PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 [87] 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. fuel pump and main relay shortage
  2. Are H22A H22A1 and H22A2 heads the same except for the JDM cams in the H22A?
  3. H22A4 with S2000 oil filter
  4. problem 911 help!!!!!!! timing belt problem
  5. D.I.Y. C.A.I.
  6. s300 vs emanage ultimate
  7. prelude computer codes
  8. Key won't budge
  9. change brake pads?
  10. H22 want idle!! IAC??
  11. 96 Prelude Knock Sensor
  12. Does Honda have a suspension bushing kit?
  13. H23a Vtec ( JDM ) questions
  14. Vtech Solenoid
  15. H23A...No Mods....What to do?....
  16. WTB:: VTEC solenoid
  17. emergency help im off the freeway on my sidekick
  18. Need Electrical Help
  19. Home made ITB's For H22A
  20. My car cuts out when I...
  21. Best method of installing kill switch??
  22. Accessing rear lower balljoint
  23. Explicit Performance Header
  24. 86 prelude si motor swap
  25. Confused about vacuum on IM
  26. Head lights
  27. WTB H22a4 Shortblock
  28. my 97 prelude randomly cuts out while driving?????????
  29. question...
  30. Weird Switch
  31. H22a Problem HELP!!!
  32. How can I fix my EGR ports....
  33. wats my best bet?
  34. Battery help for 5th Gen
  35. EGR Cleaning ports
  36. looking for H22a Turbo Base Map Crome P28 or even Hondata S300?
  37. chipping...
  38. AEM EMS base map 00 prelude
  39. Tires for 17x7.5 wheel
  40. Will 17X8 and 17X9 fit??
  41. "OEM rear window spoiler" ... ????... WTFm8? link inside
  42. What can cause vibration during idel?
  43. ATTN: Cali prelude owners FREE greddy exhaust
  44. question
  45. Uneven brake-pad wear: freezing caliper?
  46. Injen Headers
  47. h22 No Vtec Oil Pressure Switch??
  48. Valve Seals
  49. Tire speed rating for Gen 4, and brand, help
  50. How corrosive is brake fluid?
  51. question
  52. reading prelude codes
  53. M2B4 Prelude Transmission
  54. 4th Gen Springs!
  55. Crappy track results (JRSC)
  56. H22 swap using a H23 wiring??
  57. anyone using crower cams??
  58. Interior Work? Anyone have any ideas or pics?
  59. quench on the H22 head??
  60. prelude h22 build in progress suggestions
  61. smoking taillights
  62. 1 pc lights
  63. timing belt
  64. Late night headlight help please!
  65. 91 VSS location
  66. need help on converting a 92 h23 automatic harness to a stick harness
  67. Good cam/valvetrain reading material?
  68. 92-96 honda prelude parts
  69. 6 speed tranny ?
  70. BEST... n/a cat exhaust
  71. header collector
  72. Pulling apart OEM headgasket
  73. Howdy
  74. ARP head stud install
  75. What should i know to change starter
  76. how much should typical fiberglass side skirts weight each?
  77. distrib cap question
  78. Clutch pedal assembly issues
  79. 97 base prelude head replacement
  80. need help my brother's prelude died!!!!!!!!!!!!!! ASAP!!!!!!!!!!!!!!
  81. Wheel Question
  82. Power Steering Foaming...
  83. 98 SH Prelude shakes when taking off in 1st
  84. timing belt whine
  85. h23 plugs flooding wont start
  86. Brake question
  87. Installing RSX Type S Tranny in 4th gen lude?
  88. is there a switched 12v on the fusebox?
  89. Please Focus
  90. Carbon F Interior
  91. Greddy Apexi Or Skunk or Mugan
  92. JDM P13 ECU PINOUTS
  93. H22 best TRANNYS
  94. my car idles NASTY!!
  95. H22 Lifespan??
  96. ignition conversion ?
  97. fuel pressure regulator
  98. Strange sound
  99. Thermostat Replacement
  100. M2U4
  101. Lowering Negative Camber Can Be Corrected By A Camber Kit? Please Help. Thanks
  102. 5th gen rad cooling plates
  103. Can i please get some help?
  104. h22 head torque specs-why is this so hard to find?
  105. timing issues *searched*
  106. Antiseize on Axle splines and nut
  107. strut replacement
  108. are the any interweb forums secific to 5th gen ludes?
  109. Ported Head part 2
  110. Anybody know where this goes on a h23?
  111. Lude wont start. HalP!
  112. water in trunk
  113. oil pump interchange?
  114. antenna not retracting all the way down
  115. A/C kicking off
  116. this isn't the stock OEM shift knob for the ludes is it?
  117. what is the wire under the driver seat for?
  118. Picture Request
  119. How to search HT through google (since search is down)
  120. compression test problems. search is down.
  121. 2001 Prelude Radio Code
  122. Help needed, New Clutch and Flywheel but still slipping
  123. Oil leak
  124. PICTURE REQUEST 5th gen with SP2
  125. Need Assitance, would be appreciated
  126. Oem fender and hood cost
  127. H22 ECU upgrade Question.
  128. I am turboing my H22 Prelude, I have some ?'s!!! Please help
  129. How big is the opening on h22 IM's?
  130. Speedometer probs
  131. Need some suggestions on upper end setup. h22a
  132. idle issues
  133. A'pexi AFC NEO
  134. Looking for opinions on Action clutches in a DD
  135. Upper ball joints
  136. hood gas shocks?
  137. in dash gauge thread, where?
  138. Front Grille
  139. 5th generation Suspension problems after lowering....
  140. How do i Get a spare key made?
  141. type s pistons in my stock h22a
  142. clutch???
  143. cant figure ouut how to install my speaker :/
  144. 88 prelude 2 02 sensors, why?
  145. H22a head casting number
  146. 4th gen civic radiator question
  147. Smoking??
  148. Car hesitates on Acceleration. Dont flame, Search is down.
  149. DIZZY QUESTION!
  150. fuel pump problem
  151. Torque spec on sway bar end links and bushing?
  152. H22 SWAP HELP!!!
  153. car stereo pronlems.....
  154. How to read code for CEL?
  155. SH question
  156. headlights turn on intermitently.
  157. 1992 2.2 JDM VTEC - AA Man says snapped timing belt but sounds like chain
  158. Anyone considered a custom clutch system setup?
  159. New Prelude
  160. H22a Build Question- Bad Dizzy i think?
  161. All JDM H22a rated at 200 ps?
  162. 5th gen bad auto tranny
  163. H22 with Nitrous, good idea?????????
  164. alot of miles
  165. clutch recomendations
  166. 92 prelude si vtec conversion
  167. just wondering about chassis code
  168. greddy evo 2
  169. Cleaning pistons carbon buildup
  170. water in engine or exhaust
  171. My driver side window doesn’t close all the way.
  172. my headlight bulbs keep on blowing....help please
  173. H22... need help wiring OBD1 Distributor
  174. Dash Light!!!
  175. Question about oem side skirts and bumper.. Please help! Prelude Sh
  176. A/C
  177. SH-> Base conversion
  178. Can the accord NRG TQ Damp. be modified for a 5th gen?
  179. Machining Flywheel
  180. Idle problems with A/C operation
  181. ecu problems for h22
  182. Dasg Gauges
  183. speedometer problem
  184. small problems
  185. Side bumper Park Light problem
  186. is there anyway to confirm that a block has been sleeved.
  187. Smoking!!!!!!!!!!!
  188. H22A Question
  189. Stupid Question....but I have to ask
  190. ????Individual Throttle Bodies????
  191. changing shocks
  192. TRansmission help/advise
  193. Who makes the short shifter for Ludes? Not the adapter.
  194. little help
  195. Headlight decision
  196. I have ignition troubles.
  197. 4th gen. prelude wheel + Tire thread
  198. f22 parts and few h23 parts
  199. help needed with heating problem
  200. Easiest way to put fan on switch
  201. what is water wetter?
  202. o2 sensor!
  203. stroker
  204. EGR (12 CEL) after Two Hours of Driving / Idle Bounce
  205. over heating h22a!!!!!??????
  206. ITB's...
  207. Can someone read this sparkplug for me please!!
  208. Is this a 97&up intake manifold?
  209. Fuel Relay
  210. Chipping a p28 to use secondaries?
  211. Prelude SI-Vtec suspension problems
  212. cam gears?
  213. how big a stock h22 TB?
  214. H22a Vtech Head on an H23
  215. Prelude dies at idle.. Idk wat to do HELP PLEASE
  216. all oem parts
  217. Should i buy a rebuilt starter
  218. 100 octane
  219. Question about honing cylinder walls...
  220. Radiator makes weird noise after i drive for a while. Boiling // Liquid dropping noise.
  221. 5th Generation Prelude Wheels and Tires Thread
  222. Spark plugs bad again need advice.
  223. SHIFTING PROBLEM!
  224. Where did the mysterious "250whp" ATTS kill come from?
  225. exhaust upgrade....
  226. AC Compressor Question
  227. Turbo Prelude! What kind of tires should I get?
  228. Test Pipe???????
  229. HID kits ..??
  230. lights flicker
  231. Anybody ever seen this p13 chip?
  232. Honda Accord - H22a swap with EGR problem
  233. Vacuum line to nowhere?
  234. vtec wire question - call me stupid
  235. h22 stroke
  236. vtec wont egage and ive read the faq section multiple times
  237. goes into limp mode at the top of 3rd gear!! WTF?
  238. 4gen radiator for non vs vtec
  239. 92 Prelude Additional Hazzard as a Fog Light Switch (searched)
  240. fog lights
  241. water temp gauge
  242. my problems, help if you can
  243. camber kit?
  244. which cams are for me??
  245. H22 Set-up estimation + Questions
  246. H22A vs Type S Pistons
  247. prelude vacum hoses PLEASE
  248. 1987 honda prelude 2.0 si
  249. 19s on a 5th gen???
  250. Stock 98 SH Prelude 1/4 times
