View Full Version : Honda Prelude
- alignment question
- f22b turbo luders?
- B-series rods on H-series crank
- 1993 Vtec! Throwing code 43!!!! ~~HELP~~~~
- OBD1 guys, need a favor!
- Has anyone used a braided stainless clutch line?
- EGR Valve Code 12: What should i try first?
- wiring harness
- for those with 18's i have a question
- h23 timing belt problem... NEED help asap!!!
- 5th Gen Prelude auto(tiptronic to Manual) conversion
- Burning oil and i dont see it coming out of anywhere
- 2000 Honda Prelude for Sale
- coolant temperature sensor!
- Flywheel?
- shaved turn signals on 5th gen, need wiring diagram
- Best Exhaust?
- its a 98 prelude intake/header/exhaust
- smog issue
- Need info - want to buy a prelude, but which one....
- wich fuse id for the brakin lights?
- Interior Swap
- Need suspension component from someone if they can help!
- How to install 1 Piece Headlights for 92 prelude.
- Painting on clearcoat for front lip? Help! (searched)
- Preliminary Turbo h23 dyno...
- What Tires are You Running?
- lsd for a 2000 prelude sh
- Question about SS tranny
- Lets talk nitrous...learn a little....
- Anyone using 87 octane on gen4 SI?
- CF Front Lip for BB6?
- 225's on stock rims? can they fit?
- Any issues/problems with a 99 prelude type- s?
- difference between the SH and the base model
- 2.3 and Higher
- 4th Gen Prelude, minor Motor Work, please help?
- is there a how-to to remove the gauges for a 4th gen?
- 5th Gen Lude Turbo manifold
- couple of questions about part diffs b/t h22/h23
- turbo h23 oil leak
- h22 h23 engine identification problem help!
- ecu question???
- h22 /h23 rear brackets all the same ...for accord swap
- frankensteining h22 with h23
- Anyone got pics of a Leather Interior of VTEC preludes?
- LACR 1/4 times...
- H4 light bulbs have two lights "round springs" in it
- Installing Nitrous need help
- Front Speakers for 2000 Prelude
- f/s P72 w Hondata s100 and obd2-obd1 conversion harness
- Accord lips?
- fuse box cover?
- prelude issues
- how low can a prelude go??
- oil leak
- 96 vs 97+ h22 any difference?
- Anyone do the h22 belt tensioner conv. to the manual h23 tensioner?
- i have a ?":>:{ problem i cant get my car started
- Should I add these to my 98 Base Prelude?
- VSS question A.S.A.P
- Euro Intake Manifold....
- 99 integra or a 2001 prelude?
- Does anyone know if there is a plug on the 2000 Prelude to check the check engine?
- Compression Ratio and Gear Ratio
- Greddy Intercooler install
- To clarify a potential misunderstanding
- Emissions fail
- please help!! TDC on 99 prelude
- Lip for a 93 Prelude
- O2 sensor thread callout
- h22 fuel injectors
- obx twin loop exhaust
- Fly Wheel? Setup?
- exhaust help
- rattling in gauge cluster
- Shuttering rear brake?
- Bought a 5th gen - How'd I do??
- Turbocharged my lude96
- H22 CLUTCH
- S2000 Steering wheel in 4th Gen?
- Atts
- Anyone have 15"s on their 97+ prelude???
- Anyone know how to splice wires?
- H22a Conversion : VTEC is ready but engine down pipe dont fit, SI >> VTEC
- DA front end on 91 Lude..........
- P13J CEL Code 36, traction control?
- What year did the 310cc injectors come out of?
- oil in spark plug hole
- built b21a motor, need advice
- intermittent engine stalling = teh gay
- anyone have pics of full JDM interior with recaros seats
- SMSP Prototype #3 vs JDM Trust (greddy) with IB 2.5" Coll
- "Q" Motor Oil
- Question about Engine Swapping
- something wrong with when vtec
- 4th Gen Black turn signals: Anyone have them?
- Hoodpins with VIS hood?
- Injectors for JDM P13?
- Need Feedback.......Apexi WSport 2 Exhaust...And RSR Exhaust...;)
- ATTS
- smsp prototype header for sale (mod approved)
- 4th gen owners: Too loud in the cabin??
- Please welcome your NEW Prelude Forum Moderator
- H22 conversion bellhousing to B16a tranny
- Valve Feeler Gauge? HELP.
- HELP....no spark?
- How do i know if it's a Euro-R Engine?
- Prelude VTEC - Drive axle seals - How difficult?
- tokico ill 5 way ajt. how they work
- Helms on taking tranny off
- no slack to take off o2 sensor
- Need advise on 99 prelude type SH
- bolt on prelude performance???
- compression at 9:1 ratio
- h22a slow as hell
- p28 and secondary intake butterflies non compatable... will give me more power?
- We need a new moderator. Help pick your new one here
- Experiance with Greddy Emanage
- Valve Cover on my 5th gen base
- Wheatherstripping
- what should i do?
- Service connector>>>> Solid MIL.
- NSX Calipers and Hondaprelude.com
- h22 swap question...
- left turn signal doesnt work... at all...
- bad ignition sensor?
- 3rd gen ebrake cable replacement
- USDM 94+ VTEC EL Gauge into 92 Si
- H22 idle and throttle problem
- CEL Code 24!?!?! WTF!?!?!
- Integra seat in 90 lude
- Suspension problem, can't get bolt out.
- oil leak!!?
- 89 honda prelude gauges
- Can I restore my original wheels?
- Starting problem after sitting for awhile. Help!
- prelude Q's (WTB)
- Hydraulic to manual timing tensioner
- anyone add a rear windshield wiper?
- Can anyone run a vin on carfax for me?
- My car broke down under the free way need help ASAP CEL CODE 15
- Needed: 95' Prelude JDM H22A (M284) Tranny Gear Ratio's
- TEmperature Problem
- Another JDM headlight installation, desperated for help!!!!!!
- O2 sensor
- tranny fluid
- Few help questions
- cluch tranny issues please help
- mileage survey for stats class
- Stock o1 SH.. what to do? ur experiences please! :D
- H22 Rod Bearrings??????
- Quick Purchase Question
- No AC + ABS light is on
- Exhaust
- quick question
- Break in......Busted Window and jacked System
- Clutch making creaking noise
- clutch feels like its getting softer?
- skunk2 intake manifold mods?
- Clutch choice
- Some drunk guy just smacked my Lude!
- 97 HONDA PRELUDE IDLING LOW @ 400 rpm after warm up when in park/nuetral??
- RADIATOR AND CONDENSOR FANS DO NOT RUN FOR ENGINE COOLING OR A/C??? 97 PRELUDE HELP!!!
- are KMS springs and retainers good for stage 2 cams????
- 12 EGR - HOW DO I FIX?
- Bubbles in my oil WTF!!! (h22)
- good cam gears for H22?
- rear quarter panel rust!!!!!!
- 3rd gen prelude gear ratio ?
- Suspension Woes
- I need HELP!!!
- my 92 h22 prelude wrecked :(
- Honda Genuine ATF
- Pauter Rods + CPs, a note to those who plan to use this combo!
- prelude h22a water pump?
- JDM EL gauges
- Need parts, please help!!!
- Timing belts...whose do you love, whose do you hate?
- Questions about the Remote wire
- knock sensor interchangeable???
- diffrence between BB1 and BB4
- blower motor high relay.. were is it in the car 92 prelude
- h23 vtec jrsc questions (searched)
- JDM headlight install, desparate for help!!!!!!!!!!!!!!!!!!!!!
- Any one else running 15psi?
- Anyone local (near New England, CT pref) willing to do motor swap? (will pay)
- H22A1 / M2F4 Tranny Trouble
- 1992 Prelude s model for sale
- Need Help: Sun Roof Window Making Weird Noise
- seat question
- How do you determine your Engine Code to match the right Type S piston
- lookin to buy a Prelude and got some ??
- JDM headlights, how do I get to the corner bulbs?
- Tach Problem
- VSS problem
- need help/advice on fixing a previously hot-wired ignition
- Need Help, ES bushing and motor mt install Prob.
- Writeup: Fixing 4th Gen Prelude Passenger Door Power Lock Any Key Works Problem
- 92 H22a Vtec Prelude wont rev past 5300 - 5800 RPMs. Problem
- max rpm on stock springs?
- Beware of Dynotuned in Madison Wisconsin...They are scammers!!! www.dynotuned.com
- H23/H22 ECU Compatability
- is this idea rice?
- m2f4 Rebuild
- Prelude Front Brakes - Rotors Need Help
- anybody have intake & exh valve clearance for h23?
- how to break in a turbo motor
- h22a4 into 92 where h23 was
- AC Pressure Switch
- ns prelude
- Rear View Mirror
- Oil bolt wont come out
- Diffence between standard and SH
- type s cams or obx stage 1 cams.wich makes more power???
- vtec question please help!
- AEM EMS + VAFC=?
- cel & car shutoff
- SKUNK2 INTAKE MANIFOLD ON A 99 PRELUDE
- all the best parts for the BB6
- How Do You Use Sealant on Tail lights
- FOR SALE!!...97-01 prelude bodykits...'.'.'.'.'...'.'.'.'.'.
- building all motor h22/ what pistons? (searched)
- H22 Goldseries Mahle Piston Kit
- couldn't get cams to top dead center
- 3rd gen prelude w/h22a crank pulley?
- Fender Molding/Protector
- Light supposed to go on??
- 5th gen auto build
- Apexi N1 exhaust help
- turbo prelude question
- WTB
- exhaust?
- Permatex Grey on an Exhaust Leak
- 93-96 ecu question
- h23 crower valve adjustment specs????
- A few questions about my new suspension setup...
- Why fuel pressure?
- How are the power gains with the 5zigen exhaust for a 5th gen?
- question about h23 rods and h22 type s pistons
- what's this part called?
- TPS question?? need help ASAP
- Wheel offsets for 17" wheels
- General Question
- HELP converting my car from obd1 to obd2 HELP HELP HELP
- cam ?
- Finding TDC on Crank Pully
- 91 f22 in a 94 prelude ?need help !!!
