PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Rebuilding Engines
  2. h22 swap runs rich help
  3. Honda Prelude turbo
  4. lip kit options
  5. Eagle H beam rod weight vs stock
  6. h22 or h23 for gass mileage?
  7. Timing Verification
  8. JDM H22A HEADER
  9. h22a tear down
  10. Headlight retrofit questions
  11. Difference in F-series and H-series trannies??
  12. timing question. power loss.
  13. my fans only turn on when a/c is on?
  14. Annoying idle issue! can't figure it out?!
  15. Stock 335whp H22a - AV Tuned
  16. Broken Auto Tensioner caused me a lot of problems.
  17. Replace starter contacts on 97 Prelude? (JDM engine)
  18. quick question
  19. H22A NGK spark plugs (ZFR6F - 11 or BKR7E - 11)?
  20. spoiler third brake light
  21. HKS Super Dragger Exhaust?
  22. Quick Release Steering wheels..
  23. I am so [freak]ing jealous of all you guys.
  24. led light bar in wing
  25. 89 prelude foglights
  26. ***Droping RPM very low (question - need help)***
  27. Wavetrac LSD not the best designed LSD for drag racing?
  28. Headlights
  29. Intermittent Reverse gear.
  30. Skunk2 Intake Manifold
  31. stick shift convderstion
  32. connecting the ECT directly to the P13 question ??
  33. 92 Civic Hatch with H22, Air Conditioning question?
  34. 92-95 H22a valve cover torque specs?
  35. for what its worth
  36. 92 auto to manual
  37. Apexi Dunk Exhaust
  38. Purple H1-80W bulb replacement?? Please Answer
  39. No cold start, no spark
  40. Help - clutch switch to start engine?
  41. M2B4 final drive change
  42. Rear lower ball joint----
  43. H22 didn't put in one of my thrust washers!!!!!
  44. Mounting Oil pressure sending unit
  45. Rebuilding h22a...give some suggestion.
  46. 9/21 Autocross
  47. 25T caliper mounting brackets??
  48. cutting springs
  49. Built H23 VTEC Head Gasket Question
  50. timing belt
  51. Just wanted to say thanks for the guy who refered me to keylessride.com
  52. auto to manual 93 prelude si 4ws
  53. 215/45/r16 on stock wheels?
  54. Hot to uninstall abs pump from prelude 4th gen?
  55. Sunroof Problem (Searched)
  56. Front Suspension
  57. HELP!! M2S4 tranny will not shift into ANY gear
  58. Timing
  59. how do i tighten this castle nut?
  60. h23 maf
  61. OBDI/OBDII Coil Problems
  62. 4 lug on 5th GEN
  63. obd1-obd2 dizzy conversion
  64. jdm h22a stock header or greddy header?
  65. Help!?!?! 4th Gen Prelude, left head light is out? cant figure it out????
  66. Capet for 1998 Prelude
  67. best ecu for f22
  68. 5th gen prelude help please!!!!!!!!
  69. ******New Autotech Driveline Wavetrac Differentials*******
  70. Cam bolts?
  71. ecu help please....
  72. Leaking oil from oil cooler gasket area
  73. H22 Crankshaft Pulley
  74. Block Stamp
  75. H22 Manual Tensioner Swap -- Will any parts from an F22 be ok to use?
  76. f22 - h23 swap.
  77. eBay rear camber arms
  78. Which headlights.........
  79. Pic Request: 4th gen modified Hiro front lip
  80. Who makes 13.5:1 High Compression pistons for the h22 ??
  81. any coilover 'how to' for 97-01 prelude?
  82. 3rd gen.. need help!! engine wont start after timing belt replaced
  83. Looking to buy a prelude.
  84. 1993 Prelude engine stalling....
  85. JUST BOUGHT A H22a. HELP
  86. Pic Request: 4th Gen with Engine hood Vented at the hinges
  87. Raising hood in rear
  88. installing msd blaster coil
  89. what exactly does a balance shaft delete kit do...?
  90. tcu varies by obd version ? or . .
  91. Speratic Idle and no Heat?
  92. 96 obd2 p13 peak n hold or Saturated
  93. BAD TORQUE CONVERTER?
  94. 1997 Type-SH Prelude
  95. 1999 auto obd2 h22 prelude with obd1 h22 motor?
  96. CB Raido Mount under Radio...
  97. 3rd gen prelude not starting and barely holding charge
  98. maintenance required light red !!? HELP !!
  99. h22 and h23 rods and crank wat the difference
  100. 4th gen. bumper light stays on after signaling.
  101. timing belt keeps moving (help ASAP)
  102. wiring the horn to aftermarket wheel/hub
  103. Speaker help..
  104. New Prelude Need help hooking it up
  105. should i buy
  106. Power Steering Removal
  107. Will 92 Si Prelude Brakes work on Civic Eg??
  108. Are 215/55/16 or 205/55/16 too big?
  109. check engine
  110. Exhaust Problem
  111. Mahely gold serious ?????
  112. OEM Oil Cooler Leak, Cooler or Gasket?
  113. fustrating dyno day, vtec issues HELP!!!!
  114. My prelude takes 1st place for Honda-Challenge H2 National Championship
  115. need help on fuel pump
  116. ---Knock sensor---
  117. Radiator issue
  118. fuel system upgrade?
  119. venting a 5th gen hood?
  120. axle question... (searched)
  121. f22 accord tranny in prelude , mounts diffrent?
  122. foglights died all of a sudden
  123. 4th gen will not start...Need help please
  124. Quick Question about 88-91 preludes...
  125. CAR OVERHEATING
  126. Movement of rear strut bar
  127. climate control and my fans dont work???
  128. Fiberglass Triple Gauge Pillar
  129. Msd Ignition coil
  130. mahle frm compatible pistons
  131. H22 Mahle Piston scratch
  132. why would a dent cause vtec not to work??
  133. keeps heating up????
  134. I need some help on this guys plz help me out!!!!
  135. 4th gen brake help
  136. JDM or USDM p13
  137. Downshift Noise, Rattle, Clink, and Whine
  138. Need help problems with 97 prelude non sh
  139. Looking for an oil port on H22 with 1/8 " NPT thread
  140. URGENT Cooling Issues!!
  141. is it hard to install oem front lip diy
  142. cant decide, need some input
  143. Need Help Big Time!!! 97 prelude won't pass smog
  144. HELP on VALVE ASSY., BYPASS CONTROL SOLENOID
  145. top mount throttle body (searched)
  146. help, have a base model prelude and need some info on exhausts
  147. ignition timing specs for h22a?
  148. h22a upgrades
  149. h23 oil pan fit on a h22a
  150. Engine Lag!!!
  151. how to change your backlight (DIY)
  152. h22a oil pump
  153. 3rd Gen Prelude Brake Problems
  154. braided clutch line? can I?
  155. need some info about bb6 base and sh evhausts and echaust manifolds
  156. Headlight bulbs
  157. 5th Gen 4ws Fault
  158. need help on 4th gen suspension
  159. Introucing Teamzigen
  160. Wont start when hot out or when engine is warm
  161. Live video feed for Honda Challenge National Championships - Sunday 11:55 AM EDT
  162. 1991 honda prelude engine swap
  163. h22a timing belt question
  164. Noob Question
  165. wheel clearance help?
  166. Is it recomended to replace both front and rear brakes at the same time?
  167. New Car: Won't Start!
  168. p28 ecu and hondata s200
  169. TURBO
  170. F22V turbo build
  171. Need help with H22a
  172. Multiple cylinder mis-fire can anyone help?
  173. Hesitation problems? No low end power? My experiences...
  174. 4th Gen Prelude Tranny Question
  175. can some one help me?
  176. what should i put in my 01 prelude non sh
  177. suspension set ups what to get?
  178. 2001 Prelude Lower Ball-joint and lower clutch cover
  179. Headers & Exhaust Sizing Question
  180. 4th Gen lude Vtec Jack and Stand Points
  181. alternator
  182. converting my auto to manual with an m2s4-- whatcha'll think?
  183. Two big ports in the front of H22-> good for crankcase ventilation?
  184. Check Engine light??
  185. S2000 suspension
  186. Vtec Kicks on and off
  187. Is this normal?
  188. piston and rod balancing
  189. hot lude... :)
  190. Helping a buddy find a header
  191. FROM DB8 TO PRELUDE
  192. where the hell is it?
  193. OBD1 engine OBD2 chassis (SEARCHED)
  194. Good port & polish..
  195. 5th Gen problem
  196. Where is the ecu location on 1999 prelude type sh?
  197. Problem with start-up
  198. oil pump problem????
  199. Honda noob, need to find a tuner in AZ
  200. buying a used shortblock, should i get it decekd?
  201. noobie with a H22 question!
  202. CEL while coasting 4th gear...
  203. random shut off! HELP!
  204. speed sensor
  205. 97 jdm h22a into 00 Base. Stock ecu?
  206. 1997 Prelude - Idle to slow
  207. emergency! need to find Fuse Box & stereo Diagram 94 Prelude VTEC
  208. Squeaking form rear suspension - HELP!
  209. Headers (This or That)
  210. couple of swap questions
  211. 98 Lude ignition problems
  212. wtf is going on with this thing?ne one?
  213. Problem with Potential Car
  214. Heater control stuck
  215. how much do i torque clutch?
  216. Needing locations for all rad fan fuses/relays/switches.
  217. LED bulbs in a 4th gen prelude dash
  218. power slot cryo treated rotor, anyone try these yet?
  219. 99 honda prelude--can someone go to their car and confirm if this happens...
  220. CEL!
  221. ebay headers
  222. 98 prelude
  223. What Rims Are These?
  224. 4th Gen f22b1 Vtec Revs out at 4k
  225. Anyone have a Godspeed aluminum radiator?
  226. Oil Light question
  227. Timing Problem, help please.
  228. NEED HELP!
  229. Car Starting Problems
  230. need advice on what type of gas to fill up...
  231. prelude gear i found, you'd be intrested, check it out
  232. h23 rpm problem! please help!
  233. All motor h22
  234. Injector helpis much needed
  235. 95 Prelude VTEC driver's side rear wheel squeakin.
  236. Ignition Woes
  237. RPM drops with A/C
  238. brake light on help!
  239. CAMP1320 Out of business?
  240. Which kit is this?
  241. Need Exhaust advise
  242. 2000 prelude serpentine blet diagram
  243. M2F4 transmission vs. M2A4 transmission, pros-cons ?
  244. Dumb Question, About to order tires and....
  245. h22a issue/ trouble
  246. Need some diagnosis help (engine noise)...
  247. new clutch install...need help asap
  248. shift boot question
  249. rough idle still
  250. ring help
