PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 [184] 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Does this mean my H20 Pump is Shot?
  2. Apex'i Filter Installation?
  3. Calling all tune up experts!
  4. Will paint stick to my side skirts?
  5. Ignition timing Tech question
  6. prelude swap
  7. NEED HELP .. something is worng with my wheel (5th gen base)
  8. Flywheel application!
  9. Security: Power-door locks / Courtesy entry light
  10. hondata write up needed!
  11. broke an oil level sensor on the ATTS
  12. 1988 Honda Prelude Throttle Angle Sensor
  13. Problem with rear wheel camber (5th GEN prelude base) NEED HELP !!!
  14. Difference between SH, S, and base...
  15. help with troubleshooting clutch issue
  16. engine prob and broken axle i think....
  17. Another Cam Gear Question...
  18. Suggestions/Opinions on my planned rebuild in 97 SH with 145k miles
  19. saturated injectors and peak and hold
  20. diff between p13 jdm ecu and p13 usdm ecu
  21. 4th Gen: Unit all the way to the right in dash
  22. Thermal R&D cat-back - 2 videos
  23. trunk lid lining and aftermarket spoilers
  24. Looking for the Civic Radiator in Prelude Post
  25. tein hood dampers?
  26. adj cam gear slipped
  27. Why is the prelude redlining at 6900?
  28. where to buy oem lip kits for 5th?
  29. a/c removal
  30. H22 O2 sensor CEL??
  31. H22 o2 sensor qustion.
  32. ? on guages for a BB6...
  33. 92 Prelude AC Compressor? Where do I put the oil in?
  34. suspension question.. which is the right direction
  35. how to take shift linkage off of h22a1
  36. any 5th gens out there with a "wire tucked" engine bay?
  37. IDLE PROBLEM
  38. sputtering Problem
  39. Climate control Realy?? Is there such thing
  40. H22 Flywheel bolt Help
  41. 98 Base 5-spd Baseline dyno, opinions?
  42. Broken wheel stud
  43. H22 Intakes and Velocity Stacks
  44. OEM Honda Alarm manual!!!? help
  45. h22 crx vs. twin turbo 240sx **vid**
  46. anyone try to black out the OEM headlights?
  47. where can i find parts for my 90' 2.1 L Si?
  48. Looking to buy 1 stock 97-01 PRELUDE WHEEL!!!
  49. Vids of H22 ITBs
  50. chocolate milk inside my radiator
  51. anyway to bypass the h series stock oil cooler/heat exchanger?
  52. Built H22-505 whp and 378 ft-lbs at 21 psi
  53. how do i do compression test?
  54. K&N CAI Replacement filter model number?
  55. Types of Trannies? Which one is which?
  56. is anyone running 8in wide wheels on their 5th gen
  57. Optimal RPM for shift/cruise?
  58. Direction I should go with my 94 SI
  59. can't get the axel out
  60. Flywheel/ Starter :(
  61. Transmissions Questions
  62. plz give me a hand w/ these codes...im lost
  63. 86 prelude and 92 accord
  64. Which heads will work on a B20A5 motor?
  65. Apexi N1 question
  66. cv boots - how important are they?
  67. Best form or intake??
  68. prelude motor mount for 350 + hp
  69. overheating problem
  70. H22A: where do i find the intake secondary solenoid?
  71. lowering help
  72. Jumper Settings for Emanage
  73. Stock Radio Question?
  74. 93 prelude si dash cluster qustion....
  75. Euro R intake Manifold from se93
  76. H22 manual tensioner
  77. Correct Thermostat Part Number for JDM H22A
  78. Random wire clip-what is it?
  79. 01 street lude runnin early 10's on 1/4 mile!?!
  80. Stupid Question- Difference in Spark Plug Wires
  81. type sh or S
  82. What compression ratio with F23a block bored to accept H22a4 pistons and H22a4 head?
  83. Where to find UN-cut dash harness?
  84. question about exhaust piping plz help
  85. somebody help please
  86. Emission test High levels
  87. Dynoed the hatch on Wednesday
  88. 4thgen shaft problems
  89. gapless rings in H23?
  90. where is this?
  91. H23 wiring ready for H22 VTEC?
  92. 4th gen: What is normal water temp
  93. m2s4 5th gear into m2f4...its possible
  94. need a new exhaust is this a good plan?
  95. Need help.... lude was stolen...
  96. I hate my Skunk2 coilovers!! [long...]
  97. awd 93 lude???
  98. all-motor h22
  99. H23 --> which H22 injectors for obdII H23
  100. Type S oversized pistons- hone or bore???
  101. aftermarket shocks - stock dust covers fit?
  102. Car dies, Will not start......exhausted efforts...
  103. you guys think this fit 93 prelude
  104. Oil on spark plug threads
  105. black suit on back of car
  106. 5th Gen Headlight Removal
  107. Burning Oil to Fast... Engine Rebuilt?
  108. tires.......?
  109. cv boot ripped?
  110. Accord Struts and coilovers the same as 5th gen Lude?
  111. gm_syncromesh
  112. Tech Question
  113. new Headgasket... leak not as bad
  114. crower stage 2's vs. skunk stage 1's (h22)
  115. H22A1 Syncros
  116. dumb turbo questions
  117. h22 6spd?
  118. Does advancing the timing give you more low end or more high end?
  119. megan headers
  120. How much
  121. Did I lose my brakes or my bearings?
  122. What kinda 1/4 times
  123. camber kit recomendations
  124. clutch or synchronizer??? prelude sh 98
  125. does this come out when removing ac?
  126. Custom Exhaust on 94 SI
  127. h22vtec exhaust on a h23 will it work?
  128. H23: longer rev out....
  129. 5th gen Tranny help
  130. Viper alarm... Install
  131. went to the track last night
  132. head gasket size
  133. normal?
  134. anybody knows if this would fit a 92 prelude
  135. Good news: 4th gen rear lower ball joint same as front = 86-90 Legend front ones :)
  136. H23 vs H22
  137. Changing Steering Wheel...what happens to 4WS ???
  138. phantom nitrous gauge
  139. RSX TYPE S/S2000 Seats in 4G
  140. supposedly type s head
  141. anybody know wiring on passenger side of 92 prelude s?
  142. type-s/sh coolant drain plug lcoation?
  143. help on piston
  144. how to take wrist pin out?
  145. how can i tell if i got 96 and up prelude injectors (290cc)?
  146. Axle Problem
  147. Prelude Type R, need help convincing idiot there is no such thing
  148. mismatched INJ #2 and #3 FIXED by changing the #2 and #3 firing order
  149. how to disassemble 4th gen fog lights?
  150. How to take Crank Pulley off?
  151. Starting Problem
  152. H22 and H23 B-Pipe difference in lenght
  153. New to Prelude 1984 (I know very old but can I tune?)
  154. my frend busted his lude!! OMG
  155. JDM Window Visor Installation
  156. tokico hp shocks and spring
  157. trying to get a hold of seller, i forgot his user name! SKUNK2 coilovers for 4th gen
  158. 5th Gen Door Panel Removal
  159. Changing Rear O2 Sensor?
  160. prelude air to fuel please help
  161. DROPZONE
  162. jdm antenna w/ half-switch istall q's
  163. prelude flapper valve mod, will this mess up my a/f ratio?
  164. CEL help.....
  165. HELP: sucked water through my intake
  166. suspension help
  167. What's the difference between H22 and H23 engines?
  168. ???How many miles are on your H22/H23 hybrid???
  169. Gasket sets?? Please Read!
  170. climate control problem, 5th gen
  171. NEw Gearbox to be added to the G-Box codes list
  172. ///////////// do 300zx pistons fit in a h22???? i was told they do!!!!!!!!!!!!
  173. stock / stock with bolt-on 1/4 times (tuner shootout in ok)
  174. whisling in intake manifold
  175. h23 w. h22 crank question
  176. SH VS Base
  177. H23 aem cam gears on a h22 engine
  178. H23 aem gam gears on a h22 engine
  179. Need help tensioning the timing belt
  180. crank pulley bolt. Clockwise or counterclockwise (reverse thread)???
  181. 95 Lude SI - Smells Like Kerosine / Shop Estimates
  182. Making an 89' Prelude look better...
  183. Wanna to know witch pin for an air/fuel gauge for a P13
  184. MAP and other sensor wiring/tubing
  185. The Turbonator.. is it worth?
  186. Tore CV boot and worn bearings- What axles to replace; 4th gen or 5th gen??
  187. removing oil pump seal
  188. okay..why h22 gear ratios are so short?
  189. h22a4 11:1 type s pistons labor question
  190. Car stalls and CEL 3 after car wash...
  191. Removing the cruise control actuator plastic trim cover?
  192. Sunroof sounds like its gonna break!!!
  193. 96 prelude cluster question
  194. Differance between JDM H22 Intake manifold and USDM H22a4 IM?
  195. H22A1
  196. Tanabe USA looking for a Honda Prelude
  197. 93 carbon fiber hood socal
  198. ? for 93-95 4WS prelude owners
  199. how to remove nut/bolt from oil pan
  200. EL Swap...what does the "dash harness" consist of?
  201. h22..help
  202. car running rich all of the sudden??
  203. Can O2 sensor Restrict Acceleration/Power?
  204. e-brake went out
  205. Main Relay gone bad?
  206. shifting super ruff on two trannys
  207. 1996 Prelude questions
  208. "Washer trick" on the prelude
  209. noobie question
  210. jdm bumper lenses
  211. Temp guage??? Gen 4
  212. lowering help on a 4thgen
  213. So I left my lights on....
  214. 4th Gen Prelude, JDM H22A --OBD1 - OBD2 -- help or die =) jk
  215. Check engine/ATTS light came on....help
  216. JDM suspension same as USDM?
  217. check engine code 13
  218. Need to know stock USDM 98 prelude non SH fuel injector size
  219. SH cat back on SE
  220. Broken Antanae
  221. VTEC Controller
  222. Crank Pulley H22 vs H22?
  223. Trip Odometer stuck at 000
  224. Got my 40-pt inspection, got some questions (brakes, o2 sensors, gaskets, 90k)
  225. Putting timing belt back on
  226. Got some good numbers
  227. anyone have this?
  228. GSR for a EVO 8? thinking about it
  229. 92 si A/C problem.. just need some suggestions...
  230. Im curious about this "ELECTRIC SUPERCHARGER" anyone know anything about it?
  231. oil on exhaust manifold gasket
  232. Tried to install VAFC...Check engine light on... no CEL..???
  233. hondata...uber data?
  234. temp guage jumps up and down when I signal
  235. accord intake manifold on an H22
  236. Whine coming out of my speakers...
  237. Manual conversion on a '96 Jap spec prelude VTi-R
  238. Code for 5th gen speed sensor
  239. Suspension Popping
  240. ECU problems Code 3
  241. Need advice on what is best intake for my 96 h22
  242. Mahle Piston Pins Won't Fit!!!
  243. oil catch can?
  244. 10.5:1 or 11.0:1 pistons for h23a1
  245. flywheel spacer???
  246. Questions regarding Condenser fan.
  247. What hose is this called exactly when Autozone people look it up?
  248. cel code 13
  249. Timing belt questions (pics)
  250. How To: "punch out cat?" Kronn 98SH??
