PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 [118] 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. 1999 Prelude transmission woes (auto)
  2. anyone vented the valve?
  3. 4th gen
  4. Anyone use Forum Racing Crank Pulleys?
  5. Water in #4 Cylinder and spark plug question (H22 4th Gen)
  6. What length belt for Alt. only, no AC searched already.
  7. Shreded timing belt and 2 mystery bolts..
  8. realtively inexpensive exhuast
  9. Old prelude 2.0Si in 86 accord?
  10. H22 Help Please
  11. how to fix poor '92 Prelude lighting??
  12. euro tranny
  13. Velocity Funnel?
  14. Prelude Swap
  15. i want to buy injectors
  16. auto - manual (searched)
  17. JDM foglights make clicking noise when turning off lights?
  18. PARTING OUT MY H22A4! EVERYTHING GOES BESIDES THE VALVES!
  19. weird... electrical maybe?
  20. Coolant Lines Looped
  21. PCV
  22. b20 EXtrmemly rough idle i think its (ignition related)
  23. H23/Vtec piston to valve clearance
  24. got rear ended...
  25. NGK iridium IX vs double platinums (5th gen)
  26. Brake-Suspension Upgrade Question/Opinions
  27. What other steering wheel will fit a 5-th gen ?
  28. Good Paint Jobs...
  29. J-spec H22 where to find cap??
  30. What does this plug go to....?
  31. Fiberglass vs Fiberglass Composites?
  32. venting the valve cover?
  33. boots VS whorsepower with turbo
  34. Ebay ITR "style" shift knob
  35. 90 2.1si Clutch
  36. Do I need an Aftermarket Fuel rail to run RC injectors?
  37. Clutch kit and flywheel.
  38. Type S Swap
  39. Headlights NEEDED!!
  40. Possibly buying a 1yr warranty on a Lude for $900. Advice?
  41. Where is the Flasher relay located on 1986 Prelude??
  42. 98 Prelude Engine problem
  43. Las Vegas Preludes
  44. Possible Power Steering Issue- Weird Noise
  45. h22 wont start please help
  46. Prelude Si VTEC - de-cat pipe question
  47. Quick Release Hub Review:
  48. H22 Mounts for 3rd Gen Preludes 88-91
  49. Can I use any H22 starter?
  50. I Want to Trade my Wings West RS Front Lip
  51. Whats the point of adjustable sway bar mounts?
  52. Sun roof leaking like a beeaatch
  53. 1991 Prelude Si 2.1L missing like a biaatch
  54. 1992 H22A4 4WS ECU Wiring
  55. help with high beam
  56. H22- Volumetric Efficiency
  57. increasing displacement on f22 block?
  58. garret t3/t4 turbo for $500 w/shaft play?????????
  59. Factory H23a vtec?
  60. 1991 Honda Prelude Si 4ws parts
  61. Aftermarket Rocker Arm that dos NOT disable VTEC
  62. 5th Gen Prelude Airbag Removal - SRS Light / MES Writeup
  63. JDM bumper lights Q
  64. Low compression on cylinder 4, possible burnt valve. need some advice and insight PLEASE!
  65. Good radio for the lude
  66. Problems with 1988 honda prelude SI
  67. Turning rotors w/o replacing pads?
  68. IS this a good deal???
  69. garnish assembly for fog switch
  70. 5th gen taillights for sale
  71. catbak question??
  72. h22 timing belt how to
  73. H22A Swap - Two Issues...need assistance.
  74. h22a4 valve train + boost?
  75. Where and what kind of main bearings to buy for an h22?
  76. Clutch noises or is it flywheel
  77. Can someone please explain the difference between half shaft and intermediate shaft? h22
  78. calling all turbo h22 owners
  79. Anyone with a full JDM Climate Control Swap
  80. h22 headers
  81. Throttle Body Bypass Kit
  82. gauge cluster isnt working? any ideas? 93 lude si
  83. External ignition coil location, pic request
  84. exhaust
  85. NOOB QUESTION: does the oem fogs and turn signals fit on the mugen front bumper? [5th]
  86. 4WS steering angle graph
  87. **car dies after warm up**
  88. To jack or not to jack?
  89. 97-01 Prelude vs 98-02 SI?
  90. Having clutch issues...help needed fast.
  91. Noob brake question
  92. Official Headgasket-leak by the Block Stamping Rollcall!!!
  93. Feeling a bit slugish
  94. Dyno'd again
  95. Heater Problem
  96. What is this little plug on the window called?
  97. where to get Diagrams?
  98. Used Koni/GC Combo Question
  99. 92-96 PRELUDE SRS Light Removal Question:
  100. h22 missing (searched)
  101. h22 problems
  102. H22 Cylinder Head
  103. H22
  104. Misfire on Cyl 1 & 3 Only when cold H22A4, Stumped.
  105. Alarm won't work
  106. Exhaust wrap
  107. trailing arms & end links (want beefier)
  108. Need Help, Pistons/Drivablity
  109. best power adders for h22a4
  110. Customer Exhaust: Can I use a smaller diameter resonator?
  111. ignition problem?
  112. Trouble with GF's 98
  113. JDM Air Mix Motor Wiring
  114. Code 43 after major repairs
  115. Growling/Rattling sound from header/cat area
  116. Which Intake and how easy will it be to install it?!?!! PLEASE help!!
  117. Turbo Progress
  118. Greddy Radiator Cap problem!
  119. What does this connect to?
  120. nuespeed race springs
  121. Clunking/Grinding while turning right.
  122. Driveshaft: Outboard Joint + Knuckle
  123. Knock Sensor Issue (searched already)
  124. 2g Interior pics (84-87)
  125. clutch problem
  126. Is this a good deal for Brembo Blanks?
  127. where do i plug my code scanner too???????????? HELP PLZ
  128. clutch pedal going soft in 5 mins. not loosing fluid.
  129. Bent Front Rear Subframe Cradle...
  130. Rims
  131. front camber kit how to-n00b friendly
  132. '86' fuel problem
  133. Honda Badge Question.
  134. Rocker arm adjustment ?
  135. Getting cruise to work with an Auto to manual swap
  136. Back-up lights not working (searched)
  137. oh the good ol turbo lude
  138. What's your "worst" gear
  139. H23 Project of Death
  140. Help me locate Starter bolt please!!
  141. EGR Plugs?
  142. Installing Car Audio Prelude Question.
  143. Steering Wheel Click When The Car Gets Hot.
  144. How long should a cylinder hold compressed air
  145. lowered the car
  146. Clutch pedal sensor?
  147. OEM Injectors
  148. Suspicious Squeal!!!
  149. Brake lights not working (searched)
  150. HID Problem
  151. dynoing the prelude
  152. prelude headlights
  153. Differences in JDM engine harness VS american?
  154. civic radiator into h22 4th gen?
  155. South Bend clutch for my Prelude check them out
  156. Brake Light problem
  157. ECU question
  158. jdm H22A fidanza 8lb flywheel
  159. heater core
  160. ECU Fuse keep Blowing
  161. 02 TL type S rims
  162. cruise control
  163. driver heated seat not working? can someone shed some light?
  164. Are the black leather seats in my 97 SH real leather?
  165. Say it isn't so...
  166. should i get another one......
  167. prob with battery relocation and starter
  168. WTF did I do to my distributor???
  169. Do you know? *Transmission Question*
  170. pic request : Tanabe tower bar
  171. F & H block to tranny pattern
  172. EXHAUST QUESTION
  173. anyone use tigerjapanese.com
  174. Prelude selling thoughts/ideas...
  175. downpipe for preludes. squeeze between crossmember?
  176. price question
  177. Prelude not dropping revs?
  178. My sisters 99' lude was broken into, installed new ignition switch but it does not have the immobili
  179. 4g JDM retofit: My how to
  180. My H22A dyno graph after long inactive period.
  181. Buying a Prelude, need help
  182. good idea?
  183. VSS gone bad on tranny AT 97 lude?
  184. good deal?? my d16y8+$1600 for his USDM B16
  185. prelude for sale!!!
  186. Idle Problem
  187. Fuel Rail bolts
  188. Rapid ticks from starter.....and I've searched
  189. helios HIDs
  190. 88 honda prelede
  191. Passenger axle removal w/ OBX LSD etc..
  192. Strange Noise from under hood
  193. Is this considered "Good Tuning"?
  194. Slow returning idle
  195. tried to search problem with code 22 14
  196. wiring oem spoiler
  197. just picked up an obx lsd today
  198. think im sellin the lude, anyone have suggestions for my next car?
  199. Brain Crower H22 Stroker kit??
  200. Need Help, How to - H23 Head On a F22A1
  201. i have 17x7.5 rims, will these tires fit
  202. Idle too high with AC on?
  203. Misfire
  204. Part identification - Denso # 056700 - 7330
  205. ATTS Light keeps going on!
  206. 3rd gen aftermarket steering wheels
  207. Who makes emanage PnP Harness?
  208. 9904 RPM Over-rev now oil light flashes after hard braking
  209. Having trouble installing engine back into engine bay, H23 4th gen prelude
  210. 1986 fuel problem
  211. Front mount IC in N/A?
  212. Finally DYNOED JDM H22 hatch...it's been a long time comming!
  213. hesitation when cold and stall with A/C on...
  214. Dump Pipe Or No Dump Pipe...
  215. Timming Belt jumped teeth after replacement
  216. HELP.....f20A
  217. P0303 code / Cylinder 3 Misfiring BLEH.
  218. aftermarket flywheel
  219. H23 forged rods
  220. sleeving h22
  221. h23 swap to h22a
  222. 245/45/16 tires, anyone every try them on a 5th gen prelude?
  223. Stock H23 vs Stock H22 dyno charts
  224. ABS Fail safe relay?
  225. ANYTHING FOR MANUAL SWAP 97 LUDE!!
  226. Most desireable? Sh or base? Possibly buying a prelude soon.
  227. Problems Starting 92 Lude ????
  228. 4th gen lude owners in Northern New Jersey
  229. Starting to regret my na setup
  230. H22A5 in a 4gen Prelude 2.3si
  231. $$$ Rotors rotors rotors brakes brakes brakes $$$
  232. Ground Control Coil Overs with Tokico?
  233. How do i reinstall cam gears and timing belt
  234. My alternative to hood pins....
  235. drove car through water,... need help.
  236. 4ws system weight (searched)
  237. i've got $2000 what mods should i get?
  238. JDM Mirrors Hooked up to the E-Brake
  239. what valvetrain to use with type s pistons?
  240. 4th and 5th gen Shift cables the same?
  241. Steering Boot ripped: Should I be worried?
  242. Chamber Kit
  243. 18's on 4th gen stock height? pic request
  244. 92 Prelude H23 Header?
  245. Turbo Prelude brakes
  246. Carbon Fiber Hood
  247. Brake fluid resevoir leaking
  248. Searched Idle problems already
  249. Re-use Head studs?
  250. Oil Cooler
