View Full Version : Honda Prelude
- 1996 Honda Prelude Clutch Pedal Sticks to Floor
- Questions for the Pros: P28 ECU
- Tyre size for 98 prelude turbo
- Keyless Entry Question
- USdm 97 prelude H22a euro r swap parts?
- The unused bulb position in the USDM 4th gen DIC?
- D4 light flashing, intermittent reverse
- Honda prelude idles up as the car warms up
- Prelude oil pump
- 99 prelude both running headlight out
- I think I have dash lights out? (4th gen)
- Plug n play/o2 question
- Can I swap atts from a sh model h22a to a base model h22a
- 1999 Prelude reverse slips
- 1992 h23a1 Connecting Pipe... it's kinda urgent
- Honda Prelude 4 gen cup holders
- EL digital gauge upgrade question
- SCAN TOOL for JOBD (OBD2)
- 2000 Prelude H23A axle help
- Transmission oil line prelude 2001 part number please!??
- Prelude starts and shuts off after 5 seconds
- 1989 Prelude
- 95 Prelude - suspension replacement parts help needed
- 1997 Prelude BB6 Bee*R Rev Limiter Type H2?
- New to Hondas. Very noob question.
- 1992 prelude h23
- 1992 Prelude Motor Swap
- Center speaker size for 1993 prelude vtec ?
- Freeze plugs
- Dash cluster issue
- New member with weird question
- Anyone have NRG Type R seats mounted?
- 2001 Prelude H23 Bluetop swap/ Need ECU help plz
- B series
- I'm back
- '98 Prelude Check Engine Codes
- Air Intake System
- 93 prelude with f22b swap idles from 2500 down to 1000
- Drivibility Nightmare - 5th Gen Honda Prelude
- 1988 Prelude Headlight Aim Adjustment
- What is this?
- EL Dash circuit diagram and component values
- 88 prelude engine swap
- JDM H23A with P28 ECU chip help
- 91 b21a1 valve cover studs
- 1996 type S 2.2 SOHC Honda Prelude OBD1 4th gen need help with engine
- High Mileage H22A4 Need some tips and suggestions
- Should I pull the trigger on a 1987 Prelude si?
- Distributor help
- Boss kit for 2nd gen
- Prelude part weights record thread.
- What is this thing?
- 2000 Prelude H23A swap distributor help
- Prelude 3gen cruise control
- Weird 5th Gen Distributor Issue - Please help!!
- 1996 honda prelude
- 1991 Honda prelude won’t start
- H22a usdm or jdm verification
- 1993 Vtec to 1996 Si OBD2 Swap
- 2nd gen prelude strut bar
- Are h22's worth anything these days?
- First overheating, now coolant leaking
- 5th gen wiper linkage bushing?
- Harmonic Balancer question with a 91 Prelude
- My BB6 Dream Build Photoshop'ed Front End
- Mechanical conversion for 86 dirt track car
- Gear/ belt compatability issue.
- Need Help! H22 4th gen
- Thoughts on the f22 block with h22 head
- 5th gen ignition problems
- 97 prelude won't start
- TD60U Distributor Cap and Rotor Part Number?
- Need Help!!!
- Single Cam Prelude
- 96' Honda Prelude H23a non-Vtec ecu
- Honda Prelude
- Does anyone know what this sound is? youtube link
- Intermittent abs light with no code
- OIL LEAK
- H22a mods
- mchefs turbo 01 sh thread
- Legend GS CALIPER BRACKETS on Prelude
- 01 Prelude won't start... Can't figure out why
- Will a h22a4 bolt into a 96 prelude
- i need of assistance regarding wheel fitment
- 5th gen prelude// All brakes sticking to rotors
- H22a4, resurfacing of block, do I need thicker head gasket?
- Weird P/S belt problem
- No Crank No Start Solution? (98 Base)
- Blown H22A engine from1999 Honda Prelude SH. Got an Acura RSX type S w k20a2 engine
- Too much $ ???????
- Who has euro r swapped a prelude BB6
- help!! The bolts that thread into the frame to hold the crossmember won't fasten
- 95 Prelude SI H23A swap EGR trouble
- 96 Prelude front bumper signal lights??
- 4th Gen Prelude Led Bulb Type (best bulb and differences?)
- H22A4 NO Compression
- Good inexpensive brake recommendations
- 5th gen type sh help
- Honda Prelude SE? SH or non SH?
- 96 Prelude Engine Swap
- 98 Prelude Misfire and blown battery fuse
- Fuel pump not priming?
- no start..cranks
- What replacement for JDM OBD1 H22A internal coil TD-60U dizzy?
- 97 remote start
- 98 Prelude All Doors Locks Jammed
- Transmission fail?
- 98 prelude does not turn over after motor rebuild and install
- Need help
- Replace the front upper arm bushings
- 1988 Prelude with dual carbs acceleration issue
- 1992 H23 engine rpm all over the place
- Help plz
- 93 Honda prelude from h22a1 to h22a4, what's the difference and can it be swapped
- Has anyone has distributor problems, h22
- H23A Vtec blue top turbo build
- 2000 Honda prelude H22A4 with series A trans starting issues
- H23a swap in 2000 type sh
- Hello I'm Daniel
- No power after front end collision.
- 93 h22a starting issue
- Restoring GEN 3 Prelude
- honda prelude 1997 engine cranks but won't start
- Photoshop Work - '01 Base 5spd
- 1999 prelude bucking/bogging under acceleration
- UDSM H22A4 to JDMH22A
- JDM H22A What is this ?
- Need help removing interior fuse box and harness 2000 prelude sh
- belts
- 98 Prelude auto to manual (bypass Netural safety switch)
- Unknown wires
- 1991 prelude si automatic transmission shift solenoids
- 5th Gen Prelude - Need some help, advice, or.. something..
- tranny wont catch gears
- Bluetop swap 2000BB6 harness diagram?
- Leave off my vtec.
- PGM-FI relay main relay location
- Two Preludes One Engine - Project
- Rsx shifter in 5th gen
- 1992 Honda prelude
- Water in oil?
- Weird Sound from Engine?
- P28 + Imobilizer
- rear windshields remove
- JDM H22A Camshaft position sensor
- Engine HP
- Auto to manual tensioner
- Auto to manual transmission problem
- Fuel setup
- 2001 honda prelude instrument panel blue led mod
- 96 prelude si h23 obd2 swap?
- Need help purchasing new rotors and brake pads.
- 4th Gen Interior
- Gutting H series (h23a Bluetop) intake manifold
- H22A Euro R Swap in 97 Prelude SH
- 1989 Hinda prelude SI oxygen sensor wiring
- 95 VTEC Timing Belt Replaced Now Engine/Car Vibration
- 550hp on pump gas
- 96 prelude g23 build
- Honda tech in So Cal
- Strange switch - Help!
- 3rr gen Prelude exhaust question
- Where can I buy a bumper
- Can you guys confirm my DTC?
- Honda Prelude 3rd Gen Clutch
- Fuel Filler Neck Discontinued By Honda, How Else Can I Fix The Pipe
- E-brake keeps loosening up
- 1998 prelude
- Mystery oil leak from oil pump/rear balance shaft area?
- 1980 Prelude with timing issues
- Keep failing smog high NOx 94 h22a1 prelude
- RWD Conversion?! Possible?
- 98 h22 prelude head gasket replacement and timing
- JDM H22A swapped 5th gen BRUTAL IDLE SURGING!! HELP!!!
- 97 prelude cant shift problems
- Somebody please help me
- 1986 honda prelude si 5 speed. Keep surging
- 5th Gen Euro R Swap in Austin, TX
- ecu help
- Ecu help
- F20b swap ECU question
- 97-01 transmission wiring issues
- Where can i go to get an engine swap in Houston
- 1992 Honda Prelude Si Engine
- F20b swap my 1992 prelude won’t start
- K tuned shifter?
- Need Advice
- Fuel setup
- What is a good website or websites to order any and all parts for my 98 prelude
- Need some help or suggestions
- Firewall plugs
- 92 Prelude Automatic tranny/ brake noise
- 1989 Honda prelude SI 4WS
- car won't move
- 1991 Prelude will crank but won't start
- Code 4
- Prelude TCU numbering
- 1st and reverse clunk sound
- 92 prelude ; weird idle noise
- k24a2 swap
- 92 prelude won't start
- Jackson Racing supercharger belts
- A new clutch... With a few problems...
- 96 lude h22a with f22b2 ecu?
- Battery light coming on and off.
- 96 Prelude speedometer problem and shifting problem I believe
- '94 H22 starter solenoid help!
- Intercooler piping angle
- Interchangeability of H22 timing covers?
- newbee
- My 92 honda prelude brake lights wont work
- Honda Prelude parking brake will not fully disengage
- 2000 Honda Prelude Pressure problems?
- obd1 h22 water pump on obd2 h22a4 and visa versa
- Sourcing a Prelude (5th Gen) - Mileage Suggestions?
- Help with my 96 prelude
- 86 Prelude Rough Idle
- rough idle
- Prelude problems
- h22a4 compression
- The SRS light is on
- f22a1 vs f22a6
- 1999 Honda Prelude No Crank
- Clogged A/C drain tube
- 2k Honda Prelude issues
- H23A P/S BELT NUMBER
- 98 prelude no crank no start
- Auto 88 prelude si swap into 5 speed Civic lx
- prndl lights
- Cylinder head
- 1990 4wsi issues
- Help my 1996 Honda prelude makes a horrible noise when I shift into reverse
- Ignition harness wiring diagram
- Fully built NA H23 260HP - valve cover venting
- F20b with h23 im???
- What size rod bearings do i need for h22a4
- Camshaft at True TDC
- High Hp damper
- ('98/5th gen) Spark Plug Wire Recommendations
- bb6 2000 lowering limit on 18's
- Any one runs id1000 injectors on aem fuel rail h22
- 1991 Prelude SI 2.1 - Where is the A/C low pressure switch?
- Non OEM piston rings in an h22a4?
- 1982 Prelude Block Coolant drain plug location?
- Couple of small interchanges
- H22 iacv wiring
- Why stop at 8k rpm with upgraded valvetrain and aggressive cams? What weak points?
- Camber Adjustment
- T2T4 tranny case same as H22??
