PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 [205] 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Is the H series as strong as a B series?
  2. Need help. HEADERS
  3. There is a hint of blue in the black color on my freinds '00 Lude
  4. timing question
  5. sprin4g seats for bilstein shocks
  6. clutch question
  7. toyo proxies 4
  8. replacing fuel filter
  9. The Demise of my Engine.............
  10. Problem w/ H22a Euro Tranny... EURO R MOTOR
  11. FS: 94 Lude T2 wing and BW SideSkirts
  12. How to remove 5th gen prelude clock/ac vents in dash?
  13. h23 turbo
  14. AEM cai w/ bypass valve (97-01) PRELUDE
  15. Anybody got dynos of jun 3 cams?
  16. MIR
  17. IAV testing question
  18. Driver's Side Engine Mount: 4th gen vs. 5th gen
  19. Turboing my lude
  20. why is my fuel cut off at 7k?
  21. TURBO the lude questin
  22. engine problem
  23. engine cuts out at 7k rpm
  24. OIl Prob on the lude!!!!!!!!
  25. shift points?
  26. Modified Mag Prelude Feature - Representing Lude Power
  27. Can any adjustable shocks be modified to fit on a 3rd gen prelude
  28. for you 4th gen CF people...
  29. 1995 Prelude Si electrical problem
  30. weird ass headlight problem, search is out of order
  31. h23a? h22EuroR? BlueTop H22? F20B? need a few q's answered.
  32. Where can I find a good deal on calipers?
  33. BAckwards compatability h22a ~~> H23...help guys
  34. Will 5th gen seats bolt up to a 4th gen?
  35. I hear Rattling on right side
  36. prelud epiping
  37. need new manifold fast!!! help
  38. Are their any short shifters available for 5th gen?
  39. where can I order a.....
  40. high output alternator
  41. Stock internals OK for JRSC upgrade?
  42. do any of you have the stock alarm in your 4th gen still?
  43. Removing Main Relay Behind Dash
  44. What is the fastest fifth gen prelude?
  45. What turbo cams would be good to use in a 2.2?
  46. Gay Ass Jiffy Lube
  47. Need a paint job...
  48. Clutch in, car stalls... sometimes
  49. cai installage
  50. Question on Warming up my Prelude....Vtec doesn't kick in.....
  51. Heated Mirror Problem. Need Help
  52. CEL throws Code #21. i know what it is but how do i check it?
  53. Please help me figure out what is wrong? (engine related issues)
  54. HELP! Lowered my car.....have all kinds of noise now
  55. Swap complete no cruise
  56. tires rubbing fenders
  57. 95 prelude jdm front conversion.
  58. Selling 88 prelude 2.0s
  59. Golden Eagle IM...need help on throttle cable bracket
  60. obd scanners
  61. wierd idle after turbo install
  62. trouble installing cai
  63. Brake Pads?
  64. strut bar/sway bar?
  65. 5th gen front bumper removal
  66. http://www.carsponsorships.com/
  67. Prelude cranks but wont start - Is getting fuel.
  68. car seems to start rather slow but allways starts?
  69. clutch problem
  70. Starting Problems
  71. will Tein-S techs will fit on Koni yellows
  72. where to get a cheap dizzy?
  73. gude?????
  74. USDM H22A4 to JDM H22x Engine Swap - Questions...
  75. sway bars
  76. Paint, body kit, etc......
  77. dumb question
  78. 60-75 mph??
  79. will this work ?
  80. 3rd gen 4ws suspension/steering problem
  81. 1st gear problem?
  82. Air Filter
  83. H22 tensioner question HELP!!!!!!
  84. The right muffler?
  85. Engine block coolant drain bolt on Type SH
  86. spitting and sputtering after 3psi or so...3500 rpm
  87. Problem with header nuts and stud.
  88. How many fog lights can you add to your car
  89. 92-96 prelude jdm one piece lights
  90. lookin for black one piece jdm lights
  91. Si headers on H22?
  92. 97 stock cd player
  93. fastest street honda - prelude
  94. Resonator or no resonator?
  95. Very rough idle..
  96. where is the correct location to affix the type sh sticker on the 5th gen prelude?
  97. Prelude Immobilizer??? Or other sollution?
  98. Not an idle issue but stalling. I searched already
  99. Forbidden Short Shifter
  100. New Frankenstein Engine = G23 (F23/H23 write up, Long, 56K beware)
  101. cut valve cover?
  102. 90 preluder si block build
  103. DIFFERANCE BETWEEN THE SH ENGINE BLOCK AND REGULAR ONE
  104. Cam Seal/Plug
  105. f22a1 tranny
  106. Does 15" rims fit 98 Prelude
  107. Spun bearing??
  108. Tanny fluid
  109. fan problem
  110. what size rim tire?
  111. Type S Leather seat with red stiches ??!?!
  112. Sweet Deal or Too Good to be True?
  113. FS: Bride seat rails (for "version 1" reclinables -- 4th gen prelude)
  114. Whats the diameter for the 99 lude type sh exhaust stock?
  115. Crank pulley nut on H22
  116. 5th gen Lude Exhaust Question
  117. yes yet a second thread fitment
  118. Finding a Slow Oil Leak?
  119. Intake Manifolds
  120. Strut and Short shifter review
  121. Is there really alot of problems with the 2000 Type SH?
  122. V-AFC experts
  123. Brake Pads
  124. fixed my 3k rpm hesitation
  125. remote car starter 4th gen install?
  126. SEARCHED, JDM 91 H22A everything but the head, which cams, JDM91, or US95
  127. tires
  128. Random bracket
  129. Can't find spark plug wires for JDM motor
  130. Vafc 2 question
  131. 92 si overheating
  132. unorthodox power steering pulley..
  133. obd1?
  134. More check engine codes than I know what to do with!!
  135. problem!! PLEASE LOOK AND HELP!!
  136. str t/b's
  137. ECU HELP
  138. tanabe, apexi, or thermal?
  139. 3g sites?
  140. which fuel pump for nitrous..
  141. need help....high idle and bad shifting
  142. Anyone know of retrofitting exotic horns on a lude?
  143. Stopped by the dyno shop
  144. 97 Prelude smokes. What could the problem be?
  145. Just finished swapping motor but won't start... ideas?
  146. F22
  147. Quick help please H22
  148. where can i buy a prospeed header???
  149. H22 v. H23 Engine Displacement Comparison: Bore(87-90mm) * Stroke(95mm v. 90.7mm)
  150. quick question, h22 header flanges, one is a symetrical triangle and one is isosceles
  151. blocking off the EGR?
  152. vafc 2 throwing a map code 3 ?
  153. short shifter kit
  154. electrical problems
  155. jrsc question
  156. 1/4 on a h22 crx
  157. 2 quick idle questions on prelude S 93
  158. Stock headers
  159. caliper suggestions
  160. SMS header production run
  161. Replacing Ball Joints
  162. Questions on the H23
  163. h22a balancer shafts no belt?
  164. h23 turbo or h23 vtec turbo
  165. emergency help!!!!!!!!!!
  166. which camber kit . quiky
  167. any recommendation on protecting the 5th gen auto tranny?
  168. Quick heater question.
  169. tapping at low RPM
  170. Are 94+ and 98-02 accord shocks interchangeable with 92-96 and 97-01 preludes?
  171. Complete Engine gasket set Question
  172. first mod
  173. Hose Techniques SVH
  174. 2003 accord wing on my 98 lude
  175. Anyone else experience 5th Gen clunk in Right Rear of car while driving?
  176. clanking sound when driving from left of car
  177. dam sqeaks....
  178. hydolocked the motor?
  179. Does your suspension squeak in the cold?
  180. $2500 to spend, what would you do?
  181. Jackson racing boost upgrade?
  182. real bad misshift
  183. crankshaft endplay
  184. vtec brake upgrade with legend calipers....stock wheels?
  185. skunk 2 on 4th gen now bouncy??
  186. Header fitment question
  187. D.I.Y. Install Ignition Switch for '95 Prelude- any thoughts??
  188. Prelude Computer Drawing?
  189. New to honda-tech
  190. ANYBODY HAVE A IAC VALVE???
  191. JDM distributor questions
  192. time for new cat.
  193. 97 stock cd player
  194. Drilled/Slotted Rotors?
  195. Anyone ever use the RSR header for h22?
  196. serious help needed...
  197. H22A Balancer Shafts suck.
  198. Quick Q: ACT flywheels
  199. Cam Gears
  200. Should i boost?
  201. Question about springs.
  202. helms manual for 92-96 lude
  203. 1981 prelude
  204. exhaust
  205. questions about a quaife on 5th gen
  206. problems getting into gear
  207. Yokohama AVS dB S2 tires
  208. test pipe sound clip?
  209. ITR shift boot in 4th Gen?
  210. Prelude Si Vtec Missing at 2000 RMP
  211. 97 SH or 99 SI
  212. 7k for an engine swap? WTF?
  213. How much longer do you think my prelude engine will last?
  214. RE: wear on crank bearing
  215. Getting foglights out
  216. h22a head bolt torque specs
  217. What the heck is this?
  218. jdm headlights or projectors?
  219. Review: ACT 6 Puck with 11lb Xact flywheel
  220. Control Links
  221. buying new prelude within yr. or so
  222. 1996 Honda Prelude VTEC
  223. exhaust advice
  224. ACL rod bearings
  225. Tinted Lexus style rear light cluster for a 1995 Prelude
  226. Not your typical exhaust question....
  227. Trans code location
  228. belts/pullies and American/JDM
  229. wisconsin hondata tuner?
  230. Shooting flames from your exhaust????
  231. bellow boot
  232. DIY Removing Pinstripes
  233. h22 transmission problem - will not go into reverse
  234. Engine won't start sometimes!!!
  235. Need taller 5th gear and quaife....
  236. Simple 4th generation Question
  237. OMG OBX IS THE NEXT MUGEN ACCORDING TO ONE OF THE MODERATORS
  238. headlight is foggy ... wat to do ?
  239. is it true that u have to take the head to the machine shop to make stage 2 crower cams fit??????
  240. p13 -p14 ecu
  241. Having trouble passing California Emissions. Please help.
  242. H22 Removing Intake Manifold Butterflies
  243. skunk2 manifold and different ecu?
  244. engine flushes?
  245. skunk2 intake mani. vs. Euro R mani
  246. WHAT CAMS WORK BETTER BETWEEN THIS 2?
  247. Help with MBC.....
  248. Are B20A3's worth anything?
  249. How can I tell by looking at a h22 tranny if it's JDM?
  250. B-series tranny + h22
