PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. s2k seats in 5th gen
  2. camshaft install
  3. What Wheels Are These
  4. h22 prelude vtec skunk 2 manifold will it do a big difference??and how
  5. Installing fog lights after EL gauge conversion.
  6. 1995 PRELUDE sunroof problem
  7. H22A swap into 95 si, low rpm bog at startup
  8. cat-back...
  9. engine mounting, stiffness and support. ???'s
  10. Spring coil issue
  11. Transmission problems HELP!
  12. Jdm Visors??
  13. h22a (jdm) rocker locknut size
  14. Question on fitting a p5m head onto a jdm p13 block
  15. serious compresson problem help
  16. Hardrace Mounts vs. Poly Mounts
  17. Question about wheels for my bb6
  18. Question About the difference in Code 1 and 41
  19. I NEED HELP REMOVING MY VSS ON MY JDM H22A
  20. smog
  21. Do you guys think this is a good deal?
  22. Help with 4ws steer problem
  23. vibration at idle
  24. <~~~98 Prelude fuel change~~~>
  25. Strut Bars For My BB6
  26. would the usdm VSS fit the jdm h22a VSS?
  27. 4th gen wheels
  28. What Wheels Are These
  29. HELP!!!H22a Head on F20B Block?
  30. Resistor box/main relay
  31. Godspeed Aluminum Radiator
  32. Sounds like something loose
  33. Fuel Pressure
  34. H22A dies and sputters
  35. Transmission issues.
  36. 68mm bbk throttle body
  37. Clunking and wheel movement
  38. JDM H22A sensor issue
  39. H22a4 Question???
  40. Cel
  41. I WANNA SEE PRELUDES!
  42. turbo build question
  43. Axle Question
  44. odometer no longer works
  45. Prelude Motegi H22A8 manual question
  46. Hondata S300 Issues
  47. H22B swap
  48. t-belt snapped?
  49. Car died and wont start CEL code 9
  50. tranny issues HELP!!
  51. FPR to stock fuel rail
  52. Idle problem i think.
  53. is the speed sensor and odometer connected?
  54. WARNING: Dirty Towing Company
  55. can someone explain..help
  56. 96 Prelude Side skirts
  57. sh trans lsd
  58. ECU P13 transistor burst
  59. 90 Prelude flywheel?
  60. H23/Vtec BB6 few ??
  61. getting a bb6
  62. B20A5 prelude ecu codes
  63. 1998 Prelude Sh
  64. when you think of your 4th gen what do you think of
  65. Intake Manifold Plenum spacers
  66. Whats up everybody
  67. CEL on 01 prelude
  68. fuel pressure?
  69. switching core and cap to higher volt core
  70. Preludes cooling fans not working
  71. f22a1 na or turbo
  72. 97-98 cabin filter replacement
  73. car alarms
  74. Auto-to-manual conversion on 4th gen?
  75. Need some help
  76. 4ws lights on!
  77. car wont start
  78. can u use a h22a camshaft on a f22a head?
  79. bulb size for projector headlights
  80. preludes lost electrics
  81. ATTS Lights Turn on
  82. need help after h22 swap
  83. Turbo H22 Preludes: Dyno's, Setups, and 1/4 Times ! *No questions or comments*
  84. 94 Prelude Si swapping in JDM H22
  85. Thinking about boosting a 5th
  86. clutch Slave Cylinder
  87. leaking clutch fluid FAST!!!
  88. indentify this engine harness plug...
  89. water temp senson where do i hook it up to?
  90. Exhaust Tubing Kit
  91. 97 prelude, running obd1 computer, wont crank (immobilzer help)
  92. timing belt/water pump service OKC
  93. King Motorsports
  94. Any topics for swapping an h22 motor from an obd1 prelude
  95. Prelude Crank Shaft
  96. 93 prelude f22b high idle
  97. h22a head f22a block oil tap
  98. My Car wont kick into gear??
  99. Removing IAB's?
  100. 1988 Prelude Si 4ws - C+D Review
  101. help w/ finding-how to: RHD conversion for 4th gen
  102. ***JUST ME OR YOU TOO***
  103. "flashing oil light & rev problem update"
  104. ***DOUBLE CHECK***
  105. after lowering spring install, slight metal rubbing noise? plz help...SOCAL
  106. Help! Car idling low and misfiring!
  107. Egr hardwire
  108. prelude cylinder head schematic HELP!
  109. Random losses of power JDM h22
  110. Shifter Bushings
  111. Header thermo heat wrap
  112. how do you change the interior dash light color
  113. Oil pick up tube
  114. this is a engine builders question
  115. compression vs gas
  116. Engine Noise.. Clatter... Vid.
  117. car sounds loud
  118. tcu location in a 92 Prelude
  119. ???How Much???
  120. VTEC PROBLEM
  121. A/C Problem
  122. h22a head on f22a1 block
  123. EGR Valve Block Off Plate Question
  124. Some stuff I thought I'd share about pistons/rods
  125. F20C1 in BB4, Is it possible?
  126. Engine oil
  127. Accord coilovers???
  128. pics of my new daily and my turbo car
  129. How much tranny fluid H22a?
  130. Custom Bisimoto Header
  131. 92 prelude jdm h22a a/c removal
  132. 82 Carburetor adjustments
  133. i have a question
  134. can i put a b18 head on a prelude b20 block
  135. Approx labor hours and cost effectiveness.
  136. Tranny Shop Couldn't Fix 5th Gear Grind
  137. Cause of Death!?
  138. h22a4 in ek wont turn over
  139. 97 prelude problem engine rattles
  140. brake light?
  141. Grinding noisy when I crank it!
  142. 99 honda prelude problems
  143. jdm h22 auto?
  144. Looking for Lude Owner in Maine?
  145. Might be a stupid question
  146. intake manifold gasket
  147. Headlight harness not getting enough volts.
  148. Best way to take head off and on by myself?
  149. H23avtec running issue.
  150. 97 lude Sh
  151. 99 accord engine f23 into prelude 92 with h23
  152. 1997 Honda Prelude
  153. Prelude JDM type S question
  154. what is this plug?
  155. crank pulley issue
  156. Anyone use harnesses on stock EP3 seats??
  157. Prelude from canada...
  158. car smells like exhaust when i accelerate any ideas?
  159. i want better gripping tires, what should i get?
  160. labor hours for new bearings?!
  161. why did my windshield washer squirters stop working
  162. APEX'I N1 Exhaust
  163. Anyone who has already completed the H23 Blue Top Swap.....
  164. auto to manual swap 98 lude
  165. Lots of bad news
  166. timing belt troubles
  167. how do i move my gauges in my prelude
  168. 94 prelude cooling fan
  169. Problem after h22 swap
  170. hood latch messed up
  171. FITV Help... Now idles bad?
  172. BUILT BLOCK WORK HELP! HELP!
  173. *******98 Prelude Transmission Flush question?*******
  174. Anything I need to know about a 5th Gen before buying?
  175. Turbo with AC
  176. H series header question
  177. H23
  178. My SFWD prelude
  179. Problems, problems, problems.... PAYPAL $20 to whoever finds out what the problem is!
  180. Can Anyone Identify This Plug?
  181. The wrong intake
  182. how do i stop my prelude from burning oil
  183. mfactory 5.1 fd + lsd install problem
  184. Will honda Accord Main Relay work on 4th gen prelude.....???
  185. help with my H-F series tranny!!!
  186. Zero Clearance
  187. Clunking noise when turning... info please?
  188. my electronic timing is screwed up!!!
  189. 6th gen prelude
  190. Sidelined for close to 9 months. My baby is almost done!
  191. Power lock works erractly...
  192. 96 h22a knock sensor resistance ?
  193. can i mix the h23 parts in a jdm h22a?
  194. can i mix the h23 parts in a jdm h22a?
  195. ECU conversion & tuning for 11:1 comp mod
  196. H22a1 vs H22a4
  197. Threw TPS CEL replaced TB still throwing TPS Cel now what?
  198. TRANNY CHIRP...
  199. NEED HELP! OBD1 to OBD2 conversion... i did the drop, and now it wont start!!!!
  200. H22A resistor box? Won't run unless fully advanced timing.
  201. Engine stalls after starting.
  202. h22 prelude 93 wont start please read and help
  203. exhaust smell after cat delete?
  204. My prelude crank but won't start.....
  205. Flywheel timing mark not visible.
  206. h22a n/a
  207. My old 95 prelude (h22a)
  208. Can I re-tension the balance shaft belt?
  209. 94 and 99 Prelude not starting
  210. springs over stocks or save for coilovers?
  211. Transmission mount question
  212. 2000 prelude sh
  213. suspension talk
  214. new prelude
  215. booston a lude
  216. low oil pressure
  217. best gasket kit?
  218. 4th gen Prelude "Vtec" rotors
  219. ARP TORQUE
  220. BB6 head lights
  221. how do you adjust a back up light/ neutral switch
  222. 98 prelude over-heating?
  223. For those with LSD install experience
  224. auto tranny or something else?
  225. Wikipedia's Honda Information Is Horrible
  226. Need help with conversion from obd2 prelude to obd1 engine!!!! Can u help Please?
  227. I have mugen headers.
  228. 4th Gen Wings West Front Lip Install
  229. H22A Injectors
  230. accel blaster coil
  231. NEED HELP WITH CONVERSION FROM OBD2 PRELUDE TO OBD1 ENGINE
  232. Honda Prelude Turbo-kit
  233. Recurring problem starting the car
  234. Where can I find washers for Prelude lma's to put in b16
  235. h22 balance shafts *searched*
  236. New here!
  237. Replaced knock sensor...still getting code 23
  238. 1992 H23
  239. Found a 5th gen I want to buy but...
  240. Coilover Question?????
  241. just another prelude.
  242. 94 prelude vtec rev limiting at 6500 rpm??
  243. car running lean
  244. h22a4 in ek..cel code 8. help
  245. fuel ration gauge and water temp gauge
  246. installed skunk 2 mani and now its throwing a code
  247. a funny sound?!?!
  248. H22a Problems
  249. 98 prelude wont stay running
  250. CV Shaft Problem?
