp what version is this one?
  15. Radiator trouble help!
  16. New 2 The Prelude and the Wonderful world of tunning...... HELP!
  17. Here is my situation, what would you do?
  18. Some Early #'s
  19. H22 not making power help?!?!
  20. Im getting HOOKEd up
  21. stock flywheel weight
  22. Free Great Gifts***
  23. Odometer
  24. racing
  25. m2b4 transmission info
  26. ARP extended studs
  27. timing belt
  28. Speed meter problem..
  29. !!!Help me help my tranny shift smoother!!!
  30. ULTIMATE CLUTHES FOR DRAGCAR H22?
  31. You happy wit ur HID's?
  32. how R HID's on 5th gen ludes??
  33. gas mileage
  34. looking for info on centrifugal supercharger bracket
  35. CF Hood?
  36. Rough idle, and fuel problem
  37. Rear main oil seal... H22 H23 are they the same
  38. Uprated shocks for '95 Prelude vtec
  39. difference between h22 & h23 (2.2 to 2.3, how?)
  40. 5th gen speaker problem
  41. Wire diagrams for 92 prelude vtec
  42. Part Number Needed/Name of part
  43. Subwoofer in place of Rear Seat
  44. What are the effects of retarded timing?? (Already searched)
  45. Is this an electronic problem or what???
  46. new car
  47. turbo descisions- h22a4
  48. balance shaft removal searched couldn't find
  49. H23A1 Venom Intake Manifold
  50. Plastic Housing Melting???
  51. oem lip
  52. opinion on h22 cams
  53. Falken 502's?
  54. need help on body wrk on a 92 prelude sir
  55. JSP carbon trunk lid for 5th gen???
  56. Are there headers better than DC sports for 97 lude.........
  57. KYB AGX Problem
  58. DIY H22 itbs
  59. having trouble finding performance parts for 3rd gen
  60. What rev should i be driving at
  61. POLL: 4th Gen Ludes Rear Quater Panel Rust
  62. At what point do you upgrade your injectors?
  63. Cats and exhaust
  64. aem fuel rail and its leaking
  65. need perfomanc sway bar
  66. loofa sponge?
  67. JDM Type S header v.s. DC Sport header
  68. neuspeed sp3s will work with...
  69. Omni Power Full Coilovers for a Prelude
  70. H22 head on H23 block?
  71. Skunk2 intake mani ?'s
  72. ISDM 1997 h22a4 ecu?
  73. Replacing rear speaker grille on 92 Lude
  74. Advice on upgrades on my 1996 prelude
  75. Driving impression - 92 Lude SI
  76. H22A OIL PRESSURE?
  77. Do i need to get spring rates for daily driving? ( yes Searched)
  78. BRAKE BOOSTER CHECK VALVE PROBLEM ???
  79. built H22a4 ready for high boost, JE pistons Crower rods
  80. Compression test results...
  81. bypass valve on cold air intake
  82. just finished my HIDS
  83. JUst got my oil test results back... Bad News
  84. Question about H22A(4 I think) oil pressure
  85. h22 question
  86. tire size effects..
  87. Help! Vacuum leak and i need to know how to find it.
  88. Wheel interchangeability among Honda/Acura...
  89. Motul 75W90 tranny oil for 92 Lude SI?
  90. Need a FITV and left front axle for 92 si!!!
  91. i'm having lude trouble, help me out!!!
  92. Clutch pedal adjustment??
  93. Moaning noise as car decelerates.....
  94. Cats and exhaust
  95. My cv boots are cracking!! Buy new ones or rebuild?
  96. nitrous???
  97. Flywheel Timing Marks?
  98. Suspension Question 4th Gen
  99. what yall guys think about straight headers on stock h23
  100. Reverse is BACK in action
  101. About Type-S Pistons and H22A1...
  102. FLOOR MATS??
  103. open loop? ECU codes?
  104. GS-R or Prelude?
  105. Just curious...
  106. What's the exact redline on 92 Lud Si engine?
  107. Will a 92-96 2.2 ltr header bolt up to a 99 sh head? Need INFO ASAP thx.
  108. electrical problem/question
  109. Please Help 2001 SE Prelude wont start when its hot outside
  110. Kamikaze headers
  111. Transmission Options
  112. will a 2 inch gauge fit a 2-1/16 pod properly?
  113. Free iPODS
  114. Difference between Si and VTEC exhausts
  115. Leather Seats for the 5th Gen
  116. california restrictions
  117. great price?
  118. Maintenance Indicator
  119. Radiator Fan??
  120. 4th gen type r spoiler
  121. Wheres the tach output on my h22 4th gen?
  122. valve adjustment questions
  123. Any harm to the tranny if I use heavier oil?? Reg or synthetic?
  124. Slow and eats gas, what do i need to check?
  125. Japanese,Taiwan,Korea,German HID<BETTER?
  126. HID High beams?? answers and opinions needed
  127. wtb 92 prelude shifter boot
  128. Hood pins on a 4th gen
  129. timing belt snapped, read
  130. jdm h23a manifold vaccum hose diagram
  131. Just got some new tires..
  132. Have £10k to spend on my Lude. Tuning, brakes etc. What to do?
  133. Honda lifetime fuel filter? (searched already)
  134. how strong are stock axles?
  135. 92 Honda Prelude SI manual clutch replacement - how much can i expect to spend
  136. crower cam shafts smog legal?
  137. h23 timing belt install??
  138. JDM H22AS come here
  139. dimmer switch 4th gen
  140. Where do you hook up your air/fuel gauge power line in your prelude?
  141. Help! Question about ATTS?
  142. JDM 1 Piece Retro Write-up
  143. Porsche brakes on the prelude
  144. crank position sensor modification for 97 prelude
  145. SPITTING OUT 2ND GEAR
  146. h22 turbo problems need help
  147. No spark
  148. ACT STREETLITE for H22
  149. H22 swap help [PICS]
  150. Which High flow Cat?
  151. Cold air intake?
  152. dimmer switch
  153. which to buy > intake and exhaust
  154. Who wants Prelude Solid Alum front radius arm bushings?
  155. Use vent hose for tranny fluid change??
  156. 92 Prelude Si Idle Problems
  157. Those who has a green 4th gen prelude..
  158. Which h22 is this?
  159. h22 valve spring free lengths?
  160. quick question about mudguards
  161. How to get rid of trial user?
  162. will 95 block match a 97 head and tranny????????
  163. Will civic SI seats fit into a 5th gen
  164. Fidanza or Act pro lite flywheel?
  165. Transmission makes this squel noise
  166. Timing gun question - JDM h22a
  167. injectors
  168. Misfire in #1 Detected... At a loss as to why...
  169. Throttle problem...
  170. JDM digial gauge cluster ...
  171. JDM 1 Piece Headlights Retro-fitted!!
  172. Supercharger Questions? Current Set-up Plan (comments, Q's, advise)
  173. The Prelude magazine articles and reviews thread.
  174. Compression Testing Values? JDM 93 H22A
  175. where is the oil leaking?
  176. H23 vtec with h22 types s oversized pistons
  177. 4th gen Legend Brake Upgrade... Caliper Bracket Question
  178. 98 Lude wont shift into reverse
  179. 4th gen si lude broken into..
  180. Specs on F22A
  181. Open Vacuum ports Okay?
  182. price to pay for brake master cylinder replacement?
  183. Still needing an answer here....
  184. engine rebuild kit
  185. parking lights in headlights, what kind of bulb?
  186. quick coolant bypass question (yes i searched)
  187. What shocks are offered for the TYPE SH models?
  188. Coolant Question
  189. Lude won't start HELP!!!
  190. Question about tires and rotors
  191. 4th gen cat suggestions
  192. axle question
  193. PIC REQUEST: 4300K HID's on a Lude
  194. best place to buy quaife LSD?
  195. The radio is throwing an error 3 code.
  196. The $1500 question ................
  197. why can't 5th gen take out a 98 integra GSR
  198. 2001 sh transmission fit 97 base??
  199. selling car take out mods?
  200. Heatshield for POD filters....which design stops HOT AIR ??
  201. what kind of tires on 17s on a 5th gen
  202. builing a rail buggy w/ a '92-'95 h22A1 motor
  203. Question about Greddy header and the cat on 97 SH...
  204. New Idea for the Throttle Body Helix OBX Spacer
  205. To all with a Mugen header...
  206. JDM Honda Prelude Type S 220HP Piston
  207. ATTS / check engine light on after new exhaust install
  208. head gasket layer
  209. Speedo and rev-needle jumps when turning the key
  210. Massive Drop and Wheel Alignment
  211. 5th Gen Mugen Prelude Poster
  212. rwd better than fwd?
  213. will GSR spark plugs work in my h22?
  214. H23 crunk shaft bearing filure.
  215. H22a lsd tranny/H23a Vtec Engine
  216. how do i adjust vtec on V-AFC2?
  217. h22a4 brearings
  218. who did i buy that h23 from!
  219. Strange noise/vibration thingy.... need help!!
  220. What type of engine oil to use on 155k 92 Lude?
  221. 89 prelude suspension question?
  222. Bogging Issue H22 please help!
  223. Thinking about buying theft recovery prelude
  224. Idle problems? no vacuum leak!!
  225. Prelude 5 speed tranny weaknesses?
  226. Just Installed -> Kenwood KDC 7011 (discontinued) + Infinity Reference 6002i 6.5"
  227. quality of seibon cf hoods for ludes??
  228. my 4th gen for a 3rd gen lude
  229. 4ws Light
  230. few questions about OBD2 1996 Prelude VTEC's
  231. OEM front lip part number
  232. JDM black housing headlights?
  233. H22 bogging/misfiring question
  234. SH transmission
  235. Wheel Hop
  236. ABS Light, no code...
  237. a/f guage full rich, black smoke at idle? HELP
  238. changing vtec crossover piont
  239. ***5th gen recall***
  240. Front Camber Kits
  241. Need help hooking up my vtec controller please help
  242. cracked radiator
  243. Resetting ECU
  244. 17" TenzoR Mean-6 & Eibach coil-overs 4sale
  245. 4th Gen JDM Foglights
  246. LSD Tranny
  247. Problems With Turbo SH
  248. rods in the trunk (whats the name?)
  249. greddy oil filter block adapter
  250. h23a spects plz
