PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Power Draw Problem
  2. help with oil
  3. 5th Gen Prelude only needs 3 motor mounts?
  4. Turbo Prelude Issues
  5. f/h series oil type n capacity
  6. H23A bluetop Turbo?
  7. New times!!!!!
  8. how many 2nd gen luders on here
  9. I need a new Engine
  10. WANTED TO BUY ONLY :: NO TRIAL USERS, NO PICTURES - Sept - Dec 2013
  11. SALE ONLY ::.. NO TRIAL USERS, NO COMMENTS, PICS REQURED (as links) -Sept- Dec 2013
  12. Trunk popper wiring
  13. ABS light on.
  14. f22b1 sohc vtec?
  15. what's up by rear view mirror?
  16. AC works intermittantly
  17. trunk light stays on
  18. not your typical overheating issue...
  19. 99 type sh running rough
  20. h22a trans gearinh
  21. h22a4 rebuild questions
  22. Help with 4th gen mounts
  23. was throwing code's 71-72, now throwing 71-74
  24. Need help w/ 96 Prelude Si electrical
  25. Broke a hose fit on the top of EVAP canister? I´m messed?
  26. Custom switch panel
  27. 5TH gen prelude limp mode helpp!
  28. Rust in Tank 98 Lude
  29. Probably an alternator problem on 4th gen.Help plz!
  30. 5th gen windshield on 4th gen
  31. Changed Clutch and MTF still have trouble shifting smoothly
  32. 94 Prelude Cluster Retrofit
  33. Stolen 93 prelude
  34. no oil pressure on fresh rebuild
  35. Boosted pre lude help
  36. 92-95 automatic engine harness on a 5speed manual
  37. HEYYYY! YOUUUU!.....QUESTIONNN!!!!
  38. 1987 Prelude Si for Sale
  39. H22a4 to H23a swap HELP!!
  40. JDM H22A bar'd
  41. 92 h22a1 prelude need help
  42. h22a swap issues
  43. Valve spring rates: H22 vs. H22 Type S
  44. clutch problems
  45. What would you pay for this Prelude? 93 vtec 50k mileage
  46. Prelude Problem?
  47. 1994 2.3L Prelude Project!
  48. h22a ticking under load only
  49. Bad issue with prelude timeing
  50. Bad timing belt job
  51. Just how savvy do I need to be to replace my transmission?
  52. hmotorsonline.com transmission reliability?
  53. 5th gen Prelude automatic transmission reliability
  54. Prelude maintenance
  55. intake mani torque specs
  56. Noise when pushing down clutch pedal?
  57. leaking valve seals / converter code
  58. installing new transmission need help!!!
  59. Prelude Project
  60. EL Gauge Inverter Prob
  61. 95 prelude se map sensor issue?
  62. Project Prelude M
  63. Cam shaft lobe squared off
  64. 1991 'Lude...speedo and tach questions...and sunroof!
  65. Motor fitments!!! Need help !!
  66. 2000 Honda perlude base/ how to program/ tune ECU?
  67. will coil over from a 98-02 honda accord fit a prelude 97 SH
  68. help! 97 lude 5 speed manual not starting
  69. H22A CKF Bypass and P1361 help
  70. found leak !! Pics for some help !!
  71. 98 Prelude Base 5spd -knocking sounds
  72. H23A1 pics let me know what ya think?
  73. ignition switch on 4th gen prelude
  74. 4th Gen Prelude Rear seats
  75. Extremely high nox 15 mph
  76. bucking and kicking
  77. Seeking someone with Transmission experience
  78. 93 SI rough first start
  79. Does this sound like a short?
  80. H22 transmission
  81. 92 Prelude Si starting issue.
  82. something fell of my block.. help?
  83. T belt Jumped... Dizzy destroyed WTF
  84. Looks like I may have a spun bearing afterall.
  85. engine serial number
  86. Can i get by with just using "steel" jb weld or does it have to be mixed?
  87. prelude makes noise when parked
  88. Is a K2H possible on a real H23 Vtec
  89. what year is my h22
  90. headlights randomly turn off at night
  91. 93 prelude steering wheel play
  92. Timing Belt Tensioner Failure Question
  93. stock internal h22a making 243whp and 182 wtrq on mustang dyno??
  94. stock internal h22a making 243whp and 182 wtrq on mustang dyno??
  95. EXPERIENCED PEOPLE WHO HAVE BEEN AROUND THE BLOCK. HEAD NOISE. WORN GUIDES? HELP!
  96. should i buy 4th or 5th gen axles
  97. Mechanic threw in Castrol GtX 20w-50
  98. Any advise before I drop my coin on the rest of my exhaust system?
  99. dizzy problem
  100. timing belt question pics inside
  101. where to buy good lightweight crank pulley for 1997 prelude sh
  102. H23vtec fail... Machine shops fault?
  103. jdmh22a base or type sh in usdm
  104. H22 Swap Vacuum Question
  105. Best cam for h23 all motor
  106. what seats for my lude?
  107. Best replacement seats
  108. Stock internals with boost?
  109. JDM H23a Oil Light Issue
  110. m2a4 vs m2f4
  111. what is difference between open and closed deck
  112. Engine Losses Power When Accelerating/Running Rich
  113. p13 obd2
  114. 96 prelude F23A1 STOCK hlep
  115. help
  116. 93 Prelude engine swap
  117. m2f4 into my jdm h22a
  118. T2W4 Question
  119. IABs for preludes
  120. which axles to use ???
  121. all stock 1999 prelude, what's the best turbo?
  122. 92 Prelude Si temp/fuel gauge? Wiring help
  123. what's the most beneficial air intake for my 1999 prelude base model
  124. HELP with EGR PLEASE
  125. Using RTV on power steering connection?
  126. nrg wheel install srs bypass no start
  127. prelude immo help.
  128. Bisimoto injectors
  129. h23vtec swap- distributor issues
  130. H22A4 "Whurring" sound
  131. Is it really THAT important to go OE on a timing belt?
  132. Bad Distributor?
  133. Jdm tranny swap- axle question
  134. 1995 Prelude SE. What does the SE have?
  135. Does anybody else have a little shop buddy? ---"picture thread"---
  136. Cruise control not working
  137. car wont start now
  138. Usdm to jdm dizzy trouble
  139. F22 valve seals?
  140. Need help diagnosing noise...Bad timing belt tensioner?
  141. have a 92 prelude that i need a little help with hmu!
  142. Trasmissions that fit and work with h22a1?
  143. *picture* Crack in transmission
  144. 1993 h22a with 2001 h22a transmission
  145. weird noise from intake?
  146. Breathe Life into my 92 Prelude
  147. '97 Prelude CEL code p0301
  148. 93 H22a hesitation
  149. 98 Prelude SH: JDM H22A Type S fit OK?
  150. 97 Honda prelude Distributor question
  151. Wrong coolant... Now what? ... Also stalls when cold...
  152. H22 head build questions
  153. honda prelude 1997
  154. Looking for torque specs
  155. MAP sensor problem please help.
  156. Ignition coil
  157. piston rings and main and rod bearings
  158. H22 question please answer
  159. 98 base from OBD1 back to OBD2
  160. Just curious. Red RTV + VC Gasket?
  161. Lurching Issue After OBDI Swap
  162. H23 and H22 quick question please help
  163. Is it bad to run stock p13 on some 290cc injectors??
  164. Quick question on valve covers please take a few seconds to help.
  165. 1999 prelude Base exhaust system
  166. 92 F22 Prelude No check engine at start
  167. fully built h22a help please
  168. Cams?
  169. my car randomly wont start!! help.
  170. New Headlights
  171. PLEASE HELP Non vtec to vtec swap.
  172. new clutch engages immediately is this right?
  173. NEED HELP JDM climate control
  174. transmission making noise.
  175. 95 lude, just bought 98' H22, need info Please
  176. prelude tranny mount question.
  177. 96 Prelude Si H23a1 After 138mph on hwy 101...
  178. RPM needle bouncing, engine jerks a bit (with vid)
  179. no crank issue. new battery but acts dead
  180. code 9 help!!
  181. Emergency!! Please help 1997 Prelude stalling
  182. CEL code 71 help .. Bizarre
  183. Prelude Service Manuals
  184. 92 prelude ac problem
  185. 98 prelude just bough, struts and springs.
  186. Damn... I thought it was going to be easy...
  187. Can you or cant you? Honda prelude 98
  188. Swap Auto to Manual (Accord parts, not only Transmisson)
  189. Myths and Facts, How to baby our transmission
  190. Honda prelude e85
  191. The what's this for picture thread
  192. 1999 H2F (H22 to F22 Trans) stuck in fifth gear
  193. Prelude H23 turbo + intercooler kits
  194. Oil keeps dripping onto heater hose under distributor!
  195. Brakes not 100%
  196. Anyone have a white SH with stock wheels painted white?
  197. Driving 15% Gradient at 14k Feet
  198. timing belt walking off cam gears???? help
  199. Input shaft bushing or bearing
  200. Do you have a 4th Gen and a Multimeter? I NEED YOUR HELP!
  201. Pics of my little adventure on Oahu and shipping my new Prelude!
  202. LSD tranny question
  203. quick question!
  204. Emissions
  205. 89 Honda Prelude No Speedometer
  206. 1997 Prelude no start. Spark issue
  207. Prelude 85' replace distributor
  208. is it safe to lower my 93 lude w/out replacing ball joints?
  209. VIDEO. Squeaking noise at idle
  210. Mystery h22 main and rod bearings
  211. No vtec?
  212. no power to fuel pump
  213. 5G prelude highbeams bulb size problems.
  214. Clutch kills Speed Sensor?
  215. Running lights don't work
  216. alternator problem plz HELP!!!!
  217. H22 in my civic 97
  218. need main anf rod bearings for h22a
  219. Strange high oil dipstick reading H22a turbo
  220. Reverse light problems Help!! (yes ive searched)
  221. Shifting issues?! HELP!
  222. forth gen rotors
  223. Front sway bar bushing replacemant, 99SH
  224. Oil Pressure After oil cooler installed.
  225. Not enough power to fuel pump?
  226. Air conditioning issues
  227. How to tell if this part belongs on an h22a
  228. Putting together Prelude '92 engine
  229. Euro R LSD Tranny
  230. 90-00 lude
  231. been working on the problem
  232. A/C fail, no green light on dash A/C button
  233. 93 Beastlude H23 A1 JDM Head Rebuild- Tips Wanted
  234. Idling problems after warmup 96 Prelude SI h23a1
  235. HELP! Vtec frying VSS?
  236. PICTURE ECU fuse not in. Car still works good
  237. H22a leaning out!
  238. Headlight problems!
  239. I need some help from someone with a working 4th gen lude!
  240. Tachometer failed?
  241. Emissions Failed?
  242. 98 Prelude swap with F20B. Misfires on all cylinders.
  243. Euro R injector air injection
  244. Prelude Gen 4 Steering wheel
  245. Prelude H22A4 Rebuild Wont Start?
  246. noisy rocker arms any suggestions on why
  247. suspension issues cant figure it out help please
  248. Prelude SH power limit?
  249. Loss of power at a constant throttle, any ideas?
  250. H22A4 vs H22A2 on a 98 Prelude
