View Full Version : Honda Prelude
- Benefits of port welding in the head
- 91 Prelude Si won't start
- tach/shift light on a 4thgen
- Transmission Help
- What are common problems you would run into when removing Head from block?
- Acceleration slipping
- 10lb nos kit for 97 prelude
- Help PLEASE!!!
- starting problems
- Barometric Pressure Sensor
- JDM Climate control (4th gen BB4)
- h23 vtec ?????
- acceleration jerk?
- Stalling issues
- foglights
- Replaced main relay now passenger window is not working
- H22A Wiring Harness!
- Strange acceleration problem
- Emission problem: Honda prelude
- How can you tell the diff. new/old skunk2 IM design
- Brake Lines Siezed?
- 92 prelude si 4ws - front wheels locking
- questions about nitrous kits
- i have a question on brakes.....
- Review Mirrors (4th gen)
- Bad ignition switch?
- Removing/installing Engine without Hoist
- Transmission wont engage!
- rear mudflaps
- Password JDM PowerChamber Intake
- Type SH Engine Removal
- quesrion about oil and tranny plugs
- Question about bulbs on cruise control and climate control
- flywheel weights
- better mileage, H23 shifting at 2k RPM. Is it to low an RPM, unnecessary strain?
- this a good deal?
- cat problem
- Swap Question obd2 to obd1
- [H22A]Milled head and block, need to set timing.
- block seems to be ruined
- 5th gen stereo frame question
- help on engin/tranny problem please...
- NEED HELP QUICK! Car stalls everytime I let go of the gas!
- Question for my friend 92 Lude Si...Need Help Asap
- injector wires that run to the resistor box...
- '99 OEM CD Player in '97 problem...
- Prelude???
- car sputters at normal idle but with a higher current drawing accessories on it runs smooth
- Safe to drive car with Crank Pulley off ???
- low dipping idle
- 99 Lude with 64k losing oil
- Axles, VTEC calipers, and AT questions...searched..
- 92 lude h22
- Lude F%^ked up this weekend
- TURBOS TURBOS TURBOS
- JDM DC5 Steering Wheel on a Lude
- Turbo thread..
- Grey roof interior (4th gen)
- speedo is off
- Parts Question
- how many teeth
- need some pics of h23vtec
- Upgrade the H22a1 trans
- MISC H22 H23 parts
- removing rusted front brake rotor - 92 prelude
- Removing EGR CONTROL DEVICE
- radiator blew during smog?
- Radar Detectors....(blown speaker)
- Local parts stores (?)
- After Swap having some problems!
- Can a H23 take a V-tec head
- FRM and year question
- HELP please with suspension questions! (Tokico HP suspension kit)
- Help with taking off Intake Manifold!
- which exhaust to get?
- balance shaft
- 5th gen mounts engine mounts all the same ?
- Traction Bar for SH
- NGK wires HP limitations
- Burning Oil
- clutch problem...
- Eibach Sportline Springs!
- Best N/A Bang for 4 Grand?
- witch pistons do i use?
- EL gauge problem
- Hood prop.......(WTF)
- CV boot/Axle
- How to tell
- TB spacer rice.
- Something broken ? Belt // Pulley does not move ...
- My Prelude (and photography) evolution thred. Critique? 56k no
- 99Lude rear brake caliper pistons don't turn?
- RSX & ITR brake setups interchangable with 5th gen?
- Poor man's Bpi flowstack
- Would u use this belt?
- I screwed up bad, EGR plugs fell down into EGR passages.
- AEM CAI v2
- Odd P/s problem
- Euro R swap into 2000 Prelude. having problems
- What are my exhaust system choices???????
- B20 swap
- anyone rocking ground controls on their 4th gens?
- Any one know how to use a tapping set. I am trying to tap my EGR ports.
- Proposed list for GT30R Turbo build, experts please advise
- need help with a cd player
- H22 pistons on H23 rods??
- where can i get some videos of some preludes with turbo?????? www.????.com
- rim cracked
- helms link plz
- Can straight pipe cause Farting sound?
- Exhaust gas recirculation flow insufficient detected
- Got a P13 today with a solid CEL. ECU could not be jumped.
- I am cleaning out my EGR ports, need help!
- black coolant pipe question and oil filter
- Car won't start... missing ground?
- Engine Builders
- need help
- Fuel guage.....
- starting problems when my car sits for a while?
- How do you tell
- For sale AEM EMS with wideband CHEAP
- Humming noise...?
- 99 front lip OEM
- need sum help???
- Cleaning the gunk off the dash!
- accelerating problem
- +1mm OS valves with 11:1 high compression H22
- looking for pictures of AEM pulleys installed.
- FSUDD exaust????
- CHugging 2001 Prelude
- Starting issue
- Removed PS belt
- question on jdm fogs.
- Accelerates when not on the gas??
- Type-R Spoiler
- electrical problem
- getting a sh!tload of errors after replacing header, need help asap
- Tyres for 15 inch wheel?
- buying a 01 5sp trany need advise
- Type SH shock removal
- frankenstien trouble
- Adjustable Proportioning valve
- Transmission differences
- just wondering??
- JDM F22 DOHC gas mileage
- 94 prelude si auto sometimes wont start
- Inner tie-rod replacement
- where to get the bolt for the shift linkage for a 5th gen for the leanracing shifter
- starting probs. no spark
- gauge remove
- hazard lights went dead.. not my bulbs, my entire signal system
- FS: Prelude H22 Clutch
- Prelude engine mounts
- Mugen M7 Wheels fitment
- Replacing doors? (trim issues...window issues....)
- 5th gen navigation
- Camber kit for Prelude SH ?
- How To Mount Non-Hubcentric Wheel Spacer?
- shaky steering wheel
- plug and play
- charchole canister question
- 98 Honda Prelude Turbo Problems
- Automatic to manual(electrical)
- MY CAR WONT GO INTO GEAR AFTER START UP...
- Cold start issue and High starting idle
- Electrical Problems - Wire Burnout
- caliper rebuilding
- speedometer
- Anyone ever change the order of the dash gauges (4th gen)
- JDM F22B Gas Mileage
- MAHLE GoldSeries H22 Piston Kit C/R 9.0 & turboing h22a4
- Where did you fit your gauges {pics}
- h22 h23 parts complete swap what ever
- Help me with my Knock Sensor
- Rear Center Speaker Question
- Port matched Intake mani...
- I BROKE MY MOTOR MOUNT
- OBD II Codes
- Project Engine Bay
- THE END OF ALL Idle Surge - Bounce - etc Problems Thread
- h22 h23 f22 and f22b rod ?
- Setting Timing
- Skunk2 Head
- wanting 99 prelude OEM front lip
- Alternator
- 2 wheel steer conversion done.. a few questions..
- Difference in auto and manual H22?
- will an f-series gear fit h-series?
- Authentic Mugen Parts?
- adjustable cam gear question
- Needing Some help.
- engine cut out
- Nashville ludes i need your help
- My break goes to the floor....
- Type S camshafts and nitrous?
- OBD II
- Looking at last generation preludes, any thing i need to look out for when purchasing?
- h22 block busted in front.
- New headlights
- Auto-Tensioner Problems
- Power steering fluid - oem vs aftermarket
- =JDM= SiStates Engine Bay Clean! 5Speed swap!!
- running vacuum lines
- No Power During Low RPM (2-3.4k)
- What type of turbo??
- I Need Help Really BAD please read.... NEED ADVICE
- Which ECU?
- VTEC Problem (Will not engage)
- How much did your 60k service cost? Is it required?
- My setup, comments please
- h22 timing belt length and teeth count
- whats differnce h23a1-h23a3
- 96 Si swap question (H23 to H22)
- 94 prelude h23 cold air intake question
- S2k filter
- So I changed my alternator.....
- Do I have everything I need to install this oil pressure gauge?
- o2 sensors:)
- Installed H&R Springs, now UCA hits
- Trans. Help
- tranny swap question
- Spark Plugs
- 92-96 rear center console [questionss.....]
- question bout a spoiler.....
- h22 obd1>h22obd2
- Factory Door lock relay
- oil squirters
- SRS light doesn't come off
- My Hazard Lights and all signal lights wont work. plz help
- 4th gen exhaust
- Thanks Honda-Tech...
- h23a1-h23a3
- code 23 knock sensor when going over 40 mph
- Prelude Intermediate Shaft
- Throw out bearing (Just confirming)
- what dose the the"BRAKE LAMP" mean???
- New pictures... My 2001 Prelude Turbo
- Fuel Pressure Gauges
- Random miss. Need Help
- Notice a Vtec head
- 4 lug to 5 lug
- megan header for prelude type sh
- USDM H22A4 to JDM H22A Swap - Help
- Shift boots / Ebrakes / Knobs / Hubs
- Overheating
- H22a4 swap in 92 si (Pics)
- I need some help
- Solid cel after swap
- steps to lower my 1998 Honda Prelude
