View Full Version : Honda Prelude
- o2 sensor
- timing belt ?
- Busted tire rod??
- Rear Sway Endlinks
- where can i find a jdm internal cap for my distributor
- v-tec lag??
- 4th and 5th Gen VTEC intake manifold
- h22a swap code problem (searched)
- clock radio fuse
- Crank pulley removal question!!??? H22
- Fuel Problem
- Projector Retrofit Question
- Factory Fog light picture
- 4th gen fog light relay?
- i need help
- what's softer skunk or ground control??
- a lot of questions
- 92 Prelude and the blinkers
- surging idle
- BlackTrax Performence wait time: Time to throw in my cards?
- 4th gen rear lip.
- egr CEL problem
- stolen
- Shift boot suggestions needed
- 1998 Prelude black on black, 58k miles, new timing belt, $1k below book
- Tranny questions/problem
- what's the differnce=h22?
- wheel offset
- Need Help! Suspension
- Cigarette Lighter in 01 lude
- headlight problem
- Bad Gas Mileage in my lude :( HELP!
- New to preludes...
- How to: Progress Adjustable Rear Swaybar Endlinks---
- Please Help (Very Confused)
- I find the invertor for EL gauges cluster ...
- 93 Lude revving problem
- windshield wiper problem!
- 4th gen axle nut??
- my 5th gen stuck in 3rd gear!! and the stick is loose!! how can this be!!?? HELP!!!
- initial impression: Yokohama avid v4s
- v-afc II questions
- failed tensioner?
- Broken Connecting hose.
- tiptronic to manual conversion?
- Mid-engine Mini is on the road, sort of...
- HID kit on a 5th
- FINAL DRIVE REVISITED... 4.64 Final Drive?
- engine wont turn
- Coolant problems on h22
- Front Strut Tower Bar Installation???
- LSD ATTS question
- h22a dizzy 180 degrees
- mugen head/exhaust for 4genVTEC
- main relay question
- Simple Suspension Advice?
- foglights
- 92 lude h22 swap.
- h22 head on h23 block
- Trackday Checklist
- Couple more n00b questions.
- Head Studs on H22
- 93 stock si 4ws h22a - injector size?
- NSX Brakes
- ebay strut bars???
- LSD Question ...
- Strutbar Installation - Rear upper & rear lower help!!!!
- How to: Make your 94-96 USDM fog light switch!
- I had a question bout my clutch....?
- oil pressure sensor
- tanabe hyper medallion exhaust
- 96 automatic gauge in a 93 manual?
- Pics Of The Lude
- ?injectors?
- THE OFFICIAL Prelude Chassis Codes Thread
- 5th gen lude vs. new civic si
- Camber kit problem: Control arm relocater vs. Ball joint
- lude totaled?
- main relay clicking...no start
- Can you Supercharge a 4th gen Prelude?
- converting to external coil
- My Vtec is not engaging!
- motor mounts (searched)
- H23Vtec need your help please!
- H23 VTEC: Offset Grinding the H22 Crank
- anyone using an rsr ex-mag on their 5th gen?
- anyone do an interior conversion
- part # request (type s cams)
- Oil Leak somewhere??
- Inspecting Rod/Main Bearings, HELP!!!
- 3-Stage Vtec Civic Hatchback (37820-P2J-J62 Auto ECU to manual ECU conversion)?
- h23a1 timing
- Throttle Body Discussion...
- Lowering Springs
- wat could be wrong
- Lowering Springs???
- 96 Jdm h22 dyno
- What would cause Power Steering go out?
- pic request neuspeed front strut 4th gen
- h22a starting problem, 92 lude
- swapping 93 h22 oil pan with a 00...
- what bumper is this?
- WHO's using magnaflow exhausts?
- minor details. h22 turbo build.
- Oil change question
- Ticking (searched)
- Valve cover Gasket set-Question ??
- axles and transmission
- collector size and hp
- 93' Higher Mount Stop Light Problem
- bump bump bump
- which of these three suspensions???
- car not starting
- code 15 after i crossed wirez!!
- how do you tell how fast you are going with a jdm gauge
- Must be something I did? (CHOKING VTEC)
- VSS question
- My 3rd gen
- need tech help with prelude smog.
- Rack and pinion leaking help!!
- 92-93 to 94-96 el gauge cluster conversion
- Replaced Crank Seal & BS Seal
- Front speakers
- does any one know where i can find 4-2-1 gaskets for h22
- 6'7" any other tall drivers out there?
- So, I can't seem to get rid of my JDM P13 ECU, so I might have it chipped....
- Synthetic blend oil for break in
- h23a3
- Protection for OEM wheels?
- I need photos and article about EL gauges swap on 4gen
- Booo ATTS light
- prelude won't start in cold
- Fuel Pump not working.
- Q: about extra gauges on ebay
- Transmission sound NEED HELP!
- type sh/ 05 rsx rims
- bb4 front clip
- Crower Stage II +Valve Train DIY???
- JDM h22 question.
- Mugen RG wheels in a 4th anybody got them, pics??
- h22 vtec wiring for eg
- whats wrong with my pulley/engine?
- 4thgen gen carbon fiber trunk. anyone got one?
- Battery light on! 1989 Prelude Si
- Gas ???
- Rebuild jdm h22 trans
- Another 5th gen oil leak post, sorry
- clutch question
- GS-R or 97+ prelude. Which one should I get?
- CEL's on, no VTEC... common problems?
- Changing high beams 95 Prelude
- Fuel Filter
- Bleeding the clutch on a 95 Prelude
- stock prelude et.s and more ??
- new dc header lmfao 2.5" collector
- Fuel Rail???
- mugen style carbon fiber grill for the 5th gen
- 19'' wheels on a prelude
- prelude speaker bracket
- preludeonline.com help
- Lash Adjustment on H22a
- oil leak
- how to replace icu?
- review mirror
- brake light stays on
- anyone running skunk stage 2's with nitrous????
- will vtec controller effect a chipped ECU?
- can u mix match heads and blocks
- h22a in 92 lude
- h22a bearing selection. help!!
- H23 stage 3 camshafts
- Help: Removing Axles... (for motor removal) how to?
- quick question (counting cylinders)
- Please help on my H22 Project.
- help! my egr system keeps giving CEL
- h22 stroker motor
- solid, quality, cost efficient build on an H
- 5th gen taillights
- h22 doesn't rev past 6200rpm even w/ P13 ECU
- replacing tie-rod end...
- ok another noob question (serched)
- 2000 Prelude
- headers??
- shifter thread size
- 5g Quick Timing Belt Questions
- Mugen front bumper
- REally NEEd uR HELP-- Map sensor/Vacuum Problem
- Loud noise coming from up front somewhere
- Quick Question
- Diesel Fuel in the engine?
- 90 lude motor swaps
- vss sensor help
- 4th Gen Lights
- Shaking
- clutch going back? tranny? bad? 5th gen none SH
- Little help with compression ratio...
- clutch issues
- Acura Legend Caliper Brackets
- Brake Changing
- Chirping
- prelude carb prob need help
- buying a short shifter for my 97 lude
- help please! H22 dizzy wiring
- autometer need help
- what kind of speakers do 5th gens come with
- Another Heat Question-Searched
- tuning hondata vafc
- HF1 and HF2 Markings on Pistons
- What kind of headers???
- 95 J-spec H22 in 5th gen?
- rear brake piston not compressing all the way
- rims for a prelude
- has anyone here every bought from lean racing?
- my winter project.
- s2k / s2000 wheels on Prelude
- best cams and headers for nos set up
- 4th Gen passenger airbag insert
- New Ideas
- '93 Prelude H23A to F22B swap with poor gas milage please help....
- Ques Bout Knock Sensor
- keyless ignition in my prelude
- Are the 97-01 base and SH stock headers the same??????
- p28 some guy says it wont work
- Where I can get H22a JDM engine in Europe?
- bisi adpters,how much?
- IAB Kills car, ECU, Ignition wiring.
- Monitor installed in dash
- Help no reverse gear...
- CA Street Racing Penalties and Illegal Car Mods
- Brake Lines ??
- does this tranny have lsd or not (quick newb question)
- Any graphic design or other professional art h-t members out there.
- SH cams vs. base cams?
- clutch
- rattle
- please help, 91si -b16- head blown, needs new one, appraisal?>THANKS
- blocked oil passage? have questions, need answers
- Timing
- Omni power ??
- vtec solenoid code
- Valve Adjustment
- Squeeking
- help!
- Water entering through the cf hood?
- vavles
- clutch pedal falls to the floor after h22 swap.
- 91 prelude si turns over but wont start.
- prelude tranny mount
- steering wheel wont stop shaking!?
- Installed AEM UEGO Wideband: Getting code 65 (secondary o2 heater) even after resistor..??
