View Full Version : Honda Prelude
- Blinking check engine light?
- idle problem
- Need help
- 99 Prelude front dash assembly diagram?
- h23
- Searching prelude buyers guide
- NA project went bad (blown engine)...suggestions needed for 250whp.
- Change my timing belt?
- jdm head function with a usdm block?
- Would the H22 type S pistons work on the h23 block?
- Alternator Pivot Bolt Specs
- Salvage quote/parts car
- My motor is leaking oil all over the place...
- Need Info on Exhaust & Rims
- New o2 sensor and still throwing code 43
- 5th gen lower tie bar pics
- Shifter Cable issues
- Type R style wings for BB4?
- H Series Bracket to fit a D Series alternator
- jdm fog lights harness (searched)
- Free Service for 95-97 Honda Vehicles
- jdm fog light harness
- how can a JDM digital cluster fit on a usdm?????
- 96 Prelude, What engine Options do I have?
- jdm stuff
- Draining Battery...
- air/fuel question...
- Individual throttle bodies for prelude?
- NDC Bearings
- leaking hydralic clutch fluid?
- DP Nitrous...
- 94' prelude CEL
- h22 fuel line question
- f series h series
- can someone tell me what this is
- syncros
- idle surges even after replacing iacv
- 1 dim headlight 1 normal why??
- 89 Prelude Si Help!!
- type-s pistons with eagle h22a_ rods
- 97-01 Honda Prelude Projector Headlights
- New gears, at TDC, won't start
- EACV questions... Not normal.. (searched)
- where can get a set oil squirters
- Problem with the brakes, need second opinions
- h22a4????
- 02 Sensors ?
- Pictures of Wings West front on Prelude 92-96
- compression
- Clutch
- h23 tranny on h22a
- FS: H22 cylinder head, 67k miles
- bent valve?
- Noob: What exhaust sound good on these cars
- 4ws 3rd or 4th gen preludes worth it?
- h22 h23 f22 gear ratios
- Fuel Fill Door Question 4th Generation
- Cam gears
- still burnin
- One Huge Question!!!!
- Apexi N1 bolts
- 1st gear clutch/tranny problem?
- H22 low rpm hiccup?
- Prelude shutting off problem- fuel realy?? Need help!
- I don't know what to do anymore about this idle!
- fresh built h22 running like a harley. please help
- my power locks have a mind of their own!
- Anybody just replace timing belt and water pump, and not seals ect.?
- code 23?? please help tuning tomorrow
- Clutch/flywheel pressure plate
- Another day on the Dyno...Not wasted this time!
- Melting rear lip anyone have some ideas?
- Please Help! Need to figure out whats wrong!
- Auto to Manual
- Euro-R Intake Manifold
- Electrical problem climate control and passanger pwr window not working.
- JDM automatic tranny problem. Help!!
- Werid ong ong sound made when idling (usally in the 1500rpm - 2500rpm range)
- Check Engine Light/ ATTS Light (searched)
- Bad dizzy or bent valve?
- prelude parking lights... location of wire?
- another h22 sleeve question....
- ecu chip
- help on h22a and type s!!!!!!
- question about mix-matching h22 and h23 header/cat/cat-back's
- 5th Gen s15 Silvia Headlight conversion?
- traction bars
- 92 SI swap Harness question
- What bumper / lip is this? (4th Gen)
- Crower Cams...
- tein super street setup 92-96 same as 97+?
- Hotshot header....
- 4th gen JDM Internal Harness & Switch.
- Electrical problem - confused.
- Couple of questions.
- Aftermarket steering wheel
- I'm an idiot & need help geting an axel back in
- Quick question for you Luders...
- Water in trunk + Taillight Fuse Blown
- JDM headlights...
- H23 Head Bolts, Reverse Thread?
- Problems at idle
- spoon & prelude
- thinking about buying a prelude
- does anyone make an adapter mount for accord trans in a prelude
- bleeding clutch line yourself
- How to take out the piece above the center vents and clock on 5th gen?
- dizzy question
- Location of passenger compartment fuse/relay block
- installing tachometer w/shift lite
- worth it???
- How to tell between A and B pistons?
- Dash Lights + Brake Lights- Out
- vacuum leak?
- power steering removle
- RMF/i/e Dyno Results
- This goes to show you that 3rd Gens HANDLE WELL *VID*
- Swapping H22A
- Car sputters while warming up
- sleeveing??
- Power Steering causes idle drop to 500 RPM
- exhaust pipe size
- 4th Gen. Mugen Kit
- turbo ?
- Anyone have carfax right now?
- Is the OBD1 JDM H22 a 5 speed auto tranny or 4 speed?
- H23 to H22 Swap Help, just a quick question.
- Will These Work Fine?
- Weak start up in my 5th gen lude
- air cylinders on 90 2.1
- 90 lude brake upgrade
- 1994 Vtec - Odometer and Trip odometer issues.(digital cluster)
- master cylndr. (clutch) help
- compression test on F22B DOHC HELP PLZ!
- Fan Problems
- CEL throwing a CODE "0" = bad ECU?
- Any Info on DC Sports H22 Header w/ 2.5" Collector?
- newb. headers. please help
- BRAKE lamp on
- random loss of power, rmp jumps, stall, HELP
- CEL code 67
- 85 prelude
- 1990 Honda Prelude 2.1 litre
- Ludes in AZ
- Help on new N/A setup
- Removing paint from plastic
- time for new brakes!! :)
- car shakes
- what is the normal idle RPM For 5th gen prelude?
- Opinions on these Ebay springs??
- gauging interest...
- CEL 9?
- OBD 1 Prelude with 2 O2 sensors????
- h23 finally apart
- Help! Major problem.. possible cause?
- Problem diagnosing CEL Random Misfire Cylinder 1
- Buying A Lude?
- Mahle Pistons Install...?
- which oil?
- can my tranny be saved
- Has anyone ever purchased Type S pistons STD B from hmotorsonline.com?
- leaking cam seals. please help!
- Idle low from power windows
- help on my piston setup? (ABBB)
- H22 cranking issues. Expert help needed.
- Clutch messing up
- H23VTEC
- h series exhuast manifold. on f22
- how strong are stock H22 rods?
- torque specs
- can someone show me how to remove airbags on a 5th gen?
- IACV problems relating to weather? (Idle surges)
- JDM H22A Recommended Fuel?
- Auto 95 BB4 lude (H22a) with MANUAL P72 ECU?
- what brand gas do you run in your prelude?
- 1993 H22 Crank Pulley Bolt vs 1994-01 H22
- my prelude now has forced induction...
- Removing OEM spoiler for 5th gen prelude SH
- h23 w h22a crank and rods
- bodykits for my 4th gen
- Has anyone tried the RAGE header sold by Kteller?
- no reverse?
- h22 type s cams
- Balance Shaft removal????
- H23 head vs H22 head
- VTEC/IDLE SPUTTER???
- H22 sleeve questions, reringing
- front component speaker recommendations for 4th gen
- Axles: h series vs f series
- removing ABS and ATTS
- question bout Euro-R h22 and a regular h22
- Swollen coolant hose=bad thermo?
- 94-96 Center console
- cam gears
- Think I'm dumping too much fuel
- 6 hour suspension HELP!!
- 4th gen sunroof jam
- is this the correct way to connect an Oil catch can? pix inside
- bought a NRG grounding kit, where are the good point to connect it?
- Turbo oil feed hookup.
- jdm ecu and usdm ecu VTEC rpms?
- Options for OEM steering wheels on 4th gens
- ? about brakes
- old tires on new rims?
- head bolts
- dyno tuning
- Help, door is stuck!
- 88 prelude gauge lights
- Steering wheel vibration
- jdm h22a quarter mile question?
- Throw out bearing? won't go into gear hardly, pics 2/16/06
- pistons
- Quarter panel patches?
- Converting Auto ECu to manual possible? 5th gen
- noise just prior to vtec
- Write-up: EL Gauge Cluster Conversion
- B&M FPR question???
- Just wired up my 1 piece JDM lights, some problems..
- dropped ride woe's (scrapage)
- Recomendations for the nex step?
- Anyone ever seen this
- PVC Valve cover ports
- HELP HELP H22 swap problem
- EGT/Engine Question
- Airy? (Alot of Air) Noise through RPMs
- Performace Parts
- HORRIBLE gas milage. (searched) HELP
- Which pads/rotors to use with my NSX calipers?
- CEL 36?
- h22type s and h22 valve train?
- f22a1 to a f22b2
- Clutch+Flywheel
- labor charge for axle
- am i getting scamed?
- C.F. hood fitment....
- i need help selling my car..
- WWRS Front liP!!
- h23 vtec
- Arospeed RS-GT on 4th gen, anyone have this?
- Washer jets - no pressure, back jet not working
- h22 type s cams
- Leaking Coolant
- I need spec for valve adjustment for h22 type s cams
- what to do? my NRG slim hub doesnt fit the steering column
- Cams adjustment
- estimate for turboing
- 98 Prelude Random Misfire
- Engine Code 3
- 4th gen h22a swap problems
- DIY jdm headlight question
