PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 [94] 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Custom turn on switch for installed monitor behind smoked screen
  2. what around the fuel rail/fuel injectors could make a whinnnning noise?
  3. Make this a Sticky! Manuals for EVERY Honda
  4. Muffler
  5. skunk2 intake manifold
  6. running VERY rich, ok to drive?
  7. NSX/LEGEND Caliper swap on a 4th gen Si.
  8. CEL Trouble
  9. CEL 1 ?
  10. Power steering pump grinds
  11. Car Problems
  12. Ssupension Question...Please Helpppppp
  13. greddy evo2 fitment and sound
  14. Removing freeze plugs..
  15. Quickest and Easiest way to Change Alternator belt
  16. Car wont start either PLEASE HELP
  17. car won't start....LOL
  18. average dyno time for a vafcII
  19. wheel Alignement
  20. OBX LSD Specs?
  21. Replaced battery, now starter just clicks.
  22. Noise In the Engine
  23. 4th gen lowering springs
  24. prelude for sale
  25. Cluster lights dont work
  26. Overheating and weakness in my H23A1 Prelude...
  27. h22a head for sale
  28. will a JRSC fit in a H23 in a 5th gen
  29. WTF??!! [video]
  30. have you ever order ne thing from here before??
  31. delete atts
  32. anyone found a Cpillar bar for 4thgens??
  33. HELP ! question bout red key
  34. LOOKING FOR A SILENT EXHAUST AND HID CONVERSION KIT FOR 93 LUDE
  35. Locating the speed control
  36. urgent will 93 jdm h22 pistons fit 94 usdm h23 rods?
  37. AGC (S) Fuse?
  38. spring interchangibilty???
  39. f22 headers compatable with h22?
  40. ****Egr block off plate??****
  41. 4th gen Hood dampers! WOOT!
  42. ATTENTION Sh Owners *** suspension emergency ***
  43. Braking Vibration - NOT warped rotor related
  44. Idea for Traction?
  45. To remove ?
  46. Some lights on, some wont turn off, car stuttering, no power, lights dim, alternator???
  47. where/how to remove srs computer
  48. Any good tuners in St Louis area
  49. 95 prelude stalls at stop light with the AC on.
  50. 91 prelude si parts car...who needs something...anything
  51. CAMBER KIT HELP!
  52. Auto tensioner
  53. lug nut size?
  54. Kaizenspeed balance shaft kit
  55. si and Sh header
  56. 98 prelude oxygen sensor
  57. swapping h22a for f22a1
  58. F20C Crankshaft in an H-Series motor?
  59. H22a4 Complete Rebuild
  60. 99 Type sh looking for parts
  61. h22 block /h23 head
  62. help.. rhythmic vibration when 65mph+
  63. ECU question???
  64. is the cv joint of a prelude the same as accord?
  65. No 5th gear or reverse! Help me please~~
  66. anyone kno where i can download the emanage software?
  67. Clutch won't depress
  68. Need specs
  69. gauge cluster???
  70. Prelude Is it possible For AWD
  71. Head gasket and camshafts?
  72. RPM problem for ignition timing on H22A ?
  73. Ebay Header...my :thumbup:
  74. Distributor problem!!
  75. H23 to H22 ???
  76. whats the difference between
  77. H23 buring oil
  78. 1989 Honda Prelude Tranmission
  79. Hex head size for rocker arm
  80. Prelude engine problems
  81. Randy at RMF
  82. 92 Prelude needs brake pads
  83. Difficulty starting after car has been in hot sun/engine is warm
  84. Code 9
  85. Radiator leaking what radiator should I get
  86. A/C Removal Question.
  87. spark plugs got oil on them...
  88. i turboed a h23 prelude
  89. replacing rad fan motor on a 97 prelude....
  90. SH drop
  91. IAB's
  92. ok i need help for a h22 swap and mods
  93. h22a swap sensor question
  94. Will only 97+ Alternators fit 97+ cars?
  95. Scan request: 5th Gen Helms Manuanl main bearing specs
  96. autozone axles.. (better than napa?)
  97. bearing decision help
  98. Warmed up Hesitation
  99. 5th Gen Prelude Parts fir sale in the northern cali
  100. Turbo Kit for 98 Prelude - F20a
  101. M2A4 5th gear
  102. Alt Belt Problem
  103. Critical Coniditon Prelude -Some advice
  104. Ride height
  105. h22/h23 alternator difference
  106. will stock ITR rear rotors fit on type sh?
  107. H23 Vtec Setups
  108. My 92 Prelude Project
  109. My 00 prelude project
  110. kph gauge
  111. Honing H22 cylinders.
  112. hit a speed bump!
  113. New wheels, floating feeling coming from rear?
  114. Nitrous plug gap
  115. 4 gen rear fog light????
  116. H to B tranny conv??
  117. Suspension Question?
  118. how can i insert pictures?
  119. SH camber kits
  120. exhaust gaskets
  121. KYB AGX / Tein S-tech
  122. Tien Stech and SS difference?
  123. Car wont start when it rains????
  124. i hope i didnt order the wrong part?!?!
  125. CEL Code
  126. VafcII and hondata N/A and turbo questions
  127. Gas
  128. 1991 b21a1 si
  129. Its official My Service plug doesn’t Work
  130. Differences in calculation between the 2 calculators???
  131. Exhaust sound clips?
  132. Would DSM 450cc injectors work?
  133. Strange noise from fender
  134. squeeking
  135. Dont know what year my lude is!!!
  136. 6 puck ceramic clutch break in ?
  137. cat-back exhaust
  138. H23 Crankshaft Question
  139. NSX brake calipers
  140. Heated Seats?
  141. Map Sensor blockoff plate
  142. Wet Nitrous Kit Install
  143. 4WS Code 20
  144. Help Remove Prelude 1998 Stock Radio
  145. 4 wheel steering uugghh 92 prelude
  146. ignition coil question
  147. idle problem
  148. what's my best option?
  149. H22A idles on start up for a few seconds then shuts off!!!! HELP!!
  150. Knock Sensor! Do the wiring connect at the top or bottom of the connector?
  151. Removing Rear Seats
  152. cold air intake vs. k&n filter
  153. maintenance light under speedometor on !!!!
  154. Turbo'ed auto?
  155. cel 22 VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch
  156. 91 accord 5sp need help
  157. Worlds Fastest Preludes
  158. very dumb question but i just thought about it.............
  159. gear oil
  160. clutch question
  161. CEL at 50 mph
  162. help - found my oil leaks 98 lude
  163. timing belt , 87 2.0 injected
  164. Help oily plug in cylinder 1.
  165. Header suggestions?
  166. Will base modle exhaust and header fit on SH modles
  167. Prelude won't start.
  168. What Do I need to do for a Compression test?
  169. Camber and Tow in?
  170. Tranny Swap ???? NEED HELP!
  171. A/C PSI and oil question
  172. Convertible Prelude!?!
  173. Changing clutch - transmission stud bolt MUST be removed?
  174. Euro-R (PDE) vs. Stock (P13) cylinder head comparison (pics)
  175. TPS problem???? yes I searched first
  176. H Beam H23's
  177. me=retard
  178. tach and speedo fuse
  179. DOHC < SOHC?
  180. Bearings
  181. Seafoam question...
  182. Greddy TiC exhaust?
  183. Want to do list for my 5th Gen.
  184. Is there a difference between an OBDI and OBDII fuel pump?
  185. prelude exhuast pic.
  186. Suspension For a 97 SH, a couple questions
  187. hearing inconsistant whinning noise now. not ac/ps/alt belts/pullies/pumps. comes from around inject
  188. 12.2 Compression pump gas?
  189. Draining Radiator
  190. Does it matter which end of the EGR ports go in first?
  191. Help, h22a4 all obd2 into a civic wiring and other issues
  192. What is this sensor?
  193. After years of wasted thought...
  194. H22 oil Pan made by OBX
  195. changing fuel filter... need help
  196. compression test
  197. H22a hatch. questions
  198. 98 style LMA's better that 92-97 style??!
  199. Neuspeed or Vibrant?
  200. quick dizzy question
  201. CEL on after 5 min... of driving
  202. rotor removal hole
  203. Tranny Fluid Leaking
  204. header/exhaust?
  205. si tach w/ vtec motor
  206. SH Wheel Alignment in Northern VA???
  207. Cabin air intake removal.. please help
  208. question about an exhaust system.
  209. Okay found out something.. Take a look..
  210. h22a 1/4 mile times??
  211. hondata??? for h22a
  212. New relay switch .. now cars acting up
  213. have any base owners bought the SH leather shift knob from Honda?
  214. anyone has pics of 4th gen with a dvd double din not the single din
  215. obd1 h23 injector size?
  216. Possible Clutch & Flywheel Problem?
  217. Cleaning up; Just a couple questions...
  218. Throttle body spacers????? H22
  219. 83 honda prelude pcv provlems
  220. f22 boost vs na
  221. 01 H22a4 Accord - Code 9 - Cylinder Position code will not go away
  222. clutch question
  223. "Brake Lamp" Light on
  224. Hondata P72 problem
  225. car want start
  226. Motor swap. Not starting! 91 prelude Si.
  227. Turbo Timer install
  228. accord type-r head
  229. Wiring for Sensors and Vacuum Hose Routing
  230. 92 prelude obd1. VSS works about 10% of the time. Will I automatically fail a smog test?
  231. Wheels for my 92 SI 4WS
  232. Where can i get a good deal on H22a?
  233. questions
  234. Forbidden Short Shifter Update for 5th gen?
  235. 92 prelude with 96 h22a running overly rich
  236. H22 SMSP header dynos.
  237. Replacing Suspension soon..
  238. Power steering removal in a 95 prelude
  239. 3pt. Harness install?
  240. Just a slight problem with my Prelude..
  241. H22 Intake manifold TEST RESULTS !!!!!!!!!!!!!!!!!!!!!!!!
  242. F22 in a 92 lude
  243. h22 oil pan gasket.... & 92 to 96 center console/ebrake conversion
  244. Need sidemarker help
  245. H22 bottom end price?
  246. 0 pressure at start and idle then car dies out after 2 sec idle!!! help please
  247. White Smoke
  248. wheres a good place to order parts??
  249. Hello all!
  250. timing tensioner
