View Full Version : Honda Prelude
- i need help 98 prelude
- Best 5th Gen Suspension/Tire Upgrades
- h22a4 problems
- Where to buy RHD BB6 clip?
- idling problem
- h23 to h22 problems
- H22 Tuned with low HP results
- Need help with new prelude
- REAL mugen bumper for 4th gen
- can you move a 90 prelude whithout traction bars attached
- need honda part # for this plug
- im in the middle of a f22b1 swop to a 3gp have some questions
- car not starting?? fuel pump??
- What's a good or decent camber kit brand?????
- Honda prelude.New Paintjob+mugen installation
- Faulty EGR Valve reading
- LMA's
- h23 block, h22 oil pump, obd2 head...ckp?
- Steering wheel shake when stepping on the brake???
- Flat Black Muffler
- 97lude which headers are best for performance?
- DAMN KMS!!!
- exhaust header wrap
- need helP PleasE!!!
- 3rd gen steering rack play/slop - is there an adjustment?
- 3rd gen fog light replacement - alternatives that won't break the bank?
- Lous Suspension
- overheating issue.
- Want info on auto tranny 5th Gen
- Final drive?
- Question about AT tranny install 5th gen
- removing headlights on a 92 prelude HELP
- Dead gearbox on 97 Prelude VTEC need advice pls
- H23 will not idle
- prelude h23
- i need some opinions please
- Oil in Intake manifold
- bumper dampener
- RHD with LHD pedal assembly
- oil catch tank
- Base Coilover fit Type SH?
- Springs are off in the front???
- 93 prelude vtech
- HELP PLEASE! Car keeps shutting down while driving!
- Apexi VAFC Wiring
- Starting air valve and IABS JDM h22a
- CEL 9 JDM H22A
- h22a timing specs????
- Poor Gas Mileage
- New Timing Belt
- My car is freakin me out!
- Oil breather leak
- Stock Shocks giving way.... help
- Need help desperately weird problem.
- My Prelude Website
- h22a4 idle problems
- Timing Belt Broke Help!!!!
- My JDM h22a
- quick question
- clunkning noise
- H22/H23
- My prelude 1996. Vtech has a ticking sound coming from the engine head
- system in the trunk
- Buying Prelude
- No modifying needed type r front lip 92-96 prelude
- Solenoid Question
- Looking to replace 5th gen prelude stock exhaust
- what size is it?
- need some help. h22 vtec
- Timing Belt...
- Need a good machine shop in North Carolina
- swap now no spark
- Head gasket upside down?
- throttle body service???
- 97 h22a (obd2) in a 92 accord (obd1)92accord harness,which is the best compuer to use
- Repairing with air brush the chipped paint
- hesitation after warm-up
- Battery Relocation/Fuse Box Relocation issues
- do they make this lip....
- Why did Honda replace the Prelude with the civic si?
- Mods delete this please...thank-you..
- 1998 Prelude - Key Issues (lost them)
- Motor Work
- Wire tuck
- Throttle Question
- Engine swap problems
- bisimoto connecting rods
- lug nut removal problems
- ATTS Light Reset- Failed
- Need help with H22A thermostat
- Tein Flex with annoying noises
- prelude help
- 92 prelude cigarette lighter not working tried everything
- after skunk2 IM manifold install car idles for a few seconds then dies
- need help??? newbie.. stock prelude with exhaust?
- prelude digital gauges i need help
- 97-01 stock cam gears?
- mahle pistons
- 3rd gen temp gauge problem...
- h22 prelude idles 4000k
- 5k rev when running. Wont idle Help please!!!
- H22a Euro-R Bearings
- Back in the game, son!
- ..:: WANTED TO BUY ONLY ::.. NO TRIAL USERS, NO COMMENTS, NO PICTURES - October 2009
- ..::: FOR SALE ONLY :::.. NO TRIAL USERS, NO COMMENTS, NO PICTURES - October 2009
- HELP removing oil pump
- Where do I post wtb requests?
- what socket size for head bolts?
- No heat!!
- Strange positive camber problem
- Quick Q: What size is the antenna delete grommet?
- Installing 4ws
- a little more hp
- Problem with EL gauge installation
- temp gauge
- IAT sensor removal
- 1995 Prelude
- need 96 map sensor pinout
- speedometer, temp gauge, vtec problems.
- 94 Prelude , Headlight just shut off HELP!
- Please advise my h22 build
- AUX For Stock 97 SH Headunit
- 92 Prelude Smoke
- intake manifold gaskets help!!
- 92 4ws
- JDM H22A injector size
- Skunk 2 VS Venom Intake manifolds
- Maintenance schedule and a few other questions
- I want to convert to obd1 from obd2 (ive searched)
- exhaust question
- Ignition Switch problem.?
- stock wheel restore
- tp sensor question/help
- a quart every 300 miles!
- distributor rotor
- 1994 Prelude SI - Thermostat repair?
- SiVtec coil bad or other?
- H22 cams
- 98 Honda prelude Automatic transmission question.
- H22 transmission problem need help
- How do i convert from auto to stick?
- Sigh, Another H22 Thread
- new pistons:) some questions
- Open header question
- Stereo Wire diagram
- camshaft install
- All N/A 12 SECOND OWNERS
- Slicks for 5th gen!
- Question for you HT goers!?
- Please help with my dying VTEC
- lifted off valve cover, 2 rocker arms laying in the head
- Weird Vibration from Park to D4 (BB6)
- Problem starting the car
- how to make a kill switch for your car
- 2nd gen, '87 Prelude Project
- Can you vtec a 93 prelude si four wheel steering
- gear oil Q
- h22/23 vtec on a four wheel steer
- integra coil overs in 89 prelude?
- entry light/dome light
- How do I stamp a 1 after H22A
- need help!
- 3Gen Prelude **Ls/V-tec vs H22**
- Problem with H22, wont go past 3000 RPM
- FOR SALE 1983 Prelude EPIC CONDITION
- what is the function of this part?
- which coils will get me lower?
- how to tell authentic Mugen Exhaust apart from Replicas??
- 92-96 prelude intake on a 97-01
- tranny internals swap?...
- my prelude is showing cel 90 !!help!!
- 89 lude blowing smoke after warmed up
- Chewed up timing belt
- Bad grounds?
- Flickering oil light but pressure is very high
- LS/V-tec ** With AC? **
- abs light came on and ac doesnt work
- HELP 97 prelude immobilizer problem
- Anyone replaced the balance shaft bearings.
- Please help.
- 4th Gen Prelude Amp
- need help!! car hesitates
- b21 vtec?
- BRAKE CALIPER BRACKET QUESTION
- *H22 Timing Belt Geniuses - Need Help setting Timing with manual tensioner, Plz - *
- h22 hose diagram or pics needed asap
- Removing a broken sensor
- is a B20A5 engine, an interference engine?
- skunk2 manifold quick rundown of questions
- Resistor Box PLug?
- 5thgen shock/strut help!!
- How do I get rid of my shifter wobble?
- Sunroof issues 93 Prelude
- skunk2 pro 3 cams what makes them emissions illegal
- cel light
- Water in the trunk.
- JDM Distributor with USDM Harness?
- missing after warm up
- Crazy Problem???
- Prelude 96 vtec high theft target?
- 88 prelude problem
- help a noob find his speed sensor
- Prelude share any body parts with like cars?
- Unusual Check Engine Light read problem
- Any tips for the 1989 honda prelude 2.0 S?
- 4x114.3 nissan/datsun rims on 4th gen prelude
- h22a 97 prelude my vtech wont work
- p72 on a H22: NEWBIE
- Prelude Problem
- different between H22 Auto and manual halfshaft?
- I missed this place...
- 1993 Prelude Si
- h23 Question
- JDM BB4 Headlights and HID Question
- Innovative prelude Front Competition Traction bar
- Unable to get a fully close door pls help
- Another Question?
- Type r prelude?
- Oil??
- transmission leak
- Can I keep AC with this turbo kit
- any difference in a Auto to stick radiator?
- 93 Prelude Die's While Driving.
- mfactory final drive, will it fit in an h23 tranny?
- M2A4 w/SH Block Compatability?
- Need Some H22a parts
- cooling fan relay
- Ideas??
- Radiator fan issues
- HELP on pin out
- Turbo JDM Prelude Type S
- f22a camshaft
- JDM H22a Radiator sensor plug?
- UGH cant get timing belt on
- H22T KNOCKING from head
- Power and over heating issues
- exhaust flange
- final battery draining post
- compression calculating help.
- Need help Identifying problem.
- '95 Prelude 2.2L Vtec HELP!!!!
- ///Help!!!! 95 Prelude//////
- 95 h23 idling problem
- Dyno Day Results - 4th Gen H22 w/ JDM Type-S Pistons and Skunk2 Pro2 Cams
- Tire rubbing?
- Is the ABS rear brake sensor of the 97 Base Model the Same as the 97 SH model?
- engine problems!
- H22a civic EGR code 12.... argg
- h22 dies after getting warmed up
- targa top 4th gen
