View Full Version : Honda Prelude
- mugen bucket seat, any experiences?
- 3rd gen H22 swap EGR issues...
- Cleaning air filter
- Electrical boxes in trunk...can they come out?
- Can you put a USDM Distributor on a JDM H22A motor?
- Honda Prelude vtec 1995 upgrade advice
- Meshing OBD I to OBD II
- 97 Prelude Lips??
- cf quick question
- Help with idle problems
- Will Accord throttle body fit H22?
- damn problem prelude!
- 4th gen prelude (pics)
- BAR certified h22?
- Will accord or 5th gen axles fit?
- fuel pressure regulators
- Penzoil Synchromesh
- hoada canada warrenty on tranny
- Please help!! H22 auto problem Please Read!!!
- Exhaust for 5th gen
- troubleshooting turbo prelude....
- tuning of VAFCII
- which SH pads?
- MOMO hub?
- SH + Snow
- Rattle in engine bay around 1800 rpm
- 5th gen headlights?
- How much mileage do you get out of ur lude?
- motor acting funny
- Width betwen front wheels, is the 5G wider than 4G?
- question about ECU
- Question about 5th gen projectors
- jdm sidemarkers?
- its that time of the year
- Installing Deck/CD player on 4th gen
- startup problem
- how do u set your vtec engagement?
- HorsePower from balance shaft belt
- is sleeving necessary?
- 97+ Projector lights?
- does h22a jdm p13 runs richer when mods added?
- p13 and p28 questions...
- wen tto the track for the 1st time in a LONG time
- stock wheel weight?
- few things i wanna ask
- Flooded car...water, not fuel
- HELP NEED PARTS EG H22 SWAP
- turning on headlights drops idle?
- bad relay?
- H22a1 idle problems
- 3rd Gen Engine Swaps?
- No spark No fuel
- adjusting JDM Blk 1 pc Headlights. how do i get it done got 4 adjustments ?? Help !!
- f22-h22
- ECU Fuse
- New OEM wheels...worth it?
- How do you tell a JDM H22A from a USDM H22A? (I hope this is not a stupid question)
- Prelude rims
- Can someone give a definate answer please?
- removing hanger arm rubber bushings
- is it possable to put a s2000 gauge cluster in a prelude
- New Mahle Piston?
- Prelude Intermediate Shaft
- h22: dry or wet kit
- ATS!!! make something for the Prelude!!! (finaldrive)
- question about energy suspension master bushing set 4th gen
- are the obx stage 2 came any good????
- Prelude wirings..
- New help on JDM Fogs
- h22 intake manifold?
- got new axle
- CANT GET OUT 02 SPECIAL TOOL OR WHAT SIZE WRENTCH
- Hondata H23 gasket
- Early Stages of Autotensioner Failure?
- Traction vs wheel size
- Anyone else having Window molding trouble along both doors?
- how to adjust manual tensioner in h22
- does anyone sell airbag tray's out for 5th gen prelude
- Can I get away with just changing my rings????
- where should i do my 60k service on my 98SH
- H22 timing
- Throwing code 61
- type s piston with s/c
- AEM Cam Gears
- Factory Warranty Question & Rear Veiw Mirror Question
- kteller h23 header
- 92 lude givin me trouble
- is it my ecu or wire harness
- What kind of problems should I look for when getting a 4th gen Prelude?
- Slight coolant leak problem
- Anyone fabricate brake ducts for their Preludes?? Pref. 4th Gens
- h23 manual tensioner conversion belt adjustments
- Prelude SH aftermarket midpipe?
- 98 sh tires?
- what rpm you at?
- O2 sensors , should they be replaced alongside a shot cat converter?
- Rooling Road results !
- Rusted lugs...
- 4th gen P28 or P72
- 4th gen EMS advice
- steering wheel lock colum
- Weird gurgling noise coming from engine bay...help!
- please help with h23a1
- Winter tires on oem rimz (205/55 r15) found very little (3 to be exact)
- rod bolts
- I NEED 5TH GEN HELP! PLEASSSE!!
- Is this a good coilover kit?
- Carbon fiber.
- stall converter
- suggestions
- jdm climate control mod
- oil pan gasket
- 5th gen Prelude: will 205 55 R16 tires fitt (stock is 205 50) R16
- CODE 3?? Manifold Absolute Pressure Signal
- guess what was wrong with my prelude
- Prelude Question?
- Weird Brakes system help!
- H22 vtec pres. switch location?
- atts light still coming on....
- H22 Euro R... What Aftermarket FPR do i use???
- h22a type-s
- Whining noise from 5th gen
- h22 long or small journal
- what is the pipe called before the cat converter?
- Left headlight keeps goin out every 2 or so months????
- h23 with usdm h22 pistons...tuning?
- Raybrig lights?
- Top speed of stock gears 5th Gen
- Energy Suspension and 5th Gens
- Are 92-96 H22 rear Calipers the same as 92-96 H23 rear Calipers?
- will not go in reverse
- OBX CAMSHAFTS FOR JDM H22... good or bad?
- Need Help
- H22 Secondaries
- Help!:: How to tell when an h23/h22 is gonna take a dump? (main bearings, etc)
- Hood Spoiler
- JDM TPS sensor and TB question
- Katana VR-6 or Tenzo-R Mean-6 for my 4th gen???
- Legend/Prelude Banjo Bolt
- base or sh
- h22a1 automatic 1/4 mile times?
- driving with torn boot
- Skunk 2 camgears
- Si Models after 96?
- Power Locks fuse issue
- vacuum hoses....where to buy hose for h22?
- SH block with all other base model components
- prelude tires
- Does anyone have the Hytech Twinloop as a muffler with their setup? Including pics?
- Prob with 5th Gen lude
- Prelude SH acronym
- NGK wires making contact with hood...anyone else?
- ya i'm a newbie
- all prelude sites
- '95 VTEC popping out of 2nd gear...
- can i do it myself
- H22A ecu Question
- JDM H22a Transmission
- How to know my car is in prime running condition.
- 370!!?!?!?
- ecu vtec engagements
- Intake manifold....Golden Eagle or STR
- Torn CV boot question
- h22 and h23 mounting
- hesitation/idle problems
- Random misfire on cylinder 2
- oil leaks?!?!? familiar?
- h22 swap price given to me
- egr valve block off.. IS aluminum can strong enough?
- HELP!!! HYDRA-LOCKED!!! =(***
- Valvetrain upgrade...
- Building motor for boost, your suggestions please.
- will OEM LSD work in m2a4 tranny (h22a tranny)
- Center console's lil tray held on by what?
- hood, bumper..ect
- Gold Prelude on Long Island?
- Interior dash
- air/fuel ?
- ALOT of hessitation when cold, and fluctuating idle when warm???
- question about interior dash
- AEBS sleeves in CA
- rhd 97- prelude front cut
- will this sensor work?
- stock prelude springs...which is front/rear?
- euro h22 and american h22 motor parts
- Questions about a cv joint...
- .: Mobil 1 Synthetic Oil :.
- Whats the difference between JDM front lip and stock , 5th Gen
- axle back greddy evo
- help please
- Rewireing foglights
- Please help... headlights went out on freeway
- Opinions wanted - Deal gone sour
- H1 HID Kit.
- My project block came in...
- swap issues
- What could kill torque?
- h23 custom headers
- is the h22 worth it
- Simple formula to help choose a tire size
- shrilling noise after replacing tensioner. HELP!
- Turbo after turbo or twin turbo I guess
- The "How can I make my Prelude Lighter" Thread
- mugen rear bumper things???
- Shrilling sound after tensioner replacement, HELP!
- What is the most mileage seen out of a 5th Gen
- checking the igniter
- Trans question
- How do i remove my o2 sensor??
- oil leak. Why has this happened to anyone Please Help
- 168 whp on the dyno. is that low with these mods
- ecu p72 p28...
- Need help with clutch install in the OC.
- question about gauge cluster bulbs
- where to buy a jdm m2a4 fifth gear???????
- Got my F20b in.... whats wrong
- LOOKING AT GETING MORE POWER OUT OF MY 01 LUDE
- Changed Ignitor to solve starting issues?
- Has anyone seen the switch case for the 5th gen ?
- Prelude engine idle problem after missed shift
- h23 over sized head gasket
- Whats your ground clearance..mine 2.5 only, help
- Rear Brakes for 4th Gen.
- Fuel Pump question?
- How much for a blown H22???
- H22A Cambelt Service - Doesn't feel right
- what ecu do i have?? 93 sr-v
- front quarterly lining Z3
- JDM CLIMATE CONTORL
- H4 Xenon COnversion healight for 88-91 prelude
- imobolizer system
- AEM fuel filter install
- Where can you get decent priced JDM one peice headlights besides ebay?
- how heavy is the h22.
- Having lots of problems with 88 2.0 S
- is there a shop where i can get an h23 vtec built
- Anyone know any good detailer in SoCal(OC)?
- bb6 prelude 5th gen type s cams
- would sh timing belt work for type s
- have a not so tech question?
- prelude si's and brembo blanks
- Lowering 1995 Prelude
- Gear knobs & broomsticks
- I cant find a type s distributor cap and rotor.
- Why you should solder and tape/heatshrink your connections
- how to cut off my governor
- Dynoed today...
- JDM ecu
- H22 and H23a difference
