PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 [110] 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. superchargers for ludes. Who makes them?
  2. h22 girdle
  3. Rebuilding Tranny
  4. Upgrading to VTEC calipers, what rotors and pads
  5. H22 Vs H23 Boosted
  6. Throttle cable question
  7. just picked up s2k wheels for my 5th gen, doesnt fit!?
  8. New 5th gen.
  9. H22 Cams
  10. 1994 honda prelude si 4ws
  11. 92-96 smoked tail lights (searched)
  12. COOLANT
  13. Sleeve for turbo
  14. K Series Swap
  15. I'm NEW :)
  16. T25 Turbo on F22a1?
  17. 88 prelude si needs help
  18. Need heat help plz!!!!!!!!!!!!!!!!!
  19. G23 Head Swap, H23 Inake Mani ?'s
  20. Immobilizer location on ecu
  21. Can your axles start making Noise after ACT clutch install??
  22. Engine stalls at idle
  23. removing abs (in the works)
  24. h22 in 3g
  25. manual tranny swap
  26. Spray with ITBs
  27. Re: What kind of starter for h22a
  28. H23 pistons opinions
  29. What kind of damage can a broken Sperpentine belt do? 5th gen
  30. why does my fuel pump hummm?
  31. My H23A1 wont start!
  32. Ebay HighFlow Cat
  33. 4WS Warning Light on 99 Prelude VTi
  34. How could this happen?
  35. f20a4 tuning
  36. h22 head on h23 bottom
  37. I'm looking for a "How To: turbo install" for the h22
  38. Peeling window frame trim?
  39. Throttle body from domestic cars...which ones fits the h22?
  40. anyone know about h22 revhard tubular turbo manifold
  41. what's the best way to deal with rusted bolts?
  42. Pulled a few things and now car wont start
  43. weird idiling.....
  44. DOWNSHIFTING
  45. Tranny niose?
  46. Question about Girlfriend's 2nd Gen 85', blinkers wont work.
  47. New to H-T
  48. No brake lights on my 4th gen
  49. Oxidation ???
  50. New motor
  51. Need a some help!!!!!!!!
  52. Throttle Cable problems
  53. '93 VTEC
  54. throttle position sensor probs
  55. My car wont start! suspected fuel pump maybe?
  56. Blow auto tranny in 97 prelude . what to do ?
  57. H22 throttle body
  58. stick tweeters in 92-96 prelude, if so, what kind?
  59. F22b Vs. H23a
  60. Suspension Clunking? help
  61. Weird noise when I start up in the morning
  62. Cataletic Converter Question
  63. No Reverse, 01 lude, manual 5spd!! please help!!!!!!!!!
  64. anyone got a pic of ITR wheels on a 5th gen
  65. what do i leave on for the hot tank????
  66. Does any 5th gen Prelude guy have an Invidia exhaust??
  67. Strait Pipe to Performance Muffler = WHP?
  68. fit?h23 oil pan fit on a h22a4??
  69. 1987 Prelude 68,000 ORIG miles for FREE, NJ
  70. H22A2 with a H22A7 Intake?
  71. 4th gen prelude wont start
  72. H22 injectors???
  73. brake calipers upgrade
  74. Bride Brix II seat weight ?
  75. Should I get bigger injectors?
  76. 89 prelude not starting...help
  77. Anyone using SMSP, or RMF with N20?
  78. Anyone with H22a using E85? If so please post up.
  79. H22A1 VS H22A4 Injectors
  80. switching to a 5spd
  81. Climate control: not lighting up and some other problems
  82. Doin H23 Vtec... One question... recommendation on Timing belt pulley removed
  83. H22 EG Problems
  84. How much could I get for a 5-th gen "manual swap kit" ?
  85. Gauge light replacement... Anywhere cheap?
  86. Exhaust Difference between H22 vs. H23
  87. What size tires and springs do I need for this setup?
  88. Sh and base
  89. motor mount inserts
  90. Sway bar endlinks ?
  91. AEM fuel rail
  92. WINDOW PROLEM...
  93. Need help! - Whirling sound, Slow Reving, Smells Sweet
  94. Help with squeal on clutch engage needed
  95. Need ADVICE! 1 cylinder's PSI is at 45% and not passing smog
  96. h22a build!
  97. srs light flashes when clutching? what gives?
  98. Fitting heated mirrors on a USDM 5g
  99. transmission swap
  100. e-cutout or full 2.5 exhaust.
  101. pre-oiling/ post-oiling your turbo
  102. just lost my last key to my 2000 honda prelude
  103. Header and exhaust flow question.
  104. capacity of the stock fan relay???
  105. RSX-S injectors work in a H22a4?
  106. silly question about brakes
  107. need help with my temperature
  108. h22 rebuild
  109. Mechanical Problems?
  110. canadian prelude daytime running light
  111. 92 Honda prelude questions
  112. 4th gen: Gauges not working!
  113. E85 in an H22a4? Conseqences, benefits??
  114. CV Boots finally went completely out!
  115. First gear?
  116. H22A Prelude Type S, Type SH, ALL H22's All Motor Parts FS
  117. Common suspension noise?
  118. Instrument Cluster Light Color.
  119. Clutch Master Cylinder?
  120. Code 12
  121. 89 prelude help....Please b20a5
  122. 88-91 H22 Swap Info
  123. which 15 inch rim & tire combo is good for a for 89 prelude? (track only combo)
  124. fidanza flywheel
  125. vasp wtf...i need help
  126. exhaust question for a jdm h22 swap in a 99 EK
  127. How do i find out if my jdm h22 is a -96 or +97?
  128. PLEASE HELP!!!!!!!!!!!!!! NEED STOCK RODS AND PISTONS
  129. damn maintenance required light
  130. Dont like where your clutch engages? ** HOW TO: Adjusting Clutch Engagement **
  131. Changing oil in Honda Prelude h22a vtec, how many quarts of oil, and the best oil to use for colder
  132. Loss in whp...dynoes included. Please advise! Your feedback is appreciated
  133. anyone run a holset turbo on their prelude?
  134. Crazy high oil pressure.
  135. What kit is this?
  136. Anyone know a reliable place to purchase H22 balancershaft removale kit?
  137. type Sh swap in a 4th gen
  138. Question About Finding Euro-R 2nd Gear
  139. i have h22 where do u get the oil line for the turbo??
  140. whats the sensor that on the back of the block by the oil cooler??
  141. Need Help, Driver's side door will NOT open
  142. 4th gen transmission fitment
  143. suspension help
  144. which tranny fluid to use? GM FM syncromesh? Redline? Amsoil? Motul?
  145. 5th gen Headlights how many K...keeps blowing out
  146. Advice on a build
  147. Glove compartment needs locking pin
  148. Help installing H1 bulbs...
  149. MAP, IAC and TPS
  150. Cost of rebuild?
  151. head gasket
  152. window wiper spray dont work?
  153. N/A Project, Injector Upgrade?
  154. 5th gen HEADLIGHT PROBLEM!
  155. Oil Leak on top of valve cover..HELP
  156. help me on a car leak on my 5th gen lude
  157. Fast blinker
  158. H22 Rev Limiter Problem
  159. Car Stalls after Cold Start
  160. Explicit Speed Motor Mounts
  161. Suspension!! NOW!
  162. strange noise coming from front driver side???
  163. most power gains turbo h22a
  164. Switching to vtec calipers
  165. h23a1 crankshaft
  166. water temp question
  167. Hondata S300 ...any Hondata experts?
  168. C/F Sunroof
  169. HELP ME! MSD Timing retard
  170. sensor or seloniod in the lower portion of the air box?
  171. Make my idea come true
  172. Damn cable linkage snaped today
  173. supertech vs skunk2 pro series retainers
  174. Are 5th gen axleback sections interchangable with 4th gens?
  175. car starts and idles rough for about 10 seconds, then smooths out?????
  176. harness diagram h23a1
  177. Wht can I can I do to gain HP without adding turbo? to my 98 prelude
  178. The ATTS Unit : An Interesting Look Inside
  179. Where does this line go? *Pic*
  180. Painting a Grill
  181. Question about H22A
  182. tiny rust spot
  183. will a larger TB make a diff on a Stock IM?
  184. Running problems
  185. did i get a good price for my engine or not h23?
  186. 2001 prelude mounts
  187. Water leak in my trunk and inside of car(help)
  188. h22a1 block building help
  189. Side skirt painting
  190. Motor swapped, now car won't move for long periods.
  191. Rear quarter window question?
  192. overheating signal ?
  193. H2B Conversion in the Prelude Chasis
  194. Gutted Interor...Whats everyones thoughts.
  195. Write Up / How To - H22 H22a H-series Cam Camshaft Install (search friendly)
  196. fuel pump location
  197. 5th gen Prelude owners: which exhaust are you running?
  198. motor type?
  199. ABS removal in 5th gen proportioning valve install
  200. lowering spring set up
  201. ?'s on h23a1 build
  202. Where can I find a Carbon Fiber Intake
  203. IACV Qusetion.
  204. Re: Unbolted exhaust...Gains??
  205. crankshaft question
  206. Totally unrelated
  207. Buying 4th gen Lude for daily driver
  208. which would you pick 500whp 4thgen or 2006 gsxr 1000cc?
  209. Headlight 5th gen question
  210. turbo help!
  211. Accord Euro-R Manifold Plenum Measurments and Info
  212. Oil Catch Can Install. Need some help
  213. engine rebuilding
  214. My BB6 Prelude project... 56K, upgrade now...
  215. magnaflow muffler on their lude?
  216. replace main relay still having problems
  217. What do you need for 2nd gen Swap?
  218. Anyone know of good classifieds for the NW
  219. Tranny bolts
  220. 4th gen shifter cables
  221. how to remove aluminum oil pan?
  222. manual transmission swap wiring help
  223. Added some bolt-ons...dynoed and lost power! Damn this N/A Game is Fraustrating...
  224. im a noob o hondas what swaps into a 3rd gen?
  225. im a noob o hondas what swaps into a 3rd gen?
  226. Is it Possible to replace 92-96 Prelude Sunroof with 97+ Prelude Moonroof...
  227. what sus. components help w/ drag racing?
  228. BB6 Prelude / Accord Dashes in a BB4 Prelude
  229. F22A1 Block Wit a F22 VTEC head..?
  230. Advice needed! What should I do with my motor issue?
  231. Have aftermarket wheels? Get hubcentric rings.
  232. H22 variations?
  233. Can I use R 12 AC compressor with R 134 clutch?
  234. V-tec not poppin'...Why..??
  235. Type-s strut mounts
  236. 5th gen axle nut size? Searched
  237. Should i replace my timing belt? pics inside.
  238. Does a Prelude have a TCU if it's an auto?
  239. MIL Codes
  240. h23 pistons fit h22 rods
  241. air bags change
  242. h22 valve adjustment
  243. Windows, locks, and el gauges won't work, help!
  244. 4th gen exhaust
  245. Which header: DC Sport, Megan Racing, OBX?
  246. H22 Intake Manifold/Throttle Body on H23???
  247. f22a1 wiring harness
  248. What The H#LL?
  249. i need some pics
  250. Any other 5th gen owners have water in the bottom of trunk after rain?
