View Full Version : Honda Prelude
- Remapped ECU
- Mugen Dyno
- headlight conversion??
- Help with idle prob
- gudes bullfrog package probs
- where can I get a p13 rom map?
- Rubbing the bottom end
- crazy CEL... srs light doesnt stop blinking
- Nitrous Dyno Plots?
- First time dealing with this swap, a little help please.....
- ?JDM Headlights for 2000 Prelude
- Rebuilt Motor Getting CEL 7 HELP!!!!
- Interchangeable parts?
- Making it worth vortech to produce a supercharger for us?
- H23 VTEC ran... Now it will not...
- JDM type-s intake
- powergains with the apexi ws exhaust ?
- which cam is intake/exhaust?
- smsp header for sh
- Rev Limit on Stock Internal Euro R?
- Any difference in these prelude calipers...?
- H22 Head Gasket
- Whats this prelude called...
- my engine number 1011979
- My tranny code px5-7? what is that?
- 3rd gen SI "states" edition?
- t70 turbo
- steering wheel
- anybody have a tanabe exhaust on tehre prelude vtec
- 92 prelude sunroof
- EGR Code, bad? from someone who KNOWS, thanks
- Distributor Dead Again!
- air craft remover on sunroof
- anyone purchases this 4-1 header off ebay??
- Bolt size q.
- Brake lamp staying on
- code 43 fuel system delivery
- Newbie Lookin for a 'Lude, but unsure...
- AEM FPR (need new rail?) 4th Gen
- Which strut bar to use with vis cf hood?
- Quick one... whats the oil capacity of the 2.3 4ws prelude
- greddy header?
- how much HP does a 97 prelude compared to the newer models?
- 4x114.3?
- prelude clutch noise
- Fmax Turbo Kit
- Engine buliding or engine swaps?
- alternator problem(ASAP!!!)
- Question: h22 thermostat broken?
- 97 prelude hesitates
- Question: h22 tranny ground?
- crank hp and IAB plate removal ?'s
- severe problems with cam gears and head
- Import Tuner dynoed h23!
- question about automatic transmissions
- Can you swap an rsx 6-speed into a prelude?
- what year prelude did they stop using the resistor box?
- "Generic" third party honda rims...questions!
- JDM H22A ECU Question
- Bleeder screw
- JDM pistons...What rings ??
- '89 prelude motors
- 98 Prelude burning A LOT of oil. What could it be?
- Need Spanner Wrenches....
- Gsr ecu on my h22
- 89 prelude si stock exhaust problem
- Throttle Response lag
- h23 vtec dyno
- 3rd gen lip
- compression test questions....want to go turbo, pls HELP..!
- H22 bored throttle bodies worth it?
- 2001 Prelude Suspension..... what should I do??
- gm syncromesh Vs. Penz Syncromesh
- whats causing this whistlingnoise in speakers
- Prelude Day of Fun
- has anybody ever heard of this kit?
- clutch wining
- ECU Identification
- just bought 92 Prelude!!!
- VERY Weird Problem...Car Dies in High RPM
- 2000 honda prelude numbers
- IAB operation questions
- To anyone that has driven both an GSR and a H22
- 92 se/si 1/4
- Autocross w/ an Auto
- 95 Lude Clutch/Flywheel combo; Where To Buy!
- TEIN vs EIBACH/TOKICO SUSPENSION SETUP???
- WHO has used e-manage?
- To buy or not to buy?
- Quick question
- Spark Plug question *searched*
- 94 lude fog lights
- Can I run regular un-leaded on 1998 Prelude ?
- GF gettin a 5th gen
- 92 si wont start when hot out
- h23 vtec
- missing bolt that holds the tranmission to the engine block
- Simplified ECU Swap for Gen 3.
- Just bought a 94 prelude si, Don't know much ab preludes more of a civic guy. Need good websites and
- Swap Information
- Noobie prelude owner needs help
- squeeky shock tower
- Short throw question?
- prelude vtec?
- blown head gasket for 2 months
- KYB AGX VS KONI YELLOWS
- When cold, car takes longer to start. Problem?
- Need info on Coilovers
- Having hard time finding 97-01 stock Type-SH
- CEL code 12 and ABS codes 4 and 8....need some help...pleaseee
- BB1
- Spark plug wire position?
- Going from a 98 h22 usdm to a 92 h22 jdm, Need OBD help!!!!!!!!
- Braille Auto Lightweight Battery GB
- 97 overheating
- Question about Cometic metal head gasket
- size test pipe with n1 catback?
- What kind of Header do i need?
- good turbo capable of 400whp with fast spool
- How to find out what year H22a4?
- Datalogging
- 97-01 question
- Venom Nitrous Kit ?
- Will 4WS work after JDM H22 complete swap?
- stock radiator fans
- STR or AEM fuel ral?
- Knock Sensor.......do they actually go bad?
- switch to p13 ecu on a 97-01 prelude = switch to obd1 injectors??????
- vafc2 setup
- Rear suspension mystery
- Bad squeak on the lude..
- ECU Questions with Jun vavletrain
- cheap carfax reports
- Two quick questions on a 92 prelude
- gauging interest in susp. tech. swaybars for 3rd gens...
- NEED HELP WITH ENGINE ID
- pic request for a cutaway view on an h22 ::LOOK::
- all motor vs. turbo
- regular sleeves or not???
- surging idle?
- h23 vtec piston & rod question
- Gutting the cat...
- H22 Secondary's .. How to wire them up?
- How to throw 4WS code?
- VAFC and hesitation
- 98 SH EGR problem
- Error code help :/
- Fluidyne radiator for 98 prelude?
- aem v2 for 96 lude ?
- Fuel rail and regulator combination.
- Help Please, Vtec Conver with abs
- what kind of tires?
- DH-RACING.COM? anyone experience them?
- 5th gen prelude rear wheel bearings
- cooling fans
- falken azenis tires.
- IAT Help!
- Next upgrade on turbo h22 ???
- test pipe and stock exhaust
- 94-97 Accord VSS on prelude ?
- Odo and Tripmeter not working. Any ideas?
- Can I put honda MTL in after using GM synchromesh?
- Can I convert my JDM H22 to OBD II???
- h22 Engine loose.. ? for ya
- oil in #2 exhaust port.....
- Still overheating on a track
- clutch master cylinder gone bad?
- Wires to ignition to cut for killswitch
- Helms Manual Index - 5th Generation Complete
- 4 Wheel Steering Conversion
- Need ac & power steering hoses
- Car won't start/crank to start after............
- MSD 6BTM the same as 6AL
- low compression
- Suspension Quandry
- H&R race springs?
- valve clatter and a miss!
- climate control
- Accord Euro R valve clearance
- Size of stock Prelude Vtec muffler piping ?
- Piston dome cc's
- a ignition problem for 6 months!
- Road Racing
- Suspension Problems *Help Please*
- v0gueSilver_Dc2 need your help
- Did a compression test today.... Check it out.
- P28, Hondata and Prelude Secondaries Question
- does a fuel regulator help?
- H22A Auot tensioner to manual tensioner
- OMG burning oil!
- 5th Gen Prelude converting an auto to manual
- blew tranny need full swap!
- H22A Head on H23 block
- H22/H23 technical differences
- Prelude intakes
- What sensor or clip is this?
- Do I need an FPR
- intake manifold swap
- Car won't start. Need help.
- One piece headlights H4 harness
- AEM v2 and DC headers
- gas pedal
- prelude 2.2 vtec? whats it like and how reliable?
- JDM sidemarkers missing wire. What to do?
- A/F gauge install on 5th gen prelude
- Launch...Trying to tackle this ART
- Tranny Fluid
- Raising idle by modding the TB . . . thoughts & questions
- 94 VTEC outer CV joint dimensions
- blown headgasket...
- Why is my AEM fpr allowing fuel out of the vaccum port?
- Rear caliper locked up. What are my options??
- how to remove engine light
- Worthwhile Intake manifold for H22a
- idle prob.
- USDM Intake manifold VRS JDM Intake manifold?
- ENGINE is apart*** what is recommended that i buy NEW
- question about unplugging battery...
- Wierd Transmission Problem...
- Problem about a Chipped ECU for p13
- what does this part do?
- OBD1 Cat and 5th Gen Compatability
- Prelude ECU?
- Slimey Brown oil by P/s cv shaft
- Can I swap out my p13ecu for a usdm prelude?
- Can i Use the front mount from a 97 *accord* EX
- aem short V2 intake
- Engine Stalls??
- This is RETARDED!!
- H22A stroker kits - H26A.
- where do i get a flywheel lightened?
- Kamikaze headers on an H22A...
- 94' JDM engine swap problems PLEASE HELP....
- VTec COntroller ?
- Gas tank rust?
- >>> Stage 2 Crower cams with Skunk2 Springs? <<<
- revs stop at 6250
- question about vtec
- B20A Possible Updates?
- stutter...?
- h22 accord euro r motor problem
- Digital guage cluster
- topped out the lude the other day
- Quarter Mile Times Part 2
- What are the pros and cons of preludes?
- Remote starters and their wires...
- went to the track....
- guy with a 98 SH is sayin........
- Where to buy m2b4
