PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 [68] 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Balance Shaft Seal Part Number
  2. cant find
  3. intake manifold question???
  4. just wondering on a H22
  5. Need Help With CEL's
  6. KAIZENSPEED's billet aluminum spacer NOT steel anymore!
  7. H22a piston weight
  8. b18 in a 91 lude
  9. 5th Gen: Speaker Depths?
  10. help!!!!
  11. How to: Install a Wet Nitrous Kit
  12. Trouble With Axle... please H-E-L-P
  13. 2000 bb6 waterpump and crankshaft pulley
  14. piston to valve clearance
  15. EGR valve Question - Heeelp!
  16. moon roof 4 gen
  17. F20A Camshaft ID
  18. Blackstone oil analysis: bad bearings. Now what?
  19. Crower stage 2 cam with stock idle lobe and skunk2 valve train?
  20. Eibach Pro Kit w/Koni Sport - question
  21. compression test
  22. Car Stalls For no Reason
  23. Throttle body spacers good or bad. More power or dont do sh1t
  24. How can I clean the exhaust ports?
  25. Worn CV Shafts, and question about rate of wear
  26. 5th gen. Taking out back seats?
  27. I Need Help With My Brake Lamp Light is On.....
  28. misfiring on #3
  29. gear ratios for h22
  30. usdm climate control wiring question
  31. What is more reliable?
  32. ABS light on
  33. Prelude suspension spring rates
  34. 3rd gen prelude 4WS
  35. CV Joint....
  36. no reverse....HELP
  37. fuel problem
  38. JDM prelude shops!
  39. Type S swap
  40. Does Kelly Blue Book price preludes right?
  41. how to know if airbags have deployed before???
  42. 97 Prelude with JDM OBD1 H22A, run fine 1 year. Took it to Honda now I am getting Code 4!
  43. What are my options
  44. removing/ swapping h23 h22 prelude 4th gen 94 95 quick question pls help
  45. Gen V low oil pressure light at idle and tapping sound under power.
  46. Lowered 1.8'' Very bumpy.....
  47. F22 HELP!!!
  48. installing shocks
  49. got my build done but a few problems
  50. green flashing light on shift coumn indicator on dash please help
  51. Pace Setter Exhaust?
  52. I cant go into any gear...help!!
  53. H23/H22 Gearset Measurements
  54. Euro R accord vs Accord SiR and SiR-T
  55. Questions on 2000 SH transmission.
  56. how to turn check engine light off!?!?
  57. ECU fuse keeps blowing!!!!!! HELP!!!
  58. boosted prelude = a problem :(
  59. H23 Accord SiR Motor
  60. Ring gear / vss / speedo Qs
  61. h22a manifold
  62. Map sensor problem and idle is bad!
  63. Oil leak..
  64. Sunroof Noise
  65. New pressure plate install problem
  66. Trans fluid
  67. Replacing control arms and ball joints
  68. master cylinder bad
  69. ok very quick question about offset
  70. Is it always necessary...
  71. need new oem oil pan for 98 lude
  72. trying to figure out which turbo setup to go with for h22
  73. 4gen to 5th gen interior
  74. steering problem
  75. Throw Out Bearing screaming, Transmission smoking!
  76. Quick question about tuning a P28 with h23 basemap (differances between P14/P13 Maps)
  77. atts light and water leeking in?
  78. Tie rod replacement
  79. pnp hid kit
  80. Prelude transmission help
  81. EDM rear foglight in prelude? and are they legal?
  82. JDM H22 engine getting hot lately
  83. Custom door speaker pods for 5thgen
  84. RPM surging after installing throttle body spacer
  85. stripped oil pan
  86. removing rear seats in 5th gen
  87. "Turbo"
  88. ESP Strut Bar
  89. Type SH?
  90. stripped oil pan; leaking
  91. 95 prelude vtec non vtec to vtec wiring diagram
  92. nitrous questions
  93. Strange H22 OBD1 Problems. Any help!?
  94. H23/H22 help
  95. Car doesn't start now....
  96. I want a safe rev limit
  97. 2000 Prelude Burning,Smell,Power Steering
  98. Idle/Timing Prblem?
  99. Power Steering Line Repair
  100. piston install help
  101. Car dies in VTEC....
  102. 5th Gen Auto to Manual Swap
  103. Need some help
  104. state inspection
  105. pulled CELs from my h22. help to verify problems
  106. What AC/Alternator belt to use???
  107. Question about The Mantenance Light
  108. inner cv joint??? need help!!!
  109. 5th Gen - Vibration coming from front passenger side tire - RPM related - just replaced axles
  110. some head noise
  111. H23a1 Turbo help
  112. Boost an F22???
  113. "how to correct timing for dummies"
  114. 1990 Prelude Si
  115. Prelude valves
  116. 5th Generation Prelude Motor Swap
  117. bayareaprelude.com
  118. help please! I need to replace prelude si exhaust downpipe
  119. Limp Mode ECU
  120. anybody got pix of slipstreams on a 5th gen?
  121. Jdm
  122. Brakes!
  123. crower
  124. knock sensor
  125. How are your Koni Yellows set?
  126. oil dissapearing?
  127. Yet another iacv Question!
  128. Bolt ons for h22a1
  129. conversions
  130. Is Exedy Stage 1 clutch good for my stock motor???
  131. PVC Valve
  132. F23 swap while keeping H22 trans - possible?
  133. Manifold removal help please!
  134. Radius rod nut size
  135. to trust
  136. wierd clutch problem with 97 SH
  137. ive search seriously i just have to make sure!!! vacume leake question
  138. Civic Style Radiator
  139. Eibach pro system, shocks+springs
  140. need to know how to wire a distributor!!!
  141. How To: JDM Dizzy Swap From USDM
  142. 98 lude transmission rebuild trouble
  143. h22a1 manifold
  144. A Few Quick Questions
  145. alternater belt is scraping against the bottom of thetiming belt cover
  146. h22 in my civic. need help from the lude dudes.oil pressure
  147. check engine code 22
  148. engine swap
  149. Blown Enging 98 Lude
  150. Car dies out when throttle is opened.
  151. Engine Error code 12, 4ws code 62 help please!
  152. idk what 2 do??????
  153. Gc coilovers stuck!
  154. 95 Prelude V-tec swap dtc 36
  155. small light fuse blown...sum1 plez help
  156. please help still no spark
  157. 93-96 Coil wire vs 97-01 Coil wire?
  158. Overheating question
  159. Losing weight
  160. dumb noob h23 ques. ( i checked FAQ)
  161. LCA balljoint- thread pitch
  162. 18" wheels on a 93 prelude
  163. 95 nsx wheels on a 5th gen?
  164. h22 bottom end question
  165. h22 dizzy on a h23 will it work?
  166. Radiator options.
  167. ECU 98 Type SH
  168. h22 injectors
  169. polished SH wheels
  170. Hesitant idle
  171. Want info on the valve adjjustment sequence for a 1992 honda prelude
  172. prelude vacuum digram
  173. What Timing Belt I need to use for Jdm F22b Dohc.
  174. Honda prices help
  175. h22 header bolts size
  176. Where to find Torque specs and piston ring gapping?
  177. 94 prelude warm up issues
  178. Swap into 5th Gen Q's.......K swap or New H22?
  179. 4th gen idle problems
  180. CEL 80?
  181. 4th gen antenna mast...removal tool?
  182. h23 carb exemt turbo non existant? jackson racing supercharger non existant also?
  183. My ANTENNA is making a funny noise....
  184. ngk wires
  185. question about wire harness
  186. sri noise
  187. needs to ask a dumb question
  188. Wont go into gear.
  189. intake manifold porting
  190. Clutch Pedal Stuck!!! Tried Bleeding 5 times but failed...Any Clues?
  191. 94 honda prelude ABS lights on
  192. AEM wideband wiring to control Hondata s300
  193. performance rad caps
  194. Oil cooler line.
  195. No spark, no fuel, no CEL codes...on obd-1 jdm h22a.
  196. Need help about turbo header
  197. H22 crazy
  198. please help no spark
  199. Wanting to use h22a distributor on h22a motor+h23a harness.
  200. New guy here
  201. h22a power loss.
  202. how to tell what injector goes to what engine....
  203. sidemarker position help, 99 prelude
  204. Quick Question
  205. Front Lip options:
  206. Prelude 4G with a 5G H22 (total swap with harness)
  207. Anyone seen a 4th gen - > 5th gen front conversion?
  208. ANYONE know of a egual length turbo mani that retains A/C + P/S???
  209. 4th gen OEM seat covers(black)
  210. Master brake cylinder and Idle problem
  211. Shorted VTEC Solenoid/Pressure Switch
  212. Gauge mount locations - Post pictures
  213. short shift
  214. Strange h22 idle issue and tps related question.
  215. How heavy...
  216. 86 lude swap help (1.8 carb)
  217. 5th gen shifting problem
  218. Suggestions, please?
  219. Is H2B worth it ??
  220. Since I received help, I thought I'd return the favor... INFO HERE
  221. Car will turn over but won't start after motor install....completely stumped.
  222. Skunk2 Camshafts Pro 1 or Stage 1 tuner series - Here is the Answer!
  223. NEED YOUR OPINION....prelude or integra?
  224. H22 Turbo Manifold
  225. tein S tech springs on the lude
  226. 4th Gen fuel pump not turning on.
  227. Has anyone bought the EBay Roof Spoiler Wing
  228. GOODBYE TO THE PRELUDE
  229. DC header drama!
  230. header question!!
  231. POWERSLOT BIG BRAKE KIT
  232. Manual Tensioner bracket question
  233. what is this?
  234. need to get this thing on the road~!~!~!~!
  235. motor mounts
  236. Question on Vtec Solenoid
  237. Tranny leakage (weld?)
  238. h22 ATTS removal adapters...
  239. 2000 sh with a 97 base engine
  240. Going back to stock motor mounts.
  241. 225/45/17, 17x7.5 rims on 5th gen
  242. 5th Generation Prelude Motor Swap
  243. Headgasket for .25 OS pistons
  244. Bouncy VTEC on Tach
  245. Quick Q. re: DC Sports header
  246. Front Upper Ball Joint Questions
  247. any help to find aftermarket parts for 1988 prelude
  248. Car shut off going down hill
  249. h22 boggin down until 3000 rpms
  250. M2B4 Axle Length ?
