View Full Version : Honda Prelude
- CEL 41 but not 41 NEED HELP!
- 2026 Honda Prelude
- H23 Vtec (blue top) Injector Upgrades
- 1989 Prelude Crank Pulley
- H23a HTS Map Help!!
- Oil Pan Help!!!
- 1997 Prelude Cranks but WONT START!!!!
- Honda key light
- 1990 Prelude engine in 1991 Prelude SI
- Need some help with a engine part
- Prelude Mk4 leather seats
- 5th gen SH ecu issues
- Damn surging
- 2026 Prelude Hybrid
- M2b4 in 5th gen
- 1998 Prelude is running Rich
- AC vent 3 gauge pod
- 93 Prelude S runs rough&rich when warm
- 5gen prelude with 4th gen prelude si transmission
- H22a4 IAB Polarity
- ECU/PCM Immobilizer Removal Service
- 1997 Honda prelude
- Tdc senor issue
- Tuning Australian H22
- H22 timing belt won’t fit right
- Steering wheel shaking!
- F22B1 with F22A1 head. Timing belt issues
- Need help! Engine harness problems
- Distributor wiring harness question
- Knock Board Delete CEL on all the time no code flash
- Need help with engine swap
- Need a tune for my turboed 93 honda preludes stock ecm
- H22a issues
- 99 Honda Prelude no start
- 1979-1982 honda prelude hood vent
- New parts!!
- Have a leak in my distributor
- T2W4 LSD into a m2a4
- prelude clutch
- 1999 prelude Idle surge
- Accord OEM lip on 3g prelude??
- A new old guy
- VSS
- 92 Honda Prelude
- engine rough running after warm start
- Check engine light works. I can read codes. The light just doesn't cycle with key
- 5th gen Prelude wont go into fifth or reverse (help 🥲)
- [OEM+] Honda Prelude - Automatic Passenger Window
- 92 Prelude Oil light
- Prelude dash swap
- center console mod ideas
- dashboard lights
- air pipe connections
- What Part is this?
- 2001 Prelude issues
- 91' Prelude... swapped with F22B1, and M2Y4 Trans.
- Parasitic Battery Drain
- H22A ENGINE
- Iat wiring on obd2a
- Nut and Bolt List For the 'H22z1' engine and transmission
- Rebuilding engine with Type S pistons. Any Suggestions?
- Clutch problem
- Only spark while fuel pump is plugged in 5th gen h22a4
- 5th Gen P0171 CEL JDM H22a Swap, Resistor Box?
- Cruise control confusion
- CEL code reading.. OBD
- Japanese Heat Sensors
- 5th Gen Prelude Steering Wheel Help
- H22 crankshaft confusion… HELP!
- H23A Vacuum Leaks
- 2000 Honda Prelude Ticking, Burning Oil on Acceleration
- Strange misfire pattern intermittent spark only on piston 1
- 5th Gens - Base vs. SH part 2
- flywheel brands suitable for exedy stage 1 clutch, on a f22b engine
- H23 oil control orfice
- Need ECU advise
- H22a4 motor build tips
- ac compresser
- Noise when making a sharp turn
- H22A4 Rebuild, Need Piston Help
- 1997 JDM Prelude parts
- Car is much quieter than it was.
- Defective Ignition Lock Honda Prelude 2.3i
- How to make power to stock h22
- Knock knock! You still alive, Prelude?!
- What trans works best with a jdm h22a swap?
- Nippon type s pistons tuning
- 98 Honda prelude check engine light and won't start
- 98 prelude h22a jdm swap running rich
- 98 base loud noise in engine - advice before troubleshooting
- G23 problem any help please
- K20 Swap 2nd Gen Prelude
- H22a4 Crankshaft Sizing
- 4th and 5th gen prelude parts
- 5th gen prelude Engine Clunking and Cylinder 4 Misfire
- 95 Prelude Digital dash sockets
- EUDM ECU wiring
- 5th Gen H22 rear main seal
- 95 Prelude Seat belt safety indicator
- NEEDS HELP! Harmonic Balancer replacement
- Honda Prelude 1998 BB6 H22A distributor inner seal
- F20b6 swap into 5th gen prelude
- 95 Prelude heater core
- Dohc F20B swap in 3rd gen
- H22 crankshaft modification
- Unblocking EGR Passage, How Far Does This Passage Go Into The Manifold
- Cam Holder Oil Oriface O-Rings
- 2nd Gear Grind
- H22 with ivtec
- F20a4 swap with f22z2 help
- 92 Prelude h22a4 swap
- F22 to H22 Swap
- Is there digital clusters for the 5th gen prelude?
- 95 Prelude Si auto speedometer off
- 96 Prelude Engine Harness
- '93 Prelude - Need additional troubleshooting ideas
- 93 h23 sleeves
- Honda Prelude 1997 engine info
- 1988 Honda Prelude automatic very high rpm at 60mph
- Stock Honda Rims
- H22A
- 99 Lude Dizzy polarity
- I just installed a skunk 2 70mm throttle body
- H22?
- JDM 97 Base Prelude
- Prelude valve springs
- Prelude help - H23 swap
- 1987 Prelude b20z awd swap... wiring recommendations
- Skunk2 spring base question
- JDM F22B DOHC FOR TURBO!?
- f22a
- H22A4 Question
- canbus on prelude 4th gen
- 93 4ws build advice
- H22a4 Build Advice
- I parked a little too close to the curb and need help on a 02 sensor
- 5th gen manual swap
- What size throttle body would be a good fit on a h22a4?
- 93 prelude h23a blue top swap
- 96 prelude. Believe it’s a 6th gen
- Electrical issues 5th gen prelude
- Selling Prelude Dilemma
- Prelude H22z compared to h22a4 (for engine gaskets)
- Timing Belt
- 5th gen rear UCA ball joint replacement....
- Strange Coolant Issue
- Help rats chewed up wires image's inside my
- Electrical issues or what?
- 1St Gen Prelude Find
- p1259 Vtec Code - 01 Lude manual Swap
- Low Power, Lean, stalling after driving 1400 miles on new turbo build.
- honda prelude 1997 2,2 supercharger
- Retro gauges from old Hondas?
- 5th gen front bushing
- No Crank from key, but can jump starter with a switch
- 95 accord non VTEC engine harness in 92 prelude with f-22a non vtec
- 5th gen prelude suspension help
- Front end swap 92 to 01
- 01 Prelude w/93 Accord MT (H2U5) CV AXELS NEED HELP!
- Swap questions
- temp sending unit 3rd gen 1991 prelude 2.05L B21A1?
- 3rd gen prelude temp gauge is fluctuating
- Prelude 5th Gen Jerks when Idle/stopped at the lights
- 4th gen wiring, main harness to ECU and fusebox
- 3rd generation prelude CEL is blinking please help me read it
- 98 honda prelude 5sp starting/ignition key issues?
- 3rd gen prelude TPS calibration voltage is wrong
- Honda Prelude BB6 1997 H22 weird starting problem
- 1992 prelude S, h22a, cut wiring harness from the cabin
- troubleshooting 96 swap rebuild
- F20B SWAPPED 92 PRELUDE(ISO UPGRADES)
- Can I Clean Engine Parts and Sensors with Ultrasonic?
- Rust on Crank under Pulley. How do I clean and Prevent rust?
- 2001 Prelude Keys, IMMO and ECU Help
- Prelude FUEL AND TEMP GOUGE
- Balance Shaft
- 1988 Prelude Whole car rumbles while idling - Has new aftermarket motor mounts
- 5th gen lude p1259
- 1990 Prelude Harmonic Balancer
- Injector Dynamics 1050x Issue
- Tach/Speedo lights, taillights off
- bb2 swap?
- 1999 PRELUDE WON'T START
- 90 Prelude H22 Engine Swap: Looking for shop in NJ
- 88 Prelude SI will not go in to gear when car is on. Flywheel issues?!?
- 1999 honda prelude
- 98 Honda Prelude Build F20A4 -> H22A
- 1993 BA8 Prelude S temperature issues
- Engine sizing
- [Lengthy] Battery charges itself when negative terminal removed. Other issues.
- need help picking motor. h22a4 (bad sleeve damage) H22a or H23a will be FI
- Need a list..... of interchangble parts
- egr code 12 trying to understand system 92 prelude si
- Door jamb female pin connectors. What size, where to buy?
- 1994 Honda prelude power loss when air conditioners on
- Ecu problem/Fuel Delivery problem
- Need center caps for 3rd gen wheels, are there any alternate compatible caps?
- Turbo 97 lude h22 build
- 5th Gen Prelude. Not Starting. Not Cranking.
- Admission diagram f22b2
- Prelude hesitation #1000000000
- Damaged Threads on Fuel Feed to oil filter
- What parts should I rebuild on my high mileage h22a4 replacement?
- What parts do I exactly need to rebuild my H22a4 with rod knock?
- Would this H22 turbo setup mate up to my H23A1?
- Hey all new here and need some help
- 4th gen Prelude starts then stalls?
- Found this super good deal,but with problems
- 3rd gen shit cables
- which sensor this is that busted on my 2000 Honda prelude 2.2 L automaticVTech
- Stock height coil overs
- Oil Leak help
- Stock jdm Headers?
- Coolant Leak
- H22A into 1999 PRELUDE SH
- M2B4 transmission growl/Noise - even after new ISB
- H23 revved past 6500 rpm, now car won't start
- Prelude front wheel hub
- OBD1 93 prelude vtec MAP question
- Misfiring once warm
- Bouncy throttle?
- 93 Prelude S speedometer, odometer, tripometer all not working
- When to quit on a 5G?
- Is this car a lost cause?
- Honda Prelude BB3
- 94 Prelude Vtec clutch issues
- 5th gen Lude driver function broken wire fails fixed (mostly)
- 01 prelude clutch issues
- California Questions, Smog, Rebuilt Engine
- H22 Valve Guide Help
- New piston question.
- 2000 prelude compatible automatic transmission
- Hello, good afternoon, h23 project
- Prelude drag suspension help
- What header for F22A1
- "82 2nd gen Prelude 1.8 Ex dual carb
- 5th Gen Prelude replacement driver's seat
- Where to BUY 1990 Prelude Sycronizers and Bearings
- The mystery prelude
- P1297
- Bad rings in my h22
- Help with ATTS leak
- H22a Bearing and Rings Questions
- H22a shuts down while driving
- M2a4 tranny output shaft seal
- OBD1 or 2? H22a1 swap
- Can anyone help identify the part needed to fix this?
- Knock sensor
- H22a where is it going
