PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 [148] 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Front Right Knocking when turning. spring??
  2. What headers fit on an DOHC F20B Vtec?
  3. HID / Retro-fit / OEM cars ??
  4. Starting issues i need help asap!!!
  5. balljoint
  6. h23 forged pistons
  7. 4th gen H4 bulb JDM headlight wiring questions (searched)
  8. Anyone recommend a good gearshifter knob?
  9. Slave cylinder/master cylinder
  10. Adding trans fluid to oil, to break up sludge/gunk buildup...
  11. 2001 prelude dash brake light comes on
  12. Crankshaft question.....
  13. Vtecs Limited in First???
  14. bike roof rack for prelude 4th gen.
  15. Fan is staying on all the time HELP!
  16. H22 tranny issues
  17. What next?
  18. h23a1 crank
  19. JDM H22
  20. Oil Pan Interchangeability
  21. 2 quick questions
  22. Any companies modifying the Euro R manifold?
  23. cv boot question. easy
  24. Electrical problem far worse than previously reported...
  25. Idle blip
  26. EGR removal .. no one has done it successfully?
  27. steering wheel
  28. Offset Grinding V2.0
  29. f22b
  30. Greddy header on a 5th gen
  31. Strange Oil Leak
  32. need help. finishing motor install
  33. p13 ecu question
  34. will removing the air hose to the secondairies butterfly keep it open?
  35. Accord and Prelude
  36. Advice on prelude purchase
  37. Timing belt schedule interval & leather seat option
  38. Energy Suspension Motor Mount Inserts....
  39. finaly h23 apart
  40. Issues with poor idle
  41. MT pedals
  42. Chipped P13 ECU,Venom B series cam gears, Second dary butterflys
  43. H22 Integra Cables for Shifting!
  44. Skunk2 manifold vs OEM manifold picture?
  45. residue above header
  46. Gear grinding with cluth down ??
  47. Oil Control Orfices H22 Head
  48. h22 question
  49. transmission P2A8-1003988 what the heck is it and will it fit please help.
  50. How do you take the a pillar plastic off?
  51. H22a and integra type r Diff compatibility?
  52. FS: 17x7.5 5Zigen ProRacer GN+ (bronze) wheels w/ tires
  53. 4th gen passenger blue-green metallic fender!
  54. cams, and lip kit
  55. Write-up: 4g prelude manual rack conversion
  56. Type SH emblem
  57. help! in need of an 98-01 lude type-s flushmount spoiler....
  58. h22 crower springs and retainer
  59. slave an master cyldr ??
  60. distributor question
  61. Body Shop To Put Lip On?
  62. h22 cams
  63. spedometer not working
  64. Rally lude in roadracing forum
  65. clunk with cold air intake
  66. ebay header didnt come with bolts
  67. help with engine swap
  68. Window tint
  69. anybody wanna share there stock 5th gen Dyno numbers?
  70. Loud Knocking Noise? what do you think?
  71. F22 power steering hose work on H22?
  72. sigh, quik h23 question!
  73. water squirking out of exhaust today
  74. Fidanza Cam Gears
  75. engine damper compatibility?
  76. Best Halogens?
  77. Noisy rear end
  78. Looking for other Lude owners in the area
  79. Cam Timing
  80. 4th gen sidemarkers
  81. Electrical question--why won't my fan shut off?
  82. Injector upgrade for 95 H22A - which type?
  83. desperately need help ....fault codes
  84. 5th gen / 4th gen radio
  85. what exactly do i have to do to fit dsm injectors in my 5th gen?
  86. looking for DC header
  87. H23 experts, i need your help!!
  88. need input on flywheel, thanks
  89. jdm 1 piece with no bulbs
  90. any1 have pics of a sunroof/wind visor on a 92-96 lude?
  91. Anyone get a emissions warranty externsion reminder from honda dealership???
  92. Nother dumb question
  93. Speaker Wiring Schematic
  94. Wiring Question(Searched)
  95. 96 prelude Main Gauge cluster wiring
  96. Kansas Ludes
  97. h22 having tps problems.
  98. need help ASAP!!!!!
  99. dirty exhaust
  100. Question about rods for Type S pistons
  101. What Size Tires?
  102. Is there a Bentley manual for the Prelude? Looking at their site, I don't see one listed
  103. Ball joint? but im not sure.....help!!!
  104. Whats is default compression for H22a engine?
  105. Rebuilding a H23
  106. 1990 2.0si TDC (Top Dead Centre) Sensor
  107. What should I replace on a 110k H22 before I drop it in?
  108. Compression question
  109. high flow cat?
  110. OBD-1 and OBD-2 injector Question...
  111. Full coilover set not just sleeves.
  112. Are there any 2"+ lowering springs that can be used with stock shocks?
  113. Prelude SH
  114. problem after increasing fuel PSI
  115. 5th gen.. interior and exterior lights are all flickering!! HELP
  116. Need Help with H22 Thermostat/Seal in Thermostat Casing
  117. im having trouble finding full suspension for a 5th gen SH.... HELP!!!
  118. **PlEASE READ** Wierd request
  119. Cant put the new timing belt on to save my LIFE.
  120. Clutch issues....need help searched already
  121. weight of
  122. H2B Adapter Plate?
  123. Best Exhaust For 99 Prelude
  124. arospeed or b&m fuel regulator on h22a??
  125. Radio wont work
  126. Is this a genuine Turbonetics Manifold at this price?????
  127. 97 prelude no start no spark
  128. Resale value?
  129. what goes next?
  130. Difference in SHOCKS
  131. auto 2 manual swap.
  132. i need the valve lash for 88 sohc prelude
  133. State Ref won't Approve AEM Short Ram Intake
  134. bleeding master Cylinder
  135. question on a 96 si
  136. Ignition Timing Problems
  137. Carshows Near New York State
  138. F22A PS Bracket on H22A Motor
  139. Speedo Bulbs & Climate Control Questions.
  140. Retrofit work!!!(I'm finally back)
  141. Budjet for boosting H22A
  142. difficulty of replacing an abs modulator
  143. got my motor back..nitrous install pix
  144. stock retainers with upgraded valve springs on h23?
  145. jasma FGK header?
  146. What's Honda's official 0-60 time on the 4th gen VTEC prelude?
  147. I need an official link to the balance shaft recall for the 4th gens
  148. RPM needle bouncing like crazy... car sputters sometimes about to die...
  149. WIll f22 clutch work in h22??
  150. anyone running 16x8 38mm offset?
  151. $10 PAYPAL to who solves problem
  152. JDM H22 vs USDM H22 - Differances?
  153. VAFC/SAFC worth it? (searched)
  154. f22 header?
  155. CYP Sensor???
  156. 89 Prelude Si---NEED HELP ASAP!!
  157. 4th Gen Gauge Cluster
  158. Valve cover stud came out
  159. 94 lude h23 burning oil in engine
  160. question bout 5th generation preludes...
  161. prelude atts removal?
  162. type-s header
  163. need answer asap
  164. battery draining problem
  165. Auto 2 Manual?
  166. Upgraded Front sway bar endlinks?
  167. my car makes a lot of noises inside
  168. D4 Light Blinking Help
  169. MUGEN or CUSTOM MADE EXHAUAST?
  170. Breather Filters
  171. will a JDM ITR SRS momo steering wheel fit 4th gen?
  172. Pulled a code '22' 2nd time in ~1 month...
  173. m2b4....H23?
  174. I have some cams.. now what?
  175. Problems!..
  176. So why are VAFC's "junk"?
  177. Trunk Lid/Spoiler
  178. Driver seat recommendations
  179. where to buy JDM h22a tranny internals?
  180. JDM M2B4 Tranny (VSS)
  181. weird idle dropping. sparking problem?
  182. Difference between BB1 and BB4 ??????
  183. NEED HELP!!! i have some h22 injectors JA21 i need 2 know the cc's
  184. H22A - disappearing oil problem
  185. Loose Timing Belt
  186. what is needed for a 60k tune up?
  187. what susp setup and stabilizers are you using?
  188. i need 93 prelude vtec stats
  189. My 93 prelude vtec has a problem
  190. h22a4 piston
  191. what does an energy suspension insert do?
  192. f22 with h22 pistons?
  193. noise from belts
  194. 5th Gen Headlight Dissasembly??
  195. Debris from Auto Tensioner Failure.
  196. Fourth Generation Rotor Question.
  197. help me repair my h22a please.
  198. Another, Where might I locate??
  199. hood
  200. replacing 1993 prelude center console with the 1994 one.
  201. Swaping from f22 to jdm h22 need help
  202. OBD1 Tranny in a 5th gen
  203. Type S Distributor
  204. question bout the driver's left side engine mount?
  205. h22 powersteering bracket doesn't fit F22
  206. Golden eagle rear tow hook (searched)
  207. f22 vs. h22a gauges? MPH / RL?
  208. h22/h23 build
  209. Idle
  210. Bore?
  211. h23 tranny top speed
  212. EGR Valve Replacement Tech Guide
  213. Type-S or AEM?
  214. Where to attach aftermarket FPR?
  215. AC line removal?
  216. engine problems??
  217. What tranny is p2a5?? *searched*
  218. H22 Crower stage 3 CAMS
  219. Switches, gages, pods, vafc ...
  220. Neuspeed springs
  221. Speedometer acting funny - occasional CEL
  222. Water Temp/Oil Temp gauge install.
  223. anyone running he t3/67 ??
  224. '93 H23A1 Top End Rebuild
  225. Help With Timing Belt
  226. H22a1 Head gasket vs. H22a4 gasket
  227. Is PSPEC still in business?
  228. Prelude SH cams
  229. 2nd gen Prelude engine change
  230. Serious bog/hesitation problem!
  231. Would an S2000 drivetrain go into a prelude?
  232. A/C H22a compressor problem
  233. 97 Euro R, bad gas mileeeage :|
  234. What size is the rear and front "H" on a 2000 prelude?
  235. Shot shifter???5th gen
  236. whats u think of this oil cooler?
  237. stock cat with exhaust???
  238. New h22 website!!!
  239. Removing stock wing with led brake lamp, how many holes will be left??
  240. KYB GR-2 shocks, who has em?
  241. Amp hookup?
  242. JDM H22 Dyno 200whp
  243. Water Pump Problem?
  244. CCA needed to start 95 prelude h22a
  245. car is draining battery??
  246. H22 EG Dead
  247. Clutch went out (99sh)
  248. Flooding at Startup, and Other Fuel Issues.
  249. carbon fiber side skirts-SEARCHED
  250. Plugs for turbo SH
