View Full Version : Honda Prelude
- 97+ front lips
- UPDATE ON CAR exorcism
- Need help with my turbo t3/t4!
- 5th gen wheel hub
- where to buy REV HARD manifold ???
- Blue Electroluminescent Gauge How To:
- making a shh- shh- shh- shh
- Few problem with Prelude I just got, new some help.
- what online company can i order an h22 head from? is there such company?
- Greddy headers and Greddy catback on 5th gen prelude
- HELP: Why is my motor running really hot after rebuilt??
- urethane kits that dont suck for 4th gens?
- engine type question
- h22 wiring
- Attn Helms owners: Proper valve adj. torque specs, already searched =)
- What kind of header should I get for my JDM H22?
- Dude I got the same set up, but a little more
- Is the EL gauge cluster from the 94-96 Preludes plug and play for 92-93's?
- buying h22a long block, shipper want my SSN ? !
- Dyno numbers on the Greddy Header???
- are f22 and h22 crank pulleys the same?????
- torsion rods
- HELP! Is it possible for an engine to hydrolock with a stock intake?
- apexi WS
- Clean Prelude @ SlamFest in Tampa,FL 10/5
- smokin out of the exhaust...
- ....rust problem
- Any one every use acl bearings on there h22
- usdm vs jdm stock exhaust manifold
- Shifter Linkage
- Pics of My Lude What do you guys think?
- Lowered 4th gens...
- h22 or h22a
- 4th gens with relocated battery's...
- Important info for those who have an SH and want to install an S2K wheel
- My Lude
- Update: Check out the lude
- Changing out suspension..what else should I change??
- moon roof dont want to open on a 5th gen lude
- OBDII to OBDI conversion: really worth it??
- Timing Belt Question......
- MAP sensor
- ...........tranny question
- .....::::when braking......
- Never overheated, but did this morning... Ideas?
- Where to buy stock prelude Exhause Flange?
- Auto maps different to Manual Maps?
- found the problem!!!
- Putting the ca rin first gear while rolling...do any of you have this issue??
- qeustions 90 prelude
- Where can I buy 2.25" exhaust falnges?
- boost controller, and waste gate question
- Torque-Steer...what causes it??
- stock 97+ prelude wheel for sell!!!!!!
- LevelTen Torque Converter
- prelude problem
- Greddy Blue box.....
- SHIT!! got in a minor wreck.. can someone tell me how much this part costs?
- preludes......
- h23-turbo build up, need ur tips/tactics, info help secrets
- Honda Prelude for sale
- 4th gen JDM headlinghts not lined up right... why?
- Anyone ever tried running a Hot Shot H22 race header in a 5G lude?
- I Need a H22a Shifter Assembly.....
- h22 swap question
- Looking for Jackson racing Supercharger for Prelude
- Prelude piston swapping question....
- What is an Si Protek?
- h23 head on f22 block
- hondaprelude.com
- heeelp, H22A engine block
- *TAMPA, FL ROLL CALL*
- axis spider
- Quaife in a SH tranny?
- Best Motoring Jun Prelude?
- yup another tire question (very specific)
- Need Clutch 4 Prelude (Suggestions)
- p13 pin outs
- MSD Distributor Cap??
- Fastest NA 4th or 5th gen Prelude???
- Shifter cable broke!!!
- Best place to buy Koni Yelloes Online...
- 92-96 front brake caliper piston size?
- Seeking prototype cars in Utah- Free sunroof plug kit for 97+ Ludes
- Speed Sensor on H22. Please help!
- who has a pic of the smsp header?
- FS DRAG gen3 kit for 97 prelude
- f22a1 valve cover
- want to learn, need help
- Open/Closed Deck years
- Bad Vafc 2?
- So I mounted a Spoon lip to a 5th gen...
- Brightstar HID
- Going to 1/4 mile, what should i launch at?
- Are there holes where the front emblem goes?
- h22a1 gear ratios???
- NEED SUM HELP BOUT H-TECH.com
- 2000 prelude sh witch EMS???
- *56K WARNING*My Lude!
- 97 Prelude Transmission
- Lagging???
- Are H22 & h23 clutches the same?
- H22a JDM
- Next step for my h23 lude?
- Prelude 17s
- Did i just get ripped off? (kyb shocks)
- Installing shocks and springs
- 97 accord 4cyl. 52k auto pinging noise when accelerating
- putting on valve cover...got some ?'s first
- How do you get the timing belt off on a 98 H22A
- Prelude Type SH transmission problem..
- 93 h23 1/4 mile times
- MY CAR NED AN EXERCIST
- How To Tell If Crank Is Cast?
- 2gen help
- anyone with 4th gen with 17"s 40 series tires?
- halfshaft differences?
- h23 rod/stroke ratio
- 4th Gen Oem Fog light install question
- jdm one piece harness
- Alarm, power locks, and remote start question?
- 4ws help!!
- Need to find thicker headgasket
- hmm wow honda is a rip...
- Installing and Removing HIDs
- anyone elses clutch do this?
- Quick question
- h23 block with h22 head
- 250 whp
- Can anyone take some ride height measurements please
- **::Additional Moderator Needed::**
- Installing Shocks + Coilovers
- Prelude sites?
- h23 vtec q
- h22 block h23 head?
- prelude question ?
- engine light, knock sensor?
- Great....I have no reverse now...What to do?
- HELP!!!!
- Honda prelude 88 and 89 ECU pinout
- When choosing cam gears....
- JDM APPERAL?
- (specif to h22 turbo guys) should i get a t4 turbo
- is this 1/8th e.t. alright
- How do I take out AIRBAGS!! PLEASE HELP!!
- 94-96 prelude console conversion help!
- tial wastegate
- finally the dyno charts are up. Read what technician 419 says
- Will KYB AGX shocks work on an SH?
- how can i tell if my VTEC trans is JDM or even a VTEC trans??
- How much boost on buil internals??
- Would this be a good deal?
- Have a Greddy Brand New SP ll Exhaust Syatem
- how to0 remove injectors
- When are aftermarket piston rods necessary??
- 98-2001 Preludes
- i need some advice...
- modify stock intake mani. read!!!
- ECU question
- hallow cat
- re-wiring jdm headlights(help)
- what to do first
- RPM bounce (1k-2.5k) when cold?
- 93-96 vtec prelude 6x9?
- 5th Gen Recall
- 3rd Gen Upgrades
- air fuel gauge
- Lude hp question.
- CAT question
- Prelude B21A1 Info
- Simple Exhaust Question
- Why is it so hard to find a H22A4 crank?
- ACL Bearings... anyone used them? feedback? opinions?
- Changing Wire cover
- replacement crank advice
- need help with the brakes
- chiping prelude,help
- Difference in performance between Short Ram and K&N
- prelude vortech supercharger
- JDM fog lights messing with my alarm?
- OT
- Where is everyone located?
- Integrated Phone
- any good tuners in N.C.
- issues with h23 vtec
- Shop manual difference?
- Custom Gauge Placement
- help reinstalling VAFC
- Bought a CAI but the adapter is wrong!!! WHAT SIZE IS THE THROTTLE BODY???
- Anyone tried out the new Nitto Neogens
- Anyone knows where to get Type S Ait Intake assembly
- safe rev limit w/ internals?
- '01 Prelude auto ECU pinouts?
- need HELP...on custom exhaust "5th gen owners needed ONLY"
- vtec head on a turboed h23
- engine warm up time
- AEM cold air intake question
- TRANNY SWAP HELP
- Internals for H22a Turbo
- Spring Rate question.
- What's a good header for H22, 4-1 header?
- AEM V2 Intake
- sound coming from back right tire...
- all my sensors are acting up after hitting boost?
- motor mount ques
- regulator or fmu
- h22 vs. h23
- extra cable on head unit, 94 prelude Si
- winds of change
- Newbie here, from the VW world. Got a Prelude Q
- who much hp???
- 91 prelude questions
- Lug pattern?
- Tranny Question
- Question Please help...
- SHIT!!! my transmission!
- clicking noise when braking
- TRANNY
- would any resonator fit on my lude?
- FS; port and polished head f22a and jg cam gear prelude s
- VAfc 1 vs. Vafc 2
- Honda Prelude Si 4WS 1/4 Mile Time
- Loss of Power. Please Help!
- Resistor box
- Tree Sap tearing up my paint!!!
- New Prelude owner
- turbo settings
- Well, my radiator blew. :(
- header question???
- H22A SC
- H22A
- Who has used forged Pistons in non sleeved pre 97 H series blocks???
- Prelude S Model.....Radiator....QUESTION
- Turbo Prelude Suspension set-up
- Boost Lee Turbo Prelude
- prelude got hit, does anyone know of a good shop in the oc area?
- anyone have velox vx-8 or vx-8r?
- Got a problem (failed emissions)
- Can I install seat heaters?
- 5th gen cluster question
- what can you use to retard the timing for N20
- New oil filter composition
- what kinda of injectors to get........
- 300 whp prelude 1/4?
- clutch chatter vs tranny slipping???
- How strong is H23 VTEC?
- GSR rims on Prelude?
- hmmm got my JDM foglights but the instructions are in japanese...
- can you turbo a SH?
