PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 [194] 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. h22 idle problems
  2. type-s
  3. mounting OBD1 ECU in 5th gen
  4. question
  5. Car pulling to the right when hard brake, what gives??
  6. h23 + aem fpr =fitament problems and more
  7. Why do people say the BB1 is the shiznitz?
  8. Is my alternator going bad
  9. dumb question but I really need some help
  10. Will I notice the difference betwen 215/40/17 and 205/40/17??
  11. Piston rings gone.. How to stop smoking
  12. camber setting 92-96
  13. Rear brake problem
  14. Lean Racing short throw shifter 5th gen
  15. Passenger door....
  16. 4th gen for 3rd gen
  17. Horn does not work!
  18. Timming belt issues
  19. stock intake change
  20. H22a cam question
  21. 97-01 H22 question, Head bolt socket size?
  22. 92 si being weird for 2 weeks
  23. Friend got his prelude back from the shop and they said.....
  24. Check engine/ATTS light came on....help
  25. 95 Prelude Sr-V rear seats?
  26. About my wrecked prelude that i was parting out....
  27. Apexi Intake Flange
  28. P13 Knock Sensor Question?????
  29. PLEASE PLEASE NEEDED!!, THANKS!
  30. How many grounding points on a 5g?
  31. Pissed off about replacing catalytic....?
  32. RC 310CC Saturated injectors FOR SALE
  33. new speaker install
  34. 3g Power in an afternoon
  35. euro r manifold....
  36. Cat back systems???? whats the best one?????
  37. Transmission problems...
  38. coolant bypass mod
  39. Coilovers or Springs
  40. Installed prospeed last night.....
  41. 2001 Prelude SH Bought
  42. valve adjustment h23
  43. Timing Belt 5th gen
  44. Suggestion if to stick with H22a injectors or H23a1 injectors?
  45. 90 prelude and gs-r cluster
  46. is this a good deal for kyb agx's ? and does all prelude struts fit 92 through 01
  47. exhaust piping length
  48. Skunk 2 Cam Gears and Type - S pistons
  49. easy question
  50. Flushing out the engine - question
  51. VAFC tuning
  52. Built H22 Question
  53. JDM H22, will it pass smog??
  54. Headlight & Overheat Issue
  55. exhaust fitment
  56. Power loss, anyone experience a dizzy going bad?
  57. what causes redline to change? i jump from 6500 to 7400 randomly...
  58. should i buy naws for my prelude?
  59. trade carbon fiber tailights.....for ???? see pix
  60. Idle and Vtec Problems...
  61. Grinding while turning
  62. Spoiler?
  63. Taking off stock exhaust
  64. Prelude Rev limit HELP 89 lude si 4ws
  65. WILL A STOCK MUFFLER FROM A 94 LUDE FIT A 99 LUDE?
  66. Front bumper body kit with stock side skirts
  67. Header test
  68. p72 gets rid of EGR valve CEL?
  69. rps clutch heating up and slipping???
  70. pos prelude
  71. for those of you with HID's
  72. water on my pass. floorboard :(
  73. which exhaust ?? 2.25" or 2.5" ??
  74. 97' Prelude bad catalytic converter...gutted out?
  75. 92-96 Prelude service manual
  76. lower ball joint on 01 se
  77. JDM H22 1/4 Mile Times!!!!
  78. f22b motor dropped in my 92 civic, need help with what kind of spark plugs to use
  79. Which should I get?
  80. H23 turbo project
  81. JDM M2A4 Transmission + OE LSD?
  82. prelude 93 si vtec problem in vtec
  83. Gen4 Lude with H22 -> total cost?
  84. where is best price for aem cam gear
  85. Tanabe Sway Bars and Lower Braces
  86. Very Interesting Question, F22 internal, H22 head
  87. 93 Prelude Si surges and lags after car warms up
  88. installed new injectors vtec is breaking up
  89. car making wierd puttin sound out of the exhaust?
  90. who has broken a crower cam
  91. 3rd gen motor
  92. weak vtec???
  93. VTEC POINTs....
  94. some help with cel, h22 swapped
  95. prelude cams manual or automatic (any difference)
  96. what is better for a jdm prelude vtec.
  97. Type-S intake Vs. CAI
  98. fitment
  99. 97-01 prelude-struts/shocks differ from SH to non-sh models?
  100. Good place to buy Prelude interior parts
  101. best valve springs for stage 2 cams.......
  102. wtb prelude wheels
  103. main fuel relay
  104. what IAC's are compatable to a 98 'lude with an h22?
  105. what would the labor cost be...
  106. I.T.B.'s
  107. vtech problems
  108. Is my clutch slipping?
  109. looking for prices on turbo
  110. bulb size question/confirmation
  111. cam ?
  112. Well boys...I'm one of the regulars now.
  113. spoon sports spark plugs good?
  114. Traction bar setup for 4th and 5th gen ludes updated
  115. Max Compression on Type S Pistons/cam choices
  116. Buying a LUDE??
  117. has anyone painted their spoon / spoon replica lip? (4th gen)
  118. AEM EMS 30-1000 for sale
  119. 93 Prelude SI Digital Instrument Problem
  120. GM Sychromesh test and results
  121. wierd electrical issue
  122. triple pillar pod " I need one bad"
  123. h23 mani fit h22 ?
  124. Head Question
  125. 6BTM MSD Ignition
  126. wheels
  127. It is time.
  128. Power steering speed sensor
  129. Radiator for SH different??
  130. Can someone recommend some pedal replacements. 4th gen
  131. Steel brake lines
  132. clutch catch point
  133. How would i know if its lsd...
  134. Intermittent O2 CEL
  135. respraying the valve cover
  136. Lets all clear this up - Red/Blue top. What about Black top?
  137. Ignition switch in 4thgen
  138. h22 question
  139. removal of VAFC II
  140. question about changing springs
  141. OEM Honda parts
  142. help me out here guys (about jun cams)
  143. cost and any legal trouble for 5spd conversions
  144. Wings west?
  145. boosted H22's in phoenix area?
  146. Steering Wheel for 4th Gen
  147. Compression test results, how'd I do?
  148. Anyone have their stock intake box? 4th Gen 92-96
  149. Cleaning the Engine Bay
  150. Any Suggestions on Intake Manifolds?
  151. h22 throttle bodies
  152. Prelude motor in the back of an Integra
  153. Head studs H22A vs H22A4?
  154. ALL 6'1" AND TALLER 5thGEN PRELUDE DRIVERS!
  155. Difference Between H22A w/lsd, and H22A4 SH???
  156. Would I be alright risking OBX Camber kit?
  157. will a jdm h22 IM help with my turbo set up?
  158. P13 A12 h22 ecu ODBII pin out
  159. what´s your milage?
  160. Recaro SRD's for the lude
  161. idle rev problem need help asap
  162. Mugen Header
  163. How do i get this shock off????
  164. AV Engineering (precisionh23a) Tuning Session - New Orleans feb 2-5th
  165. should i take out ac equiment or keep in?
  166. What temperature for Opening my headight
  167. stock rev limit & vtec crossover
  168. jdm upper strut mount
  169. the price of my car
  170. How in the F do yo put Timing belt back on?!
  171. my brand new h22a
  172. 95 dash/radio size questions
  173. Anyone Parting out their Lude?
  174. Vis Mugen sides Question
  175. What should i do?
  176. 11:1 pistons in h22 - who's done it? gains?
  177. Quiet aftermarket muffler (used?)
  178. tranny problem please help
  179. lost
  180. Breakdown list
  181. Compression
  182. Oil cooler seal replacement
  183. Where have all the coyboys gone
  184. Coolant lines for fast idle
  185. The only JDM kit for a 'lude only 375!!!
  186. field-vafc/trouble shooting
  187. who is the guy that has a silver 5th gen prelude came into baxter auto parts (oregon)
  188. h22 tranny
  189. JDM Type S front lip
  190. engine swap
  191. Just bought 92 Prelude Si today!
  192. Tragic...
  193. FPR needed with a VAFC?
  194. Torque converter? Need help asap
  195. High Flow Cat/Test Pipe and Mugen Header
  196. tach problem?? anyone else with this......
  197. Everything I need for swap?
  198. stock c/r what cams?
  199. HELP ~ installing the caspers o2 simulator
  200. Please Need HELP with H23A2 swap Info ?
  201. taking off fenders
  202. OBX Headers any Good?
  203. Starting my head swap tonight.
  204. 89 prelude dies !!!!!
  205. WTB euro R crank pulley
  206. timing mark
  207. Vtec Crossover
  208. Pic Request: OBD1 h22 injectors
  209. broken clutch?
  210. What time am i capable
  211. 1997 Honda Prelude. Red with black interior.DOHC Vtec Auto. 115K miles.Clean
  212. Descisions
  213. OEM vs Aftermarket Axle Replacements....
  214. good buy?
  215. 90 prelude inx conversion
  216. F20Z1 crank case will fit on H22?
  217. Got an issue, might need to get a different car.
  218. Hissing noise from air conditioning..help please!
  219. Prelude stolen
  220. motor swap
  221. bfg g-force sport
  222. elementary oil question (found nothing w/ search)
  223. Need help with taking apart the bumper
  224. Prelude 3-d generation engine swap
  225. need help with head removal
  226. major head work
  227. E-brake boot??
  228. Prelude Transmission
  229. What to do with a h22
  230. Need HELP about these rims..!!!
  231. ******Prelude Forum Rules Update******
  232. Opinions needed on damaged H22 tranny (large/detailed pics)
  233. Accord struts/shocks on a prelude?
  234. upgrading to vtec rotors and calipers, same master cylinder?
  235. stationaty antenna - searched already
  236. Oil leak, found it, not sure how to procede, help!
  237. Lude Lighting!
  238. Problems with chipped ECU on H22
  239. Intake Confusion (Resonator butterfly's VS Secondaries)
  240. engine swap....anyone here want to do it for money ??
  241. Headlight Harness
  242. Looking to buy a Prelude, need some advice please
  243. Turbo Help???
  244. engine rebuild
  245. radio code for 5th gen
  246. double vtec yo!
  247. Porter Electric 5th Gen TD-77U Distributor Review/Install
  248. Taking my car to the track for the first time
  249. Rolling in VTEC for long periods of time......
  250. Looking to replace B20a5 with ????
