View Full Version : Honda Prelude
- Looking for a driver-side fender Milano Red for a 5th gen Prelude
- Oil leak by distributor...Help Please!
- need help, h22a4 into a 4th gen
- h23vtec bluetop swap help please
- Swapping cylinder heads
- USDM H23 --> JDM H23 Swap Inquiry
- Best for rebuild
- 94 ABS light.
- Vtec - Vehicle That Eats Children
- oil pump cover
- Dropping a 5th Gen
- Blue Top Prelude Engine Light Is On
- Automatic 97 Prelude
- New user purchase advice needed!
- Emergency Brake Cable? Caliper? Or both?
- H22 problems
- Success!!! 3rd Gen B18C-R
- 5 Speed Overdrive?
- My f20b race car issues
- tranny fluid
- Crank pulley wobble! wtf
- 98 Prelude non SH transmission rebuild kit problems--please help!
- 1996 Prelude S OBDII to 1992 JDM H22a OBDI Questions
- Blocked coolant passages on headgasket
- '00 prelude hydrolocked? ecu replacement?
- ECU replacement.....used okay?
- Toe Adjustment
- spark and fuel, no start
- b16a problem
- Oil Leak Problem & Oil Pan Question
- knocking sound as soon as the wheels rotate
- The best weight reduction
- Power Window Problem
- ATTS and Honda DW-1 ATF
- Headgasket considerations
- ► WANTED TO BUY ONLY :: NO TRIAL USERS, NO PICTURES - Sep/Oct/Nov/Dec 2011
- ► FOR SALE ONLY ::.. NO TRIAL USERS, NO COMMENTS, NO PICTURES - Sep/Oct 2011
- 92 Prelude ignition timing ? ? ?
- aftermarket parts for a 85 prelude
- How do i know if i have OBDI or OBDII?
- Springs
- 1990 Prelude 4WS transmission issue
- Overheating with AC on
- 4th gen/ 5th gen brake rotors
- Throttle body (blox 70mm)
- which exhaust?
- obd2 p72 will i run into immobilizer problems?
- F20B questions
- HELP! Misfire problem
- Main Bearing problem
- honda prelude dirt track car
- honda prelude
- NEED HELP!
- 01 SH ignition timing not adjustable?
- possibly for sale
- 98 Prelude Hesitation, RPM jumping, etc...
- open diff to quaife lsd
- H22 power steering belt...
- Turbo H22A does not start
- steering column swap?
- 2000 type sh need help!
- 94 prelude auto to manual question
- Honda Prelude 1992
- 5 prong disaster.
- How am I supposed to align the rear top hat...
- Official Lightest Preludes List
- Radiator hose internal diameter?
- tranny or clutch?????
- Help identifying engine
- Trying to put cv axle back in and I see this in the transmission . . .
- 4th gen rear speakers not working
- Shifter Cables
- 95 Prelude CV Joint
- h22 header help
- F, H, Trans onto H22
- 4th gen auto to manual swap question.
- Tranny issues
- What is this part? Where does it go? 1989 Prelude Si 4WS
- 91 lude b20a oil pan on h22a1
- h22 cometic head gasket Brand New
- Jdm yellow fogs help
- M2B4 gearbox grinding
- Painting my fourth gen~~
- HPDE In car vid of prelude
- 98 lude with h23a1 vtec questions please help..
- Newbie--problem
- h22 no ac no powersterring belt size help!!!!
- Prelude Ecu
- racecar question 91 prelude
- 91 prelude - racecar issues, HELP
- Plugs too cold?
- H23 in 2001 Prelude Won't run.
- blew a headgasket, new swap or mill head.
- 4th gen prelude cluster help
- h22 questions
- Evo 9 Eneki lug nuts / hubcentric rings
- 2001 Prelude Type SH I might buy
- 94lude dizzy trouble
- 91 lude F22 swap...
- Sad day in the lude community
- h23a vtec into a 92 prelude si non vtev help!!!!
- May buy a '93 H22 swap with high mileage on body. What to look out for?
- New h22 swap in 93 prelude
- 89 B20A5 to jdm B20A w/Transmission Questions
- I need to know Everything about the H23 swap
- 3rd Gen - Dash Removal / Wiring / AC System
- new from nepa
- F23 to H23A Blue top w/H22 tranny What ECU?
- I need T belt, water pum, tentioner, seals for H23A Blue top
- Cant get the p1399 code to go away, tried everything!
- 5th gen Prelude has mechanics stumped…ideas?
- 95 turbo prelude suspension questions
- how can i....
- 5th Gen EGR - input
- 93 Prelude Brakes question
- Euro R parts in a 4th Gen?
- Re-wiring
- Anyone swapped a CRV/Accord 6-disc into a lude?
- Need help just purchased a lemon, now I am stuck with it.
- i have a question about my motor in my 92 prelude
- oem prelude headlights
- Main realy troubles...SEARCHED FOR HOURS
- 98 Lude-auto to manual- immobilizer-red key
- please direct me to.......
- FREE(+S&H) SWITCH PANEL(W/FOGS)
- JDM h22a with chipped p28?
- N/A h23a1 non vtec 180whp 180wtq???
- FOG LIGHT RELAY #'S
- H22 vs h23 intermediate shafts... Which one is longer?
- FS oem 5th gen prelude Muffler & springs
- Obd2 engine to Obd1 engine
- AC compressor not engaging
- Radiator fan doesn't run
- Oil light when braking hard
- H22 ext coil in crx question
- just bought my lude
- Crank pulley fell off, put back on cranks but wont start
- Should I trade?
- cmc question
- H22 external coil wiring question
- 92 prelude cd changer?
- 9.65@153 in a Prelude Congrats MD23vtec
- Sputtering, loud pop, dies...wont start.
- 1993 prelude Brake problem
- Toe Adjustment
- new here. power steering
- 5th gen OEM CF Trim Kit - Pic Request
- Head tech
- Door ajar chime is driving me nuts! please help.
- need some advice
- 5th gen trunk --- picture request of inside at the top
- converting prelude sh obd 1
- Charging System Fault
- Pulling out a H22a4 engine
- CEL code 9 H22
- Clutch goes ˝ way to floor, Tranny won’t go into 2nd or 4th
- Where to put a aftermarket temp sensor on a f22b?
- New member needs some help. =]
- hello its new guy....
- Anyone know the true fix for the 2-3k rpm hesitating???
- Type-S Cams
- brake issue, pressure builds when pumping w/ motor off, but losses pressure when on
- Ignition Switch for 4th Gen Prelude... Can I cut out one from an Accord or Civic?
- Need to flush metal out of oil galley
- jonathan2006's '94 Prelude Si
- Buying A Fifth Gen
- tachometer help plzzzzz
- F23a5 block for h22 head
- Another ABS Problem
- '00 Prelude SH immobilizer system.
- f22a1, prebent intercooler kit???????
- cleaned IAC now idles low and stalls, worse than before
- h22 crank in F20B???
- H22a Prelude wont start!!
- Overheating. . . Really?
- 2000 prelude issues
- SH to Base Prelude?
- looking for meets or races in az
- Shifter cable question.....
- 1997 Type SH engine swap/trans swap questions
- 97 Prelude power window, mirror, and lock problem
- Quality after market fans? ? ?
- 93' Prelude clutch fork not fully returning?
- nippon racing type s pistons good on frm cylinders?
- noob build
- Steering hub woes
- h22 tps
- New Prelude Owner
- Difference Between Driver and Passenger Side Axles
- Large injector fuel pump setups
- H23A3 Head vs H23A1 Block
- 4th Gen Progress Rear Sway Bar /w Endlinks
- 88 Prelude CEL on but no codes
- what trans do i have?
- f22d help..
- Black box???
- H22a strong gas smell????
- It's always an electrical problem
- prelude wont start after driven alot
- 3G want to build n/a
- Where to find the feul pump relay?
- Clutch Fork??
- jdm fog light questions
- ATTS EXTENSION TUBE AND AXLE OILD SEAL REPLACMENT
- 5th Gen Cleaning IACV help
- BPI Flowstack size? 3inch or 3.5 ?
- 92 SHIFT CABLE
- 1989 Accord lx-i help
- h22 type s. NOS problems
- VSS connector
- F22A4 Turbo Build (for anyone who cares lol)
- f22b help
- OEM EXEDY vs. STAGE 1
- F20B IM VS H22A IM
- one last time i swear it
- quick question
- speed sensor help
- Obd2 Cam Gear Tuning----Myth Debunked
- looking for 2001 prelude parts shipped to AK
- which transmission
- T3 turbo in an 01 Prelude?
- another idle issue
- major oil leak after bottom end rebuild
- venom 400
- 92 prelude not starting, H22A w/ p13
- el cluster rpm problem
- 4th gen coolant leaking
- Just bought a 2001 Prelude...with an H22Z1
- 86 prelude si trans problem
- where can i buy parts?
- H22A4 smoking, rebuild questions
- When/Why did your original H22 POP?!
- need help picking the right clutch
- Bad ECU?
- Mounting STR fuel rail to stock Intake Manifold
- putting a jdm h23a into a 96 honda prelude si
- Oil Cooler
- f20b with h22 head * what head gasket to use*
- Hum from the gas tank
- Replaced alternator battery and brake light comes on for short time
- what mods should i do?
- Prelude SH code 7?
- Can't decide
- 99 Prelude SH Complete Suspension Overhaul.
- Speedometer Problems, please help...
- Crank Pulley Issue
- Cam Gear?
- Mode Control Motor
- 1992 Prelude Transmission Help
- Calling allmotor H23vtec Guru's
