PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 [99] 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. 92' Prelude
  2. HEADER ONLY?
  3. AEM DRYFLOW?!
  4. KYB SHOCKS?!
  5. 96 prelude different body frame?
  6. what is this sensor(between vacuum from fuel pressure reg to intake manifold) jdm h22a
  7. Noise when i shift
  8. h23 Wire tuck.
  9. radiator
  10. tach test connector
  11. Balancer Belt
  12. JDM headlight install help!!!
  13. hood dampers and suspension
  14. clutch and flywheel vs. RMF/SMSP header
  15. 4K RPM at 80MPH
  16. What brand for Valve Seals?
  17. JDM or USDM Fogs and Switches?
  18. good pistons / rings
  19. settings for performance street alignment?
  20. mounting 225/45/17s on 17x7 rims with neuspeed springs
  21. O2 sensor bad?
  22. my car won't start ( no spark )
  23. Heater Bypass Hose
  24. transmission compatibility
  25. jdm headlight install
  26. Problem: Car won't start.. code 20 or 21 im not sure! HELP asap
  27. Removing butterflys in IM for boost?
  28. 5th Gen Type SH or Base Model?
  29. turbo
  30. gear problem
  31. 7 hours: yellow capsule retrofit (pics)
  32. what am i expected to run
  33. how do you remove the side skirts for the bb4
  34. parking brake cable? difference between sides and years?
  35. WTB OEM H22-23 shiftlink
  36. VTEC / smoke problem
  37. Can't find where to buy this piece
  38. Question on shaving H23 head
  39. HID Lights for 4th gen. 1pc Blackedout headlights
  40. Dash harness questions....
  41. 1998 Honda Prelude
  42. White smoke = coolant (water)????? HELP!
  43. some please help?!?!?!?!?!?!?!?!
  44. HELP ME
  45. Seat belt harness
  46. si to vtec brakes, do i need abs computer?
  47. help jdm h22a in 92!!!
  48. Suspension Question....PLEASE HELP!!!!
  49. changing headlight bulb.
  50. 92 lude wont rev, past 3200rpm's
  51. OK to remove egr vacuum control and egr control solenoid
  52. EGR Port & Carbon debris
  53. autometer water temp gauge????
  54. Anyone have a radio pinout picture?
  55. prelude suspension
  56. where can i get my h22 transmission built............
  57. Engine shutting off after 25 minutes of use...
  58. braking issues
  59. M2B4 Prelude Trans. Expert needed!!!
  60. ?? Would air get into the coolant system if ...
  61. H2B Swap Tranny?
  62. question???????vacuum lines!!
  63. h23 crank
  64. Transmission for ludes?
  65. Heat wrap MR header?
  66. Need some help
  67. 97 prelude size and offset.
  68. skunk 2 coilover 97-01 prelude
  69. Stock 5th gen muffler wanted
  70. 91 SI, need picture of relays in engine bay box
  71. f20b rods wtb
  72. Need help on odb1 to odb2
  73. 5th gen. Koni yellow's on a 02 TL-S
  74. 1994 center console into a 1993
  75. axle pulled out.. all messed up! help!
  76. 4th gen. prelude seats into a 5th gen. prelude
  77. ATTN Ground Control owners (locating p/n #?)
  78. 4th gen aftermarket / racing seats
  79. Euro Intake Manifold Modification Writeup (European F20B H22A Single runner type S)
  80. NOS on an A/T
  81. fuse box diagram ???!!!
  82. stock radio question
  83. resonator
  84. Aftermarket ECM
  85. how to tell legal/non legal headers?
  86. heat shield for headers?
  87. Trans DTCs
  88. 4th gen body
  89. power steering cooler..
  90. OBD2 Turbo Preludes?
  91. 12:1.1 compression daily driver
  92. Replacing primary 02 sensor with AEm UEGO?
  93. wideband o2 with autometer gauges AF??
  94. really oily black rersidue on my back bumper-- B20a6
  95. straight pipe would
  96. anybody own a h22 tuned with an apexi neo
  97. Adjusting clutch?
  98. BPI Flow Stack Yes OR NO
  99. someone please help. MAP sensor!!!
  100. Issues with JDM H22 swap
  101. H22 swap
  102. 'rolling' digital odometer [Archived]
  103. Pics for 4th or 5th gen manual rack conversion ??
  104. 15" RA1's and steelies on a 97+ lude...will they fit?
  105. O2
  106. machine shops in north jersey
  107. losing engine oil
  108. wierd acting idle after by-pass just need a clarification
  109. Prelude engine conversions/mods
  110. Blaster Coil-No Spark
  111. Where to buy oil pump???
  112. precisionelite vs. 98vtec / the battle for 13's
  113. Reverse Grinding
  114. Shift Boot Question
  115. shops to sleave H22 block
  116. h22 making wierd cricket noise?!
  117. need help rebuilding a JDM F20B for boost
  118. ABS computer 5th gen
  119. want
  120. mugen????
  121. question on intake manifold
  122. h22a1 vtec problem?
  123. mugen front bumper???
  124. VAFCII on an SH?
  125. im new and i got a question
  126. fuse box
  127. gas/temp gauge, cig lighter, and radio stopped working at different times?
  128. High Revving H23.
  129. Megan Racing Rear lower tie bar problem.
  130. Fuel Return line.
  131. RHD CONVERSION
  132. 3 bar map question
  133. H22a4 - What can I do with it?
  134. question on flexie pipe
  135. Prelude front conversion
  136. Aftermarket radio, antenna question
  137. h22a intake mani vs h23
  138. H22/H23 Crank Pulley
  139. boosting a h22a
  140. ground controls and KYB shocks
  141. vtec controller is it worth it?
  142. Which set of springs is the rear and front?
  143. haven't really seen this idea for an antenna replacement
  144. What exhaust system will work better for my 99 Prelude?
  145. quick ignition timing question. external vs internal coil matter?? getting 6degrees timing
  146. -I know you're sick of it....But here's another exhaust ?-
  147. arc intake
  148. Ok i am getting no feedback on the vafcII
  149. WANTED: PRELUDE driverside engine mount and H22 tranny
  150. springs and shocks
  151. Where can i order...
  152. taking off head without taking off intake manifold
  153. vacuum line question
  154. atts questions
  155. piston rings for mahle gold series
  156. -I can't find the link?-
  157. matal plates under back seat
  158. h22a1 head on a h22a4 block
  159. $2500 + h22a= what should i get here guys
  160. i want h23
  161. i need the tq spec 4 a h22a4 the arp head studs
  162. Installing Valve Cover
  163. this may sounds stupid but
  164. O2 Sensor- Who is the OEM?
  165. 93 Prelude Swap Question
  166. Dirty Intake manifold? help?
  167. misfiring due to carbon buildup?
  168. turbo question
  169. VTEC question
  170. Prelude S prop valve diagram
  171. oil pressure sender unit
  172. Weird shaking problem when accelerationg around 3500 RPM
  173. S2k oil filter...oil pressure ???
  174. Baffled oil pan
  175. pics of traction bar ?
  176. has anybody had the problem with their digital gas and temp gauge
  177. Tachometer dead, intermitant bounces, engine runs perfectly.
  178. Axles ..OEM or Napa brand ??
  179. loss of top end power....i think
  180. skunk2 pro1 vs skunk2 pro2 cams
  181. factory o2 sensor angle
  182. tapp size for 02 sensor bung??
  183. Installing AVC-R?
  184. wire identification for tach problem
  185. Using a H23 crack pulley on a H22??
  186. 4th gen quarter miles
  187. New GReddy TiC Exhaust sound?
  188. low rpm engine clunking?
  189. Balance shaft Removal??????s
  190. choking noise in my engine
  191. Civic suspension on a Prelude.
  192. wire tucked engine bay pics
  193. skunk2 tie-bar HELP!
  194. car still shaking
  195. Rear suspension curse for prelude owners?
  196. EL cluster wiring diagram
  197. -What's that sound?-
  198. im new with forums but familiar with cars
  199. port and polish?
  200. Help a new quy...
  201. RC Injectors
  202. Rear window Visors
  203. Vtec oil usage?
  204. Intercooler piping
  205. Black Smoke Problem And Leaking Oil.
  206. VTEC Swap Questions???
  207. question about altenator belt?????
  208. doing an interior conversion on my 5th gen
  209. Very bad clicking noise from ..?
  210. dohc head on f22 block
  211. Rod and cop question
  212. engine swap
  213. H22A4 Rebuild Questions
  214. 2008 Prelude?
  215. lowered 4th gens!
  216. Ground systems or voltage stabilizers?????
  217. h22 euro r header
  218. Flywheel quetion?
  219. H22 on F22 Turbo
  220. Turbo on A/T H23
  221. Electric Supercharger
  222. apexi turbo timer
  223. HID problem
  224. Is this trade worth it?
  225. Just bought a Prelude...worth it?
  226. Intercooler piping and air filter problem
  227. weight question
  228. $$Fair Asking Price$$
  229. what is H2B?
  230. JDM H22/ USDM H23 garage sale
  231. aftermarket OEM parts?
  232. Need your opinion
  233. 2 problems..i need some advice
  234. What gears do these correspond to?
  235. anyone using bloxs racing parts
  236. Sway bar bracket broke off.
  237. Calling all slammed ludes (Fender lining/rubbing/etc)
  238. Aftermarket Spring Rates For 4th Gen
  239. oe part numbers
  240. BRAKES
  241. Battery Drainage/Seat Belt on 91 Si
  242. Any 4th gen flat black preludes out there?
  243. bout to get some slipstreams
  244. jdm window visors
  245. Valve question
  246. Future Prelude Owner's Buying Questions
  247. LED light for vtec?
  248. do I need mid-rise lift to remove cylinder head on 5th gen?
  249. high flow cat --> stock cat
  250. magnaflow muffler sizing
