View Full Version : Honda Prelude
- Top Speed Limiter HELP!!!
- Bleeding the coolant
- my h23 vtec all motor build
- H22a
- people with lip kit, i have a question
- o2 sensor help
- Leakdown Results
- Oil consumption - rings vs. valves
- some advice for the noob...
- will a h23 oil pan fit a h22a?
- Iacv Plumbing (Searched)
- Head swapping on H22A
- overrevved and...
- Fender Question
- camber kit for 92 prelude
- best tranny for H22A
- 4th gen rad support
- some questions about clutch
- Turn Signals
- Wet vs Dry Nitrous
- 5th gear pops out?
- Best ECU
- zr header off ebay for my prelude
- what is the difference between CAI and short ram?
- '94 Prelude swerve under braking
- UPDATE: Of the 95 Prelude Accident. This is the main and final post of the topic. Need your advice.
- Knock Sensor / Throttle Question
- obd2 to obd1 ( yea im sorry)
- Erratic clutch operation
- jdm bb6 bumper
- pics: koni + eibach sportlines
- nsx calipers
- 00 prelude camber question
- gas pedal sticks
- ATTS control unit install
- where is thermostat? h22a
- 5th Gen JRSC exhaust question.
- Car rev's itself while air conditonor is on??? Plus more
- jerky acceleration
- Bolts on Cat Converter are rusted on WD40 nothing help
- clutch parts need help
- whos running Eibach pro kit?
- h22 high compression turbo questions
- Grinding, kicks out of gear.
- CEL Code 6: ECT - JDM don't have them?!?!
- h22 alternator tensioner bolt part number
- Tuning an SH
- apexi Vafc wiring???99 lude
- Reinstalling/reinstalling timing belt with auto tensioner
- CHANGE PRELUDE BOLT PATTERN FROM 4x114.3 to 4x100???
- 95 Prelude accident!!! Need your advice.
- Gasket Sealant
- Problems with starting.
- Dumb Question
- Need recomendatio for a coolant stop leak solution
- h22a oil port question?
- Is there a diff between 97+ injectors vs. 92-96?
- Tranny Swap
- Car died while driving...refuses to start. Please Help!!
- just bought a prelude and i have a couple q's
- What parts will I need to convert my H22 to run OBD2?
- (4gen) lights fade...almost flicker....
- anybody use an autopower roll bar?
- VTEC H22A overheating problem
- springs and shocks 4thgen ----> 5thgen
- towing with a prelude (realalisticly)
- auto 98 Prelude tranny
- '94 Prelude Manual Transmission Oil Question
- '94 Prelude Timing Belt Change Info
- SMSP header on and Bisimoto Tuned.
- saving of bottom end
- Greddy Evo2 US-spec
- what is the best exhaust system for 5th generation prelude?
- IACV: safe to just unplug?
- h22 chokes!!!! HHHHEEEELLLPPPP!!!!!!!!!!!
- Apexi VFC Install
- egr and skunk2 intake manifold!!
- short throw shifter or short throw adapter
- Coolant overflow
- Need help installing stock stereo to 97 prelude
- a few questions for a friends h22
- ITB's
- My 570whp H23a1 Set-up by AV Engineering
- Strange loss of power with h22
- Whining noise near valve cover
- Final drive
- Looking to paint my Apexi WSP2 exhaust
- 1990 Prelude 2.1 couple questions
- Catalytic Converter problem?
- New Paintjob! Help me find the right shade of red...
- need help starting 98 prelude with 95 motor
- Removal of intake control solenoid valve and capping vacuum line
- WANTED: 5gen driver near Tempe/Chandler, AZ - mod approved
- doorpanel parts (clips,) where is this part?
- Turbo not working right
- Question About Air Intake Hoses
- EGR Flow
- car won't start
- what can i do to my prelude to git going faster
- Knock sensor (again)
- h23 header w/ h22 exhaust???????
- balancer shaft belt or your Accesory Belts too tight..
- a 5 speedTAKATA GREEN!!
- gear ratios
- Ever had a bent crank?
- Connector ? Dont know what its for ?
- Flywheel Marks to set Timing on 92 Prelude
- Progress Swaybar
- starter
- Pro series stage1 cams VTEC activation point
- difference in axles?
- Shifting Problem
- 37820-P13-N50
- 1986 prelude help
- need some help!! TimingBelt, water pump, tensioner
- 92 rear interior - 94-96 rear interior? //// Engine Overheating?
- what year thermostat/coolant switch?
- over heat? help please
- JDM Type-R seats in BB6
- 5th gen radio in 4th gen?
- JDM 1pc's. (write up, parts, etc) thx for help.
- Need help quick pls, no power and lotsa bogging
- What is the normal water temp?
- Distributor question for anyone that has taken one apart
- Seatbelts not retracting
- im new to preludes and have a couple question
- GM Manual Trans. Fluid?
- Koyo radiator help
- middle rocker arm wear?
- How much would a shop generally charge to install all new suspension bushings on a 97 SH?
- I NEED SOME HELP WITH MY 94 HONDA PRELUDE T3T4 TURBOED
- Valve tap, or something else? Video Inside.
- just got a 2000 prelude sh what to upgrade frist
- Jdm h22a distributor cap
- what is adjusting your camgears do for you
- NEW suspension for the lude
- Hoping for an answer asap ... noise coming from valve cover.
- Question about oil filter location.......
- kteller race header ?
- my 97+ prelude wont start cold?
- secondary timing belt on h22
- steering wheel shaking at high speed
- CEL code write-up
- weard cold idle?
- hi guys
- vaccuum diagram for 5th gen
- No power to the fuel pump!!!
- CEL code 9
- mah prelude is smokin!!!!!!
- About to buy a 2001 Type SH tomorrow? Need some help
- Weard, dont know if its a tech Q
- Aftermarket steering wheel fitment
- spudering at low rpms
- iab kicking in !!! stuck
- search already but needs clarification spoon calipers on prelude si brakes 1992 needs help?
- 93 jdm h22a w/aftermarket flywheel
- iab ground or positive signal
- Bogging issue getting worse. Searched.
- speedometer needle stickin
- so i have another problem with my 3rd gen
- Little Bit of Help?
- ABS Light
- front lip for 4th gen & short shifter
- carbon fiber hood? hood pins or no hood pins???
- price for a usdm h22
- Tourqe settings for aftermerket headers
- 90-91 prelude si potential
- 89 prelude crash test?
- Greddy Header Opinions
- need a vac line diagram for an 86
- Fuel Rail & injector question?
- clutch problems
- JDM power folding mirror not working anymore!
- 97 Prelude SH : Tein S-Tech's back to OEM ... how?
- msd 6A
- My car will not idle or accelerate. just dies :(
- ECU question PLEASE HELP
- speedometer problem
- h22 motor spec question. PLEASE HELP ME
- H22A LSD Problem
- How do I check the check engine light (2000)
- Code 45 off with fuel injector cleaner?
- oxygen sensor wireing
- H22a running on only 2 cylinders
- iab solenoid
- car having trouble starting (cold)
- how do i stop beeping sound
- Skunk Manifold and 70mm TB..Which ECU??
- TB spacer
- One step colder plug ?
- H22 Transmission Issues
- Questions About Swaps and Exhaust
- got me a set of SSR Type-Cs... need your opinion on an idea for them
- Parts Wanted
- climate control? please help
- will these rims...
- squeaking sound when i turn steering wheel
- bb6 parts for sale
- Runnin rich? how?
- type s motor in an SH?
- h23a turbo on 5-7 psi
- How often are you guys changing your oil?
- HOOD DAMPERS FOR A 93 Lude?
- 5th gen manual to automatic ecu conversion question
- Vtec problem!!! help
- 4g h22a swap downpipe problem
- wheel hop, how do you eliminate it?
- My damn car failed a smog test.
- prelude distributer problems
- Vacuum Source For Vacuum Board
- help: air/fuel gauge setup
- 5th gen short shifter
- wheel offset question
- getting too much spark...
- Head Gasket Question
- how can i tell which is type s cams?
- Idle Problem?? ---------motor perfect though...------
- how bad can it be?
- Headlight / Lightbulb problem....(ghosts)
- Installing Exhaust
- ATTS Filter
- Possessed Fan?
- brakes hitting the floor......wtf
- 98 prelude auto Tranny to 97 manual tranny swap questions
- Power Steering Rack Misbehaving
- 1995 Honda Prelude vtec Preformance
- BB turns over wont start D4 flashing speedo bouncing
- replacing AC compressor
- Clutch Squeal - Recently Replaced
- Lsd or not
- Wheel bolt snapped
- h23 obdI vs obd II
- HELP- 96 Prelude S model has an alarm going off!! I don't even have an alarm on it.
- h22 stock injectors
- Squeaking from passenger wheel area... when turning
- How do you adjust the RPM needle on a manual 97 prelude?
- OMG
- Rpm Needle shakes past 5k
- Motor mounts upgrade. What's best out there?
- Rallying Spring Rates
- Clutch Disc
- Engine stumble when radiator fans turn on
- open door....light comes on ..... beep, beep, beep?
- Stalling when coming to stop
- Question regarding my clutch.
- 2.5" exhaust ?
- Pulling out CELs on a 96 Prelude OBD1
- some OEM parts # questions, etc etc
- VTEC problem (built turbo H22A4)
- p14 pinout....help PLEASE!
